View Full Version : Metro
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. Timing Belt Wear -What are the Symptoms?
  2. Fix or Forget
  3. Hate to say it, but my '95 has got to go
  4. 97 metro - rough idle, 35 mpg
  5. 92 metro oil pan
  6. Unusual Noise
  7. 96 geo metro crankshaft pulley bolt keeps snapping
  8. 93 Metro Low Compression doesn't raise when oil put in cylinders
  9. Fuel Injector Replacement - Thanks for the Heads Up
  10. 96 geo metro hot soak no spark
  11. Can Master Cylinder Be Bad Without Leaking?
  12. Getting Brake Drums To Go On
  13. Two into One
  14. The Proper Order For Replacing Rear Brake Shoe Hardware
  15. Bogging on the Hills
  16. Fogging up the Car
  17. Emergency Brake Light
  18. Timing Belt Tensioner
  19. MPG versus year of Metro ?
  20. Repairing the Rear Window Defroster
  21. huge mileage problem, getting worse, need help!
  22. Can all metro transmission interchange? Are there different Gearings?
  23. This is easy. please help
  24. Anyone tried the homemade sea foam
  25. Air Bag Light Keeps Coming On
  26. Thermostat, Coolant Pump O-Ring
  27. Intermittent air bag light
  28. 91-94 Timing Belt Cover (are they the same)???
  29. 92 1.0 check engine code
  30. TPS- think mine is bad
  31. 42 mpg on new rebuild?
  32. 92 metro door panel removal?
  33. Water Manifold off Pump
  34. 1997 Geo Metro LSI 4Cly Auto shitfing Problem
  35. help id this(coolant temp switch)and its wires to it
  36. help id this(coolant tep switch)and the wires
  37. P & G question
  38. Body question
  39. simple timing ? I hope.
  40. 94 geo metro 1.0L 3cyl timing marks
  41. 92 1.0 throttle plate tbi
  42. 91 geo metro dies at stop signs then wont start
  43. There was a Mouse
  44. Leaking after assembly
  45. '96 Metro starts then immediately dies
  46. rebuild engine break in oil
  47. What oil?
  48. catalytic converter
  49. The eXtreme Metro Makeover
  50. Looking for headlight connection for 95 metro LSI
  51. valve cover gasket
  52. Help! Power washed my 93 vert engine. Now it looses power at 2K RPM
  53. 93 metro lsi hardtop
  54. Looking for cheap crank 1.0
  55. Fuel Pressure Gauge for TBI
  56. About to embark on CV change......
  57. Main bearing jounal question, 1.0l
  58. The Phoenix is now 4WD !
  59. coin tray
  60. 91-94 metro rear clip
  61. PARTING OUT 1991 Geo Metro 1.0 3 Cylinder Automatic in NC (Need Parts?)
  62. Check Engine Code 51
  63. hot weather start problem
  64. 92 Metro 87 Sprint???
  65. Metro door hinges 4 door to 2 door....
  66. 96 Geo Metro LSi gear problems
  67. Dead Metro -- Need help troubleshooting
  68. cant get 95 geo to start
  69. Advice on buying used metro
  70. 1995 GEO Metro 3 Cylinder Cooling System part question.
  71. Good machine shop?
  72. 2000 Metro Fuel Tank Issue. Unbelievable!!
  73. Blown head gasket, cooked on oil removal?
  74. Battery/starting issue
  75. Center Console
  76. Tire Recommendations?
  77. Passed Emissions...AGAIN almost 200k miles
  78. It's Alive
  79. The Silver Bullet lives :))
  80. Anyone live near Milton, FL?
  81. 96 Geo Metro Lsi with tapping rockers
  82. Front Brakes & Rotors replaced
  83. Brake Fluid Reservoir
  84. Geo's invited to Economy Run event
  85. Anyboby seen my hubcap?
  86. Metro stalls at startup sometimes and won't re-start without pushing pedal to floor.
  87. Don't laugh - any Hotwheels of Geo Metros sold ?
  88. '91 XFI TPS Adjustment
  89. rubbing sound
  90. 1996 geo metro no spark
  91. Fix or Junk?
  92. Throttle body parts for sale 1995 Metro 1.0L
  93. Profesional opinion needed pleaase!!
  94. Rasing from the depth and old geo
  95. R-12 replacement
  96. Post engine rebuild update
  97. windshield replacement
  98. Evil Lug Nut
  99. Headliner question
  100. A/C Question. Can the temp switch cause problems.
  101. Intake Gasket Question. Can I use RTV instead.
  102. Thermostat replacement
  103. Geo metro carpet
  104. White Sparkplugs
  105. It takes two (My little Frankenstien)
  106. Parcel shelf solution
  107. Oil Pressure
  108. Discolored headlamps
  109. Prepare for the worst/hope for the best
  110. Geo Metro 1.0 Turbo
  111. How cool is this
  112. Wheel Bolt Pattern List - If you need to upgrade from 12" wheels etc.
  113. re-tap threads
  114. Oil Pan leaks again
  115. codes
  116. Crank Sprocket
  117. Starting Problem looking for suggestions
  118. Looking for Suggestions
  119. buy an old geo and update?
