View Full Version : '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. 95 wont start
  2. ls vtec project
  3. 93 ex coupe runs for 20 seconds
  4. 93 civic engine swap
  5. b16 into 5g cx hatch
  6. Need second opinion on spark issue
  7. 92 honda civic dx grinding noise in engine
  8. Please Help!!!!!!!!!!!!!
  9. 94-95 civic swap
  10. B16 bottom end with B18 non vtec head?????
  11. check out my civic 4x4
  12. AEM air intake
  13. Need help with overheating engine please
  14. 95 civic air conditioning issues
  15. P14 ECU (Prelude Si '92-'95) in a D16A9
  16. Need help on my civic ex 95
  17. 93 civic noise after tune up/brake job
  18. New Idle problem install of throttle body Spacer
  19. 95 Civic LX trailing arm bushing replacement
  20. 1995 civic lx
  21. need help on d16z5 swap to a 95 civic
  22. Hybrid Water Leak
  23. paint color
  24. please help me! 95 civic ex
  25. Coolent leak
  26. 94 Civic with constant high pitch humming in front end....
  27. hella overheating prob
  28. my 95 civic lx
  29. where can i fnd t?
  30. Puzzling Brake Issue
  31. mini me swap idle problem
  32. Cruise vacuum line on 90s Civics
  33. Honda Civic Hybrid
  34. 95 civic idles rough only when warm.
  35. Which Civic should i buy
  36. 95 civic injectors not firing
  37. 89 Civic with 93 D15B dies when warm.
  38. How to change dsitributor
  39. 94 honda cranks but wont start help please
  40. 95 civic cx engine swap
  41. Air conditioning recharge
  42. Just bought a 95 Civic Sedan
  43. Valve Cover Gasket Problems
  44. 93 civic dx engine size
  45. d16a6/d16z6 minime trouble
  46. 92-95 custom hatch cargo cover
  47. Intermittent wiper in a CX hatch
  48. Honda civic motor swap
  49. 92 Civic Hatchback Problems Help Please
  50. 92 ex timing belt not lining up at TDC (cam pulley/crank pulley)
  51. 93 civic weird idle surge need help
  52. Projector head light with HID
  53. 92 civic sputtering problems
  54. IATS Help?????
  55. 1992 civic w/b18b1 swap.
  56. ecu p30 a010 information
  57. 93civic with mini me swap pleae help????
  58. 94 civic ex not cranking
  59. car pulls to the right...
  60. Cruise control into a civic CX
  61. vtec tranny
  62. Replaced timing belt now no spark
  63. 94 civic dx rythmic pulse
  64. Mechanic said it was a puzzler...... sputter, loss power, check engine light
  65. changed tie rod wheel still shake
  66. 1995 4dr civic 5spd..tie rod
  67. Using tin foil for blown fuse?
  68. 92 2.4l honda civil EX ALARM on DASH
  69. 92 civic dx will not start
  70. 1991 civic, rough idle, jumpy rpm, extreme coolant leak..
  71. Can you raise the compression ratio on a d15b7
  72. '95 DOHC ZC engine idling erratically
  73. need info on engine
  74. 95 civic,with TEC dist.no spark,help
  75. im about to do a engine swap
  76. need info on wich engine swap?
  77. speedometer problem
  78. Engine cranks but won't turn.. I don't understand?
  79. Brakes still squeaking
  80. 1995 Civic coupe door swap
  81. where is the main relay and where do i check the ecu
  82. my engine wont start
  83. 94 civic coupe b16b
  84. Civic 93CX Swap Zc started and stop ... help please...
  85. 95 Civic EX
  86. My reverse keeps grinding!!!!
  87. keeping a/c
  88. 1995 Civic Surge Problem Not FITV or IACV
  89. 93 hatch cx/non v-tec to a 96 1.6 v-tec problem
  90. vehicle speed sensor? help!!!
  91. 95 civic 5speed -tach hook up
  92. Fix My Car!!!!!
  93. 94 civic lx 5 spd problem
  94. 95 5speed swap??
  95. Can I swap a D15B7 for B18A1
  96. What engine is a cheap swap with potential
  97. civic thermostat replaced but engine is still over heating
  98. 94 honda civic
  99. 94 honda civic
  100. 93 Lx Speedometer/Odometer don't work
  101. Intermittent Wipers don't work until pushing key into the ignition switch.
  102. Auto tranny
  103. I have a real gas problem
  104. 94 hatch with 98 integra dash
  105. Suggestions on what to fill my transmission with?, GSR 5speed
  106. No vtec???
  107. B18b swap needed info
  108. hardly running sohc VTEC
  109. 1992 CX Starts and quits after 2 minutes, anyone????
  110. Speedometer stopped working
  111. 1993 Honda Civic Vibration in front end at lower speeds
  112. P28 chip auto trans issues
  113. idk whats wrong...
  114. rad overflow bottle issues...
  115. Indian Civic Hybrid Review
  116. 94 civic LX does not start
  117. which header will fit ls/b18b1 ???
