View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15
  1. Dash Vents
  2. temp gauge wacky
  3. stereo wiring for Geo Metro 1997
  4. I've been scarce lately...
  5. Problems With My Metro
  6. ground effects, body kits?
  7. 97 trans HELP!
  8. Egr and #3 here we go again
  9. Ohio snow killed the Metro
  10. Gave up the '96 Metro
  11. weatherstripping for a 91 convertible?
  12. Idle control solenoid
  13. 96 geo for sale
  14. Windshield Wiper Fluid Engages
  15. Empty Radiator Coolant Tank
  16. WTB: Keyset from 92-94 Automatic
  17. Convertible Top Frame
  18. Metro's rule !!!!!!!!
  19. haze on composite headlights???
  20. Convertible Top Help!!!
  21. check engine light on....
  22. timing problems 1990 metro ?
  23. Hesitation at High Speed 94 METRo PLEASE HELP
  24. Missing VECI lable 94 Metro
  25. 1997 Metro, Service engine light
  26. engine ping
  27. burned out ignition fuse
  28. 95 1.0 Fuel Pressure
  29. 92 Metro Ragtop Part Needed
  30. 93 geo metro crankshaft pulley
  31. Sign of the times!!
  32. 1990 geo metro tensioner plate
  33. 96 metro 4sale
  34. metro wont start
  35. 86 Sprint (Metro to be) starter won't engage
  36. 93 head rebuild?
  37. Can't get the key out.
  38. EGR coincidence ?
  39. Idle tip
  40. drivers side window 94 hb
  41. How hard is it....
  42. Throttle stop screw
  43. Tranny problem found (WOOHOO!!)
  44. Tranny problem found (WOOHOO!!)
  45. Water in oil
  46. What all years will this tach fit?
  47. Hi, I'm new to the forum and have a question.
  48. Aaaaarrrgggghhhhh!!!!!
  49. rotor speed ?
  50. 95 GEO wiring diagram found.
  51. lets see some smokey burn out pics
  52. Right Headlight Metro 96
  53. Help with Connector on firewall!
  54. Idle Drops Dramatically with AC
  55. '96 1.3 liter lifter noise
  56. geo parts cars
  57. speaker size?
  58. Poor idle
  59. rough throttle - JERKY GEO
  60. need wiring diagram
  61. Any suggestions welcome!!!
  62. FS: Ready Sleve for 3cyl
  63. Puzzling Power problem *not compression*
  64. FS: Suzuki Swift GTi Springs (stock lower springs)
  65. Need Help with My 1.0
  66. GM p/n for 89-94 Metro/Swift
  67. FOR SALE 95 Metro 3cyl 5spd
  68. Radiator Fan always running
  69. decals?
  70. Geo Metro Headlight Warning
  71. 1.0 heads needed...
  72. front hub removal
  73. Ever seen this b4 -- repairable??
  74. 1993 geo metro computer swap
  75. Praying to the Audiophile Gods
  76. Where do I buy new 12" tires?
  77. Anyone interested in a GT
  78. 99 North American Metro Body (bumper)
  79. 1995 Geo Metro TPS specs ?
  80. toneau cover
  81. metro convertible transmission
  82. Newbie needing parts
  83. need wiring diagram
  84. CV joint replacement on 96 1.0 Metro
  85. WTB: MK2 (89-91) Light Grey Dash in MINT Condition
  86. Testing the EGR Valve
  87. child lock inside doesn't open from outside
  88. How do I find GM part numbers?
  89. 95 Metro Carpet
  90. '94 2-door Metro driver side window regulator needed
  91. My Fuel Sensor is kinda whack...Can someone help me?
  92. Hi Everyone Im a Proud Owner of a GEO! And I love it!
  93. poor power on hill starts poor acceleration
  94. 1996 geo metro lsi trans seal
  95. need cheap parts for my geo metro
  96. Thermostat Question
  97. Oxygen sensor on 94 Metro
  98. need help with my 95 metro
  99. Timing and Custom Hood Scoop
  100. 94 geo metro engine id
  101. 93 Metro Front Brakes
  102. Throttlebody Gasket
  103. Help With Timing!!!!!
  104. Headlights on create drag on motor...
  105. 1996 Metro air bag light blinks then stays lit
  106. 1994 Trans. in a 1996 metro? Possible? Other problems too.
  107. Acceleration Hesitation
  108. some irony and a standing "o"
  109. 97 1.0L Head
  110. Source for underdrive pulleys?
  111. Where to buy window regulator for '96?
  112. A few questions about the GEO Metro.....
  113. Throttle body gasket question
  114. Timing Info Etc.
  115. changing the fuel pump?