  120. 93 1.3 starts than dies
  121. blower motor
  122. 94 metro auto trans shift problems
  123. Bumper Stickers Seen - Just For the Fun of It
  124. XFi Camshaft Swap - How To
  125. Metro Drags when it gets warm...
  126. Who recemends a place to buy a reman head
  127. hard to reach nut
  128. Speedometer Off
  129. Dead Turn Signal
  130. bolt size needed?
  131. 1991 Metro 1.0 L will not start.
  132. Pulling engine/transmission
  133. Distributor o ring needed 99 chevy metro 1.0l
  134. Starter Repaired
  135. Several Parts needed 92-94 metro swift
  136. 92 metro top replacement
  137. Metro has grinding problems--please help
  138. 97 Geo Metro LSI Auto 4cyl TIMING??
  139. Manual transmission on Metro - can it be adjusted?.
  140. Leaky oil pan
  141. Need correct rear wheel bearing torque spec
  142. 1994 metro to 1995 swift engine swap
  143. Valve spring keeper tool
  144. 93 Geo Metro Won't Crank
  145. Replaced Spark Plugs with NGK's
  146. New Tires WOW
  147. It's ALIVE.....
  148. Keepers picture?
  149. Finished rebuild tonight. Won't start
  150. Door Pins?
  151. Where does this wire go?
  152. Camshaft oil seal
  153. Noisy Spark Plugs and Wires on the Radio?!
  154. Loose spark plug bad performance?
  155. A/C low-high pressure graph
  156. Antifreeze/Coolant Colors
  157. Brake sensor
  158. What is this?
  159. camshaft broke
  160. Johnny
  161. How do you get the keepers back in?
  162. tension spring broken
  163. Burned Valve Photo
  164. tension sproket spring broke
  165. A/C compressor clutch
  166. How do you remove the valve springs?
  167. A 4WD Geo Metro ! ?
  168. 94 Metro 5 Speed Manual Transmission Rebuild - PART 2 - Assembly
  169. metro exhaust pipe diameter?
  170. 95 GEO Metro 3 cylinder overheating
  171. Block oil check valve (photo)
  172. Head Off! What Next?
  173. 94 Metro chokes, sputters, then dies, no power
  174. Hole in pistons
  175. Trunk Struts
  176. Geo Metro Starter Compatibility Question
  177. Trans???? slow shift floor the gas and it barely goes!
  178. Fuel Injectors:Will this work??
  179. '97 ECM Metro
  180. 2nd Annual GeoPalooza 7/25/2009
  181. 95 GEO METRO OBDII Compliant?
  182. trans click?
  183. Good replacement struts?
  184. Loses power under acceleration
  185. Sloppy Shifter
  186. auto to manual trans?
  187. oil pan where are you?
  188. lifters and cam question
  189. 94 Metro 5 Speed Manual Transmission Rebuild
  190. brake rotor question.
  191. Its good to be back!
  192. What kind of engine is this?
  193. Why does "Double Clutching" help change gears ?
  194. 95 GEO Metro Temp Gauge not working.
  195. Brush got Stuck
  196. Transmission Flush
  197. speedometer needle jumps/erratic
  198. front wheel bearings?
  199. Convertible Warning...
  200. Where are you located?
  201. Metro Convertible Top Replacement
  202. Loud lower frequency sound at idle and when stepping on gas? Error code 51
  203. Who has one i can buy? (Radio parts)
  204. Door Problems 4 door Sedan
  205. need spark
  206. Uh yea, one problem figured out...on to the next.
  207. New to the forum...again
  208. Alternate Gear Oil Filler Hole
  209. Indexus Metrogloditus
  210. Metro won't stay broke...
  211. Ignition Switch
  212. troubleshooting coolant flow
  213. Fixing a Code 51
  214. What are ALL the symptoms of a worn out Manual Transmission ?
  215. clutch question...
  216. 94 xFi error code 13. 315,000 miles
  217. Heater not as Hot!
  218. Can A Timing Belt Being Off By A Tooth Affect Compression?
  219. New to the Metro Scene
  220. to much gas
  221. The Mouse has been in a fight/ Seat Info!!
  222. carpet
  223. 91 Geo Metro Check engine light Code 51
  224. 5 miles out of a water pump???
  225. Capturing Videos that won't normally save on certain web sites
  226. Crazy ? for Auto Trans Experts
  227. Manual Transmission Video
  228. High Idle?
  229. Gas Tank Filler
  230. Bench Seats for '93 Metro ?
  231. A qestion about cold starts
  232. who has a good winter (sub 0 deg F) starting metro?
  233. 2000 geo metro
  234. Where do I get info on engine rebuild/replace options?
  235. I've Split the Case - Now I'm Confused
  236. This is one for the books! A "puzzlement"
  237. Weird! '92 5-speed linkage just got super-easy to shift
  238. New Cylinder Head Pinging
  239. '92 XFi: intermittent high idle + high temp
  240. Cylinder Head Replacement
  241. Adding an extra battery
  242. Do not read this message - it may cause enlightenment.
  243. 1997 geo metro 4Cly Auto Terrible Acceleration... Please Help me solve this!
  244. Yanmar Metro Clone
  245. Headlight fix
  246. Window Regulator 2door / 4 door ??
  247. car starts wont stay runnin
  248. map sensor
  249. Distributor cap gasket
  250. 97 4cyl lsi 4dr wont start or shift from park
