View Full Version : Metro
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12 13 14 15
- fan resistor block
- Fan Switch
- Making an offer on an 89 Metro XFI?
- Steering boot kit
- How many convertible owners out there ?
- high RPM
- valve cover replacement
- 1985-1993 & Up Metro Sprint Reapir Manual on CD $12.50 (FREE S&H)
- Hatch holding device for weak struts?
- Front Left Turn Signal Dead -Rear Fine - Any Suggestions?
- Something to try...mpg improver
- 98 Metro won't start
- 1991 Metro back on the road - thanks!
- geo metro
- Silly Q about the headlight bulb
- Tach
- geo metro
- 91 Metro 3cyl automatic rear main seal leak.
- Leaking trans shifter shaft seal
- timming belt question
- how do u adjust the rear brakes?
- transmission module replacement
- this is for all
- 1.3 smokes
- Lower Control Arm
- Water pump and starter question...
- 91 metro 3cyl exhaust manifold heat shield question.
- running rich...new O2 sensor
- Wont start when warmed up
- 97 metro 13" rims
- need your opinion please!
- Another timing belt question....
- 91 metro wont run
- mysterious oil leak
- Taking the crankshaft pully off a 1.3
- DTC 13 - O2 Sensor
- my metro did something interesting today...
- Stuck Oil Pan
- valve cover bolt torque specs
- Coolant tube Replacement
- Head Gasket , 2000 Metro
- replacing rear wheel bearings
- In search of an antenna...
- cam seal leaks and leaks and leaks...
- Blown motor, cracked head
- I need a new timing cover! 1.0 Metro...
- a/c delete
- Replacing clutch cable
- Best Control Arms?
- Geo anyone
- 91 Metro 1.0 Automatic Engine Rebuild Photo's
- 91 Metro New rings etc. bunch of questions?
- Windshield wiper mod.
- Crank Pully Question
- Best mpg with a Geo Metro?
- Some trick to inserting the speedometer cable in the Transmission?
- conv top weatherstrip
- jumping to read trouble codes
- Geo metro alternator
- Deer and cars
- fast idle
- 93 Geo Metro HB 5-spd-Brakes and alignment
- p400 code
- XFI Ground cam in 1.3 litre engine
- Foaming coolant, rust... etc.
- 2000 Metro LSi water pump and timing belt
- Brake booster port 1997 geo metro
- Metro Getting Hot
- Electric Fan - Engine Overhearting
- My Steering Wheel Horn Cover keeps falling out!
- Anyone done a timing belt?
- whats the expected MPG on my 97 LSI
- Help! I'm Electrically Challenged.
- P0340 Camshaft position sensor
- manual trans. oil
- smoke
- 91 Cooling System Tube
- clean the stuff out from behind the front fender splash shield
- Rebuild or Replace?
- 1997 geo metro 4Cly Auto Over heated and...
- 93 Metro Hatchback -Broken Seatback Mechanism
- 91 Metro 3 cyl with poor compression.
- New rebuild installed
- 1990 metro ECM
- 98 Metro Inner Tie Rod Boot Clamp Question?
- Good deal for a 96 Metro Sedan?
- head lights on 97 metro 1.3
- Spark Plug Inquiry
- Battery Terminal
- Changing Wheel Bearings
- "93 Metro, Things I learned This Weekend
- '94 Geo 1.0L Crank Pulley Bolt Removal
- Should I pull engine with or without tranny?
- Metro parts availability
- 2001 metro issues
- Strange and Unusual Sound
- What Offset On A 91 Metro XFI For Aftermarket Wheels??
- HHO Hydrogen fuel cells ? Has antone here tried it?
- 95 lsi code scanner
- Please help...
- Driver side door gap
- Holy Ebay Ad!
- Double your gas mileage???????
- Ev3
- why won't shift into second gear?
- Seat Swap???
- Side Window Weatherstrip
- 12" Tires for Sale I came across! NEW!
- Upgrading Bumpers & Headlights
- Is my proportioning valve shot?
- how much piston clearance is acceptable
- won't start when wet out?!?
- 95 geo lower control arms
- Bigger Horn
- wheel stud
- 97 Metro belt replacement
- 97 geo metro stopped running
- Swaping 1.0L for JDM
- Water Pump Replacement
- Did a rebuild on my 1.0L now runs rich.
- Re-keying a Metro Hatchback door lock
- I need help to find geo metro latch
- wont start after water pump change
- installed xfi cam should i install ecm
- where to find a 1.3L exhaust manifold?
- where to find 1.3L exhaust manifold?
- 93 geo handfull of questions
- idles good bogs out under throttle
- Seat Modifications In my 96 Metro Hatchback?
