View Full Version : Metro
Pages :
1 2 3 4 5 [ 6]
7 8 9 10 11 12 13 14 15
- Was this feature an "Option" on Geo Metros?
- 91 Metro LSi Conv. - Squealing Noise.
- Couple Issues
- Metro NOOB
- 94 Metro odd reverse
- 1993 Geo Metro Flywheel problem
- Good Deal?
- Interesting Symptom, What Do You Think
- Can I do a "Home Front Wheel Alignment" ?
- Hopeful Metro owner...
- heres a new one-fuel filler tube
- 97 metro broken a frame
- To the Forum Manager - BIG Problem!
- Burning Valves in the 3 cylinder engine
- Please Educationalize me on Clutches...
- ...My 96 Geo .....
- 94 metro flywheel transmission bearing
- 38mm tire offset work on a 92 Geo?
- Taillights interchangeable?
- Need spare tire clamp/jack bolt???
- '93 Metro 5 spd manual oil level
- DMV notification when changing engines?
- Can It Be Done??
- My Hwy Breakdown and Quick Fix
- Distributors
- Results on my 92 Metro so far...
- Any auto trans parts worth saving?
- Engine turns over but won't start
- Battery hold down bolts/bracket?
- checking o2 sensors with multi meter
- Map Sensor - 1990 Geo Metro, 3cyc.,Auto, Air
- 02 sensor
- '97 four cylinder
- Throttle Position Sensor...malfunctioning?
- Ignition system...92 Geo Metro
- very fast idle
- Temp Guage Stopped Working
- Towing with a Geo Metro.
- 92 1.ol crank seal
- New coil...MSD 8202 or 8222?
- Metro want to raise suspension.
- Wal-Mart's 5W-30 Motor Oil
- 1990 Geo Metro - Little Or No Power At Cold Start
- Splash shield...passenger side front
- geo metro speed parts
- tranny
- 1990 Geo Metro Gas milage?
- Cold starts and Mmisfires - 1990 Geo Metro
- 97 metro still bad milage
- Diagnostic Scanners
- Replacing water pump
- New Ignition coil...MSD Blaster 2 good?
- fuel tank size
- Using ATF To Thin 10W30
- im loomin for a windsheild
- need some serious help on this one
- 93 Geo Metro - Won't start/stay running
- Block drain?
- Engine question
- Tight Ignition Switch
- Different ECUs
- Warning System - Lights On - '93 Geo Metro?
- Check Engine Code: 1995 Geo Metro
- Windshield Replacement
- anyone running 3 cyl on carb help me???
- auto/manual starter compatability
- Oxygen Sensor
- Manual Transmission - Clutch Bolt Fill Hole
- Uneven Idle
- what tranny's would fit?
- Will P275/80 R13 tires fit a 1995 LSI?
- How insane can this lack of privacy thing get ??!!
- Driveshaft question
- Do Auotomotive Parts Manufacturers Listen?
- Nuther airbag question...
- Okay seriously, WHY did they stop making Metro's?
- pulling engine
- Anyone have a '93 Metro 3 cyl Fuse Box Map?
- Folding Back Seat
- 97 metro hold brake and car still picks up idle
- Need everyone's advice - thinking about getting a Metro!
- EVAP tank pressure control solenoid vac valve??
- 93 Conv. Metro available
- Airbag question...
- Sticky front end, 93 Metro....
- Question about Clutches
- Battery Corrosion
- 1998 Metro No power to fuel pump - Emergency Switch???!!!
- Broken clockspring
- 92 Geo and 99 Malibu Same Problem
- does 95 hood fit on a 94?
- oil in carb
- Does anyone KNOW which Oil Filter is best?
- What Pressure Should Be Run In Tires (Nitrogen?)
- defroster fan switch
- Loud ticking/knocking in engine
- smokes bad ,good comp, running rich, help
- Suspension change: Good idea or Bad?
- Piece of Junk Geo I am beginning to hate these things....
- Problems with timing
- Geo Metro Code 15 Help.
- Can a 4,6,8 cylinder Tachometer be set for a 3 cylinder?
- 1995 1.3L, Canadian Model, Two Automatic Transaxle Questions.
- 96 1.3 LSi with a P0420 Code
- How do you reset the "check engine" light?
- Dropped alternator into motor oil. Is it scrap?
- Oil Level - How Important Keeping It at Top Mark?
- '94 Fuse Box... where?
- Tires - Nitrogen versus Air
- fuel injector problems
- Problem with pulling to the right
- The Flight of the PHOENIX !
- Which brake pads/parts?
- Adding 'Cruise Control'
- Geo Metro No Spark--No Start
- Metro Lighting Solution
- Oil Type And Brand Preference?
- ScanGauge question
- Parts for Airbag Replacement
- 1993 metro, front right rattles on take off
- Loud as Heck squealling
- timing question '94 1.0
- Anyone ever put a 350 in a Metro?
