View Full Version : Sonoma/S-15
Pages : 1 [2] 3
  1. 1996 sonoma 2x4 lift kit
  2. K&N Help
  3. 1994 Sonoma Stereo Install
  4. adjust seats to my 1992 sonoma
  5. weird noises
  6. sticking rear brakes
  7. '94 Sonoma SLS 4WD Problems
  8. magnetic fuel saver
  9. Door Adjustment
  10. Read First - FAQ & how to thread!!
  11. K&N filter
  12. 99 heater control problem
  13. CPI Fuel Pressure regulator
  14. 02 Sonoma service engine soon lite
  15. transmission problems
  16. Front driveline Intermittant grinding/gear clash 4x4 01 ZR-2
  17. Front End Parts (what r they called)
  18. Horsepower
  19. Intermittent jerking in acceleration
  20. Advertising Mistake?
  21. won't even begin to start
  22. vibration from driveshaft on 96 sonoma 2WD
  23. Fuse #9 keeps blowing
  24. Heater intermittent
  25. Help battery problem!!!
  26. 2003 sonoma wouldn't go into 4hi or 4lo
  27. removing factory radio help
  28. 1996 Sonoma fuse panel
  29. Front End Assembly Swap
  30. Air pump problems!
  31. vaf
  32. 98 Sonoma demon-possessed guages
  33. 2002, Sonoma, 4WD, Auto, Bad Noise when cruising
  34. 1994 Sonoma 4WD Stuck in 4Lo Need Help Question on Front Drive Shaft & Encoder Motor
  35. Need help Finishing disaster, putting parts back, after oilpump, rear seal replacemen
  36. Headlight/Buzzer Problem
  37. fuel gauge
  38. '94 cutting out under load
  39. 80,000 miles on my sonoma
  40. 2001 GMC heater core removal, DONE!
  41. 2001 sanoma V6 heater core removal
  42. HELP!!!!!Lower Ball Joint Removal on 94 Sonoma 2WD
  43. 99 2.2l Problem
  44. 98 sonoma 02 sen.
  45. lining up transmission on 98 sonoma
  46. lining up transmission on 98 sonoma
  47. Door pin and bushing repair How-To!
  48. sonoma shifting question
  49. The elusive door sping tool
  50. Replacing trans myself?
  51. 98 Sonoma 4 cyl plugs and wires
  52. Serpentine - replacement costs
  53. no cold starting '00 sonoma
  54. cel light comes on
  55. Websites for sonoma parts performance
  56. 2001 sonoma max wheel size
  57. 4x4 Problem
  58. Help!!!
  59. gauges and lights going crazy then dies
  60. transmission
  61. 2.2l Need MORE POWER.
  62. Console?
  63. Tail Gate Cable
  64. 93 Sonoma 4.3 vortec, more power?
  65. 95 Sonoma Automatic Transmission
  66. sonoma gt.....starting hard
  67. 'Bubbling' sound when cold
  68. 94 gmc 4.3 hard start and engine surge
  69. Stereo install help
  70. MAF sensor & wiper delay circuit board location
  71. Help Truck Died!!!!
  72. 1993 GMC Sonoma 4X4 - Stuck in first gear!
  73. Heater doesn't work. 2000 GMC sonoma
  74. 1996 Sonoma
  75. 92 Somona 4.3 Liter
  76. Gas In Oil
  77. Horn Location on 98 2.2
  78. 98 manual transmission/no reverse
  79. Grinding Noise first gear
  80. widest tire size 1999 Sonoma
  81. OBD II Code PO410
  82. engine swap
  83. Moderator Suggestions
  84. 95 Sonoma lower ball joint
  85. Slow, sluggish, what should I change first
  86. 1994 Sonoma 2.2L Low power.....
  87. 2.2 EGR location ( I have searched with no luck)
  88. check engine light comes on at at around 45mph
  89. Sonoma 350 Swap... Need info
  90. 1999 Sonoma SLS
  91. tranny sounds at 60mph HELP!!!!
  92. Slave Cylinder????
  93. Transmission problem with reverse
  94. Squeel in front end when slowly turning
  95. Rear Rotors
  96. Truck Not Running Right? Hard On Fuel And Sluggish Power? Try These First.....
  97. any probs with rearend noise? 4.10 locker 2.2 2wd
  98. Getting 16mpg
  99. 1996 auto trans pushing fluid out dipstick
  100. Power brake booster on 1999 GMC Sonoma
  101. 1995 Gmc Sonoma Help
  102. Bed Rail Length???
  103. How much oil do you add when you change your oil and filter?
  104. 1999 Sonoma Starting issue
  105. Pics of my Sonoma
  106. Possible short causing batt drain?
  107. 2.2L HP Tuners- read
  108. Starting Problems
  109. Will these Euros work?
  110. '91 Sonoma Key won't turn all the way in ignition
  111. upper, lower bumper, grill, LH & RH fender.....
  112. 1998 2.2 2wd muffler ?
