View Full Version : Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20
  1. Tanabe Racing Medallion Exhaust ????? vtec vs si
  2. Urgent!...but quick (AEM pulleys belts)
  3. Performance Dyno?
  4. FOR SALE '92 Prelude Si
  5. cold air intake
  6. Auto vs. Manual
  7. 50/50 Alcahol mix??? what kind of alchaol?? What is ethanol and where can I get it??
  8. Cam gears...
  9. Sportshifter vs Manual
  10. master key replacement
  11. H23 header on h22a?
  12. 90 Prelude Si
  13. Prelude vs. Civic?
  14. which prelude
  15. Internal External Swap
  16. 89 prelude
  17. *NEW PRICES for 89 V-TEC B18C lude*
  18. FS/FT/WTB: Classifieds
  19. aceshigh is really smart when it comes to ludes
  20. are the older ludes better than the newer ones
  21. 350z vs 5.0
  22. Help! Removing PS Pulley
  23. 84 Prelude idles rough
  24. prelude SH vs. rsx s
  25. Clutch?
  26. a sign of a racing clutch nearing the end of its days?
  27. Need help with bogging problems
  28. Prelude Specifications Thread
  29. 98 Prelude vs. 94-95 Mustang GT
  30. 19" Katana Inspires W/Tires
  31. Why doesn't anyone ever mention these...
  32. looking for a 92-96 prelude
  33. Prelude beats Integra
  34. Idle, Vtec?
  35. leather seats (i want!)
  36. DC Headers?
  37. thinking of buying a 1st gen
  38. Autocrosse
  39. missing a bolt that holds the tranmission to the engine block
  40. wheel and tire size
  41. wat does prelude mean?
  42. Prelude beats Civic
  43. help wit a 87 lude
  44. Is 500 Degrees enough
  45. prelude convertible!!!
  46. Tein vs Tanabe
  47. Awesome Buy On Brembo Rotors
  48. What the hell is a code 36???? anyone???
  49. prelude the best?
  50. Grommets?
  51. how much does the auto to manual conversion cost?
  52. Header install problems!! HELP!!!
  53. buying a honda prelude with high miles
  54. Stock H22a Crankshaft pulley anyone?
  55. Apexi S-afc Thread (questions, comments, advice, etc.)
  56. Broken valve cover stud?
  57. please help,Crazy engine rattle!(long)
  58. What Rims?
  59. Head Help
  60. b16 in a prelude!!!!
  61. 83 prelude engine conversion
  62. ATTENTION PEOPLEZ - exhaust, camber
  63. Running a richer fuel mixture
  64. door panels
  65. recommended exhausts
  66. idle
  67. coilover system vs. struts and springs
  68. Durability of Silicone
  69. Do you think these will look good?
  70. speakers?
  71. Control Arms
  72. vidz and sound clips on prelude exhausts
  73. Are pulley's worth it??
  74. 3rd Gen Prelude owners look here
  75. Can Header harm a Prelude??
  76. Antenna Motor Works, But Antenna Doesn't Move
  77. prelude wheels
  78. Are preludes still made in japan?
  79. H23 Vtec Conversion
  80. lighting question
  81. 4ws ..... problem ???
  82. Got some decisions... si-> vtec? turbo?
  83. Weel Her's Is My Idea
  84. What's my 1/4 mile time??
  85. Help
  86. Prelude SI compared to 300zx N/A
  87. What's 93' Firing order on distributor!!?? forgot to write it down
  88. Lower Ball joint
  89. lowering car... need camber?
  90. Parts?
  91. new brakes
  92. horn: points of failure
  93. Altezzas?
  94. Air Ride
  95. 4th gen prelude calipers
  96. Need help with new radiator
  97. 10 second 4th Gen Prelude Is it even Possible?
  98. Exhaust Tunes.. what sounds good?
  99. HELP! Automatic Transmission Scratch...Standard?
  100. 4th gen prelude si help
  101. Crank Nut, left or right
  102. SRS light
  103. Brakes in Preludes Common Problem???
  104. Header problem
  105. 4th gen headlight removal sucks A##
  106. Removing Valve Cover
  107. Electronic Dash?
  108. Engine swap
  109. Exhaust Noise, please help
  110. Catalytic Converters
  111. AcesHigh for president!
  112. valve ticking: need ideas
  113. Speedodmer Problem
  114. Where to start for Newbie's
  115. fs/ft 1993 prelude vtec
  116. you guys see any Lude 92-95 for sale ?
