Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Spoon Crate Motors
1994 Civic DX throttle body is sucking in too much air
95 VTEC Intake vacuum hoses
B18b1 surging
fuel pump
Timing marks 93 civic 1.6
fuel pump
95 Civic Top End Swap over to VTEC, Need a few answers!!
94 Engine Swap Question
My buddies 585whp Civic... Interesting night!
Power problem.
Corners and Tails Out
Gas Milage on 95 ex
is p30 good for d15b vtec ?
b16a 88-91 long block
Yea!!!!!
Head Gasket... Help!?
Dash Conversion
rear panel
Radiator Fan doesn't work
body an paint
plastic stuff in doors?
Installation of headlights and gauges
95 Civic pics
Hatch+h22= 12's???
Parts For Sale!! Time For A Tune Up!!
Wiring diagram for gauge cluster 94 civic dx?
Vtec
ex transmission
do anyone know about b18b longblocks
91 honda HB engine swap
civic wiring help
ex gauge cluster
what do i need for this swap. 97 b18b1 into a 94 civic
1993 Civic EX for 4250
Looking for a civic coup
Tranny Fluid
Most Effective Swap
Foglight installation instructions needed for 92-95
how know sir tranny ?
Question for your Civic guys regarding the JDM SiR hatchback (EG6)
civic beat a eclipse?
Help!! What's wrong with my NEW starter?!
95 sohc d16z6 vtec civic ex
throttle position sensor
torque dampener
help
Low gas milage after replacing fuel filter
battery problems
jdm corder lights for 95 4dr civic
junkyard b18b
Engine swap 93 CX
which can kill the GTI
gauge bulbs
polyurethane bushing sleeve
clock /radio reset....
Compression checks
Fuel filter
Vtec Light
HID conversion
how to set clock
Wont start
Engine Overheating
Oil Help
Loud Rubbing Noise
I'm so happy, I just gotta tell somebody!
Help Me Choose...
anti-freeze not working??help please...
How to get the car on jackstands???
Wanna do a RHD?
hi :)
vtec
kittin
d15b7 ta a d16z6 engine swap
95 Civic EX: Problems going into/out of PARK: Automatic
need storing precautions for my civic
Master Cylinder + ABS question.
honda problems
i need a speedometer...
anyone have a stock 95 shifter?
were the hell i am suppose to start to make my honda better........
Woodruff Key fell out
94 Civic LX Starter?
strange noises under acceleration
need a part asap!
I am stuck with ball joint nut installation
What do you think my car is worth?
B17's and 92 Civics
anyone selling
ignition lock broken...help
ECU Worth the 40 bucks?
torque
1995 divic dx trunk light?
How to: Automatic Door Locks/Keyless Entry on '95 Civic?
92 Civic buckingand shakeing on acceleration
Rev limit on 94 dx?
front axle do it yourself?
front axel with or without ABS, difference?
where is the main relay on 92 dx hatch
Drain transmission oil when replacing driveshaft?
Should washers and nuts be replaced every time?
cx gas mileage
94 civic dx speedometor problems
Why people, WHY????
Replacing radio/heater bezel?
power door locks
horn harness
problems with reverse
blue smoke at high rpm's
2 questions......
News Flash: Nitrous Cures Warts(lol)
Hood cable and latch
engine is noisy!
steering wheel shudder
94 Civic Tweeter grills
drag advice
95 civic ex fluids
stock 94 civic....clean
racing question...
how many hp on a 92 civic si?
a cam ? and a shock?
steering making wining noise
95 civic wont turn over, but stereo still comes on
here we go......
idle problems
Honda Turboz
B16 engine and stock tranny
how to save gas ?
wiring
muffler tape?
header swap
95 Civic LX -- Rear End Package
need drag advice
Which engine do I have?
buying a 95 civic ex!
buying a 95 civic ex - anything i should look for?
jdm d16z6...
95 civic Water Pump? Overheating
Questions about LSD no not the drug.
taking doors apart?
fuel pump not priming
Easy to install Racing Seats on Original brackets?
instrument panel 95 ex
Is my civic JDM?
ebay headers
No bumper supports! only new bumpers
Wobbling Crankshaft Pulley
94 civic ex brake problems
breaks upgrade
wheel safe to drive on?
wheel locks
mini-me/frankenstein
do i have to use the h mounts,
Rain Bad
Looking for a pic of wiring harness
can i swap f22b into my civic
swap help...
Radiator flush question
resistor for gauges
92 Civic Fan Motor Not Turning On
94 Si rotors heating up
how much hp can a dx clutch handle??
headlights...
injector/motor cleaner
Muffler situation
pedals sticking
motor and tranny swap in 92 civic hatchback
Major oil leak
d16y6
Aftermarket Stereo Removal?
Speedmeter problem
Car Alarm Install for a 1995 Civic DX
jdm d15b swap!!
95 Ex 4d boost
95 Honda
American Drifting sensation wins drifting contest in Iraq!!
good deal?
Common Electrical Indiglo question
1995 Civic Dx Stolen & recovered.. Ignition Screwed ?? HELP ME !!
Need help on stock 95 1.5 sohc Civic temp no start situation...
On my mind at the time...
95 Civic Passenger door handle
I'm a newbie and I need advice on a swap
d16y8 vtec solenoid plug
JDM front bumper????
desperate!
Off Topic
94 Civic Speedometer Problem
yet another camber question
compelet info about ECU
testy spedometer/odomemeter/fuel gauge
wich is the best d series motor
Electrical Starting problem
95 Civic DX bought with no start
Made my p-flow lol!!
change your ECU from auto to manual
vtec ecu or non vtec ecu
Speedometer problem part 2
Replacing Speedo Seal
Whats the difference between 94-97 honda civic ex's?
is that dengours at the ecu ?
92 H22A Hatch Flooded
My Honda is overheating
clutch install gone bad i think!
jdm foglights?
manual tranny fluid change
how to wire in the vtec
lsd tranny
several honda questions
92 dx hatch won't start
I need a bolt..........Help....Will work for Bolt
parting out 94 cx HB
are all obd1 fuel inejctors the same
Not enough oil on startup?
Installing Corner Lights
02 sensor for 2001 corolla
95 civic accel. and then some
93 civic AC rattles
93 civic AC rattles
help with swap
throttle body ?
cable hook for a 93 civic hood
Damn O2 sensor
How To Check CEL CODE?
RS*R, HKS, or Buddy Club?
swaped a si cluster into my dx srs light on
obd1 or obd2????
K20 transplant;)
b18c or b18c1
bulbs behind rear defrost and cruise
swapping stuffs
Tranny ate my dipstick!!!
turbo questions
Diff kinda Civic accident
Update on the RHD conversion
Fuel Issues
6 1/2 to 6x9
PLEASE Help her doc! Let her LIVE!!
Wiring Trouble Please Help
head swaps,info, looking for 1.6vtec head and some help
92 civic first time changing brakes help
94 Civic EX window fit 94 DX?
What size speakers?
7000$ wut to do?
site for name of parts with photo ?
air filter
Good Buy?
tickets??????
Difference between EX & LX & DX
all im reading is D15b7s suck balls!!
Web
AF
