View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15
  1. poor mileage
  2. 94 Geo Metro Valve Timing
  3. 91 metro engine replace?
  4. Engine Whine
  5. clutch pedal help
  6. noob Metro owner with a few questions
  7. Installaton of alternator belt - Help Please
  8. stilll wont run right(92 metro) 1.0 motor
  9. car wont start after using carburetor cleaner...plz help!!!
  10. cruise control 95 metro
  11. I Need To Know What Size Bolts Go In My Motor Mount.
  12. turbo question?
  13. timing a 1.0 geo?
  14. wont start again?
  15. Good compression, but still burning oil. Help!
  16. antenna?
  17. motor running but have some ???s
  18. Geo Metro Upgrades
  19. HELP!! Fuel Pump not working?!
  20. geo metro 95
  21. radio antenna
  22. removing alternator
  23. HELP:rear main seal
  24. Metro bodies in Illinois
  25. What size is it?
  26. timing
  27. Engine compression test
  28. Key stuck in ignition - '95 Metro
  29. Driver's window off track - 95 Metro 3-door
  30. I am an idiot!!
  31. Need a timing belt cover
  32. Motor swap issues
  33. what do you think?
  34. timing belt
  35. 92 Metro key broken off in ignition
  36. rpm question
  37. Trick to stabbing the engine?!
  38. idle rough
  39. Just bought a '94 Metro
  40. pcv valve trouble..at wits end
  41. The DREADED clutch slip!!!
  42. Fuel Atomizer 2000
  43. No spark
  44. 95 1.3 check engine light
  45. Coolant temperature switch connector removal
  46. Over Heating
  47. need help
  48. 3 cylinder head help
  49. Occasional Mystery Smokescreen
  50. Auto transmission slow to engage
  51. Idle begins to race very high after I start
  52. brakes
  53. Transmission help
  54. 92 geo metro - alt or battery???
  55. tune ups/coil/stuff
  56. Auto to manual conversion
  57. A tool/toy to improve everything running wise 96+ Geo's
  58. Metro Engine Problem
  59. I need an information about 3 cylinders suzuki
  60. 5 spd transmission
  61. Help!
  62. Cng Metro?
  63. Easy 5 speed question
  64. Car wont start
  65. Anyone ever run their geo on an alternative fuel?
  66. GTi Engine
  67. Automatic Overdrive
  68. 1991 Engine Noise
  69. 1995 Geo Metro - Engine Oil
  70. Head Gasket Price
  71. Timing Belt Leaking
  72. 97 Geo Metro 1.3L Engine Problem
  73. Steering control box
  74. need brakes in front
  75. F1 Fuse keeps blowing Advice Needed
  76. final drive ratios
  77. Rear side window seal
  78. Odd radio question
  79. ERG valve
  80. Washer fluid pump
  81. Hatchback release lever and cable
  82. a few questions
  83. Stupid headlight question.
  84. 95 Metro questions
  85. Surprised!#!
  86. 2000 metro timing belt problem
  87. metro wont start backfire through throttle body
  88. line blows off ,runs poorly
  89. Need help on combo headlight switch wiring
  90. 96 1.0L Where's the fuel filter?
  91. Possible Engine Swaps?
  92. cv joints
  93. Metro Running Again
  94. piston rings
  95. Overheating
  96. Steering wheel and airbag removal question.
  97. WANTED:: Geo Metro LSI Convertible top boot cover BLACK
  98. 96 1.0L Timing belt looking for instructions
  99. making tubular headers for my metro
  100. compression
  101. how reliable are Geos?
  102. Checking for codes
  103. sounds like an 18 wheeler
  104. 92 XFI For Sale $450
  105. geo 1992
  106. 93 geo metro won't start
  107. Metro will lurch, lope, surge, cutout on driving
  108. Need parts...
  109. 95 Metro very hard to start, squealing noise until warmed up...
  110. Surging & missing fixed
  111. 97 metro running rough
  112. How do you check the transmission fluid level and what kind of fluid does it take?
  113. new motor change wiring problems
  114. Water leakage at pipe going to water pump
  115. Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!!
  116. my 91 metro won't start...help!
  117. Got it!!
  118. Code P0400
  119. pooor gas mileage
  120. 97 geo metro distributor
  121. WTB Geo Metro convertible
  122. quits at normal operating temperture
  123. Error code 14
  124. Cannot get engine up to temperature
  125. Regular Beam lights won't come on 2000 metro.
  126. O2 Sensor seized in manifold....HELP
  127. insulation
  128. 97 Metro Heater Fan Prob Solved.....
