Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
what year is my Z6
1.6L VTEC D16Z6 SOHC to DOHC Conversion?
rmf header
intake manafold questions
vtec-e
Help with a steering problem
windsheild replacement
Dashboard
95 Civic Ignition Timing
power option upgrades
d15b7 swap mini me y8 help
Parasetic draw while car is off?
92 civic lx
92 Civic Momentarily Dies
D15Z1 Engine rebuild - head machining?
Honda Civic EX engine for sale?
Rollin chassis
Rollin chassis
Timing Belt Replacement
How much should it cost to replace radiator mounts and get alignment?
Brake Trouble
advice for b16a2
Trunk lid needs help.
Lowering springs, adjustable coil overs
alternater wont charge battery!!
How Much Could I Get For My Car????
taillight/dash lights out, but fuse not blown
Oil Cooler
Why dose it shake?
installation of eurolite instrument cluster....help needed
Hail Damage! Sux!!!!
diff between whp and bhp ?
Buying a new car - wut should i get?
civic95 won't start, it cranks and sparks ok
Resistor...
Blue Tinted Headlights
91 civic lx starting problem
D series motors and tranny
Vtec hesitation
extended warranty?
Simple Oil Question
Cat for Civic?
93 EX Power Steering?
My 95 EX Pics
Is it my clutch?
Gear Box Honda
Q about 93-95 Civic coupes
Catback Exhaust System (need everyones info )
what does that mean RB26DETT?
Clutch Problems
This is really sad
Correct Head Gasket
92 d15b with 91 d16 si head swap -Help.
b16a4 swap problem
vtec not working yet working
Replacing rear glass shocks
quick civic question
86 civic engine into 95 civic
Header
Valve Tick
Tranny Question
94 civic dx
Tail light help
i would not be any thing from skunk2!!!!!!
is www.xenocron.com good ?
please need help....
Hooked up battery backwards
steering problems
does any one............
ready to give up
'95 Civic alternator question...
what dose this mean?
what kind of.........
Cleaning air filter
Engine Hop
Transmission Problem
K20A2 swap?
Pinks!!!
z3 Fenders On a 94 Civic Ex Coupe
wich setup would make more power/faster?
have to replace plugs every month 93 d16
17's chippen bad
benefits of Control arms and tie bar
93 Civic Wont Start
Import!!!! Rhd
94 civic Si Exhaust question
Custom
93 civic lx --> d16y8 swap
vtec
Piston's question
Automatic To Manual 92 Hatch
Diff Ecu Wit Diff Motor
Invader Tires?
Engine & Tranny Installation
clutch problem. please help.
Surging idel
what this mean ? >the dyno
Need Help!! RPM's dropping
HELP---93 civic lx d16y8 swap
95 civic just quit
Coolant smell and light smoke
Skipped timing?
my 92 civic thanks you all for yor help
Honda civic LSI 1992 engine wont start when its raining
Whight smoke and rough idle
If I...
proplem upload photo
...help...
Gauges
Check this! Civic with teggy front end going mad cheap
d15b2 in a 92 cx???
Problem!!!!!!!!!!!!!Help!!!!!!!!
alternator help
can anyone help?
Installed short shifter now tranny makes noise
cx tranny with a ZC
car wont start. please help becaue i need to fix it fast
Looking into a 92 hatch With h22 JDM..
Throttle adjustment?
how engine cut off
OPEN THREAD(engine swap)
i need help with my fuses!!
Block Swap HELP!!!!!!
Turbo Help!!!!!!!!
great site
Wing Transplant ideas?
auto ecu in manual tranny
Turbo Manifolds
Turbo Manifolds
1995 civic
93 Civic DX wont start
Rev Limiter
guage cluster
93 Civic SWAYS on freeway. SCARY!!
what MSRP mean ?
dry rotted tires
power steering fluid
Ex d16z6 Engine, 5spd trans, ect. priced
rally edition??
Help car won't start
Brake light darker
intake manafold
Syncro's
Several Mother Frickin ?'s
a/c and heating problems
Automatic Transmissin
Plastic inside doors
Code 43
New Civic Buyer
car just died
what is DSM
How to adjust camber?
h22a harness
93 civic power door locks
ECU tricks
undercar plastic guards
door pins
Chip Question
Engine Trouble... PLZ HELP!!!
comp ratio
some questions about d series
what is FMIC
92 Civic with 220,000 miles
Broken Hood Release
P28
93 civic speedometer not working
Vibration
Good exhaust
how much for power
94 Civic Wont Start
Want A Civic
94 Civic Ex Need Help
92 4dr o2 sensor
gas mileage
turbo question
d15b7
New headlights, need new bulbs
5th gen d15z1/ 6th gen d16y8 head swap?
Help Please
Need a Motor
Help Dropping Car
Denji Jaguar Eye Wiring Harness HELP PLEASE
long crank time
how attach picture
hatch lifter prob
lost horsepower
RADIATOR LEAK IN 95 Civic EX
B16A SIR Bogging under load.???
how to install turbo
What's the Best clutch for my set up??????
need carfax..plzz
low gas indicator
low gas mileage in 95 civic
Oil change freq
Surging ANSWERS
93 Civic Headlight 2d And 4d Difference?
spark plugs help
outside window trim for 95 civic dx
93 Civic Si Rebuild (to stock) need help!
Cheap way to light up your gauges.
D16Z6 In to 92 Cx Hatch
Clutch problem
im blowing black smoke
car alarms
Piston help
Piston help
Clicking noise front wheels
sir front clips from japan question
motor swap guides on ebay, good or bad?????
battery charging problems??? HELP
Control Arms
92VX intermitent drive problem
Fed up erratic idle
Swap CRX pistons in Civic Vtec
turbo question
squeeking brake noise
car stalled after 40 secs. now wont start!?
oil leaking by the timing belt cover
transmission question
94 civic tranny/clutch issues
Easy question on check engine light
94 civic Hatchback
My car.
92 Civic Hatchback Head Removal
Better civic??
what is psi
USDM Engines
Ok, so I'm getting a civic...
Stuff in my tank
Tranny ??
dual halo projector headlight problem
motor work
Question about an engine i might get
3 cylinders
cluth oil leaking into cabin!
inner tail lights
A Clean 93 Si Stock-ish Owner With Some Questions
need some advice for D15b
fuse panel cover diagram 93 vx hb
spring rates for rear(heavy a$$ subs and amps in trunk)
Can Anyone Tell Me...
Mini Me Starting Problem
95 hatch ?'s
bad bushings?
Tranny or clutch
Repair Manual
turbo boost
don't know what to do!!! help!
Web
AF
