Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
a/c wiring
Vids
Need help - Y8-Y7-A6 compatibility???????
Engine swap question.
Replacement Radiator
Liquid wont spray
internals question
Instructions for lowering 94 Civic
Stripped Distributor Rotor screw
Idle too high on my 95 Civic
ok bad dash problem
witch floor mat for my civic?
just quess
I'm New
Sideskirt length
B20
Broken fuel gauge?
Car Not Starting
Guage cluster in 94 civic dx
rod question
ferio!!!@@@#@#@!$#@!$$!@???
d15b7 to d15b swap
Stupid Radiator
overheating problem!
Headlights and Gauges .. anyone knows where I can find them ? (photos included)
carsponsorships.com
What could you do with $12,000?
Interior vent painting
EK Conversion??
93 civic fuse help
timing belt replacement
Timming issue
Help with hesitation please???
Best performance tires?
Help Please!!! I don't know what is wrong...
Looking For A Hatch
knocking on the firewall
Fuel pump queston......
Short Video
Cel 5 ????
civic radio wire coloring
94 Civic's no start problem
95 civic ex wiring problem
Which hatch...
ECU Code - 1
in the market for a car, need some info
Building Block
sunroof problem
mini me sohc vtec....d-series 4 life!
94 EX Noob questions
is the eg6/ek9 good for auto Xing ??
98 civic motor in a 92 civic body
Looking for a stock exhaust manifold..
Sponsor Question...
Newbie questions
does anybody know what brand on exhaust and intake is good in hp
attn: rice burners
gar eating tooo much gas!!!!
Smoking Front Left Tire Area
Want to make a swap need advice?
Drums or Discs?
i/h/e question
Squeaking, vibrating from Distributor Cap '92 Civic
Yoooooooooo...check out this Acura V6 3.2L swap on a civic!!!!!
looking for a cargo cover for my 92 civic hatch
another start up question 92 civic ex
Apc
Civic Type-R
usdm or jdm
No Start, No crank Help
newbie checkin' in
honda civic CX...
02 sensor problem
Civic HB and VW gti
95 civic lx engine swap
opinions on jdm
180whp racing clutch?
Timing belt tensioner noise????????
Too Many KM's?
Got a ticket for modified Exhaust, need to ask a question
gsr civic swap help?
95 Civic DX Idle Problems
Another stupid question
93 civic speed limiter
limited slip differential in the snow????
Thinking about FI, got some Q's
Blown Engine - Want D16Z6 or full B swap
Headers Help
Sumthin's wrong
gauge in cluster busted help
I so should have gotten a CRX..
JDM ZC rebuild Question.
summit ignition system.
need a part
SI Tranny
ignition problem
Will Vtec Kick In If Car Is Up In Air
brake light!!
passenger turn signal wiring
O2 sensor WILL NOT come out..
weight
headlight issue
completely new to this
Curious to know?
Sound clip on my D16Z6 8700 RPM
Rear Brakes
Random yank
fender question
quick sensor question
Injector problem
need help with gauge installation..
knocking valves problem
Header Performance??
transmission swap cost
Redline question
Troubleshooting Problem
AEM big brake kit
brake upgrade
Already use the Search feature...couldn't find it..
HELP!! 1.6lt vtec 4cly-SWAP??????95 civic
4 sale?
Pearl White Civic
Vtec Engine Swap
Irratic Idle w/ heater on?
Plans For a 94 Civic EX with the V-Tec
Shorts out when I hit Brake?
D16Z6 swap into 92 civic VX
White Rims, HELP!
RPMs
RPM>>>>>>>>>>>>
D16z6 and VTEC
troubleshooting anyone?
another already answered question....
Small question...
rear drum grind
B18B1/B20 Hatches check in
vtec for non vtec. need help
hood fix?
Integra XSi Swap??
s2000 steering wheel
b16a??
V-tec or Not?
Whats faster?? 01 accord or 93 civic
What is that annoying rattle sound??
Gauge cluster/ tire size change ?
trunk problem
95 Civic Hatchback DX tach install problem
what model?
Painting int. Vents
How to Install Ignited Start button for Civic 92
headgasket crack between cylinders?
About to start building up
Help With 12 second Eg:b18C-R
O2 sensor replacement.
stereo problems
stereo wiring
??d16z6 rebuild questions??
94/95 civic
Is this a joke or something
pages from helms manual needed/take off dash
paint
need ecu badly
v-tech wiring question #2
DISTRIBUTOR ( spark-plug wire order on distibutor for each cylnder-1234)
Lip kit install
JDM parts
Throttle body spacers
another frozen fuel line question
Psst... Hook up inside.
Timing trouble, bogging, timing backfire, HELP.
hyundai needs help
push button ignition
Fast/easy Way To Remove Distributor
Tune Up?
benefit of spoilers
Rear wiper question
Exhaust clicking
Just a thought...
you may think its rice or not but...
fuse keeps blowing - wiring questions
More Torque
Overdrive
Brake Master Cylinder
hood insulation ??, interior noise ??
Electrical Demons. Honda Priests?
Performance upgrades...new clutch needed?
93 civic
Cold Air Intakes...
how to replace radiator support???
Some A$$hole TRIED to break in my car, Losers.
d16a8 (zc?)
C32A swap
help me find engine!!!!
need a part
Max RPM
95 civic w/ no spark (cold weather?)
code 90, not sure what to do now.
Links Links Links
Temp. Gauge Malfuntion?
Selling All Original Hatchback!!!!!
non v-tec to v-tec
Check Engine Light: Code 41.. fix?
rotor size?
front end swap???
FORUM RULES AND GUIDELINES - MUST READ!!!
Potential of Supercharged/Turboed SOHC?
Blew it up today.........
difference of d16 and b16
Stupid ABS Light
Idle Problem... (I know, I know)
Couple pics
civic alernator problem
Help! I need an Idle Control Valve!
i am a newbie!!
Re: tail lights, running lights, and instrument lights out!!!
parts!!!
Problems and questions about my 93 civic
Transmission Swap Manual to AT
92 civic
Quick, Need help on this!!
97 dedan door handles on a 92 sedan
Rear disc on 4-Door
Driving rich
Radio Bezel Please Come Out
inner fender????
muffler
massive confusion!!!
poor lil 4 door
FS D16z6 vtec motor and tranny
civic crankshaft pulley bolt
wiring v-tec/want more power
Long time members have been wanting this for a long time
Worst Luck Ever!!!
Honda Factory Shop Manuals
favorite body stile
blown crankshaft seal
Best headlight bulbs?
94 Civic CX Head/Motor Swap D15B8 to D15B2
reply to 4 door mods
b16a1 or b16a3
ecu swap?
mAd m0dz Q
question about headers
1995 Honda Civic oil change
95 Honda Civic Mods Part2
Headlights "On Alarm"
key holes
CEL just came on..
Are civic's wired for power windows on dx's?
automatic to manual swap.. cost?
Web
AF
