View Full Version : Metro
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12 13 14 15
- 1991 Metro Idles Rough for about 5 seconds
- Trans case broke - can it be used?
- 94 Metro Code 1 flash then 2 Flash
- Sprint/Metro Powertrain Swap
- 96 Metro - No Go
- 91 Metro 3cyl Timing belt help. Timing belt tensioner?.....
- Duh......1.0l Fuel Adjustment???
- overheat issue
- Metro TBI
- Any 5 speed Transmission rebuilds with pictures available?
- I named my rebuilt Metro "The Phoenix" - now NASA has one.
- Auto transmission difficult to shift out of park.
- Blinkers won't come on and fuses good.
- 94 XFi engine swap into 93 nonXFi-No Spark
- Does 92 Metro have auto door locks???
- Can the Metro accommodate a Toyota 5SFE drivetrain?
- 1995-2000 Trans/Clutch Removal Guide (PICS)
- Bummed Out On Rich Fuel Problems
- starters
- 98 3cyl Metro Randomly cuts out and stalls
- AC problems
- Very Rough Idle
- Egr "sensor"
- Storm Seats into a Metro?
- Help - Eng identification, crank pos sensor
- Timing Belt Cover
- Summer Gas Mileage WOW, is this real?
- 91 Metro High Idle When Warm
- hard to start
- Coolant Tube Problem
- tach
- VSS code 24 after installing cruise control
- Almost had to shoot my geo
- One thing I hate besides the fuel filter's location
- Just as I pulled in this morning ..
- Metro A/c Freon Capacity??
- Parking Brake Release Button
- Metro Newbie with a 1.3L
- 3 Cyl Interference Engine Debate
- $4.00 a gallon gasoline??
- tires
- Front Crank Seal Removal
- Odd & Assorted Questions for Metroglodites
- 97 Metro LSI dies when it gets hot
- Control Arm some help please
- Temp Gauge readings
- 13" Wheel upgrade mpg drop...
- If you plan on exhaust upgrades
- compression on a 1.0
- 91 Metro 1.0 3cyl. Automatic Crank seal advice needed
- 95 1.3L timing set, and specs
- Rocker Panels?
- 91 geo metro lsi help plz
- 95' 1.0 trans
- Bad fuel pump?
- Article on CNN.com
- Metro Frame can be saved!?!?!?
- Rough idle while cold
- Failed Emissions Test
- Speedo problem
- Control Arm
- Exhaust/oil pan
- bypassing Oxygen sensor after cat
- Selling my 92 Geo Metro (*tear)
- My Metro's new exhaust!
- Getting a newer car (not a Geo though) thought I'd share...
- Will 175/70 fit 99 Metro?
- 1994 metro dying
- Super high idle
- 1993 Metro Back Strut Removal - Blast!
- 1994 metro stalling
- Looking 4 Geo Metro 91 Parts
- metro with oil in air filter housing.
- troubles with trouble codes
- discrete wiring idea
- need air intake hose
- Hard to start & no power
- 91 Idle Air Controll!!!! Where Can I Get One
- Could a 3 Cylinder Metro be made to run on Ethanol?
- 99 metro uneasy on highway
- 94 Metro Engine/transmission swap
- Idle Speed Control Motor
- Tire size
- Replacement Top Recommendations
- CV axle noise how to tell
- Throttle Position Sensor
- Climate Control
- Getting Vehicle Warrentee Offers - Garbage?
- Dashboard Painting
- Timing belt cover
- 95 Geo wiring issues
- Adjusting timing
- O2 Sensor and Fuel Filter Where Are They?
- Engine I.D.
- Instrument cluster installation
- tach problems?
- Help 97 Geo Metro throttle position sensor
- Installed an A/C belt now New sounds
- Geo Gauge White Face overlay
- 91 Lsi Convertable. Shocks and Vacuum Hose Chart ?
- It's a BumbleBee!
- Crazy Parking Jobs In A Metro (Picture)
- New P155-80-12" KUMHO POWER STAR TIRES - 2 Sets of 4 left!
- test
- my 12 to 13 inch steel wheel upgrade project PICS
- The way Metros Die - rust out in the control arm / underbody area (PHOTOS)
- Help, Car Engine Runs Fast
- Exhaust upgrade
- strut time
- 97 1.3 metro dash light
- 1.0L Head removal guide
- hwy mileage in the city
- Alternator noise
- Head light issues
- Does it do ANY good to use STP (Oil Additives) ?
- Exhaust Pipe Soot
- 96 LSI revving engine when in neutral
- going from 12 to 13 inch wheels, alignment needed?
- 93 Metro cuts out @ hiway speeds...
- Automatic trans blowing fluid on top of trans???
