View Full Version : Prelude
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Engine Problems
  2. How Fast Was I Going Officer?
  3. Looking for a prelude
  4. Post your ride
  5. Looking to gain knowledge on preludes, help?
  6. H23 vtec
  7. how to?
  8. throttle body spacer gains?
  9. prelude IAT sensor
  10. car broken into, ignition mess up
  11. 1988 Prelude Si "Check Engine"
  12. 90 prelude 2.0s
  13. Tachometer Problems
  14. Woohoo!!! 98 Prelude!
  15. Carsound catalytic converter Info?
  16. 92 prelude ignition starter prob.
  17. Pilot Bearings
  18. Pricing a 1994 Honda Prelude
  19. PLZ HELP!!!Speedometer! Need serious Help!
  20. Odd noise from my 2000 SH
  21. sway bar
  22. crash
  23. what be better and easier
  24. intermediate shaft location
  25. cv joint repair
  26. button on transmission Gear shift
  27. Catalytic Converter Question............
  28. 1988 lude tip on no start
  29. Headlight Headaches
  30. 1990 Prelude High Idle and fluctuation JSPEC motor
  31. FS: Used DC Sports Short Shift ADAPTER (5th gen)
  32. 2001 lude burning oil badly...anyone head of this?
  33. Mahle Pistons???
  34. 1989 Prelude fuel filter pressure test
  35. oil filter adapter O-ring on 93' prelude
  36. Help!!!im Stranded!!!
  37. Who would win
  38. 1 Bridgestone Potenza RE92 205/50 16 V
  39. Turbo psi?????????
  40. Question for 3rd gen owners
  41. I Just Got My Prelude Just ......
  42. Import 1988 Prelude SI 4WS?
  43. Turboed Prelude and RT/TT
  44. short shifter!!!
  45. rear susp. 1 inch off HELP!
  46. H23 block with H22 head good HP?
  47. intake question
  48. b20a question...
  49. All Motor Or Turbo??????
  50. Whats the Difference
  51. sh parts on a jdm engine
  52. tell me Im crazy....
  53. Help Replacing the Brake caliper gasket
  54. Help me!!! 89 prelude has now power top speed 35mph
  55. smoking car
  56. obdii port location?
  57. shooting for 300
  58. Need little help on 4th gen engine swap.
  59. 1992 Honda Prelude Crankshaft Pulley to loosen
  60. i've got an electrical problem. . . i think
  61. oxigen sensor
  62. Cant get My rotors off My Lude!
  63. My Prelude Type SH vs. Friends Integra GSR
  64. post ya pic?
  65. 93' MT Shift Linkage Bracket Broken
  66. weard idle
  67. Heater???
  68. I Have An Idea
  69. 89 Prelude 2.0SI Leaky oil pan please help!!
  70. 89 si Taillights
  71. psi on a supercharger??
  72. compression test results?
  73. Fog Lights
  74. '88 4WS Power Problem
  75. Question About Cat Converter
  76. Need some help...
  77. Prelude as a road race car?
  78. A few questions about my 80 Prelude
  79. Will DSM 450cc fit a 99 h22?
  80. tail light ???
  81. Atts???
  82. 88 Si 4WS Clutch Question
  83. screwed up h23, need assistance with where to go
  84. h23a-shuts off while driving
  85. Gonna rear end somebody
  86. HEad cc's the same?
  87. losing oil motor knocking. Could be rear main or rod???
  88. confusion!!!!!
  89. Centerforce clutch?
  90. 5 speed tranny
  91. 90 prelude
  92. solenoid????
  93. EGR Valve trouble
  94. skunk2 valves
  95. Just got a prelude..good buy or not?
  96. 1988 prelude 4ws
  97. reving idal in park but not drive
  98. 88' 2.0XX Imported Prelude Audio
  99. Question about a heater on a '91 Prelude
  100. 88' Prelude 2.0XX import Questions??????
  101. How Low Can You Go????
  102. Do the other mods still come around?
  103. factory cd player removal.........
  104. new h22a got a desperate question please help.
  105. code needed for my factory cd player......
  106. fenders
  107. Finally my jdm h22 is in!!
  108. Lowering and Camber effects
  109. Quick question - 98 Lude w/ DVD
  110. 97 sh acting weird.
  111. Prelude SR?
  112. 93 H22 prelude
  113. 93 H22 prelude
  114. Weird squiling noise... Cant figure out what it is
  115. 93 prelude auto hardshifting
  116. 84' Prelude Engine swap questions
  117. 90 honda prelude si "overdrive issues"
  118. hard choice on import
  119. headlights
  120. Performance muffler problem
  121. which ludes have vtec?
