View Full Version : Metro
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Emergency Brake Light
  2. Timing Belt Tensioner
  3. MPG versus year of Metro ?
  4. Repairing the Rear Window Defroster
  5. huge mileage problem, getting worse, need help!
  6. Can all metro transmission interchange? Are there different Gearings?
  7. This is easy. please help
  8. Anyone tried the homemade sea foam
  9. Air Bag Light Keeps Coming On
  10. Thermostat, Coolant Pump O-Ring
  11. Intermittent air bag light
  12. 91-94 Timing Belt Cover (are they the same)???
  13. 92 1.0 check engine code
  14. TPS- think mine is bad
  15. 42 mpg on new rebuild?
  16. 92 metro door panel removal?
  17. Water Manifold off Pump
  18. 1997 Geo Metro LSI 4Cly Auto shitfing Problem
  19. help id this(coolant temp switch)and its wires to it
  20. help id this(coolant tep switch)and the wires
  21. P & G question
  22. Body question
  23. simple timing ? I hope.
  24. 94 geo metro 1.0L 3cyl timing marks
  25. 92 1.0 throttle plate tbi
  26. 91 geo metro dies at stop signs then wont start
  27. There was a Mouse
  28. Leaking after assembly
  29. '96 Metro starts then immediately dies
  30. rebuild engine break in oil
  31. What oil?
  32. catalytic converter
  33. The eXtreme Metro Makeover
  34. Looking for headlight connection for 95 metro LSI
  35. valve cover gasket
  36. Help! Power washed my 93 vert engine. Now it looses power at 2K RPM
  37. 93 metro lsi hardtop
  38. Looking for cheap crank 1.0
  39. Fuel Pressure Gauge for TBI
  40. About to embark on CV change......
  41. Main bearing jounal question, 1.0l
  42. The Phoenix is now 4WD !
  43. coin tray
  44. 91-94 metro rear clip
  45. PARTING OUT 1991 Geo Metro 1.0 3 Cylinder Automatic in NC (Need Parts?)
  46. Check Engine Code 51
  47. hot weather start problem
  48. 92 Metro 87 Sprint???
  49. Metro door hinges 4 door to 2 door....
  50. 96 Geo Metro LSi gear problems
  51. Dead Metro -- Need help troubleshooting
  52. cant get 95 geo to start
  53. Advice on buying used metro
  54. 1995 GEO Metro 3 Cylinder Cooling System part question.
  55. Good machine shop?
  56. 2000 Metro Fuel Tank Issue. Unbelievable!!
  57. Blown head gasket, cooked on oil removal?
  58. Battery/starting issue
  59. Center Console
  60. Tire Recommendations?
  61. Passed Emissions...AGAIN almost 200k miles
  62. It's Alive
  63. The Silver Bullet lives :))
  64. Anyone live near Milton, FL?
  65. 96 Geo Metro Lsi with tapping rockers
  66. Front Brakes & Rotors replaced
  67. Brake Fluid Reservoir
  68. Geo's invited to Economy Run event
  69. Anyboby seen my hubcap?
  70. Metro stalls at startup sometimes and won't re-start without pushing pedal to floor.
  71. Don't laugh - any Hotwheels of Geo Metros sold ?
  72. '91 XFI TPS Adjustment
  73. rubbing sound
  74. 1996 geo metro no spark
  75. Fix or Junk?
  76. Throttle body parts for sale 1995 Metro 1.0L
  77. Profesional opinion needed pleaase!!
  78. Rasing from the depth and old geo
  79. R-12 replacement
  80. Post engine rebuild update
  81. windshield replacement
  82. Evil Lug Nut
  83. Headliner question
  84. A/C Question. Can the temp switch cause problems.
  85. Intake Gasket Question. Can I use RTV instead.
  86. Thermostat replacement
  87. Geo metro carpet
  88. White Sparkplugs
  89. It takes two (My little Frankenstien)
  90. Parcel shelf solution
  91. Oil Pressure
  92. Discolored headlamps
  93. Prepare for the worst/hope for the best
  94. Geo Metro 1.0 Turbo
  95. How cool is this
  96. Wheel Bolt Pattern List - If you need to upgrade from 12" wheels etc.
  97. re-tap threads
  98. Oil Pan leaks again
  99. codes
  100. Crank Sprocket
  101. Starting Problem looking for suggestions
  102. Looking for Suggestions
  103. buy an old geo and update?
  104. 93 1.3 starts than dies
  105. blower motor
  106. 94 metro auto trans shift problems
  107. Bumper Stickers Seen - Just For the Fun of It
  108. XFi Camshaft Swap - How To
  109. Metro Drags when it gets warm...
  110. Who recemends a place to buy a reman head
  111. hard to reach nut
  112. Speedometer Off
  113. Dead Turn Signal
  114. bolt size needed?
  115. 1991 Metro 1.0 L will not start.
  116. Pulling engine/transmission
  117. Distributor o ring needed 99 chevy metro 1.0l
  118. Starter Repaired
  119. Several Parts needed 92-94 metro swift
  120. 92 metro top replacement
  121. Metro has grinding problems--please help
  122. 97 Geo Metro LSI Auto 4cyl TIMING??