- 1996 Geo Metro Radio interchange
- Heater Vent for Dash
- 96 LSi tranny problem...help!
- Any techniques for getting a valve cover off?
- Paint code location
- '95 Metro questions!!!
- Lower Strut Brace From Turbine Tech?
- Seat Belt Return Springs
- '91 Metro Quit, now won't start.
- What to do with a "parts car"
- Cylinders...
- Ignition short
- Transmission Problems?
- Brake Pad clips
- Finding Rocker Panels?
- Trouble finding 12" tires
- Official Metro Parts Mail Order list
- 1991 geo metro engine swap
- Diode module?
- 96 Engine swap
- Rust on rocker panels?
- Valve adjustment
- Rebuilt engine, Drinking oil...
- 97 metro 3cyl.timing
- heavy black smoke from exhaust pipe
- awesome mileage on dirt roads!
- Rear buzzing or humming sound
- 1998 metro help please!!!
- Clunking sound in Metro rear end question
- Replacing Struts on a Metro 92 1.0 liter
- Anyone thought of a Hybrid Metro?
- Different MAP sensors...?
- 1998 Metro Idle Problem...HELP FAST!!
- Metro 3 cylinder 1989 - 2001
- 1994 engine in a 1997
- P0136 code - can I wait?
- 1.0 atx transmission problems...
- Need picture of how charcoal canister is hooked up
- A compilation of all my '93 Metro threads saved to a CD
- Replacing Fuel lines on 92 metro 1.0
- clutch slippage when i lay on gas
- Looking at 95 Metro 129,000 miles
- Highest Mileage on a Geo Metro? I mean Odometer Mileage not MPG
- Setting up the Timing Belt & Distributor
- 1997 Geo Metro 1.0 Low MPG
- Results from my compression test
- 96 metro 3cyl cold start floods bad above 1800 rpms when warm runs fine
- How does the older 3 Cyl Metro advance the spark?
- coolant problem question
- Broken timing belt
- ignition problem
- Man trans swap
- Spark Plug Poll - For and Against Bosch platinum Plugs
- Metro won't start
- intake manifold
- Rough idle and misses sometimes when taking off from stops.
- desperate for an answer - geo clutch
- What happened with Platinum Spark Plugs? Almost quadrupled in price!
- '97 metro - clutch and TBI questions
- Rusty rocker panels
- '97 metro - control arms/ball joints
- I need some help...
- halfshaft help
- Holy Molie! You can save these threads to a CD !
- 98 metro po400 egr code
- Help replacing a part on a '93 Metro
- 92 Metro 1.0 Auto install to 92 Geo Metro Manual
- A way to Clean the Carbon out of the IM Passageways !
- Selling my dead 91 Ragtop.....
- New Tires
- Window Hop Cured!
- Need gas filter (in between pressure sensor and tb)
- Need to know what a part is
- Erratic idle speed
- Haynes manual missing a half-chapter??
- timing sprocket spacer or crank walk?
- Geo Metro 1994 1.0L, No Spark from Secondary on Coil! ECM? Please help!
- water leak
- Message to Moderator(s)
- How does oil get thru all those bearings?
- 1995 Metro 4cyl-Auto Trans Problem
- Airbag Malfunction
- Metro 1.0L: What's the letter after G10 mean?
- Disable daytime running lights
- idling versus shutting off at lights
- Need a new IAC valve...anywhere I can get a new one for cheap?
- My wife's Idea! Can it be done...?
- How do you clean the Carbon out of the Intake Manifold Gallery?
- Car tries to die when headlights on/heater on, any suggestions?
- I need help ID'ing a knock...
- Need Headlights..
- wanted metro 13 inch wheels
- Good buy?
- Headlight Bezel
- headliner replacement help
- Oil Pan, RTV? Gasket? or Both?
- Thought Metro Was Dead
- drive shaft won't come out
- Why does my car sound like this? (VIDEO)
- Alternator belt broke on the road
- Air Bag Diagnostics
- Persistent Annoying Timing (Or Something) Malfuntion
- '93 Metro electrical question:
- Timing help
- 94 Metro shift issues
- need cat converter info please
- nothing!!!
- A discussion of engine function.
- Valve Adjustment
- 93 Geo, no start.
- Looking for a replacement Metro :-(
- Vacuum diagrams
- If my 3 cyl dies - I have a solution !
- HELP! can't find Metro part
- Strange brake problem
- NOT the end of my '93 metro...Life after death! RINGS
- Busted Piston Skirt - '92 XFi - how long will it run?
- JDM or Replacement Engine Geo Metro
- Electrical short causing shifting failures
- JDM engine in a 95 metro
- 97 Geo Metro 1.3 no hot start
- air intake question
- Is a "cover" needed?
- 93 Metro 1.0, Slow Crank/No Start problem
- That's the end of my '93 Metro.....
- 94 GEO prob
- rough engine idle and fuel pump noise
