View Full Version : Metro
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12 13 14 15
- Fouled spark plug on 92 Geo Metro 1.0
- 5sp Manual tranny FILL PLUG?????
- EGR Solenoid
- 97 1.0 Horrible Performance
- just purchased
- 02 sensor/MAP sensor
- fuel guage is wonky
- HELP! Bad TPS?
- 97 metro 1.3 l spark timing-please read
- Reassembling the TBI and getting it running again.
- 95 Geo metro
- 97 1.3 Timing mark Alignment - belt
- radio panel
- Best oil weight/type
- Tailgate Struts
- 96 Metro start/run issues
- Does the 1992 Geo Metro have power steering?
- What else can I check?
- 96 metro starting problem?
- stripped bolt won't come out
- 1.3L engine swap - manual to automatic? Help pls.
- Where is the "check plug"
- Rain X Removal
- '97 metro clutch problems
- 94 Metro ignition switch
- compression test
- Failed HC (PPM) Emissions
- New engine for my 2000 puddle jumper
- Searching for parts...
- oil filter dripping
- turbo cam
- 9th digit of VIN
- o2 senser #1 bank#2 (geozuki,help!!
- Poor MPG / California ECU - I think I may have found the problem!
- 94 Metro suspension questions
- Oil drain plug tightened by Superman!
- Need to know which front wheel bearing is bad!
- 96 Metro Shift Solenoid A
- Good place to buy accessories
- Tailgate Lock
- BrainBuster - Bet you cant figure this one out!!!
- 98 metro california duel cat converter
- Need Technical Assistance
- transmission squeal?
- replaced engine, no fuel, no spark,
- Year compatibility
- 96 Brake adjuster
- High Pitched Whiny Metal Sound from Front Right Tire
- 02 sensor #1 heater failure?
- I need wire harness and diagram for 97 3cyl
- 3cyl in Tracker, What do I hook to run???
- Engine Swap 1997 I3 into 1990 TRACKER!
- Annual 95' Geo Metro Summer Update
- hmmmm makes me wonder.....
- 97 Geo Metro
- '92 Metro w/ Racing Stripes
- Homemade oil catch can and new air filter
- Steering wheel shimmy
- Head replacement?
- was there a daihatsu metro?
- what struts should I buy?
- belts
- Anybody ever welded the unibody/control arm?
- explain thie ghetto race...
- Putting Different Horn in Metro question
- Choices: 4 door 90 Auto or 2 door 92 5 spd
- radiator flush help
- repair manual recommendations?
- swapping 1994 l3 into 1997 chasis
- Rebuild current engine or do a JDM swap?
- Anyone disable the Daytime Running Lights?
- 96 metro cranking problems
- Huge clouds of smoke intermittently coming from car
- 94 metro 5 speed sloppy shifting pattern
- 98 Metro Lsi: A/C has failed after light impact
- electrical failure
- Is there a "performance" ignition timing setting?
- Timing way off after timing belt job
- 96 metro fan won't work
- How do I replace the Fuel Pump?
- Do we have to set ignition timing after timing belt install?
- Severe oil leak from crank seal
- Body replacement?
- Will Sprint 5 speed transmission work in metro
- Air Conditioning
- How much would you sell for? 96 130k, 1.0L...
- 95 engine into 96 metro----crank sensor??
- 5W30 vs 10W30
- What is wrong with the A/C system ?
- Bearing popped out of control arm
- Fuel Milage Update
- 2000 metro 3-cyl rebuild
- engine conversion
- Idle constantly going up and down
- The Dreaded Milky Oil
- question???
- Will a seat from another vehicle fit Metro?
- Geo Metro Simply The Highest Mpg Car
- Desert Driving, HOT: Suggestions
- 94 xfi sticking starter solenoid
- Rod knock - Can this sometimes be an easy fix?
- 1994 Geo Metro overheating/GloriaMetro
- 1999 service manual for sale
- Check Engine light comes on only at heavy load
- hinge bushings
- 95 geo metro 1.0 Rebuild and now I have no oil pressure.
- AC Question
- 96 LSi Tranny fluid puddle on top of tranny
- 97 metro changeover 1.3 to 1.0
- Help with Installation of Timing Belt
- HELP! Looks like I got the wrong timing cover from Chevy dealer.
- Simple Chevy/geo Metro Question
- 95 Metro LSI losing power
- this is gonna be interesting
- overheating
- Metro Mud Boggin!
- Awsome Interior? Whaddya Think?
