Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
D16Z6 head on a D17y8 engine
F serires swap?
center caps
d16z6 v b16a2
car dies when i turn hard right.....
runnin rich yo
95 civic auto trans problems
95 civic overheating...frustrating!!
Integra brakes on 94 hatch
Show me your Intake Manifold!
Need some help with headlight alarm!
engine swap
low rpm studdering
EG Hatch strut connector stripped out
wiring diagram
Tampa Where you at????
B16 turbo
Civic not starting
TRANNY GOING OUT? need help
My New 92 Civic. (Im New!)
Engine Mileage
help me figure out why my fuses keep blowing
lowered 92 civic with b 18 having problems
1993 Honda Civic Hatchback SI Need Help
Melted Bumper
'95 Civic dies when engine is just warm?
What head/tail lights will fit in a 3dr?
Cut Harness?
Cluster interchangable from EX to DX?
What is better to put into a civic?
Turbo...
Clikity-Clak Name That Noise :)!
Compression ratio's by the pistions?
sideskirt question.
New Cylinder Head Question
Fuel Cut Off To Early. Cut Off At 6500rmp
Brake Job
Rough Idel / excel after Car has Warmed up
Decent exhaust on a budget?
CIVIC 94 windshield washer
It just gets worse and worse....
My trunk won't close
95 honda civic wont start
Trouble with Brake Lights!
which trim for me!?
need advice on 94 civic dx
Exhaust Questions - Whatcha Got?
acceleration problems...
Japan Si cluster into 95 Civic DX
AC system recharge. ac not cold enough
Anyone seen this B series swap DVD?
ABS Brakes?
What's the output on a stock alternator for my 95 civic? How many amps?
LS tranny vs b16?
Alternator belt
are D15 engines interference?
Wiring Diagram for a JDM Climate Control
intake smog help
type r turboed
95 civic swap-a-roo
Started up, stalled after 5 seconds, won't start!
95 civic ex coupe 1.6 ltr -83,000 mi -won't get +20mpg?
putting a y8 header on a d16z6 and tb question!!!
d16z6 with y8 parts?
92 Civic DX SRS light on after clock spring snafu...
main relay?
Stereo problem- fuseOK, wiringCorrect...No constant Power
Bad Injectors???
95 civic d16z6 ???
ecu coding problem?
fuel system problems
HELP!!!! Suggestions for Rebuilding Motor
prelude fuel injectors
Some exhaust related questions
dizzy question
Exhaust repair mesh
Poor Idle
a/c question
power window and lock conversion
For those of you with Main Relay problems.
accidentally put ATF instead of oil
My B16 is so slow!
Tech Questions...
d16y8 into d16z6 car
95 Civic hatch
92 Civic Dash
black smoke
wtb cheap engine
PGM-FI Main Relay, 94' Civic LX
4 door WONT START???
my list of problems (92 civic dx)
Engine Noise... yay
Whats the Chance of a Warped Head?
95 Civic Losing Water But Not Out Of Hoses
95 Civic Poor Idle & Hesitation In Acceleration
Need a picture of a 1995 Honda Civic DX engine
92 civic sedan possible engines
Need immediate help... How to pop the hood with a broken latch
Oil Pan Gasket
new fuel filter or pump...please help
Car stalls once operating temp is reached?
Disk Brake Conversion Question
any step-by-step on changing an axel?
honda civic and autocross
help! question for integra to civic suspension & brake conversion
Car is not using all the fuel??!?
Heat/AC question
'93 Civic Console
Need model number for '93 civic ECM
what size is the bigest vtec????is it the h22???
Help My Honda Civic
94 civic-No spark
well... if anyone cares
Dead
What to do with 7-8 Grand
Shift Linkage
1995 Civic EX Intermittent Wipers Don't Work
b16a2
CRX vs Del Sol vs EG
what would be best to put in a civic 94 coupe
Tps ??
SRS Light Reset????
Power steering for DX manual EG
need help with oil leak
Another 1992 Civic That Won't Start
help poor civic died on me ?
wat should i do k20 k24 or h22
D17a2 swap into eg
Can Someone Help Me Out?
civic shifter safety lock release
Erratic Idling
????????????d15bvtec?????????
Torque converter not locking?
difficulties
heating problem
Importing a JDM Engine to Vancouver
oxygen sensor
heating/air con controls
window
crower cams ???
Lost in Japan, Civic or Integra?
95 Civix EX Auto trans filter
Help with engine swap??????
need help with cool air intake
93 Civic ex grinding brakes
1995 honda civic dx, need help installing rear speakers
fuel system reset in a 94 honda civic??
Newbie Need help with replacing driver seat 95 civic
wiring for passenger door..
Jerky decelleration
WTB! 93 civic hb this n that..look
Slow on take off????
timing belt help!!!
????????????Need Help??????????????????
92 civic wont start
Home made intake..
lower control arms
tranny of B AND F changable?
Preformance Advice
LS/VTEC turbo Civic or B18C1 turbo Civic
Idle speed
Turbo on a B16A2 Engine Questions!
more carbon fiber..
Weird Idle Problem
engine swap hlep plz
Ok Settle This Once And For All!
girlfriend in trouble #2
girlfirend in touble
max hp
Buying a '94 Civic
Input needed please! Is this worth buying??
'94 Driver's window
Car smokes a little when i hit vtec...
integra intake?
Axle Removal
How can I make my ride smoother?
95 Honda Civic EX Value????
Radiator
98 tranny in 93 eg6?
Motor Mounts
ac install
Will a 95 4door hood fit on a 95 ex coupe?
93 civic D16Z6
Civic DX 1343
Ok my car runs fine, but it sounds kinda funny when i accelerate
Replaced starter, still nothing happening
Motor swap help
Will a b16 tb fit on a d16z6
93 Civic Bushings Cracked/Safety question
Going to the salvage yard! & my 1st pix of my 95 ex
Engine runs poorly in drive, Fine in Park?
95 Civic will not start if it is warm
My 1st honda...
Converting EG4 to EG9
POST YOUR ?'s HERE!
b16a3 in 1996 ?
fresh air leak
Rust...
Platinum +4's
idling help
Will I be alright?
need some help with yellow koni struts!!
89 DOHC ZC on a 94 civic ex
Auto to Manual parts
D16/B16 header question
h22a in a civc AC a go?
Engine mounts....REAR!!! HELP!!!
Help! Moisture in trunk...
question about the HP
Motor Swap
Question on itake manifold
Magnaflow exhaust for a 95 EX..
Ignition Switch or something else?
timming belt cut
plz o plz help me!!!
Brake pedal travel
rear lca bushings
'88 integra LS/B18 question
type-r swap
Carfax?
how to fix engine code 4
Where to buy Valve cover Bolt???
95 to 99 front swap
Can some one help please
My car won't start! Please Help!
Replaced d15b7 with d15b2. something is wrong.
flat spots on tires?
dash light out
93 civic dx engine swap
Alternator Belt Tightening Question
EX Tire Size?
inner rear trim panels
Steering Wheel Allignment???
is there a cheaper alternative for wiper blade
skunk2 manifold carb eo number
transmission swap
Fuel filter line loosening
block switching (if that makes any sense)
Electric Supercharger That Works
d16z6 help needed
I need some help with my civic
help with build?
B18B Info
civic is revin high
Help -- advice needed!
93 Civic JDm Fog Lights
gsr cam and b16 cam
ECU plug?
What do you call this cable?
Web
AF