  117. wheels w/tires for sale
  118. springs
  119. H22 onto a 1990 prelude?
  120. Car sometimes stalls when driving,help?
  121. FAQ and Table of Contents
  122. Auto to Manual Conversion
  123. 88 Si questions. Advice on parts needed
  124. How much will i need to do.....
  125. no spark
  126. Where are the 3rd gen's at?
  127. Pic REquest
  128. Is it possible
  129. Online Service Manual???
  130. Help! First Car And Its F@#ked!
  131. Better automatic shifting
  132. Painting stock wheels! Help!
  133. My New Prelude
  134. Fuel Pump or Ignition Problem
  135. Turbo or Super?
  136. why is my speedometer freaking out?
  137. what ignition?
  138. Problem with 1995 Si Speedometer
  139. 4-1 or 4-2-1?
  140. Hydro Help
  141. MY 1/4 times
  142. B20 horse?
  143. How much to install bodykit?
  144. Question.... How much HP can they take ????
  145. GS-T VS VTEC Prelude
  146. What Wheels Look the best on a 92 lude?
  147. Hood Scoops Increase Air Flow?
  148. 4th or 5th gen Prelude V-TECS?!?
  149. turbonater??
  150. Dual Exhaust on Prelude V-Tech???
  151. The Notorious H23A to H22A Swap
  152. turn signal
  153. how much have you spent?
  154. cam gears for high boost?[h22]
  155. black bumper lights
  156. JDM wire or H23 wire harness???
  157. Negative Camber....PLEASE HELP!!!!
  158. 4-2-1 or 4-1?
  159. H22A Timing Belt? Whine
  160. Would the rims look cool?
  161. squeaking and camber help
  162. Leak in intake manifold. JB Weld??
  163. prelude targa top
  164. Need help from Serious Prelude Modifiers
  165. Quarter mile?
  166. Active valve exhaust systems.
  167. Air Ride
  168. Please Help!!!!!!
  169. Better Booster = H22A Vtec ..or.. H23 Non-Vtec???
  170. exhaust system difference
  171. Which Turbo Kit For Prelude?
  172. NSX/Prelude
  173. main wiring harness
  174. I/H/E horse power gain
  175. Mugen Headers?
  176. Need Help!
  177. Prelude 1/4 times
  178. 15 pound wheels, alot?
  179. 86 Honda Preludes 2.0Si
  180. 92 LUDE PROJECT with S2000 engine
  181. How hard do you run your lude?
  182. h22a swap, p13 ecu problems..please help
  183. headers torque specs?
  184. What next?
  185. 97 Prelude 4 sale
  186. will 90-93 integra body kits fit?
  187. horrible luck, headers, power steering
  188. Prelude :::::::Automatic vs. Manual::::::::::::
  189. Odd rattle
  190. How Many Miles?
  191. Looking for an engine
  192. 89 PRELUDE V-TEC FOR SALE (rare!)
  193. 88 Head light options
  194. spoiler ?
  195. runnin some power wire...quick help
  196. price for 2nd gen transmition?
  197. Possible crankcase problem?
  198. Prelude '90 info needed
  199. Used prelude enging pricing?
  200. Bouncing Idle Fix(i Have The Answer)
  201. 3rd gen with some problems
  202. 89 Prelude with some questions...idle, exhaust, battery light
  203. Lude Redline
  204. How much power can you get from a H22 ?
  205. Generations
  206. 93-96 lude specs
  207. Suspension Help
  208. timing belt
  209. Exhaust question...
  210. What kind of tires do you have?
  211. power steering belt replacement
  212. Detonation: The Engine Killer
  213. Prelude dash lights
  214. 1995 lude speaker sizes
  215. timing belt keeps breaking
  216. condenser fan relay keeps on frying
  217. SH Cooling/Alt. Differences?
  218. a/c smells like puke
  219. Lude Wheels
  220. idle control problems on my 92 si
  221. 4.5" Silencer?
  222. Winter Is Over!!!
  223. ...More questions on turbocharging a VTEC...
  224. Attn: AcesHigh
  225. Whats the difference between base, SH, and SiR models for 5th gen preludes?
  226. Muffler or Exhaust system catback?
  227. block rebuilt for 20 psi, H22A
  228. ....Some few Newbie questions....
  229. Buy a 91 Prelude yes or no?
  230. Update on the Making Power Thread
  231. Any one know?
  232. Here's something cool for us 4th Gen Owners
  233. 5th gen Lude or 2004 gti vr6
  234. 88 Si engine swaps?
  235. Intake??
  236. H22a swap
  237. trannys
  238. Brakes
  239. prelude or si?
  240. Si to VTEC Engine Conversion (Various Electronics)
  241. Coilovers
  242. JDM headlights
  243. Check Engine Light Diagnosis
  244. Is it rich fuel?? Guys, help me out here..
  245. lots of info on turbos and superchargers
  246. pistons
  247. 5th gen. SH prelude differences
  248. need major help with my MSD ignition install
  249. Performace improvements with gsr ecu in h22a
  250. LOL... a guy with a 97 buick skylark wants to race me