  129. Another way.....
  130. intractable mystery solved 96 metro
  131. Turn the key forward and nothing! Electrical gurus please help
  132. Was a CD an option?
  133. brake rotor removal
  134. Heater Fan Only works slow on 3rd Position..97 Metro
  135. Should I buy?
  136. Anyone got a Transmission Pump For 3cyl
  137. 92 Metro eating belts
  138. 2000 LSi blowing a fuse
  139. Engine Swapping
  140. Crank Pulley/Belt Cover-last things in my way to completion!!
  141. Wanna meet my metro?
  142. Transmission Fluid Change
  143. exhaust
  144. 97 Geo Metro Problem
  145. Timing Belt/Exhaust Manifold
  146. 95 metro starter/headlight problems
  147. Manage Your Heat!!!!!
  148. 96 Geo Metro, Whats wrong?
  149. Engine Teardown
  150. 92 auto trans slipping
  151. What options were available on a Metro?
  152. 96 geo 1.0
  153. Compression Test results
  154. At my wits end!!!
  155. tranny fluid on manual tranny
  156. Increase Performance AND Mileage!
  157. 99 Chevy Geo Bumper
  158. Almost ready to end crankshaft seal saga...
  159. 97 Geo Metro won't start
  160. New board
  161. NO START update....
  162. Merry Christmas!
  163. Phantom air leak
  164. Thrown Rod?
  165. Need A/C compressor
  166. HELP!!!-car won't start
  167. diffrent distrubutor
  168. Hope someone can help.
  169. How to replace woodruff key on crank?
  170. Selling Haynes and Popular Mechanics manuals
  171. alternator belt problems
  172. wipers wrong?
  173. Snow Driving
  174. code 31
  175. 92` Metro,cure for high idle,poor mileage
  176. P0113,P0400,'96 Metro
  177. vacuum help
  178. Heater won't heat
  179. Looking for 1996 neon gauges
  180. 93' metro died on hgwy
  181. 97 Geo Metro Lsi fuel injector problem
  182. 1995 1.3 L crankshaft pulley clearance
  183. Block oil port?
  184. Power Steering Pully
  185. Metro Hood?
  186. 96 to 95 engine swap?
  187. 92-94 radio bezel
  188. Metro Upgrades 1.0 3 cyl Standard
  189. fastest metro? who has it?
  190. oil cooler sandwich mount?
  191. Good radiator.
  192. anyone need tail lights?
  193. WTB: Timing gear for a 96 1.0 3 cyl
  194. Help a Newbie Please
  195. Think I ruined my engine (w/ pics)
  196. wheels and tires on 94 metro
  197. Alignment and New Tires (Issues)
  198. 93 e-brake
  199. Body water leak - drivers floor fills up
  200. manual transmission drain plug
  201. Intermittent reverse on geo metro
  202. Did I bend a valve?
  203. which clutch should i use?
  204. uses a little oil 89,000 miles worry?
  205. Hi-Low Rpm's?
  206. '92 Metro----Blower motor only works on top 2 speeds!
  207. need to carry a little more weight in back
  208. best spark plugs for 1.0
  209. changing clutch, how hard? 3-cyl metro
  210. metro looking for speed
  211. '92 - 5 spd problems
  212. f/s: GT bumpers/sideskirts/spoiler
  213. No manual. Need help to set clock.
  214. Automatic transmission noise
  215. creaking scary noise.
  216. timing of a 96 geo metro 1.0 liter
  217. Hesitation after idling in gear....HELP
  218. engine swap, not typical?
  219. cheap good wheels n tires, will they fit?
  220. outside door handle stopped working (metro hatch)
  221. green sensor on intake?
  222. Source vehicles for Metro
  223. Timing Gear won't come off
  224. what to check
  225. idle
  226. 29 miles per gallon on my 3 cylinder
  227. testing oil pressure?
  228. massive amounts of oil getting ran tbi unit
  229. Idle Recovery
  230. No power in my metro.......need help
  231. pipe,exhaust source?
  232. air valve on TBI 89 metro?
  233. How do you remove driveaxles?
  234. 95 5-speed troubles
  235. geo hubcaps
  236. Platinum Spark Plugs
  237. Just one more to go. Next Level Performance
  238. SpiralMax .. very interesting ..
  239. About lightcovers
  240. timing
  241. how much to change timing belt (3 cyl 1.0 L '97)
  242. front control arm/ water pump
  243. $70.00 Turbonator/ YES or NO?
  244. IAT Sensor 1 ?
  245. 1992 Metro throttle body
  246. Metro Steering!
  247. Geo metro 91 pdf repair manual
  248. 29.5 mpg / 3 cyl hatchback
  249. Ignition Switch
  250. 96 Geo AC has stopped working but everything else OK