  116. Sending Unit/Scan Tool Hookup
  117. 97 Metro
  118. 1994 Oxygen Sensor
  119. MPG Help!!
  120. Kill Story> Team Metro 1<> Team Coyote0
  121. Where Is The Gas Filter Located 05 3cyl Metro
  122. I give up! How do you get the gear shift knob off?
  123. loss of power after warm start
  124. 97 geo metro problems
  125. Good Deal?
  126. fuse pannel
  127. Audio Systems
  128. backfires thru throttle body
  129. Wanted: Geo Metro XFI
  130. loss of power
  131. Suspension swaps
  132. Engine Missing or Surging at Higher Speeds
  133. 94 Metro problems (codes 13 and 51)
  134. Taking the Muffler out in CA of a 94 3banger
  135. My friend can't get his 3 cylinder to run right no matter what he does.
  136. Transmission interchange...what years are interchangable?
  137. need diagram in hurry....
  138. help
  139. '92 Metro with 14 inch wheels...read if you are considering this..
  140. Headlight upgrades??
  141. Rack and pinion problems
  142. 92 Metro Conv. Code 23
  143. timeing
  144. F/S: Metro w/GT swap(not mine)
  145. Headlights wont shut off
  146. motor knocks - rebuild or new?
  147. Fogging
  148. suzuki swift GTI
  149. metro keeps squealing
  150. A good one about head swap
  151. What mpg are you actually getting?
  152. standard or upgraded emissions
  153. '94 Metro code 15: coolant temp
  154. How much is a 2000 Geo Metro worth???
  155. Help with Trouble Codes!!!
  156. crashed the metro
  157. the need for speed
  158. Free parts. Come and get them.
  159. 96 geo metro
  160. 93 metro poor gas milage
  161. 94 metro
  162. What Type of Mtl
  163. Radiator starting to leak - '93
  164. Need REPAIR MANUAL for Geo Metro LSI
  165. 92 GEO Metro-1 99 Mustang Gt-0
  166. Radiator from a stanard & use in a automatic?
  167. NEED Owner's manual for 96 Geo Metro LSI
  168. Headlights quit working (Fuse Blows Always)
  169. Metro Ragtop
  170. 95 metro head bolts
  171. Rca Jacks
  172. 94 Metro Lug Pattern
  173. headlights??
  174. Custom Headers request info
  175. Tachometer Question
  176. Surging and loss of acceleration on '92 Metro
  177. high HCs on emmissions test
  178. starters
  179. I want suzuki swift G13b engine
  180. engine wont ignite?
  181. faulty interior fan speed control
  182. wing nut for airfilter casing
  183. '91 Geo Metro wont' start if engine is hot?
  184. metro engine install and surge fix
  185. Has anyone used one of them Turbonators???
  186. suggestions for seat replacement
  187. Instrument Panel Cover
  188. Check Engine flashes once, then twice??
  189. 93 engine swap
  190. I need a Top. '92 LSI
  191. 92 Metro engine missing?
  192. 95 1.3 no power
  193. dash still not working...
  194. Alternator 94 metro replaced 3 times
  195. drive belt questions
  196. I am thinking of selling my 95 Metro
  197. '94 Metro Still Overheating!!!!
  198. No ignition buzz when key is turned, wont start
  199. manual trans dip stick on 96 1.0???
  200. For sale:91 metro
  201. runs,losespower at3/4 pedal down idle is all over the place
  202. steering
  203. Metro Motor Lifespan
  204. cannister
  205. Codes
  206. Pimped my ride
  207. Auto Transmission help please!
  208. 97 Tranny in a 95 Geo Plz HELP!!
  209. '00 1.3 burning oil.
  210. crank / gear problem
  211. WTB radio for 95 metro
  212. Spash Shield
  213. leaking and i dont know where....
  214. checked the fuses....
  215. '94 Timing Belt
  216. 2001 Metro DUAL-COIL, NO-SPARK
  217. okay got the code....
  218. Probably a Fuel issue...
  219. Steering Wheel Adaptor Kits??
  220. Which is faster?
  221. Urgent! Dirty Metro Transmissions (literally)
  222. Air Filter
  223. Headlights
  224. Cruise control for 96 Metro Manual
  225. VERY Interesting...Please read
  226. Water Pump
  227. My metro beat up a Honda Odyssey!
  228. few more ?s afte r motor change
  229. 95 metro code 31
  230. 90 Metro Air/idle up valve Question
  231. I just have to do this !
  232. EGR trouble...still
  233. Trade my Mazda Turbo for your 4dr.
  234. engine swap from 89 suzuki swift to metro
  235. how do i find check engine codes?
  236. Struts
  237. OK what's the trick to yanking off the transaxle case?
  238. Fuel Gauge/Hesitation
  239. looking for a eng for my geo
  240. Code 23, On 1990 Lsi Metro 1.0 Ltr
  241. 350 in a metro?????
  242. engine swaps on a automatic geo metro hb??
  243. my metro is weak on power
  244. poor mileage
  245. 94 Geo Metro Valve Timing
  246. 91 metro engine replace?
  247. Engine Whine
  248. clutch pedal help
  249. noob Metro owner with a few questions
  250. Installaton of alternator belt - Help Please