  113. 2001 sonoma 2.2l flex air pump malfunction symptoms
  114. Oil Leak at bottom of engine
  115. clutch seems to make starting intermittent
  116. Newbie
  117. Cooling Fan cover
  118. Tranny Problem
  119. 98 Gmc Sonoma Intermittent Starting Issue
  120. petcock on 200 sonoma 2.2
  121. clutch adjustment
  122. Recordable carchip?
  123. MFI Asssembly conversion
  124. engine swap ??s
  125. Apple ipod to factory stereo!
  126. Factory Stereo... RCA output???
  127. smog pump
  128. brake lights and signal lights????
  129. code for stereo theftlock
  130. no start
  131. 1998 Sonoma
  132. rear view mirror reattachment
  133. Overheating??
  134. factrory wiring? is it all there?
  135. suspension conversion??
  136. ac relay switch
  137. help on a tach
  138. help...98 sonoma 2.2 starter removal
  139. transmission
  140. Service engine soon light???
  141. 96 sonoma will not start or dies on me at random!
  142. chirping
  143. brake problem, pls help
  144. HELP..Can't get cooling fan off pump
  145. 92 gmc sonoma brake light problem
  146. interchangeable transmissions
  147. **Transmission Codes - What They Mean and What Happens**
  148. popping nose when turn
  149. How to check feron(R134a) level?
  150. DEX-COOL Engine Coolant Information
  151. 92 Sonoma Brake Fluid Leak
  152. 92 Sonoma Smog Pump Replacement
  153. 92 Sonoma Electric Window Fix
  154. daylight lights not working
  155. 2.2L 99 Sonoma stalling at low speeds/stops
  156. thermostat location on V6
  157. Door Wiring problem
  158. New Member information
  159. Noisy Lifters.
  160. Surging @ no load conditions...
  161. Leaf Spring Lift Question
  162. A/C clutch rattles
  163. AHH help me !!! clicking at startup.. wont turn over
  164. Cylender Heads for V6
  165. Brakes sqealing while going down road
  166. Engine noise after warm up
  167. exhaust pipe 2.5" to 3.5"
  168. 92 brake warning light on
  169. Coolant change?
  170. 2001 4WD tranny problem now....
  171. GMC Problem please Help
  172. Exhaust Question
  173. Help on '98 Sonoma door wiring...
  174. LED and Neon wiring ?s
  175. 2.2 sonoma will cutout when i accelerate! HELP
  176. Replacing The computer on my 2.2 sonoma/s-10
  177. generator lamp L
  178. Sonoma 2001 gas mileage
  179. Fast Idle
  180. Crazy oil leak.....
  181. A/C problem, help pls
  182. 99 sonoma torq converter lock up /O.D. ?
  183. Self Tune Up
  184. Warning lights troubles
  185. Multi Fuction Switch replacement
  186. 91 sonoma looking for a new tailgate
  187. what else for my engine?
  188. Timing 2.2L
  189. Engine help!!!!
  190. rough engine
  191. Missing fuses?
  192. 96 Sonoma Fuel Pump mystery
  193. «Hiss» coming from the gaz tank
  194. Rims
  195. 2002 electrical problem
  196. 2000 sonoma flex fuel won't start
  197. Bad Aftermarket Ball Joints
  198. sonoma engine help
  199. rough idle
  200. flushing coolant
  201. 01 Sonoma low oil pressure at idle and service engine soon light
  202. tach
  203. popping noise when turn
  204. 4X4 problems... all the usual fixes arent working
  205. 2001 factory alarm: going off by itself
  206. what shocks for 98'?
  207. What else should i change?
  208. 98 sonoma idling problem
  209. Factory Xtreme body parts. Where to get them?
  210. Question about flushing break fluid
  211. '94 Sonoma rebuild differential estimate?
  212. Surging Sonoma 4.3
  213. 4X4 problem
  214. Tail light help
  215. Sonoma Recall-lower balljoint anyonw know?
  216. Fuel Filter fuel line
  217. high idle
  218. jerking at low RPM
  219. high idle
  220. For Sale: Air conditioning knobs
  221. 2000 sonoma quit while driving it, and won't start
  222. stalling and bad idle
  223. 1999 Sonoma Wiper Problem
  224. Fuel Line Nut Kit
  225. My 4x4 comes and goes PLEASE HELP!!!!
  226. 4 Wheel drive not working....
  227. non-injecting injectors
  228. 96 4.3 Coolant leak
  229. clutch problem
  230. Search Before You Ask Questions!
  231. bumper conversion
  232. Stereo system for 2000 extended cab Sonoma?
  233. 99 Sonoma - Engine dies after 1 second (alarm??)
  234. Tires For A 96 Sonoma
  235. Lift-kit
  236. manual 2000 GMC Sonoma "chuggs" in rainy/foggy weather after warm up its fine
  237. Under Hood Wiring Harnes Diagram For A 93 Sonoma Vortec Engine
  238. 2000 Sonoma door speakers...
  239. 84 Indy 500 Official Truck
  240. Closed Loop Help
  241. 4x4 stuck
  242. Weird Engine noise during cold months
  243. no floorboard heat, feet are freezing!!!
  244. needing power
  245. Anti Freeze Leak
  246. 2.2 freeze plug locations
  247. 1998 Sonoma No Electrical at all...
  248. 2000 Transmission Problems
  249. sonoma loading up
  250. 1998 Surges