  118. No Acceleration
  119. Hesitation Troubles?
  120. Speedo problem on 94 Civic
  121. Switching LS motor from 92 HB to 95 EX
  122. 95 honda civic tranny problem
  123. 3 rear main seal failures in 1 year
  124. Short Shifter bracket for an eg?
  125. P30 ecu with code 36
  126. 93 DX speedometer problems
  127. d16 headers on a d15 motor
  128. Windows won't roll down
  129. Hatch on Hatch action
  130. Stripped steering wheel thread
  131. Need advice on anti-theft pedal locks.
  132. 1993 civic stater problems
  133. d16z6 keeps throwing an engine code 15
  134. B20 and i want more power
  135. thinking of buying a 1995 civic plz tell me if its worth it
  136. 93 civic busted power steering tank/pump
  137. HELP! Locktronics on a CIVIC
  138. 95 civic wont start
  139. B16 swap tach problems PLEASE HELP...
  140. civic misses at idle`
  141. high idle gas smell
  142. wont rev up!
  143. 94 civic LX stutters
  144. 94' Civic Overheating
  145. 1st gear wants to pop out...only 1st
  146. Rear brake drum and general brake question
  147. 93' civic problems
  148. Dampness on front passenger floor
  149. Stock 95 civic hatchback 4 sale in san diego
  150. Spring Frustration
  151. 95 honda civic ex v-tec
  152. del sol running on 3 cylinders
  153. Are these mounts all I need?, (97 GSR b18c1 into 94 civic hatch)
  154. 02 Sensor
  155. JDM EG From Germany
  156. ECU Problem
  157. Just bought 92 civic
  158. Turn signal doesn't work
  159. CR-VTEC "the right way"
  160. question re Auto Tranny fluid
  161. Engine swap question
  162. is a SOHC ZC worth fixing up?
  163. Spark Plugs Problem.
  164. My Civic 94 EX does not start......please help.
  165. Wtf Tranny Dipstick Is Bent
  166. 92 Civic wont start
  167. 93 5speed need a motor please help
  168. 93 civic 5speed need motor
  169. B16A SiR II Tranny
  170. B20 cylinder walls thicker than H22's?
  171. 92 si ecu code 22? and
  172. Brake enhancements
  173. 92 cx with d16y8 obd1
  174. 95 civic Must push gas pedal??
  175. FRONT END CORE SUPPORT DMG!? HELP! =O pix!!
  176. Help In Buying A Civic
  177. left side blinkers stay on
  178. weird problem
  179. 92-95 Civic DX and EX cam sprockets
  180. Why are sk2 cams $200 more than obx and blox?, What's the difference in them?
  181. b16 head value?
  182. 95 Manual Honda Civic - Shifting problems?
  183. D15B7 and the D16Z6
  184. 94 Civic Alternator
  185. License plate screw size
  186. Civic EK9 Type R gentle climb
  187. Steering Gear
  188. 93 civic won't start
  189. 1993 civic will not start
  190. Engine search for 92 CX....
  191. Runs and stops
  192. Water pump question
  193. 94 civic no spark
  194. 95 Civic EX Stolen ECU
  195. What's the stock exhaust diameter?
  196. motor question on a 97 civic ex
  197. rebuild my gsr
  198. Strange idle issue
  199. '95 LX No cruise control or horn
  200. has any one done this
  201. 1995 Civic LX - Please Help!!!
  202. B16A swap into a Ford Escort
  203. 92 civic injectors
  204. I need help
  205. fluctuating idle, checked spark plugs, then car stalled and now won't start.
  206. No brake lights or horn
  207. motor questions
  208. Don't hate me....what would be faster?
  209. Header comparison
  210. Just got a wrecked 97 GSR
  211. Coolant loss mystery
  212. 95 Honda Civic Missing and has a strong gas smell
  213. Want your opinion guys
  214. replacing turn signal assembly
  215. 94 civic cx distributor O-Ring
  216. 94 civic cx distributor O-Ring
  217. d16 intake/throttlebody on d15 head?
  218. NOOB -B16A2 swap, what dizzy's..
  219. NOOB -B16A2 swap, what dizzy's..
  220. clutch? or tranny?
  221. air/fuel ratio
  222. civic ecu?
  223. dont know what type of engine i have
  224. my car wont start...help please!!!!
  225. 4040 vs 3030 Prop Valve?
  226. 92 Civic: trouble getting the key out in the cold
  227. 92 Civic: wierd rattling noise in the cold
  228. Head gasket questions
  229. Which alternator produces most current?
  230. My unsolvable mystery! - Gas smell/ low mpg
  231. integra brake booster question
  232. head question
  233. civic questions
  234. Error code 21 after engine swap
  235. electric window
  236. timing belt
  237. Knock Sensor
  238. Civic rear disc conversion, What parts will it need?
  239. turbo questions
  240. decat pipe?
  241. How long will it last?
  242. 1994 Civic EX
  243. ...any ideas?
  244. turn signal problems
  245. poor air con
  246. clutch does not seem to catch fully when releasing it
  247. check this out
  248. Fried Battery, anyone know what i should do?
  249. Problem With Car Battery!!! Need Help!!!
  250. 95 civic auto trans problem
