View Full Version : Metro
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 [ 14]
15
- Emissions
- Low compression = valve replacement '93 metro
- Whistling noise when accelerating?
- drivers window goes off track
- Temp and Fuel Gauges
- I think I killed my compressor
- EGR Valve for 1.3L
- Dash swap
- Lifters or Cam?
- should there be a slight vacuum when you open the gas cap
- Instrument Cluster
- Overheating 91, Fan probs
- TPS adjustment
- Exhaust Manifold Cracked
- i need some help with tranny questions
- One of those questions... hmnn...
- selling 1998 metro engine+parts/need body
- Who sells aftermarket A/C compressors?
- Need an ECM for 93 PLEASE HELP!!
- problems continue for my lemon (metro)
- Intermittant drivebelt squeek
- Rear wheel rumble, can't pull
- what's it worth?
- 1997 metro 1.0
- 96 1.3 probs
- Fuel Gauge
- want to buy 97 and up Geo Metro HB
- what's my 97 geo worth?
- 2000 Metro question of questions
- Wanted: Used Geo Metro
- 91 Geo Metro A/C Question
- help
- 92 geo metro
- Anybody want to buy a used head?
- metal flakes in tranny oil
- Plug gapping question
- Geozuki GTi auto to man conversion
- Heater/AC fan works only on top two settings
- surge
- my Suzuki Swift wont start and my mechanic is stumped! can someone please help me!
- transmission shifter cable
- 1996 Geo Metro Sedan rims
- A/C problem
- Swapped engine out & it won't start '94 Geo
- Canadian vs. Japanese Metros
- headlights
- 95 MEtro Check Engine Light will not stay off! HELP!
- No Spark
- speaker cover removal
- '95 Metro - Dim Headlights
- timing belt problems
- Time estimate on swap?
- 91 Metro Adjustment....
- Lots of smoke
- F/S: 1991 Suzuki Swift GT
- 2000 STUPID METRO!..ignition key won't turn
- engine surge...i think...
- what mileage can I expect out of Geo Metro 1.3 L Auto
- Does the XFi get highest MPG?
- Idle Speed Control Valve
- 95 Metro Temp sensor Problem
- auto to manual trans swap
- Geo Metro in TX?
- what is the difference in the EGR's Auto vs. Manual?
- 1995 Geo Metro Door Stuck
- Tach reference signal
- (yet another) problem
- Will not hold speed
- engine swap and tranny questions
- pluged egr
- Timing
- drive my 97 to Oakland from Peoria, Illinois
- strong gas smell
- Fuel Pump
- Engine squeal
- Radio
- 95 Metro 27 MPG ALREADY TUNED. Suggestions? BEtter MPG??
- 94 Metro problems
- Sprint Motor Swap
- sick Metro, no codes.
- Metro pause wiper and cruise control?
- tranny swaps question just to be sure...
- 98 metro tranny swaps and smoking engine
- trans
- Reringing Old Geo 1.0 Engines
- Wanted: Used 94 Metro factory service manual
- Wanted: Swift gt with bad motor for......
- 1995 Geo Metro Questions!!
- Where To Find Used Engine?
- Would it be possible?
- Cigarette lighter and radio on same fuse?
- Cooling problems
- 91 Metro still rough idle
- cv shaft
- 96 metro causing me problems
- 1991 Metro ignition cylinder
- anybody know?
- 95 Geo Metro Upkeep
- 93 Geo Metro belt Squeal
- '94 geo metro -electronic spark control distributor
- Strange engine vibration at idle
- throttle body
- 93' Metro convertible parts *free*
- 1.0 compression test
- 1987 or 1988 Sprint/Firefly Parts Needed
- Sell Metro
- 95 Metro No Front Signals, Valves Rattle at Start Of Accel. and smokes for one second
- Can a 91 Geo Metro go 75mph on 2 cylinders?
- Where to buy new OEM or better suspension arm bushings?
- F/S 14" aluminum rims w/tires.
- catalytic EGR cleaner any good?
- no poser. starts shifts. when I turn off muffler is noisy
- starting problem (timing belt?)
- blowby
- engine swap what about the tranny?
- new fuel injectors?????
- 93 metro convertible
- metro parts for sale
- how many vaccum hoses are there?
