View Full Version : Prelude
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
- 98 JDM F20B on a 01 H22a4
- 1987 prelude si performance
- What Clutch Is Best
- Belts for JDM
- Help Me!
- Insane NA HP.
- 4th gen Si PWNS LAPD
- I need your 2 cents
- Engine!!!
- PReLUde HiGHeSt Possible Horsepower???
- Turbo PReLude .. H22+H23 ?
- gf can't reach clutch
- p13
- I need help diagnosing a problem
- Factory suspension question~
- Radio and clock
- OBD question
- help
- 95' prelude swap?
- Fog Lights...again
- Rifled Throttle Body Spacers?
- help please
- superchargers
- Linkage or Tranny?????
- Header Changing Color
- Distributor Seal...?
- stalling in the rain
- How do I race?
- Wierd knock in wheel well.
- Turbo-ing Model S
- Fully built h22 head 480 miles, crower everything
- brake lamp light wont go out
- TorqMaster Sparks
- Need a driver side door
- h22a4 in a 92 si need help
- leaking fluid from tranny
- Electrical problem in dash
- Turbo 90 si?
- Please HELP someone must know rhis?
- anyone know about the 3rd gen trans
- ouuucchhhhhhhhhh !!!!!
- skunk 2 cam gears, need help
- Car won't start/crank
- ***92 Prelude Engine LOUD SCREECHING NOISE Coming from distributor area***
- 3 inch exhaust
- Tachometer is spastic
- 88 Lude Shifter cable
- 2nd Gen parts 91 prelude I NEED
- little bit of white smoke
- Clogged fuel sytem?? Help
- Wont Start
- engine buildup questions
- 02 sensor
- Prelude starting problem
- proper way to store the prelude?
- My headlights aren't working right *need help*
- Broken sway bar
- The Ludeness of it all
- problems when it rains
- vtec controllor?
- 92 with 166k
- Ebay Coilovers for $20!?
- Neutral Dropping?
- Instrument panel and all dash lights going out
- Major oil leak
- steering wheel shimmy
- Having trouble with the door panels..
- Vtec?
- 1982 Prelude bumper specs?
- R33 Skyline Conversion
- 1989 prelude headlights stuck in up position
- Alpha Werks?
- Which Exhaust?
- Fuel Efficiency Optimization Mission
- 2G Tire Size Question
- Need Head
- 4th gen prelude ..Whats the differences in year and trim models?
- 93 prelude problem
- ECU - Air Conditioned
- Heated brakes
- misfires, stalling, stellar handling!
- wheel berrings
- 95 prelude si h23
- A Problem help!!!!
- Fog Light Covers
- Fan trouble '85 Prelude
- 89 honda prelude
- Blue Lights at night
- Fender Liner
- Exhaust time
- 95 prelude h23a idle problem
- Update On 90 Prelude Starting Problem
- The Rights of Automotive Hobbyists - NO MORE UNLAWFUL VEHICLE INSPECTIONS -petition-
- 86 lude going down !!
- Replacing Oxygen Sensors
- Alittle Help
- Cruise Control Problem!!
- Aem Short Ram
- 2nd Gen Ignition Mods?
- Short ram
- Has anyone actually replaced their own clutch and/or timing belt?
- anyone at all
- she's smokin
- what's your top speed?
- What Should I Do? Please Help!
- door panel etc.
- dead battery!?!?!?!?!
- need a H23 motor!!
- ABS Brakes
- who has ebay intakes?
- My Prelude Is to Loud
- more help, clock went out!
- ATTS leak when under pressure
- 92 prelude need major help
- some advice from the expert please
- 1989 lude motor swaps!!!!!!??????!!!??!?!?!?!?
- screwed up tranny??????????????????
- Help! ABS light and master cylinder problem Help!
- Where is AcesHigh?
- question about brake caliper piston?
- slow
- Starting problems
- looking for gear heads near akron ohio
- Recall "SeatBelts 92-94 Ludes"
- Lude Vs. Celica
- Engines
- Am I hurting my LUDE
- Help me decide what rims to get
- Whats causing this?
- Ok whats going on here!!
- What RPM
- engine light problem
- Srs??
- Lude speakers
- 93 prelude VTEC owners?
- Vtec from a 97 Lude into my 92 Si
- Single Or Dual
- No VTEC?
- Tsudo Cat back
- slightly confused
- JDM Power folding mirrior instal?
- buying 92 prelude w/ blown engine, after searching still h22a q's
- my lude is trippin
- preludehead change q
- 97-01 Blackhousing headlight idea
- Whaddya think?
- for sale
- 93 prelude si
- locked radio
- easy radiator question
- power door lock and window problems...help
- how to activate SRS
- vtec rotors vs. si rotors
- Questions Questions and more Questions
- Good Deal?
- fast cars just arent as cool anymore
- i need help with my swap
- Motegi MR7?!?!
- Radio/Clock/Key Less Entry
- true jdm h23a
- weird problem
- exhaust, header, intake what brands will give me the most HP?
- jdm headers
- carb problem?
- Just got a Prelude
- Prelude Eyes
- Trouble finding 89 prelude compressor control unit, please help
- Trouble finding compressor control unit, please help
- Having trouble finding 89 prelude a/c control unit
- exhaust fiting h22
- Exhaust Gasket
- Clutch has alot of freeplay
- Prelude Si staring issues
- h23 crank in my h22?
- help w check engine light
- sunroof question
- radiator difference?
- 96lude speedomeder don't work please help
- h23 JE Pistons
- H22 Eagled sleeved block
- What does this mean?
- H23 IACV Help!!!
- DIfferent Trims
- knock sensor probs
- Possibly buying a new prelude
- idle h22a jdm prob
- i need help with my 86 prelude!!
- Handling
- 92 Civic shox in a 92 Lude?
- 89 HOnda prelude a/c compressor wont kick in please help
- Question about rotors...
- problems with swap
- Which internals for BOOST
- Possible hydro lock
- 89 prelude 2.0si 4pd a/c condesnor won't kick in please help!
- Are Bendix Pads Good for a Lude?
- 93 Prelude SI blown head gasket
- fuel pressure reg setting {psi}
- ABS code 1-2
- hi-flow cat
- Driver side Mirror Help
- Need JDM Mirror wiring Diagram
- 92 Lude Girgles Noise
- H22A swap
- question on ecu swap
- out of ideas
- rubbing sound at start
- evo2 exhaust system
- electrical problem
- Prelude idle issues (again)
- check engine light. decrease of power.
- prelude
- vtec problems
- cam gears
- Which Funkin Harness??
- Help Me Please
- H22 or H23 Tranny?
- engine swap
- carb number question
- Vapor Lock???
- OBX Cams Camshafts
- Prelude Remote Programming... HELP!
- Stronger Master Cylinder???
- How do I take the sunroof off?
- jet upgrade
- wheeel offset on 5th gen lude
- My 92 Si
- Strange noises....power loss
- Good Honda Buys
- seat belts dont lock
- what to do?
- top of the line prelude
- which rims for prelude.
- 17" Rims "Problem"
- lowering the car
- 2000 or 2001
- h22 front clip
- best exhaust
- leaking coolant... from 3 places
- Leaking tranny oil. HELP!!!
- Usual Tranny Problem
- suggestions
- Prelude S Vs. Si Vs. Vtec
- turning over, no start intermident
- H22A engine Serial Numbers
- Help me start this biaatch!
- JDM Type S conversion
- USDM parts
- How fast are these cars exactly out of the box?
- Looking for 92-96 with blown motor