  122. Windshield Wipers
  123. Prelude 4th gen 4WS
  124. power steering leak
  125. 92 prelude h22 head on h23a block
  126. Knocking from pass. side rear wheel-well
  127. From Atts To A Jdm Engine
  128. What is H22b & F22b ???
  129. 99 Prelude or 06 Civic Si?
  130. anyone ever attempted this??
  131. check engine light
  132. Shops in Austin, TX
  133. Solid Engine Mounts
  134. Something's Wrong with my RPM
  135. jdm h22a1
  136. some one please help Swap Problems
  137. replacing antena motor
  138. Engine Swap for a 92 Prelude.Help ME!!!!
  139. Weird winding noise
  140. Rpm 1500
  141. stuck clutch
  142. About to buy a 90 prelude.
  143. 84 Prelude gas leaking from carb area
  144. I need major help my friends.
  145. H22a swap
  146. H23a1 replacement options
  147. '88-'89 prelude not getting spark?
  148. header ??
  149. 2001 prelude 0-60/quartermile?
  150. check engine light
  151. 99'-00' Civic Si vs 2001 Prelude Base
  152. 2001 Honda Prelude Turbo and horsepower options
  153. 1991 Honda Prelude
  154. radio hookup trouble...'89 prelude si
  155. new hoses
  156. SH vs. non-SH tranny
  157. 88 prelude help...beeping is driving me insane
  158. Please Help!!!!
  159. help
  160. Check Engine Light and No VTec
  161. 1990 2.0 si prelude worth $1100?
  162. Speedometer not working
  163. vtec
  164. vafc
  165. Intake?
  166. Looking @ '89 Prelude, any suggestions?
  167. Clutch for 93 Prelude Si
  168. 1989 Honda Prelude si
  169. Well here it is..
  170. body kits..
  171. '96-'96 VTEC Prelude, is it worth it?
  172. hmm chips?
  173. vtech rpm?
  174. whats the best?
  175. need parts
  176. Cam Gear ???????????
  177. vetec preblem????
  178. ATTS and VTEC -- something wrong with my Type SH
  179. What not to do to you lude
  180. 4th Gen 2.3L Si Question
  181. light conversion
  182. 83 prelude will not idle
  183. E-Brake Light while Sharp Turning
  184. AC CRX questions?
  185. my '92 prelude is...
  186. Longevity of the '89? & trans. swap?
  187. Newest Apexi N1 Sound Clip!!
  188. Best Launch Out Of My 97 Prelude ?
  189. Broken Engine Mounts
  190. Autometer AFR gauge Wiring?
  191. Is this a good deal?
  192. A'PEXi N1 Exhaust Sound Clip
  193. Hard to start and will not idle
  194. What motor do I use?
  195. Have u heard of this??
  196. Help Helo Lude Wont Start!!
  197. head noise, cam bearing?
  198. Supercharge ???????
  199. 95 S-type Sunroof?
  200. 5th shocks to 4th
  201. h22a ignition timing
  202. punk'd boss's ride
  203. Top speed thread closed?????
  204. 95 vtec head on a 00 block
  205. 96 H22a into 93 prelude body
  206. Engine swap problem
  207. good deal for turbo??
  208. serios problem, need some help please
  209. where to buy ludes?
  210. h22 in a 89 lude?
  211. tail lights ??????
  212. h22a idle problem
  213. engine
  214. cant decide
  215. throttle body cleaning?
  216. 1991 Honda Prelude Si 2.1 engine has a problem
  217. 89 Prelude Rough Idle, engine dies
  218. Low Fuel Indicator Lamp
  219. How Can I Get My 98 Lude Lighter
  220. Sold My Prelude This Morning, Good bye
  221. totaled 92 lude
  222. Prelude mods?
  223. exhaust
  224. Tein suspension
  225. h23 dropped in accord - newbie question
  226. approaching timing belt change time
  227. approaching timing belt change time
  228. regarding buying a prelude..help
  229. this is gonna sound dumb...
  230. 92 prelude problems
  231. ABS light
  232. Speedo off??
  233. 91 prelude Si RPM is running high
  234. h22 or K20 swap????
  235. if i should buy this prelude?
  236. Whats next for an F22a?
  237. are h22 parts interchangable with h23 parts
  238. P13 ECU and H22 Valve cover
  239. 94 prelude vtec vs 91 300zx 2+2
  240. diagnostic plug location/knock sensor
  241. Sup, I'm a brand spanking newbie
  242. Tachometer installation?
  243. 88' prelude relay/fuse layout?
  244. tranny, fuel pump or fuel filter clogged? help!
  245. Serpentine belt schematics?
  246. 92 prelude Brake light problem, pls help
  247. Slotted Rotor direction
  248. surging
  249. 98 JDM F20B on a 01 H22a4
  250. 1987 prelude si performance
