Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Geo
> Metro |
View Full Version :
Metro
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
WTB: winter car
mmm.. Fresh Stories...
About gas type
Pulled Engine for Chk UP, Now tranny doesn't work.
turbonator ???
Volts of the alternator
'94 Metro headlights
high idle, please share your knowledge!!!
Has my engine exploded?!
changing a starter?
plug wires.....wow!
BAD Oil Leak...already changed crank seal...HELP!
91 XFI motor swap
Motor Swap
geo metro head gasket replacement question
Metro will crank but not turn over. (changed fuel pump and fuel filter)
cold weather problem!! Help please
Need help bad!!! failed emmisions
geo metro transmission interchange
replacement carb
Poor Gas Mileage
Mileage / Timing
Looking to buy a '94...have a question.
WTB 1.3sohc for 95 metro
Electric problems on my Geo
92 Geo Metro @ 1.0L A/Trans
Cheap used motor - no junkyard close has one!
96 FI Metro Running Lean
???90 Geo Metro 2DR HB Bodykits???
Replacing 95 Metro Computer
rear wheel bearings
Frozen Throttle
Help with Metro and saying Hello!
1994 geo metro has a noise during deceleration
1994 Geo Metro
95 Geo doesn't like the rain...
Need help 97 Metro problem...
blower motor switch help
90 geo metro LSI for parts or sale
Need help ASAP
Does anybody got any ideas on this?
Help me save my baby blue!
94 Metro Auto Trans Problem
Muffler/Fuel Sending Unit
WTB: Geooooo
Owners Manual
91 Headlights..
Problems after changing plugs and wires
advice on new exhaust (1.0 L '97)
Lights Problem
Parts Car?
geo metro 91 info
Vote Today
Transmission Swap - What years can I use?
high miles
92 Metro Trans Problems?
Trailer Hitch
temp gauge not working...fan not kicking on
Bad catalytic converter?
oil leak?
96 metro no head lights
No idle and fuel blowing uot top of throttle body
code 41 fix
motor stall
power steering
easiest way to change engine in a 95
Radiator info?
MK2 (94) to MK3 (95)
A Few Questions
bad belt slip/squeel problem.
gas mileage
94 metro lack of power
Life Altering Descision
Metro fuel pump inertia switch location?
96 metro 1.3
squeeling
1.0 to1.3 Swap?
91 Firefly Charging problem..
daily driver mods
lancer oz wheels?
96 metro - Am I the only clutch abuser?
rust
Geo Metro replacement?
code 12 geo metro ?
hopeless?
can you diagnos this one
geo metro 1994
Need help running down a short
Metro Muffler (attn: Geozukigti)
DIY Air Intake mod
Rear disc brakes for my metro.
1991 geo metro 1.0l
1 dead metro
1994 Metro LSi Bad Milege/performance
Geo Metro AT rebuild
Metro LSI Blowing Fuse
Best way to Pull Motor?
'92 Metro pinging...
-------------Suzuki Swift GTi--------------
94 Metro Failed Emissions "Pressure Test"
Need vents for 95 Metro
want to build a 96 Metro sleeper...
oil sending unit
Beware / Danger / Of Faulty Hood Latch Causing Major Damage
Anybody have instructions on changing timing belt?
A/T vs 5 spd
Idle RPM too high
bad noise
Unusual electrical problem / no spark / no gas
High performance Geo?
any other active metro forums?
need some advice
cv joint
Diagnostics Connector
Siezed Calipers - Can they be unseized?
Needed: Source for 1995 Geo Metro Window Regulators
no heat just cold air
Carbon buildup again in EGR passages - '93
Project car please help me
97 LSi exhaust question
95 geo metro - didn't pass smog
Newbie with Problems
Import used engine or rebuild?
Weird smell when driving
high output alternator
What year is my new motor?
Ends Tonight... Parts 92 Metro
One picky question in here
96 metro seting the tps
96 metro air flow meter???
Geo Metro Xfi 1994
92 w/burned valve?
96 geo metro
Geo Metro video - 9.46@142.5mph
1994 geo engine and tranny swap
broken harmonic balancer 96 4-cyl
96 Metro hard cold start
96 metro nothing fix it
Dies at Stop Sign
Fuel pressure
timming problem
1991 backfiring
efe connector....
My '93 is making a bad bad sound
a heat stressed part?
Does the 1 liter 3 Cylinder need backpressure to run?
Metro GTA 1995
91 metro coil probs
Dead Cylinder
1998 chevy metro transmission noise
metro please HELP!!!!!!!!!!!!
93 Geo Metro
wont accelarate pleeeeasseeee help
1997 geo metro running problems
convertible frame parts 91 GEO
No heat from vents only cold... help!!
Parts
92 Metro parts for sale
Need info on metro convertible boot
Fuel pressure regulator-$20???
1995 Does Not Start
Drivers side rearview for a 97?
95 Geo Metro 4 cyl TBI trouble
99 geo metro 2nd gear shift problem
97 Metro Starts only when it wants to
Surge Update #2
Code 51
Replaced both control arms - '93 Metro
car not starting tac tac tac sound
Fan not working???
Still getting hot?
wierd idle problem
97 Metro question
new metro owner questions
99 GM:Hard shift tran becomes soft?
93 Metro weird things
exhaust leak
geo metro any good?
New Member
Ok, time for you guys to give me a hand
94 Geo Metro - Fan doesn't blow
1997 Geo Metro LSi 4 cyl auto
G13k engine swap
94 Metro can't read codes. need help
fuel filter?
Parting out 1992 Metro
About air filter conversion
'91 - Fuel Injector won't work.
Want to tune up my Metro
engine swap (my dream)
geo
sprint tranny question
poor acceleration
95 Metro pass mirror swap?
Geo genius' Please Help Died, wont start
tie rod help
Chevrolet Metro lsi 1.3L 2000
Geos are great
Catalytic Converter
anyone have radiator for sale?
Here is a good one about EGR valves **UPDATED 19/AUG/2004**
No Warning, died overnight
need a motor
92 Metro Ragtop Pass. Headlight
Help, need a convertable top frame !!!!!!
Need gear ratio information
Largest oil filter that will fit onto the 3 cylinder?
97 with quirky ?electrical? problems
Hey guys!
Pics of my Metro!
100 bucks for a motor
PICS of the GT convertible done!
please give ideas
Considering things...
Found a 90 Swift 1.3 for 200 bucks
lights
did any Metro/Firefly/Sprint/Swift have a rear wiper option?
Old Geo Engine
Valve Seals
changed mind again (keeping it) lol
I've given up!!!
94 Geo XFI Engine mild surging
Just did a compression test, results not good :(
no compression
'97 Crappy Acceleration
Procedure for setting timing?
code 51
surge update (not fixed)
Can't Get KeyLock Assy Off!!
EGR valve
93 Geo No Hood $500
99 metro pops out of 5th gear
5w-30 or 10w-30?
And another one bites the dust...
1995 Geo Metro Hood Change
Do I have a burnt valve?
Dieing heater fan… I think?
93 drinking oil
electrical problem
1998 METRO engine, tranny 4sale or may buy body
92 Metro auto trans shifts too early
Rear window defroster
Still NEED ECM (L2) for 93 metro!!!!!
Car Trouble Need Help Fast Plz
Thinking about buying a 93 Metro
Alternator making whisting - whirring noise!
Need Oil Pan
Geo Metro owners manual
New update *GT Convertible*
Web
AF