- 93 geo wont run help......
- Code readers..
- Engine numbers
- ok... I need some help.
- overheated geo solved
- should I buy an 02 sensor off the internet?
- Need an EGR for a 97 metro 1.0
- EGR really clogged w/carbon clean out or new?
- 1996 geo metro ignition problem
- Headlights
- Is EGR sensor same as o2 sensor?
- EGR VALVE change on 97 Metro
- Blower Fan
- Catalytic converter
- Need To See Hooked Up Geos!!!
- runs like crap if i rev it up
- engine knock
- want to buy one
- 94 metro unpredictable non-starts
- 94 w/funny timing marks
- vaccum leak cause loss of power?
- tuneup?
- Curious about coolant temperature sensor operation
- swap or not
- noise in rear of car
- 96 manual transmission question
- Metro went for a trip through a river....
- 95 metro code 15
- burned up after cat oxygen sensor and burned out catalytic convertor
- geo still overheats
- Is it a dog to slap another tranny in?
- Engine interchange..
- Throttle Position Sensor/Throttle Switch Adjustment
- front seal leak
- error messages
- Chevy Sprint: Tranny shifting irregular!
- Geo Metro Transmission ?
- Removing 1995 Metro steering wheel\airbag
- forced air intake
- 94 Geo Metro idle and performance trouble
- Oxygen sensor cause loss of power?
- cat converter or transmission sound under car?
- timing belt easy to install? Oxygen sensor?
- Metro for sale
- suzuki Motersports
- How to set static timimg on 93 convertible
- How to replace the alternator?
- geo overheating
- 90-93 Geo Metro Top NEW!! $155.00
- Fuel & Temp Gauge max out when driving forward
- starting problems
- Small water leak behind water pump
- 97 Geo Metro Starting Problem, very unique, please help!
- metro oil air filter??
- Oil and air filter?
- Wanted
- '97 Engine Surges
- 94 automatic poor acceleration
- Tach and Dwell Meter
- Tachometer
- parts for metros
- lost two lower speeds on heater fan,
- Adding air conditioning refrigerant
- metro mpg
- '95 Metro - The cure for burnt valves is...
- Geo Metro Radio
- audio comp car....
- used engine problems
- recieved used engine
- My geo will not start
- Oil Consumption ?
- only 18 mpg
- Metro Mod
- Throttle body w/ Manifold for SALE
- interior lights
- Tapping Hydraulic Valves
- headlight wiring
- Question About A/c
- 93 Metro, not getting gas
- '93 Convert A/C from R-12 to R-134a
- No Power - Sluggish!
- Please help *IAT location*
- Is it really the clutch?
- What's the best year metro to buy?
- Transmission Question
- suzuki swift web pages.....
- should i replace belt before i put used engine in
- question with headlights
- 1996 Geo Metro 1.0 only firing on 2 cylinders
- metro will not start
- 97 metro died
- NO Dash Lights?
- Low Idle
- Metro 3 Cyl Firing Order
- anyone need a map sensor
- Metro rear disk brake conversion possible?
- 1992 metro parts for sale
- 98 chevy Metro (what rims?)
- 97 METRO for sale
- Project Metro Vert II Arrived!
- 1994 Geo Metro
- Idenity of button behind shift???
- How to Loose bolt in end of crank.
- 97 Geo Metro Service Engine Soon
- 90 metro DIed on the road, see what I've tried I DESP need Help
- replacing CV axle shafts
- drive line vibration
- Rattle from under the car durring shifts
- LUGNUTS!?! and turbo questions
- No spark
- going to buy one, maybe
- Changing oil
- Used head and cover
- TB w/ Manifold for sale
- Trying to air up tires on Geo Metro
- 96 Metro headlight problem
- 96 1.3 liter metro problem
- My own project vehicle
- metro performance......
- Need help. 91 Metro
- Used Radiator w/ fan
- Hello
- front disc rotor replacement
- Radiator for sale
- Fan Blower switch broke - replacement?
- 94 Metro died and wont start
- Need ECM for 95 Metro 3cyl
- 1.3 liter engine troubles...
- Wanted: Geo Metro convertible
- A/C Vacuum Solenoid Valve - 1993
- Guidance Needed!
