View Full Version : Metro
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12 13 14 15
- Is there a 'Wheel Interchangability' list available?
- 95 metro
- 2000 Metro CV driveshaft question....
- Hatchback lock cylinder
- electrical question - 95 Geo Metro lsi
- Finding a new tranny, what to look for?
- I thought it was 'Engine Noise' !!
- 93 geo metro Won't start
- 1995 Geo pings when under heavy accel or hill
- 95 metro 4cly ecu pinout
- Fastest way to remove the engine 1991 Metro
- 95 engine in a 97
- won't start in cold weather otherwise runs perfect
- Block or dipstick heater?
- re: brake bleeding instructions
- frozen steering??
- 98 Metro- No Fire
- Switching wheels/tires...1997 to 1994
- Sprint/Metro transmission swap?
- Bad synchro...replace tranny and engine?
- Auto dimming side mirrors?
- Idle/Brake problem
- engine for sale
- Would a '91 engine fit into a '93 Metro ??
- Auto Tranny Problem
- lost my cool(ent)
- Incredibly frustrating camshaft seal problem
- brake switch problem
- What is the correct thermostat to use
- Radio light bulb voltage?
- Throttle Body Vacuum Hoses
- no power/acceleration when going around 45/50 mph
- New Geo Owner (93 HB, 5sp, 1L)
- Door Handles--Interior
- Shifter stuck - Anyone else ??
- Belts squeal, but only in cold weather
- WTB gauge cluster
- finally back...after about a year
- 96 geo metro floods out
- female looking for help with 96 geo metro
- '93 Metro 5 spd Transmission - fill where?
- A nice way to discuss Digital Photo Images of Metros!
- Piece of Junk
- Parting ways with 91 Metro
- Exploded Diagram of Geo Metro Throttle Body Anywhere?
- Final drive ratio
- Big smoke screen - then normal.
- 92 metro bad mileage
- Flywheel Dowel Hole Missing
- What causes all of this smoke?
- engine interchange
- Oxygen sensor
- Motor Oil weights - meaning of numbers?
- Back-up light switch - location??
- 92 Geo Metro is completely dead!
- Should we use High Detergent, Thinner Oil?
- XFI and LSI Manual transmission ratios
- HELP ! What are symtoms of valve (head) problems?
- 94 geo metro
- geo tranny
- Can't change Idle on Throttle Body
- Is 40 mpg enough?
- Periodic Poor Performance, missing, no power, etc
- 93 Metro - Could run better!
- Drive Belt squeak
- Ignition Timing Off by 2 Degrees
- Is it worth switching to a vert auto tranny?
- rear window defroster
- Engine Cooling Fan Question for female
- Poll - Metro peculiarities - Body & Interior
- Poll - Metro peculiarities - the 1 Lt Engine
- performance effects of ignition timing advance
- lost my service manual: need torque #'s
- Carbon Removal
- 92 Geo metro will not time???
- hatchback release
- Snow Tires ?
- FOR SALE housing air filter cover from 1992 GEO METRO.
- removing drivers side door panel
- interior parts
- 93 metro vehicle speed sensor
- Geo Metro 1995, No tails lights, No head lights
- Distributor advance part???
- fast idle problem found
- DESTROYED my clutch tonight. 4cyl trans. in a 3cyl
- larger wheels for 94 metro
- Zero Compression Prob. Found
- Cabin air filter in 92 Geo Metro
- Crank Pulley Removal
- radio
- Here's a stumper
- good or bad sensor?
- 2 problems
- 1995 geo metro
- key broke in ignition
- JDM engine blowing steam - Metal Intake gasket?
- 15W40 oil???
- ECM (ECU) ground wires (E1 & E2, GR/BK) floating!
- 2000 chevy metro lsi where is the fuel filter
- 95 Metro still having problems
- Front Wheel Bearing - Which side from the sound?
- Timing belt and water pump replacement
- 86 Sprint running poorly
- Battery? starter?
- ZERO Compression in Cyl 3
- Is it difficult to replace a '93 Metro Engine?
- Need to replace cam shaft, how much is too much?
- Does everyones valve knock under load?
- service engine soon lamp lit
- '93 Metro - Adjusting Idle for Winter ????
- Valve specs dims
- loose caliper
- help identify engine part
- PCV valve clogging
- motor swap wiring problem
- Thinking of buying a Metro and have some questions
- peculiar driveability problem
- Changing Alt Belt '96 Metro 1.3
- Original Motor and DTCs
- Parts/Accessories Recommendations/help
- Highway Reliability?
