Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
What do you call this cable?
b18c3
3 random questions
where is the fuel relay on 92 dx hatch
93 Civic Ex VS 96 Ek Hatch
New: Please help? Civic VTEC!?!
Website List
Acceleration/Hesitation issue?
Different oil weight for winter?
Scary moment today- Brakes
coolant system pressure abnormally high
water pump installation guide
B16A Mounts
Help!!! Honda civic cx , no start
93 civic EX check engine light
runs rough at idle and worse in reverse
B16A ?'s
p28
Power Steering Bleed Out - Can I go without?
Guage Cluster mileage?
oil pan gasket
95 civic AT crank pully wont come off!!!
94 civic dx interference motor?
Speedometer 10 mph higher.
1995 Dx Inconsistant Idle
Door Skin Replacement!!! Help!!!
How do I hook up this air/fuel ratio gauge?
question about electrical system
93 coupe CKP code 4
quick question
93 Civic Si Weird Noises From Engine
93 civic tail light,head light,and corner .
exhuast
Removing cat. converter
cel code 19
kyb gr-2 shocks
automatic tranny help
How do I install the dash trim in my '93 civic?
carb to injection?
P73
93 civic. I was just jacked!
Need a new clutch advice?
D16Z6 Timing HELP!!!
technecal question about oil pump
Evil... Very persistant Stuck rotors.
94 civic A?C compressor wont run
Opinions on Engine swap
Exhaust video clips
transmittion leak
Heater hose routing Help!!
Optima battery nowhere to be found??
Alternator or Battery?
Is this the bumper cover or complete bumper
Paint codes?
springs
93 Civic Disc Brake Conv.
Heater core replacement
what do you think?
struts or shock
Brake Help
Cant find power lock plug! NEED HELP!
Removing part of exhaust pipe on 95' DX
d16z6 or d16a9 or d15b 3stage
b16a2 swap, but d16 ecu/tranny/mounts?!!
???? about 1993 Civic
long time to start in the cold
Brake Sensor on 1993 Civic..
Runs fine cold, bad warm
Need help with 93 coupe dissy problem
How to replace my thermostat ?
ticking noise after shutting engine off
is this engine in USA ?
How much to fix this, rough estimate.
looking at a 94 Civic
Chilton or haynes ?
What would you spend $150 on a 94 coupe
Aftermarket Lower Control Arms and Sway Bar
ATTN: who bought ebay headers?
Clanking sound
stereo
ecu code?
look here to know the clynder head year
95 civic ecu question
Keys matched
Thermostat Question
radiator
possible?
Need help kinda new at this. Plz and Thnx!
How can I find out what replacement engine is in my car?
engine code places?
How many miles is too many?
exhaust leak
1993 civic
Security L.E.D.
D-b!?
Badges
Tie rods?
H22a SWAP issues. PLEASE HELP
Core Supports reassembly Help
Questions Help needed =)
Suspension problem
93 Honda civic no start!
Overheating stock 94 ex coupe
attempting to stall
Check out what just came in the mail...
need help with this
JG camshaft 85vt35 valve setting spec need help
Odd Idling Problem. 93 Civic SI
93 civic 1.5 head gasket bolts torque and tightening sequence?
cam gear
93 civic dx speed sensor ?
D16Z6 engine needed
S-AFC 2 Problems
95 civic what wires are needed?
Cutting the springs to lower my 94 honda civic
harness conversion
tranny help 95 civic DX
water pump?
Rough Running
How to Change the Head Gasket In 94 Honda Civic EX
window molding
true or false
Water ddipping w/ ac on
I'm Confused
Please Help... Engine Problems with 94 Civic EX
new heads
How much would it cost me to replace the exhaust?
Replace O2 sensor question
alarm remote programming
turbo d5b7
tough time
Duraflex?
B16b
head gasket?
dashboard lights on my '92 civic
Issue with my e-brake..
My New Civic Si
Transmission Shifts Late
K&N filter oil?
"projector headlights" on my 94 civic hatch?
95 Honda Civic Dx Horn Slowly Died...
Need help on who makes this civic piston. Thanks
ebay header feedback
More questions...
steering rack removal
94 civic?
Hatchback question...
i am looking to spend 15k on a car
JDM H22a issues
95 Civic EX 1.6L automatic/check engine light/no air
what is the CFM
'92 Honda Civic When warm starts and stops...?
92 dx poor acceleration
different civics
Rusty Oil Pan on a '95 Civic DX
Need Help Fast!!!
fuel gage light
Help car won't start - no spark
eBay headers and cat, yay or nay?
Tranny swap
Headlight not working w/ new bulb
Clutch/transmission problem
95 DX engine surges when in idle
93 Civic HB; Car's Died on me for the last time.
homemade PVC pipe intake?
Cooling system Meltdown
wtb these parts
Instrument light not working
D15B7 Performance Parts
'95 Civic DX - cut antenna cable
95 civic 1.5, octane 'ping' ?
New Engine
Engine cranks over but it won't start, need help
A/C trouble
95 Honda Battery Light
Honda Helms Manuals!
b16a vs. gsr swap
Clanking sound in front end
Buzzing noise after start-up? 94' Civic Ex
how does this sound?
Engineers Wanted!
92 - 95 honda civic Rust! Quarter Panels
Mega Squirt?
D16 axle to D15 tranny
how to identify the si tranny SOHC
what should be a good exhaust kit?
how to define the 170 hp b16a?
My car just randomly died while I was driving...
name of part ??
stupid question
do engine oils make a difference?
Do fuel injector cleaning chemicals really work
tranny code?
1993 civic bucks
D15b7 Mini-me d16z6 Running only 2 cylinder??? HELP!!!!
Electrical help
best tranny for b-series?
b16a swap
jdm gauge cluster
Need Help With Xplod Head Unit
need help finding my tire size..please..
93 lx wont start
cel with p08 ecu
what good is the D15
what do u all think abouit this.is it worth it
exhust cans
quick vx question
anyone good at photoshop?
94 civic high output alternator?
vtec
what is mpg mean ?
Easy electrical question about grounding
95 Civic got 46.8 mpg?
dropzone?
Tranny Install
safc2 start ?
Strut bars and other braces
Tire Rotation
Decent cat?
wipers are too slow
Grounding
IAT sensor mod
cheap DIY mods
d15b jdm turbo vs golf v6
3 grand budget, can it be done?
d15b ecu with d16z6
selling my 92 civic
Ignition Timing
New throttle body help
What is the easiest and cheapest engine swap
Will this bolt up?
Add Vtec on ZC engine?
92 civic alternator problems
Civic burning oil
long block? short block?
95 civic ex ECU problem
Cold Air Intake materials
what is DPFI?
hi/low throttrl in safc2
Pictures of my 94 Civic Ex
Electronic Principles
Really rich exhaust...
engine light
knoking sensor
which ecu should i use?
93 Honda Civic Burning Water/Antifreeze
strut bar/sway bar?
o2 sensor
not impressed with vtec eg civic
Web
AF