  123. Manual transmission on Metro - can it be adjusted?.
  124. Leaky oil pan
  125. Need correct rear wheel bearing torque spec
  126. 1994 metro to 1995 swift engine swap
  127. Valve spring keeper tool
  128. 93 Geo Metro Won't Crank
  129. Replaced Spark Plugs with NGK's
  130. New Tires WOW
  131. It's ALIVE.....
  132. Keepers picture?
  133. Finished rebuild tonight. Won't start
  134. Door Pins?
  135. Where does this wire go?
  136. Camshaft oil seal
  137. Noisy Spark Plugs and Wires on the Radio?!
  138. Loose spark plug bad performance?
  139. A/C low-high pressure graph
  140. Antifreeze/Coolant Colors
  141. Brake sensor
  142. What is this?
  143. camshaft broke
  144. Johnny
  145. How do you get the keepers back in?
  146. tension spring broken
  147. Burned Valve Photo
  148. tension sproket spring broke
  149. A/C compressor clutch
  150. How do you remove the valve springs?
  151. A 4WD Geo Metro ! ?
  152. 94 Metro 5 Speed Manual Transmission Rebuild - PART 2 - Assembly
  153. metro exhaust pipe diameter?
  154. 95 GEO Metro 3 cylinder overheating
  155. Block oil check valve (photo)
  156. Head Off! What Next?
  157. 94 Metro chokes, sputters, then dies, no power
  158. Hole in pistons
  159. Trunk Struts
  160. Geo Metro Starter Compatibility Question
  161. Trans???? slow shift floor the gas and it barely goes!
  162. Fuel Injectors:Will this work??
  163. '97 ECM Metro
  164. 2nd Annual GeoPalooza 7/25/2009
  165. 95 GEO METRO OBDII Compliant?
  166. trans click?
  167. Good replacement struts?
  168. Loses power under acceleration
  169. Sloppy Shifter
  170. auto to manual trans?
  171. oil pan where are you?
  172. lifters and cam question
  173. 94 Metro 5 Speed Manual Transmission Rebuild
  174. brake rotor question.
  175. Its good to be back!
  176. What kind of engine is this?
  177. Why does "Double Clutching" help change gears ?
  178. 95 GEO Metro Temp Gauge not working.
  179. Brush got Stuck
  180. Transmission Flush
  181. speedometer needle jumps/erratic
  182. front wheel bearings?
  183. Convertible Warning...
  184. Where are you located?
  185. Metro Convertible Top Replacement
  186. Loud lower frequency sound at idle and when stepping on gas? Error code 51
  187. Who has one i can buy? (Radio parts)
  188. Door Problems 4 door Sedan
  189. need spark
  190. Uh yea, one problem figured out...on to the next.
  191. New to the forum...again
  192. Alternate Gear Oil Filler Hole
  193. Indexus Metrogloditus
  194. Metro won't stay broke...
  195. Ignition Switch
  196. troubleshooting coolant flow
  197. Fixing a Code 51
  198. What are ALL the symptoms of a worn out Manual Transmission ?
  199. clutch question...
  200. 94 xFi error code 13. 315,000 miles
  201. Heater not as Hot!
  202. Can A Timing Belt Being Off By A Tooth Affect Compression?
  203. New to the Metro Scene
  204. to much gas
  205. The Mouse has been in a fight/ Seat Info!!
  206. carpet
  207. 91 Geo Metro Check engine light Code 51
  208. 5 miles out of a water pump???
  209. Capturing Videos that won't normally save on certain web sites
  210. Crazy ? for Auto Trans Experts
  211. Manual Transmission Video
  212. High Idle?
  213. Gas Tank Filler
  214. Bench Seats for '93 Metro ?
  215. A qestion about cold starts
  216. who has a good winter (sub 0 deg F) starting metro?
  217. 2000 geo metro
  218. Where do I get info on engine rebuild/replace options?
  219. I've Split the Case - Now I'm Confused
  220. This is one for the books! A "puzzlement"
  221. Weird! '92 5-speed linkage just got super-easy to shift
  222. New Cylinder Head Pinging
  223. '92 XFi: intermittent high idle + high temp
  224. Cylinder Head Replacement
  225. Adding an extra battery
  226. Do not read this message - it may cause enlightenment.
  227. 1997 geo metro 4Cly Auto Terrible Acceleration... Please Help me solve this!
  228. Yanmar Metro Clone
  229. Headlight fix
  230. Window Regulator 2door / 4 door ??
  231. car starts wont stay runnin
  232. map sensor
  233. Distributor cap gasket
  234. 97 4cyl lsi 4dr wont start or shift from park
  235. Squeeling Fan Belts - doubling up the pulleys
  236. Fuel filler hose not letting me fill up
  237. Exhaust flange gasket
  238. Removing wiper/headlight switches - button replacement
  239. Here is something for you Geo guys to talk about
  240. Seat Belt Rewinder going Belly Up...
  241. Oil filter alternitives
  242. fan resistor block
  243. Fan Switch
  244. Making an offer on an 89 Metro XFI?
  245. Steering boot kit
  246. How many convertible owners out there ?
  247. high RPM
  248. valve cover replacement
  249. 1985-1993 & Up Metro Sprint Reapir Manual on CD $12.50 (FREE S&H)
  250. Hatch holding device for weak struts?