- 91 Geo Metro - No EGR!!!
- metro inner tie rods
- oil leak at distributor
- brake lights not working
- heater core
- Conversion
- Metro body kits and accessories...where???
- Interior Light
- 91 metro starter
- Sticking fuel sender?
- 1997 Geo Metro stalling
- Where is ID plate located?
- New Owner Question
- Fuel Pump Behavior
- Howdy Folks
- heater core, which hose is in, which is out.
- Please Comment Soonest...Thanks!
- Removing Alternator
- suzuki swift vs geo metro?
- Geo Questions & Search
- Hello
- Overheating
- Car deck install in 88 Firefly (CDN Metro)
- Alternator Bearing Replacement
- Winter Tires
- 93Metro 145K,runs good. @idle, speeds up for 1 sec, and cuts gas for 1 sec. PLS help
- Water Pump Replacement
- 95 metro no power
- Compression Numbers
- 97 metro tranny problem
- Dirty Oil
- Overheathing
- Attention all gas mileage enthusiasts!
- Gas Mileage Increasing Devices: Poll.
- O2 sensor mystery
- Help with Engine Noise Diagnosis
- Hood release
- Will '98 Metro seats mount in a '94
- 1994 metro looks like spark plug melted
- how many miles on....
- boggs down after warm up
- Metro needs Tracker Window buttons to hold them close.
- Gas coming out of my throttle body
- Geo drives me nuts help needed
- Keeping a stady speed, Please Help
- geo metro underdrive pulleys????
- Computer (ECU) Question
- Softer ride
- Metro engines
- Tachometer hookup
- car idles rough
- Amount of Esther Oil in Compressor?
- What is going on?! on death row!
- Some pictures of our two Geo's
- Hard to get to Intake manifold nut
- General Questions
- Metro Door Hinges
- timing belt tensioner
- Geo Metro 95 Clutch
- geo metro tranny
- help with conversion
- How clogged can an EGR valve be?
- that damn driver door window
- throttle body
- Air conditioning fuse 15 or 30 amp?
- Muscle car metro...
- Need Help locating tranny Parts
- Dogde Stratus 97 - Coolant Temperature Sensor
- Code 15 Coolant sensor circuit
- Help I accidently cleared the engine codes
- Geo Metro FHi 94 turns over, but won't start.
- Coolant disappearing
- 91 geo trans issue?
- trouble putting throttle body back on
- 1994 Metro Check Engine light on
- Is it a bad idea to drive too fast?
- windshield seal
- geo metro
- I need a couple of interior trim parts
- rip off or not
- 93 1.0L won´t start????
- Major Oil Leak 3 cyl.
- Auto tranny does not shift up or down
- engine cuts out under load
- broke college girl in need of help!!!!
- GM Screws You on Parts Costs !!
- 93 geo auto trans no sec gear when warm
- Swift parts on a Metro
- '96 front crankshaft oil sleeve
- Intake manifold water gaskett leak?
- Please Help!!!
- tork specification for the lug nuts
- did i pay too much
- engine tranny
- Horrible gas mileage
- 1990 3 cyl,Has fuel diluting the eng oil.
- Metro prices / availibility
- '98 to 2001 Geo 1.3L torque curve
- 96 geo tranny making noise
- 96 Metro 1.3 timing belt off 2 degrees
- We want the Metro back!!!
- 1992 geo metro trans problem help
- distributor cap position
- Check out this Metro!
- '91 Metro just won't start
- Suspension upgrade
- temp guage acts like vacum gauge
- help a rookie
- Tire recommendations
- 1995 Metro 1.0 leter won't pass emmissions.
- XFi
- setting the timming belt
- 1994 geo metro where is my fuel filter
- 94 Metro Auto trans stays in Drive gear?
- OE stereo
- what are you getting for MPG
- Need this running by tuesday...
- Wiring diagrams
- A arms & lower ball joints shot. Difficult to replace?
- *shifty eyes* GEOZUKI AWAY!
- XFi 89-94 ecms, oem part numbers ?
- Need Help W/ Engine Code...Got Code, Don't know where or how to fix it
- where to get the largest selection of used parts ?
- blower
- How can I make the Horn Pad stay put ?
- Easy way to lub the gas pedal thrust cable?
- Is there a code reader for a 91 3cyl?
- v8
- MAJOR problems with 1989 metro
