View Full Version : Metro
Pages :
1 2 3 4 5 6 7 8 9 [ 10]
11 12 13 14 15
- I need a Geo Metro but I don't need the engine
- What i've been up to.
- 95 Metro, Need I say more!!!
- battery backwards
- Destroyed radio antenna
- cig lighter and radio
- 98 chevy metro- no spark whats the problem?
- Water on passenger floor
- Geo Metro Roof Rack!!!
- 1996 Geo metro distribitor
- Geo 1.0L Vibration is kicken my BUTT
- Roof Rack for my Metro...
- I need to know!!
- This one is a tuff one to solve, PLZ help!
- Steering Problems/Wheel Tugging
- manual transmission plug problem
- 90 Metro 1.0
- wheres the paint color code
- Metro steering wheel
- Are metro clutches hard to fix?
- Thinking about buying a Geo Metro. Couple questions and are these good prices?
- Crankshaft Pulley Bolt TOOOO TIGHT
- 1995 Geo Metro Idle speed
- Do it yourself brakes
- 98 Metro Will Not Fire.
- Engine Change Options...
- SCARY Car Problem (not Metro related)
- Engine Internals! Where to buy?
- Timing / idle irregularities
- engine dies and won't restart
- Parting out. 89 GTi automatic
- transaxle
- Would you prefer a 5 speed manual or an automatic?
- naughty automatic transmission
- Timing Belt walking off
- '95 3 Cyl Man 1.0L 25 lbs of compression loss in cylinder!
- timing belt installation w/o marking
- Convertible Frame
- Electrical Problem
- Key broke off in a 92 Metro
- Mechanical engine noise - 3 cyl 1.0 L. ?
- swap 4 cyl to 3 cyl is it possible 1997
- Alternator belt tension
- Fuel pump info
- Ordering a JDM
- Noise Diagnosis
- Coil Spring Ratings
- new engine?
- Need Help identifying part
- JDM help
- '95 Metro OBD-II
- Can a Geo Metro with 12 inch tires use 13 inchers?
- The Problem buying 12 inch tires for Geos !
- First post -- first Geo
- Pulley pulling problems!
- 1996 Metro CV replacement.
- sry
- Need some advice
- ugliest frikin cars ever!
- got some major probs with my 96 metro
- 1998 Geo needs motor!!!
- CV Shafts - What years will fit?
- HELP !! CHEAP CRankshaft for metro 2000
- 1996 geo metro//should I keep it???
- 1993 Metro 1.0L BlowBy
- 2000 1.0 wont turn over at all..
- evaporator ac 1996 geo metro 1.3
- replacing the dimmer switch
- Metro 3 cyl thermostat temp
- Is there a SMALL, CHEAP Tachometer for a 3 cyl Geo?
- 2000 Chevy Metro
- How to get rotor off? Hub retaining screw stripped
- 1.0L JDM engine
- AC parts for sale
- Geo jumped time
- gremlins in my geo!
- Water warping rotor? EGR question too...
- 94 help!
- 92 Metro Ragtop-Parts
- 89--sprint 3-cly carb engine-need help
- cuts out @ full throttle
- Paint removal
- 1.0L 5spd 38 mpg w/o AC -- SO WEAK IT'S DANGEROUS TO DRIVE ON HIGHWWAY
- maximum driver height
- Running Rich Injector
- you don't know 91 geo metro( i need help)
- Valve Lash Adjustment on 1.3L engine
- 95 1.3 engine parts for sale
- Does a '93 have a Fuel Filter ?
- PCM location???error code 42
- 96 geo metro passenger mirror
- Mechanic running me crazy
- Does anybody know what this car may be worth ?
- where to find head bolts?
- 1989 2door dodge shadow
- 1997 Geo Metro LSI needs home
- Fuel Tank Capacity
- Cam gear marks alignment
- New Exhaust System?
- 2000 metro wont start
- Replaced 1.0 head- Can't get it started
- 98 Chevy Metro Heat Fan Switch Control
- 98 Metro Auto Transmission Problem
- 97 Geo Metro Stalls
- Metro Wanted to Buy
- In the middle of swapping engines
- Ragtop Repair
- replacing timing belt
- 1.0 hp specs
- Looking to purchase a 1990 LSi Metro Conv
- Burnt exhaust valve...again
- Gas Light
- 93 metro for sale to good home.
- Need a transmission
- 93 geo metro wont start
- Loss of power/backfiring under load
- AC System Removal question
- How to Change the Fuel Filter?
- 86' Tempo for SALE
- engine swapping
- Another 5 speed tranny
- How to time a 1997 Geo Metro
- 5- speed tranny
- 1993 metro antenna
- Rough idle with air on, dies when coming to a stop
- A/C Compressor Seal
- Left front click with Vehicle Speed
- Center console from another car?