- EGR Valve - O2 Sensor
- "Creaky" Shifter
- no start at times
- Halfshaft Installation Help
- Lxi Cam
- 95 Geo Metro Won't Start
- Cuts Out at 45mph
- Water Pump
- Ohio/Pennsylvania Gather - 09/14/08
- Frame broke, cont. arm moved..NOW WHAT???
- metro engine id #
- Metro Models - Confused
- Cam Sproket = SNAP!!!!
- How do you remove the rear spindle/knuckle bolt?
- great website to price used metros
- 97 metro no heater fan on high - whats up?
- geo metro # 2 cylinder misfire
- METRO 12in. TIRES on ebay! Act fast! Best price on the web! 145R12 145/80R12
- adjust timing
- I need a rebuild on my 1.0L
- idle rise & fall
- Broke down no start
- Please Help!!
- PLEASE HELP me Identify this engine!
- 98 Metro 1.3 4 Cylinder Oil leak advice needed...
- Please Help! '97 Chevy Metro LSI Engine wants to die when I step hard on the gas
- Rear stabilizer bar
- Rear wheels rusted to break drums
- Is this Metro worth buying? 1998 1.3 Automatic LSI?
- Proactive Oil Burning Prevention:Head Gasket Oil Drain Issue
- Carpet for 98 2dr LSI
- Overdrive for Metro
- Acetone and Xylene as Fuel Additives
- Coolant Tube O-Ring
- New rebuild won't start
- Metro Vs. Smart Car
- For Your Information - Automotive Repair Manuals on CD's
- Need o2 sensor for 99 lsi. also head rebuild?
- 1995 1.3 L LSI Auto Mileage Testing Results
- Old Headlights - New Life
- Rusted out Metro frame repair
- I need a new convertible top for my 93 Metro
- geo metro body search
- Synchros stuck in Geo Metro 5- speed manual trans
- Wiring for Aux. Lights
- replacing my 1993 Metro's convertable top
- forum seems to be working again
- Piston Swap
- This forum not working right
- Optinum Valve Timing For A 1.0
- Timing issues
- Metro Fuel Tank Capacity
- Alternator terminals
- I need a Metro XFI model
- Geo Metro Used Parts On Forum?
- EGR Electrical Connector
- timing belt
- Throttle Position vs Fuel Consumption
- Metro Fsm Download ????
- Shifting problems solved. :-))
- More Geo body damage questions
- Drum Brake Help
- 92 metro need help finding parts
- Struts and Strut Bearings (?)
- Geo metro quarter panel replace
- valve seals
- oil burning issues
- Inside door release handle
- annoying noise!
- Foggy headlights
- On oil, viscosity, and burned exhaust valves
- '93 Geo Metro 2 door hatchback 1.0L 3Cyl 5Spd HOW MUCH IS IT WORTH?
- I need to order the middle vent on 90 metro
- code help
- Help me diagnose this problem, ONLY 17MPG! in a metro!
- Best way to replace rear motor mount?
- Link to engine ID codes?
- '98 metro 3cyl, 5spd - new owner
- Replacing the oil pump
- high mileage oil
- Exhaust suggestions
- 1996 Metro
- torque specs
- 02 Sensor Check engine light 97 Geo
- 1994 Geo Metro Loses Power
- Those hard to find 12 inch tires!
- Antifreeze Leak....where is it coming from?
- There's this thing on my engine.....
- Interesting article, this is why I am happy with my Metro!
- 95 1.0 5 spd. rebuild
- 1.3L Head to Block Allignment
- I have a feeling i'm in the right spot now
- A question for GM Line Rat
- 98 Chevy Metro. pls help
- 1994 geo metro distributor cap rotor
- thermostat
- Desparately Need A Valve Cover!
- 94 XFI Starts but wont run?
- Renewable Energy Forum
- 99 metro cargo cover
- Repair Manual
- 2000 1.3L Valve Lash Adjustment
- Automatic tranny starts in second gear
- Rebuild time! Best Place to Get a Rebuild Kit?
- oil in air filter
- 91 Metro 3 cylinder Possible sticking valve. Options and advice needed.
- 95 Geo Idles wide open!
- Speedometer Gear
- 4 cyl fuel mileage.
- Can't Fit In '96 Metro...might Sell!!
- Code 23
- This can be simple but...
- I'm Lost On The Map
- Tranny swap???
- Save the planet: Buy a used Geo Metro
- Metro/swift Parts Available
- METRO MILEAGE TIPS (as promised)
- Looking for someone to rebuild my 96 1.0 metro engine
- Checking Engine Codes
