View Full Version : Metro
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15
  1. Vin #
  2. replacing lifters
  3. Bogging with anymore than 1/4 throttle
  4. too much heat
  5. where does my oil go?
  6. Need some help.
  7. 1993 Geo Metro 3 cyl - Wont Start
  8. window regulators
  9. crappy gas mileage
  10. '97 drivers side mirror question
  11. Timing On A 95 Geo Metro?
  12. Headliner replacement
  13. Speedo Problems
  14. 91 metro cranking problem- Need Help!
  15. cruise control
  16. timming
  17. spindle nuts - change every time?
  18. metro wheels
  19. window regulator
  20. Metro wont start
  21. Applying something learned on this Forum....
  22. Clacking noise. Front center of the car.
  23. oil additive needed
  24. performance upgrades for cheap
  25. Can I Overfill The Radiator?
  26. Best Light Bulb
  27. Changing Water Pump
  28. 93 geo metro pcikup coil bad again
  29. pcv valve clicking at idle
  30. 95 metro squeeling alternator.
  31. 1992 Geo Metro replacing the Fuel Pump
  32. Cylinder Head/Rocker Arm Wear
  33. question?
  34. metro compared to suzuki
  35. some questions....
  36. Changing 92 Metro Clutch
  37. ? on crank position sensor
  38. MPG...what happened??
  39. 1996-97 Metro colors - which available?
  40. Metro Success Stories
  41. Peeling paint - how to fix?
  42. Speedometer not working
  43. acetone in gas
  44. mistery no start problem
  45. miles'gallon
  46. Oil on air filter
  47. 1995 Geo Metro O2 Sensor Wiring Colors
  48. Wiring schematic needed
  49. high idle and surge on 95
  50. '91 Geo dies at stop sign
  51. 1995 Geo Metro O2 Sensor Wiring Colors
  52. trick the ecm for more hp
  53. What Motor Do I have??????
  54. Auto Trans. help PLEASE
  55. 5 speed hard to shift when warm
  56. 1993 Yellow Corner Light Replacement
  57. Installing sunroof - hard to do? bad idea?
  58. 1995 Geo with rusty suspension
  59. key broken off in ignition
  60. 94 Geo Has Spark Flooding Cylinders
  61. 2000 4cy Air Filter
  62. WTB - 1995 or newer Metro, for body
  63. Newbie here w/questions on control arms!!
  64. 1.3 4cyl relisted
  65. JDM's carburation to EFI
  66. WANTED: Stock radio for 97 metro
  67. 1993 Eats Alternator Belt
  68. Factory tach cluster 98 3cyl
  69. 1998 metro
  70. Let's compile a list of automotive ACRONYMS.
  71. Engine & transmission swap - possible?
  72. Auto trans interchange question
  73. VIN # question
  74. All this JARGON - it CTHOOM !
  75. testing and cleaning EGR
  76. Rear brake adjustment
  77. 1996 1.0L needs engine -- Can I use 1995 JDM?
  78. Click Click ... hard to start info
  79. 97 front end problems
  80. 97 2 door metro quarter window question
  81. Electrical System Shorted
  82. Code 42. Engine turns over but won't start.
  83. engine coolant temperature sensor
  84. Intro- 1990 Metro Convertible
  85. '96 Front Wheel Lug Bolt CrossThreaded
  86. For sale 13.
  87. Low vacuum and flooding
  88. 95 Metro Timing Belt snapped
  89. getting alternator out of engine compartment
  90. fuel pump install success..
  91. Coil Pack or Crank Sensor?
  92. cam gear
  93. cam gear
  94. 95 Metro Parts for sale
  95. How do you get the crank pulley out?
  96. home front-end alignment?
  97. Ignition/Electrical Short - 92 GEO Automatic
  98. tune up parts
  99. how long do your tires last?
  100. neutral at high RPM
  101. 2000 Metro poblem
  102. EVEP Canisters
  103. How do you replace the Clutch bearing in a 92 metro???
  104. 97 wipers won't go.
  105. Rust Question
  106. 1.0l engine into a 1.3l '98 metro???
  107. 99 Metro engine runs Cold-Warm-Cold-warm
  108. Manual Trans Work
  109. Need help with this
  110. How often do ECMs go bad?
  111. Cutting and using new gaskets
  112. my service engine soon light comes on one one day but goes off the next??
  113. How to take (save) the pictures here....
  114. 1997 geo codes
  115. I Found It!!
  116. head gasket
  117. Geo Metro start trouble
  118. G10 transmission for the 3 Cylinder Where the hell do i put in the fluid.
  119. Geo Metro Starting Probles Not the Starter
  120. '96 1.3L metro - is this a deal?
  121. speedometer quit working
  122. fuel filter or battery?
  123. Newbie 98 1.0 HB
  124. anyone here used an exhaust pipe repair kit?