- new to metro lsi
- A/C wiring schematic??
- 95 Geo Metro Engine Change
- Aftermarket radio antenna 91 Metro
- EGR CLeaning
- 97 Geo Wont start!!!!
- Broken Convertible Top (Header)
- Engine swap
- Question regarding Dodge Shadow (lol)
- geo metro moter swap
- 3800 Supercharged engine swap...
- O2 sensor and brakes
- Automatic Door Locking
- storm and metro blocks?
- Ac Removal/Horsepower Increase
- Rear disc brakes
- Self-esteem boost for us geo guys, lol
- radiator upgrade?
- MAP sensor for 91 Geo Metro 3 cylinder
- Electronic Turbo???
- Radio Removal/CD player installation
- 1997 Geo Metro Headlights
- JDM Motor swap/no power
- Oh yea, you're jealous :-P
- 91 Geo for sale in Vegas
- No Power in a 95 1.3
- how much tranny fluid???
- brake rotor removal
- Cranking Problems
- A/C Unit for a 93 Metro
- fuse map
- JDM engine replacement. Done!
- It's 110 degrees outside..........
- Window Problem
- Any oil pump tips?
- why the hell is this happening!!!!!!!!!!!!!!!!!!!!!
- Tapping Solenoid Starts Car
- Hollowing out the catalytic converter.
- geo metro steering knuckle removle..
- Whats the average gas millage?
- Click at relay box, NOT starter
- A/C compressor noise
- Intermitent Start Problem
- how much hp?
- 91 Geo Metro Valves Replacement
- 91 geo metero crankshaft removal
- 2000 Metro Stock Stereo Removal
- tires for 96 metro
- Radiator Bolts
- automatic/manual
- good news bad news engine compression test
- Fuel Tank Baffolding??? Something Else???
- need for the plastic around CD player and lighter
- 94 Metro PCV location
- Disappearing Oil
- Tps
- Parts for sale
- How to disconnect auto door locks?
- I may have a Geo for sale
- Inop A/c
- 96 Geo Prizm Squeaking Problem/Steering Pump Problem?...Cant Figure Out what it is?
- '93 Geo Metro 1 Lt 3 cylinder MOTORCYCLE Engine?
- Geo transmission
- Poll - What is your Metro's Gas Mileage?
- i want/need a geo
- 93 Metro rally car
- Where to get window seals & Weatherstripping??
- Tps
- 5 speed popping out of gear
- metro fuel problem female needs help.
- 1993 Geo Metro head gasket
- Can't find the daignostic fuse receptacle to check my check engine codes
- 97 Metro LSI Hatch Dies?
- Looking for Parts... and info
- Type of Oil?
- body parts?
- metro/swift valve cover needed
- Beeper inside when ignition turned off !
- Anyone who knows timing belts replacement?
- Is the Suzuki 1.0 L engine an oil user?
- Geo Metro 96 Auto Trans check engine light on
- Metro - Hatchback, LSi and the XSi - ?????
- Remove/Replace Radio- 1994 Metro
- still looking for 3 cyl performance parts
- Spark Plugs???
- Tire Pressure versus Miles per Gallon ??
- Are Geo Metro Automatic Transmissions any good?
- coolant flow through TB on 1994 Geo Metro?
- 99 Fuel Filter, HELP!!!
- water
- interior exhaust smell?
- Fuel Injectors?
- 91 Rotor change ( FUN! times)
- Could this be a fuel pressure problem?
- Geo Mechanic?
- Problems starting my 92 Metro ...
- 2000 chevy metro, no start, need help
- Downshifts into 2nd at 50mph.
- Does anyone have a Jensen CD615x CD Player in a GeoMetro?
- Summer is coming are you ready to stop your Metro from getting too HOT?????
- Any other good forums?
- Dashboard
- 89 metro timing belt
- '90 - '96 Metro Wanted Spokane, WA
- Coolant Vanishing Mystery
- Window Regulator - Drivers side
- Timing belt - scraping noise?
- Obd
- 95 Metro Dim Headlight
- need sterio codes for 95 geo metro HELP???
- dashboard and headlights sun damage
- Metro 5.5" Brake Booster Question
- problem with brakes on Geo Metro 97
- 94 metro buy back from insurance
- FYI: Code 51 on 95 Metro
- radio backlight not working?
- I'm looking for info.. on performance mods
- SUDDEN no start..
- 96 metro fuel capacity? rear deck?
- ** Metro Forum Intro **
- 92 Suzuki Swift Headlight problem
