Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Geo
> Nova/Prizm/Spectrum/Sprint |
View Full Version :
Web
AF
Power steering problem
please help 95 geo prizm lsi
1997 prizm firing order
Possible oxygen sensor power problem? 95 prizm
Turbo geo performance...???
91 prism charging problem
90 prizm proportioning valve
Secondary Ignition Issue - 94 Prizm
car shakes when accelerating into right turns
IAT Sensor
96 Chevy geo- size of auto tranny drain plug
95 Prizm Control Arm Bushings
How do you remove the distributor from a 1994 Geo Prizm?
96 Geo Prizm (No Power)
1994 Prizm acceleration problem?
help with water leaking under dash
95 Geo Prizm Rattling/Knocking
1993 Geo Prism The same as a 1993 Toyota Corolla?
Shift Knob Replacement - Auto Trans
95 Geo Prizm - Windows dont work,someone help?!
91 Prizm, 2 problems (idle and tranny) confused..
96 Geo Prizm - Horrid Grinding In Front Wheels
1996 Geo Prizm lsi will not start
'95 Geo Prizm - Light next to headlight?
Bad MPG and loud
94 Prizm Clutch/Trans. Problem?
Oil leak on 1996 Geo Prism
93 Prizm lug nuts/wrench
How do i eliminate power steering??
1995 Geo prizm misses at higher rpm
Steering rod boot?
1994 Geo Prism - automatic **HELP**
1995 Prism tach cluster
Geo Prizm purchase advice
Where to get factory replacement springs?
Replacing dome light?
geo head lights
Geo...
96 1.6l Starter Removal Question
95 Geo Prizm wont start! PLEASE HELP!
Pre buying help
Wheel/Tire combo
1994 Geo Prizm Lsi Handbrake Problem
97 prizm Lsi VSV HELPP
96 Prizm with occasional engine stutter
1991 Prizm only shifts out of park with shift lock override
Geo for sale
Cluth or Transmission?!?! 93 Prism
95 prizm oil capacity
Having problems with my beater car.
Driver's Window Issue
1993 Geo Prizm - Battery Indicator Light is Intermittent
Car shaking badly! PLEASE HELP!
91 Prizm won't start in park unless
91 Prism-changed fuel filter, didn't work
Prism fuel filter-where is it?
A Good Deal??? - 93 Geo Prism
How many miles on your Prizm?
when is getting warm outside the engine is running intermittent
96 Prizm front brake problems!
1999 Chevy Prizm started running rough, misfire in # 1 and # 4 cylinders
'92 Prizm starting problems in hot weather
90 geo dies while running.................
abs problem
92 prizm problems plus wont stay running!!!
fluid leak up in dash 1991 geo prism
Heater Blower problem
Ignition Problem
92 prizm started one day, now nothing
Push starts but wont key start
turbo in geos
How to replace the stock radio -96 GEO
89 Geo Spectrum timing
95 Geo Prizm ignition
93 Geo Prizm M/T 1.8 ignition code
93 Prizm a/t no first gear
Possible ground problem need help badly
Low brake pedal
ECM location
94 prizm airbag
92 prizm 1.6 sohc interference?
ABS and Brake light always on
Where is the speed sensor in 94 Prizm?
'94 Prizm: blue smoke, using oil, running rough
I Want to install a Tach....help with wiring
95 prizm turn signals dont work
93 go prizm speedometer/odomoter broken
93 geo prizm tail lights/dash lights fuse blown
95 Geo Prizm 190k miles wont start... no spark
Wiring guide
Hard time finding 96 Prizm angel eyes/halo headlights
Seat belt replacement
95 Prizm Power Steering Hose
1995 geo prizm fuel filter
NEED HELP 89-90 Geo Prizim
Coolant leak on 95 Geo Prizm
Where is Fuel Shutoff Valve on a 1991 Prizm?
Brake drum rear
96 Geo Prizm camshaft sensor code. but I need help
92 Prizm Brake Problems!!!
prizm missing on 2 cylinders
Help fixing 1996 Geo Prizm Trunk/Gas lever release
Replacement parts
Axle Replacemet
92 Geo Prism DOHC/Timing Marks
95 Prizm, can't get the shifter out of park
My prizm is making a noise
Car Audio Installation
automatic prizm reverse
idle poor when stopped
3spd tranny drain plug?
Geo prizm rumbling
shifter cable for 1993 Geo Prizm 1.8L
flat spot on starter
Brake lights non-working
Prizm clutch problems
93 prizm dying out
ABS dash light
Battery draining fast
Vehicle weight?
Starting issues
1995 Geo Prism 5 speed tranny adjustment
94 Prism LSI spark plugs
93 Prism Battery Lite is On
94 Geo Prizm clutch problems
94 geo prizm dash board lights not at all
Steering column lock override
Bad Valve Seals? How To?
valve clearance check 60k?
4age blacktop and 6 speed into 93 prizm
Kenwood P-NAV617 - In-Dash DVD 7" Touch-Screen Receiver---- $600
check light
need help with 97 goe prizm erg valve and wipers
Small issues with 1996 Prizm
Power windows won't work, 1991 prizm
Hard Start Hot
Hard Start Hot
1996 Geo Prism Idles High
1990 Geo Prizm, trouble starting
1992 Heater Motor Repair
any spectrum owners still around
1995 Geo Prizm Possible Oil Pan Leak
1991 geo prizm radio wire colors
geo prizm 97 1.6L spark plug gaps
Geo Prizm 95, break system replacement
um
Web
AF
