Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Good Buy?
tickets??????
Difference between EX & LX & DX
all im reading is D15b7s suck balls!!
95 civic ex
i need some pointers
93 Civic Auto Shift Cable
Auto. transmission problems
Carbon Fiber Side Skirts
Torque Converter Install Question
turbo ???
shortest tranny for d15b ?
What's a fair price for this car? PLEASE
Buying a 92 Civic - Problems to look for?
Switch Headgasket... question
94 honda overheating
Weird anoying noise, need help!
Car Is Bogging Down
Gas Mileage Improvement
Why do i feel stupid 4 axin this
Expansion Valve? need help :(
Pix of the creature.
95 civic wont start
94 civic ex with odd markings on the engine
replacing stock antenna
D16z6 with D16y7 block.. will the turbo manifold of the d16z6 fit with the d16y7?
D16z6 with D16y7 block?
question about gauge cluster
Questions about 92 Honda Civic
Im a DSMer wanting to buy a civic project car....heres some of my ideas and questions
92 civic with b18ls swap
92 civic with new dash from 95 acura ?help?
93 civic mods.
94 Honda Civic
what is gsr ?
car sale
anyone ever got a turbo kit from here?
Does this sound like a good car?
need swap help
am i running rich
Replacing stereo
power window conversion
5 gen civic sedan fog light
front window all jacked up
92-95 4dr civics
95 civic dx swap to d15b (vtec jdm)
B18B boosted
Caliper Specs
94 Civic overheating when on Highway.
Just Plain Stupid!!!
Would it work?
New yet not
Temperature Guage Maxing out / motor not hot
How much are we talking???
b16 problems
92 civic with zc swap?
92 civic engine swap query
A dumb question and a smart one... (about stripping)
radio install
Need Opinions
Which wire from ecu is rpm/tach signal?
help...my cooling fan fuse just melted in the fuse box...
Effects Lighting
Axle Boot
civic parts fs
Is there an exhaust that helps you get better gas milage?
Quick Sunroof Q.
figurin' this forum stuff out
turbo D series?
rev limiter
honda ex 95 cruise control not working
d15z1 vtec-e default rpm engagement?
94 Dx Brake Question Ani Or Non?
tranny problems
95 d15b7 to 93 d16z6
my honda after dewin 70 on the freeway
confused about civic dx tach
Can i bypass my oxygen sensor on d15z1 vtec-e
tach in a dx?
Just got a 95 cx, just a couple questions i have.
will a ex cluster clip into a dx
need help
my hatch
squeaky suspension
motor swap d16z6 to b18c1
best engine for civic to accerelat?
>>B18c swap into a 94 ex civic<<
why a 92-95 4dr civic?
burned ignition
timing problems
Interior Lights HELP!!
maximume acceleration
gauge cluster question
camshaft hell help =(
hatch-coupe insurance rates
Speedometer
car stalls
6000 redline?
way too much play in shifter PLEASE HELP!
proportioning valve a MUST for teg rear disc conversion?
Start Up: ITB's on my Civic...
Idle control solenoid location
I Need Da Radiowiring For A 94 Honda Civic Someone Cut Wire Harness Off
O2 sensor question.. NEED QUICK RESPONSE
Ecu question
engine coolant
CX and DX 0-60 and 1/4 times
Hard getting shifter out of park
sunroof wont open in 95 honda civic ex
Tell me everything I need to know about installing a 4-2-1 header.
power window relay ???
A/C Issues - 95 Civic EX 1.6L -
95 Civic A/C Trouble!!!
vtech head on non v-tech block
help, looking for fender for 93civic
My new Civic
Airbag ???
My civic fails to start sometimes
Overheating Civic....
accord brakes?
Newbie Here
Cam Question for ya ladies.
over cammed?
over cammed?
VTEC not working
ECU Code 43
will 96 civic rims fit a 95 civic
red line on a civic
How do I adjust the idle on my car? Is this my problem?
My brake joints squeak and I can't find where to oil! Please Help
'95 Civic won't start
pulleys, what are all of them?
A/c fitting question
jstu got my civic!
turbonator or tornado? that is the question
engine ID
tranny swap
++Walbro 255LPH HP fuel pump++
drivers side mirror cracked!!!
best tranny
baffled muffler
AT transmission problem!
Possible Clutch Problem???
Timing marks off, advanced to the max
92 Si Hatchback Gauge Cluster????
Reverse Lights
Just bought a civic and its shaved......
93 civic EX vtec: idle rpms surging NOT EGR
honda civic ecu
Daughters 95 fluctuates in power on road
Oil Inside Distributor
Dude, Where's my gas?
Head Gasket? 94 Civic Ex w/D16Z6
A/C Drain Hose ???
Stock/OEM civic parts?
dash lights need help please
Engine Question
Transmission Filter
92 CX Hatchback Won't Start!!!
92 Si Won't Start
door handle/latch
auto 5spd swap ?'s
Overheating and Transmission failing
coolant leak
tire chamber
wipers
Compressor clutch keeps disenging
automatic transmiton problem
bogging and oil in spark plugs plZ heLp
Totalled
some engine swap guidance
My Civic...
Door panel removal...
Major bogging and cold start problems
Need Help!! Car won't start
Oil
i need to know the best motor to put in my 92 civic vx
92 honda civic rpm probs
Boost gauge
1992 Civic EX has no EGR?
Actuator
Camber Issue
95 civic ex question.
Help please! My 95 civic ex won't start!!
radio antitheft device
Some Guidance please on 92-95 Civic
Suspension work
New AC compressor? Please?
Painting stock brake calipers...
95 Stereo Removal question.
1993 Honda Civic Back Seats Will They Fit?
Connecting My Cd Player To My Car!!!
Stereo Installation Question!!
compression numbers
1992 honda civic stereo/cd player connections
Stereo Help Please Help Me!!
New to site
95 civic stereo problem.
92 Civic Hatchback Vti Stalls when running A/C
Technical Assistance Needed
Help With Stock d15 Shifting Points!!!
d16z6 timing
my exhaust pipe
Question about installing a 2-piece header..
Civic Exhaust on accord
Turbo charging
Audio and Intake
swappin' D16y8 in '92 civic cx hbk
timing degrees
O2 sensor or new engine?
95 HB speaker size?
Lowering Nitrogen Oxide Levels
93 Civic not right
Do I treat my car bad?
zc turbo? or b16a2
axle question ls/v-tech on 93 civic help?
h22 turbo?
rebuild engine, supercharger combo
95 Civic quit running
Help me out here
94 civic d15 problems!!!!!!!!!!!
93 civic DX not running right.
Whats the difference?
engine problems
brakes are stuck on 94 civic ex
spoon spoiler
All these AC problems lately?!!?! lol
New to the soup what do i do with a 94
Installing a AC in the DX
tampa street racing
92 HB DX overheating
14.6 stock d16 at the 1320
ZC/D16 Head Gasket Change HELP.
need to confirm this about AC
alternator drive belt issue
need an ac system
I Canīt not find my civic ecu computer!!!!!!!!!!
Free Strut Bar for 92-95 Civic Si Hatchback
Seafoam additive question
Found my RHD parts........Cheap
Putting in an automatic transmission, need help
whats it worth
OBD1 To OBD0
Window Regulator for '93 Civic Coupe
airbags
A/C help with '94 Civic
exterior is done..eg coupe
93 Civic Ex
Web
AF
