View Full Version : Metro
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15
  1. 99 metro 4cyl. smokes - worth rebuilding?
  2. 95 1.3 Auto trans question
  3. more temperature problems...
  4. tempeature problem
  5. 8-valve vs 16-valve
  6. HELP!! trying to time 96 metro 1.3 l 4cyl
  7. 1999 1.3 Timing Marks
  8. ignition fuse on 92 Metro
  9. registering on teamswift.net
  10. hesitation
  11. What Should The Amps Reading Be In A Compressor?
  12. Looking for a good metro frame/body
  13. Correct Iridium Spark Plug Gap
  14. 1994 Geo Metro xfi 1.0 Fuel Filler Neck
  15. Metro convertible & Adding Factory Air
  16. How Do I Prevent Dash Fade?
  17. Looking for advice - Frame
  18. 91 Metro Splash Shield
  19. Need acondenser fan motor
  20. Question About New Exhaust for 94 Metro
  21. lights question
  22. finally insurance $
  23. Intake Passages
  24. Side Mirrors
  25. Cant get key out! help!!!
  26. setting initial timing for gas mileage on 1.0L
  27. Clutch
  28. Should I Worry about my Emissions Test?
  29. Daylight running lights not working
  30. Have any metros hit a deer?
  31. Check engine light
  32. Fixing a Tranny Leak W/Pics
  33. Shifting issues
  34. Vacuum problem - Car works great! Crazy!
  35. A/C conversion Help
  36. Alternator Belt Flies out the back of the car
  37. Electronic ISC
  38. Squeaking Belt
  39. Engine Block - Transmission opportunity
  40. Steering creaking
  41. Need: 94 Metro Transaxle Control Module (TCM)
  42. Just bought metro #3
  43. insurance $ ???
  44. Now I have a Tachometer in The Phoenix...!
  45. no speed reading
  46. 97' Geo Metro Crank Gear worn out
  47. Throttle Position Sensor
  48. Air Conditioning problem (AC Relay)
  49. Fixing the clutch yourself? Parts source?
  50. 1992 Geo Metro Automoatic
  51. Buying New Catalytic Converter?
  52. Spark Plug Gap 94 Metro..
  53. Ive got a 96 metro 1.0 liter ignition problem
  54. Airconditioning help
  55. OBD Connectors
  56. 95 geo metro Emissions
  57. Conversion - lsi convertible into xfi convertible
  58. geo engine vibration
  59. Condenser fan
  60. Control arm info
  61. Help, two wires, and no place to put them
  62. Headlights on a 95 Metro
  63. 2000 1.3L auto transaxle swap
  64. GEO Metro XFI?
  65. Idle Speed
  66. Low idle problems
  67. Computer Code Problem
  68. New clutch but now grinding near fifth gear
  69. Distributor ??
  70. Balancing the Flywheel on 93 Geo Metro
  71. Metro Lifespan?
  72. head light/tail light swap out of a swift gti to a '91 metro
  73. shift linkage-exploded view
  74. no spark
  75. Engine compatibility per year
  76. problems
  77. codes 46 and 51
  78. Trani popped-can I get it unpopped?
  79. local guy builds electric geo metro!!
  80. Dipstick tube gone AWOL
  81. 1990 geo metro ECM
  82. 1994 idle speed
  83. 95 Metro flooding
  84. 4 door front seats in two door car
  85. VSS on 5 speed
  86. Driveshaft Question
  87. I tend to exceed the speed limit....
  88. 96 metro shift malfunction
  89. Um how much would it cost?
  90. Removing bolt with stripped thread
  91. ECM Scan Tools '95 and earler
  92. 90' Metro high idle
  93. If it's not the starter, then what could it be?
  94. Want to buy
  95. Is it the Starter
  96. 95 Metro Test SW Affect On Timing
  97. Help!!!!
  98. The Wal-Mart tire controversy (?)
  99. How are the wheels aligned?
  100. Strange sound
  101. Need some advice and opinions about my 91 metro
  102. Strings for cargo cover, where do they anchor to?
  103. Radiator Support
  104. swift conversion
  105. 96 Geo Timing belt TDC Question
  106. 96 geo Timing belt a no go
  107. A/C-Heater
  108. L4 engine Interchange 1997 Geo Metro - 1995 Swift
  109. cooling fan never comes on?
  110. 91 metro 12"tires?
  111. water pump longevity, jackstand points
  112. Suzuki Swift taillights work on a 92 Metro?
  113. info on suzukird 1.0 3 cyl header?
  114. few quick questions
  115. Is this a deal?
  116. 94 Metro Terrible Acceleration - FIXED
  117. Frt. control arm change..
  118. Check Valve In Head
  119. Check engine light flashes on acceleration
  120. 93 Geo Metro Problem
  121. '93 Metro Weak Takeoff/Not the Clutch
  122. 1990 Geo Metro using oil
  123. where to get a rebuilt short-block
  124. Cargo cover...can you find them?
  125. Under the Reinforced Bumper
  126. smoking engine
  127. 97 Metro 1.3 Downstream O2 sensor
  128. My new LeBra installed on my 92 Geo!
  129. What is the miles per gallon difference 3 cyl to 4 cyl ?
  130. Bolt pattern help
  131. want to buy geos
  132. 96' or 97' motor into a 95'
  133. Stupid question, but will this work?
  134. '95 Geo For Sale
  135. shift problems
  136. Hella Optilux 2020 driving/fog lights!
  137. Want to buy these parts?
  138. '93 Metro 4 Sale
  139. 92 metro engine in a 96 metro electrical problem
  140. OBD II diagnostics
  141. won't shut off
  142. How to destroy a metro
  143. which cam mark?
