View Full Version : Metro
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13 14 15
- What is the lug pattern size???
- What do you guys think??
- PSI Question
- annoying squealing belt!
- 1.3 has no acceleration when it's cold
- just making sure...
- Hard start in cold temps.......
- Odometer failure
- The Story of My Metro
- map sensor not conneced 97' lsi
- Car Dead....driving me crazy!!!
- Intermittent fuel problems when wet
- fuel pressure prob or not
- Low Idle, What to Check?
- ARGGGG!!!! ANOTHER PROBLEM! This time it won't start
- Geo not shifting
- Tire ordering issues
- WANTED: 1991 or 1992 in NC area with clear title RUNNING OR NOT Parts Car.
- Protecting the Metro Frame
- Ignition Cylinder
- Morning Smoke: Possibly Moisture???
- Electrical Disaster or not...
- the continuing metro electrical disaster
- Wet Distributer
- disk brake drag
- 99 METRO 1.3 liter computer for sale
- Starting issue in a 96 Metro
- Brand new bearing set for sale
- E-85 Ethanol
- WD-40 and Unwanted Paint
- Anyone have an extra auto trans
- Belt squealing then breaking
- Sticky Ignition
- Stopping a loud creaking sound in the rear...
- Engine Vibration -- gonna be fatal, soon?
- 85 Octane Fuel
- Getting my Geo's windows tinted.
- 96 1.3L head gasket replacement
- Drip Stick Tube
- Metro 3 speed automatic transmision
- Adding sway bars to a 94 metro
- NOT AGAIN! - Heater Problem
- Need SOME HELP Plz. Cranks Shaft Gear Broken!?
- aftermarket new 92-94 door handles review
- I love my geo but I have an exhaust problem that sucks...
- Looking to Buy Another
- Why so Long
- Bucking Metro
- Bucking Metro
- Window Washer Fluid and Nozzles
- Suspension problem?
- What year tranny will fit my 96 1.3L ?
- Geo Metro of Death!
- 94 Metro Loses Fast Idle When Cold
- Why Is It That...?
- My heater fan quit working - 20 °F !!!
- 94 Metro EGR Solenoid
- 1999 Geo Metro will not reverse.
- ignition failure
- How difficult is it to replace Transmission's Bearings?
- 98 Chevy Metro/ Floods out when cold started
- side moldings
- 97 Metro Intermittent Starting Issue
- Question about the AudioVox Cruise Control
- Slow Crank
- Troubleshoot/replace starter
- stereo and a/c blew
- Stereo and A/C blew!
- Squeeealing - Shreiks of the damned...
- How do I engage the window washer on a 96 Metro Sedan, automatic
- 1992 Metro suspension
- Can a loose A/C belt cause it A/C problems
- Replacing center dash vents
- Transmission Oil Fill Plug
- Getting different tires
- Alternator bolt
- cow jumped over the metro
- sway bar link replacement part?
- new metrophile
- intermittent buzzing from dashboard
- Everyone have a MetroChristmas and Happy New Gear!
- Tire decision
- 94 metro floods hard to start
- Frothy Oil
- NO Charging
- Low Fluid is or is my Transmission finally toast?
- Rattle in back right rear
- Power vs Altitude and Cold Air
- I need help with a 96 metro
- Ignition Module Location???
- 1999 1.3 still no spark on 1-4.
- Can't beat Ebay just bought
- Car too cold
- Steering column lock
- What is turning in the Transmission at idle, clutch out?
- 1994 metro odometer not working...
- Cam seal, crank seal, water pump questions
- Draining Cooling system !
- Finding my Snow Tires
- Air Compressor Advice
- Dead Windshield Wiper
- My trip to Mexico and cars there
- 1.0 L twin-cam turbo w/ 101 hp Metro
- Freeze Plug - 96 Geo Metro
- Snow Tires
- 99 SOHC 1.3L metro...timing chain or belt?
- Changing the Brakes
- location of computer in a 93 geo metro
- Air Filter and Connecting Hoses
- PCV Hose
- Measuring Horsepower
- Metro running rough
- 91 1.0l tps adjustment
- Off Model Question
- The Silver Bullet lives on!!
- Considering buying a 95 metro.. questions
- how to remove the belts?
- Automatic transmission gear ratios
- Rough Idle
- Trying to post picture of the Dragon!
- Tinted Windows
- tires I found
- I have a question about TBI's
- 94 Metro mystery sensor?
- 90 Metro cold on hiway warm in town.