- Oil leak on timing cover side
- 97 metro check engine light
- hood latch position
- how to replace hood 94 metro
- 97 metro wont start.
- Why can't I post pictures?
- 96 1.3L idler pulley?
- anyone looking for a motor swap for their metro?
- HELP! I cant get my darn tires off!
- ECM Help
- instrument cluster swap
- trouble removing centerbolt
- Headlight Problem Revisited
- can you help me balance my brakes?
- loosing spark - '96 1.0l
- Surge, surge, surgin' when warm
- check engine light
- New Brakes squeaking
- Anyone need a G10 1.0L motor - eastern Ontario?
- 91 metro ideling problem
- Clunk from rear
- Geo Hubcaps
- 1996 Firefly (with 1.3 L 4 Cyl Metro Engine) low compression #2 Cyl
- Idle constantly changing
- 94 Metro HORRIBLE Emissions Test!!!
- Two questions
- miss in 90 metro 3 cyl LSi
- need back window for 2 dr 91 metro
- 94 geo error code 13
- spark knock
- radiator for sale: for 1.0 5-speed, 1 year old
- A/C not Working
- 1997 geo metro
- Would it hurt anything to remove the AC Pump?
- Lets get this bugger back to working!
- I'm Baaack.... Got off my dead butt! Timing Cover. WITH PICTURES!
- fuel guage
- geo metro bad milage 33mpg help help!!!
- Help with replacing Rad on 96 1.0 manual
- JDM engine dist.
- Where to get parts?
- changing auto to manual
- wheel bearing noise?
- 16 valve engine on99 and up
- Time for me to move on to the Celica Forum.
- Older Convertible Tops - Hazy Windows
- resistor spark plugs -- ignitors (coils)
- How to improve gas mileage?
- Help with 1997 Metro Wiring and Vaccum lines
- Water Pump O ring
- geozukigti where are you?
- 1994 Metro Codes 46 & 51
- Exhaust Hanger
- Auto Transmission Fluid level
- Transmission swap 95-98
- work vehicle?
- Platinum Spark Plugs
- Cabin Air Filter
- Scored a 61k actual mile car
- repair procedure for rusty control arm supports?
- About to Buy a Metro
- fuse, turn signals, auto transmission
- Geo Metro factory Delco radio question
- Engine swap.. Need help!!!
- weatherstripping 1998 geo metro
- picture of a 97 geo 3 cyl with the timing belt cover removed
- parting out 93 swift: 1.3 sohc - eastern ontario
- coolant leak at tube on back of water pump
- geo metro wanted
- 2000 Metro rough idle with air on
- 92 metro convertable body rust ?
- 93 - front rotor replacements - hubs
- Broken Radio Antenna
- '94 tranny quirk, control solenoid?
- Disc brake conversion
- Great price on Walker exhaust for my 97 Metro
- Another '98 not starting
- Where is the Blinker Fuse located?
- I need help!!
- Auto Transmission Gasket
- Headlights Problem
- Oil pressure sending unit location
- White Face Guage Overlays
- 4.10 vs. 3.89
- 94 engine R & R
- 92 Geo Metro Squeeling
- 94 Geo Metro questions
- 92 geo metro 1.0 won't run
- Lower control arm bushings
- 98 wont start
- 92 metro help needed
- 98 Metro Transmission question
- Soon to be for sale
- Metro Run on
- Will a 2000 1.0 replace my 1996 1.0
- MPG question
- Weird Surging problem-93 w/ 90 engine
- Emissions related question
- Woodruff key
- Rotten Egg Smell from car
- 1989 Geo Metro LSI: sputters/lose power at 55mph..... again
- 93 Metro Bucking
- 1994 Metro 3Cy 1.0Ltr
- 98 Metro clutch R&R?
- 92 Autimatic To Manual Conversion
- looking for cheap small parts
- WTB: 90-93 convertable LSI
- cabin air intake
- what wheels fit?
- Engine practically dies when lites on.
- Looking for a parts car
- 2001 Geo Metro mileage drop from 52 mpg to 38 mpg, why?
- how much does it cost you to drive?
- 95 Metro Rough Cold Idle
- 92 Metro convertible horn (lack of)
- lubing hatch rails
- rear brake adjustment
- Idle roaming.
- Still no start 97 geo metro
- front end clunk
- V4?
- Should tires turn freely or have resistance?
- 97 no start
- brakes and rm\pm affected by fan blower
- Need a few parts--Does ne1 have these!??
- Car just started skipping??
- measuring rims/and off set
- Best way to lubricate a Speedometer Cable?
- roof rack weight limits