- 12" tires & rims.
- 94 Metro timing
- '97 Help
- Installing an A/C unit on a 96 LSI
- wheels and tires
- Ignition timing - 92 Metro
- 97 metro
- Front Wheel bearing Replacement
- '92 Metro idle
- Over play on clutch pedal
- General Metro models
- Newbie - 1993 Metro Convertible with fast Idle
- Burning Smell
- Help Metro multiple symptoms, need fix
- test
- No more Geo - thanks for all your help...
- Here's my Metro
- '95 Metro 1.3L Error code 15
- 1998 3 cylinder firefly won't start!
- The UK gets it...
- Compression Test
- Code P0420 again.
- EGR passage cleaning
- Passenger Side Rotor RED Hot, Caliper or Brake Line?
- Which weight oil?
- clicking noise
- Putting the Belt back on
- Exhaust Bolt Springs
- electric fan
- What IS this sound? - Come on you Geo-geniuses! Help me out!
- Easier with tire on or off?
- Bad gas mileage
- Cylinder Valve Job :)
- Spark Plug Gaps - Regular vs Platinum
- oil on plug 3 only 300 miles.
- Rear Swaybar Bushings
- Drum Brake Removal
- Tbi 911 / 411
- How to Post Photographs on the Forum
- Help, Crank but no start
- 1991 Geo Metro 4 door ( Bad Gas Mileage )
- What is this sensor?
- Losing Coolant over time
- 4 or 5 bolt crank pulley
- weak fuel pump?
- Lug Nuts for 13inchers
- 92 XFI Rebuild. Runs GREAT! But vanishes in a cloud of SMOKE!
- Block Rebuilding 91 3 cyl
- 91 Geo Metro 5 door 12 inch rims
- Fuel pump
- 1991 3cyl Metro (FAN QUESTION) Are both fans supposed to run at same time?
- 95 Metro - Coolant Temperature Sensor
- 92 Metro timing
- P0300 - Random/Multiple Cylinder Misfire
- 91 Metro 1.0 3cyl. automatic engine idles high then low in park and sputters up hills
- Metro Parts Interchangeability ??
- Stubborn Bolt
- 93 metro xfi no spark issues
- 1991 Firefly(Metro) parts available..Toronto
- Repair Manual for 97 Metro
- Femaledriver prism fuel filter
- Code 51 & EGR 94 1.0 L
- Need Website for Wheel/Rim Vehicle Swapping
- Engine swap
- Crankshaft Pulley
- 2000 geo metro / suzuki
- 0.9 vs 1.1 bar radiator cap
- Problem shutting puter down to check timing.
- Manual Tranny help
- What gives..???..trannys different
- 2000 Chevy Mtro wont start hot
- Head Job/Ring Job
- Replacing front crankshaft seal
- 91 egr
- Kiss my rear 4 bucks a gallon!!!
- Tranny swap, will it work?
- Camshaft Pulley
- For Dr. Bill...HHO generator
- 95 Metro 1.3, loads of work, still no run
- 97 Metro speedometer quit
- Final drive ratio
- Vacuum advance for distributor?
- manual transmission oil?
- Wheels for a 93
- Timing Belt
- Strange Smoke and Smell
- half-shaft help
- transmission whining!
- 96 EGR Solenoid?
- 12" to 13" wheels
- Rear window defogger
- 96 Sedan-Check Engine Light-CEL does not blink with the Fuse Test
- How does one reset the SRS (airbag) light?
- 14 inch wheels? .. anybody?
- fuel pressure
- Lifters on 1 Lt. engine
- Changing front struts
- 92 Metro wont start after hard braking
- Newbie's 94 died on freeway
- Electric Fan
- Reasons for poor fuel mileage
- 12" versus 13" tires for fuel mileage
- Finding a MAP sensor
- Metro Achilles Heel (at least in Northern climates)
- Front Wheel Bearing change
- Syncro problem
- 95 metro 1.3L camshaft sensor needed
- I need torque specs.
- Slow returning to idle speed
- Car Won't Start
- I really need a timing belt cover and a crank & camshaft sprockets
- MAP Sensor, What is it?
- engine bogg
- Wire harness problem
- Another Nasty Noise
- Well boys!!! What do ya think??!!??!!??
- Engine swap
- Car Bogged Down
- Factory Service Manual
- 90 to 94 Engine block swap
- Engine dies when decelerating
- Slime!
- Rev limiter????? 95 metro
- 95 4cylinder wont rev., No power
- A Nasty Grinding Noise
- Geo fixed
- A/C heater fan switch
- Great Snapped Bolt on Control Arm! Now what?!?!
- Any demand for Metro's
- When to call it quits with a Metro.