  144. AC Not Working Need Help
  145. '93 Metro Broken Door Handle Lever
  146. timing or electrical at fault, or...?
  147. 10mmx1.25 acorn lugs work on 13x5.5 rim?
  148. Here's a GOOD reason to keep your clutch adjusted correctly!
  149. 94 metro 1.0 terrible acceleration
  150. Which 02 sensor (1.3L)
  151. 96 Metro/Firefly chassis rust can someone give an opinion if salvageable?
  152. before dashboard re-assembly
  153. Wisconsin to Florida
  154. Headlights
  155. Wanted 93 Metro Convertible For Parts
  156. Need help ID'ing 3 things
  157. Headlights and Dash Lights go out when turned fully on
  158. New Owner ....Lots of Questions
  159. Massager on the gas pedal
  160. White spark plugs
  161. Error Codes 41, 46, 51
  162. Different Headlight problem
  163. EGR Valve Mystery
  164. Problem finding 13" tires
  165. 1.3 Automatic Transmission
  166. Passenger side engine splash shield?
  167. Anyone have these hard to find parts?
  168. Seeking Metro parts
  169. How are Metros for repair?
  170. Any Theories?
  171. An insight on my engine purchase experience I had
  172. Does having more compression create more vacuum?
  173. This is what happens when you get to liking a car...
  174. Strange Noise 2k LSI Automatic
  175. Resonator - Is it important?
  176. Was this feature an "Option" on Geo Metros?
  177. 91 Metro LSi Conv. - Squealing Noise.
  178. Couple Issues
  179. Metro NOOB
  180. 94 Metro odd reverse
  181. 1993 Geo Metro Flywheel problem
  182. Good Deal?
  183. Interesting Symptom, What Do You Think
  184. Can I do a "Home Front Wheel Alignment" ?
  185. Hopeful Metro owner...
  186. heres a new one-fuel filler tube
  187. 97 metro broken a frame
  188. To the Forum Manager - BIG Problem!
  189. Burning Valves in the 3 cylinder engine
  190. Please Educationalize me on Clutches...
  191. ...My 96 Geo .....
  192. 94 metro flywheel transmission bearing
  193. 38mm tire offset work on a 92 Geo?
  194. Taillights interchangeable?
  195. Need spare tire clamp/jack bolt???
  196. '93 Metro 5 spd manual oil level
  197. DMV notification when changing engines?
  198. Can It Be Done??
  199. My Hwy Breakdown and Quick Fix
  200. Distributors
  201. Results on my 92 Metro so far...
  202. Any auto trans parts worth saving?
  203. Engine turns over but won't start
  204. Battery hold down bolts/bracket?
  205. checking o2 sensors with multi meter
  206. Map Sensor - 1990 Geo Metro, 3cyc.,Auto, Air
  207. 02 sensor
  208. '97 four cylinder
  209. Throttle Position Sensor...malfunctioning?
  210. Ignition system...92 Geo Metro
  211. very fast idle
  212. Temp Guage Stopped Working
  213. Towing with a Geo Metro.
  214. 92 1.ol crank seal
  215. New coil...MSD 8202 or 8222?
  216. Metro want to raise suspension.
  217. Wal-Mart's 5W-30 Motor Oil
  218. 1990 Geo Metro - Little Or No Power At Cold Start
  219. Splash shield...passenger side front
  220. geo metro speed parts
  221. tranny
  222. 1990 Geo Metro Gas milage?
  223. Cold starts and Mmisfires - 1990 Geo Metro
  224. 97 metro still bad milage
  225. Diagnostic Scanners
  226. Replacing water pump
  227. New Ignition coil...MSD Blaster 2 good?
  228. fuel tank size
  229. Using ATF To Thin 10W30
  230. im loomin for a windsheild
  231. need some serious help on this one
  232. 93 Geo Metro - Won't start/stay running
  233. Block drain?
  234. Engine question
  235. Tight Ignition Switch
  236. Different ECUs
  237. Warning System - Lights On - '93 Geo Metro?
  238. Check Engine Code: 1995 Geo Metro
  239. Windshield Replacement
  240. anyone running 3 cyl on carb help me???
  241. auto/manual starter compatability
  242. Oxygen Sensor
  243. Manual Transmission - Clutch Bolt Fill Hole
  244. Uneven Idle
  245. what tranny's would fit?
  246. Will P275/80 R13 tires fit a 1995 LSI?
  247. How insane can this lack of privacy thing get ??!!
  248. Driveshaft question
  249. Do Auotomotive Parts Manufacturers Listen?
  250. Nuther airbag question...