- 1998 Chevy Metro LSI 5 speed: stiff shift lever
- loose valve cover gasket/oil spraying?
- Unwanted Paint
- Cold Mornings
- New Headlights
- MPG Computer for pre '96 Metros?
- Port and Polishing
- 99 metro 4cyl no fuel injector pulse
- Car Stereo/Radio
- More Horsepower
- CV Joint, Bearing, or ???
- Thanksgiving
- Tire size calculator
- 92 Metro automatic won't shift
- Timing Belt R&R job cost?
- car wants to die when I shift
- Thank You Everyone- Metro Dead!
- Need transmission mount
- Help-geo timing whos right?
- 1990 metro timing marks
- Need advice on problem-no start
- Fuel Saver Chip
- Geo Metro Mini Truck Conversion
- 1990 3cyl fuel pressure specs
- HELP!!!! Heater not blowing very hot!!!
- ohm values 90 metro 1.0
- Lihtan geo service manual
- Ideas Anyone?
- Is an Oscilloscope useful for Automotive repairing?
- No Fuel Through Injector--No Start
- Push button Ignition
- Car stalled - is there a problem on the way?
- 98 metro floods
- 12" tires are making me MAD!!
- Is the Metro 4 cyl engine same as Suzuki Esteem's ?
- Clearing up the Tach issues
- 96 Metro LSI VSS Location And Picture If Possible
- A/C belt - do I NEED it?
- Metro Transmission
- 93 Geo Metro Center Taillight
- Po780 Code
- Oil Pan Drips
- A Few Screws Short
- Motor Mounts
- new engine
- My Shift Lever Rattles...
- PCV Valve plugged
- Timing Marks
- Service Manual vs. Haynes Manual
- 98 metro engine swap
- Driver side window
- I Checked the "code" from the Check Engine Light - OK, now what?
- headliner
- Replacing thermostat?
- 97 geo wont start
- Geo Metro Exterior Door Handle
- Winter Storage ?
- Door Handle Repair
- HELP 99 Metro 4cy Keeps Fuel Fouling Plugs
- Ring Replacement.. Doc you SOB!!!!
- ??? Gas Filter???
- Tightening up the 5 speed shifter
- Help! Car up and died
- Water Pump Going Bad???
- We're back!
- oil pan/catalytic converter
- Hate to ask.. Oil Capacity 1.0l
- exhaust manifold studs
- Valve Seals
- How to clear up composite headlights
- '92 Metro 1.0 Exhaust Question -- pipe diameter
- 93 Metro Idle Problem
- Why do my miles/gallon fall off in Winter?
- Torque Steer
- Will parts fit?
- August 1993 Geo Metro, Starting problems
- leaking brake
- 93 metro cooling fan
- '97 Metro (1.3L) Intermittent stall/sputter
- problem with 95 Geo Metro
- HELP 99 Metro 1.3 No Spark
- Outer CV joint removal
- 95 Metro: back-up lights out
- HELP - AGAIN - Very SLIGHT hesitation while driving - itermitent check engine light
- 1996 Geo Metro Schematic Needed
- PCV filter location?
- 94 Metro engine problems
- HELP NEEDED IN A HURRY! Metro 3 cyl DIED this morning, won't restart
- XFI question
- Interesting Automotive Situations...
- rear brake locked up
- Replaced broken timing belt, now head gasket is blown? Why?
- Who Knows the Most Efficient Intake Air Temperature?
- Weird problem when filling the tank
- Metro wants to DIE when A/C is turned on. Please help me!
- 2000 Metro 1.3 Tick at idle
- Fuel Tank Capacity
- Humming noise after highway drive from rear
- The error in determining Miles/Gallon....
- Window washer setup/hoses
- timing for 1990 geo metro
- Burnt valve?
- Air Conditioning
- 95 1.3Lsi Metro Fuel Problem?
- Squeeky engine
- a/c clutch???
- How do you know where to set the timing?
- 94 Metro burning anti-freeze
- Metro : 1.0 vs 1.3
- Roof Rack
- Help high idle after I rebuilt engine??
- post-metro suggestions?
- Engine revs up when started, surges when warm
- Is there a "Trick" to adjusting the Window Regulator?
- Valve Burning - any way to know before disaster strikes?
- Head bolt tightening sequence and torque
- Any POWER CURVE (rpm vs torque) published for the 3 cylinder Suzuki engine?
- Going in reverse
- Wheel size
- Clutch Adjustment
- Can't clear code
- Gas mileage issues
- Idle Speed
- Dash Lights
- Manual Window Track