  125. Bottom Half of Throttle Body Exposed !
  126. 97 geo 1.0 manual tranny swap to auto
  127. Offerings
  128. 2000 Metro LSi dash fuse blowing
  129. Has anyone ever installed a ROBERK wiper delay?
  130. Adding a/c to a '96 metro
  131. A very good investment indeed!!!!
  132. Burning Oil, and Smoking
  133. coolant in #2 cylinder
  134. Front oil seal partially out and leaking
  135. fuel pump replacement
  136. should i put my broken timing belt cover back on?
  137. Cargo/ Hatch cover on ebay
  138. valve cover ventilation and pcv
  139. Taking the Throttle Body Apart - Lower half.
  140. Fuel Line Pressure - Best test point(s)?
  141. '91 Metro Convertable Top replacement help
  142. Coolant Leak near CKP (Crank Pos Sens)
  143. Oil leak prob
  144. body mods for 91 geo metro
  145. will a CRX engine fit in my 91 metro?
  146. melting head light wire with no short to ground!!!!!!
  147. 2000 Metro Tie Rod Ends?
  148. fender
  149. feulpump prob.
  150. Can't shift down from 3rd to 2nd ?
  151. 1991 metro cranks but won't start - Mystery
  152. Important Update!!
  153. Bent Strut
  154. pcv valve
  155. Hard Shifting....
  156. 5 Speed Manual Replacement
  157. headlight swap question
  158. Safe to rinse TBI head with Gasoline?
  159. 1995 and 1999 the same?
  160. EFI on 'roids?
  161. XFI without vacuum advance on distributor?
  162. Took TB off - Checked Sensors - Partial Results
  163. Front Wheel Bearing Going Bad?
  164. diagnostic connector on '96 metro
  165. Driving Geo Metros "aggressively" - EPA
  166. E3 sparkplugs... anyone using them?
  167. driveline vibration
  168. Vacuum Gauge - which hose to tap into?
  169. 1997 geo metro throttle body injecter
  170. will 98 headlghts fit on a 97?
  171. Whats my engine? / Other probs...
  172. 96 metro ECM temp. sensor location
  173. Removing & checking the TPS - easy?
  174. Incomplete Shifting Through Gears
  175. Is Ugly now "In" ?
  176. 93 Geo Metro with no spark of pwr to FI
  177. Shift Solenoid and O2 Sensor '97 Metro
  178. A new Thread on ECM's
  179. timing belt replacement
  180. mad metro!!!!!
  181. blown head gasket?
  182. strange rattling in 96 LSi
  183. Very, very wierd idle...help!
  184. 93 GEO Metro Auto, Problems
  185. '96 Metro Trans Problem
  186. Message to the Moderator(s) - Suggestion.
  187. 1.0L and #3 cylinder
  188. Rear wheel bearing discrepencies
  189. Those nasty alternator blues
  190. Timing 92' Geo Metro 1L
  191. Identifying Sensors - 1993 Geo Metro 3 cyl TBI 5 speed
  192. 2000 metro cold start prob.
  193. alternator tips
  194. died while driving
  195. TPS adjust
  196. Where would I install a Vacuum Gauge?
  197. Please help identify these goodies....
  198. XFI ECM interchangability
  199. ? on Fuel Regulators
  200. FYI - For those who haven't seen an ECM
  201. something weird
  202. cracked side mirror
  203. Problems97 Geo Metro Stereo and Service Engine Light
  204. Metro roof rack?
  205. locked out need help
  206. 97 metro parking cable broken?
  207. my built up 1.3 DOHC engine for sale..
  208. power and mpg loss
  209. Testing Fuel Pump Pressure - HOW? WHERE?
  210. 1990 Firefly convert tire pressure?
  211. how to clean crud off of composite beams?
  212. year of motor
  213. 93 1.0L MAP sensor code?
  214. Need a good factory tape deck
  215. 96 timing belt and alt
  216. 97 geo manual swap to automatic?! problem?!
  217. poor gas milage
  218. 97 GEO loses power intermittently
  219. New Exhaust system in New England area
  220. hydraulic valve lifters
  221. Check For Vacuum Leaks - Carb Cleaner - Explain ??
  222. Holy Moly!! This is unreal!
  223. 97 geo
  224. Head lights doing weird things HELP
  225. AT controller
  226. How can you test continuity with an ECM and O2 Sensor?
  227. 99 Metro Blower Motor
  228. 97 metro engine stumbling
  229. Simple Question on Side view Mirrors
  230. Information about ECM \ PCM of Metro's ?
  231. Wheel came off
  232. EGR failure
  233. 96 LSI....cargo cover? Also, what is this?
  234. Replaced alternator and battery....NEED HELP!
  235. Is removing the one TB Fuel Injector difficult?
  236. where is the coolant teperature sensor?
  237. 93 Metro Electrical???
  238. Clicking noise at idle
  239. 7 °F - '93 Metro running bad of a sudden!
  240. cylinder head bolts
  241. hard to start 97 metro
  242. 96 geo headlight problems
  243. Which is Best Manual Transmission Fluid ?
  244. 96 LSI fuel capacity?
  245. instrument cluster swap
  246. New Question
  247. Changed Front Brake Pads - tic tic tic....
  248. 95 5 speed transmission interchange question
  249. Awesome Product Alert, Buy NOW!!!
  250. $300 metro
