View Full Version : Jimmy
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11
- 2000 GMC Jimmy-A/C, Heat and Defrost don't work!!!
- Pop or Klunk
- 95 GMC Jimmy hesitation, fuel gage jumping
- Serious Oil Leak! Need Help!
- 93 Fan control switch
- Torsion bar?????
- 94 jimmy sudden death cyndrom
- 94 Jimmy GMC suddenly dies
- Door pin
- What's the differance?
- Low Engine Temp
- Jimmy Digital Dash
- I don't have any idea...Idle/Park
- Fuel Pump Regulator
- Fuel pump wiring harness
- Shifter does not work
- 2000 GMC Sierra Tranny Problem
- '95 Jimmy heater smell
- 97 Jimmy front suspension
- Fuel Level Sending Unit
- cold start engine tick
- Jimmys problems..........
- 1992 is making a really bad sound...But runs great!
- A couple questions: Fuel and Oil Pressure
- 2000 jimmy no heat
- 4 wheel drive problem Jimmy 1995
- 91 Jimmy problems
- 1998 Climate Control - LEDs
- 2001 Jimmy heater problems
- 95 jimmy nut kit installation
- 98 jimmy gas guage doesn't work...follow up
- Coolant Temp Sensor for gauge
- 94 Jimmy 4.3 W coolant flow path?
- 1996 jimmy heater housing falling apart
- waterpump fastener sealant (white)
- rear window washer path
- 2001 Gmc Jimmy
- fuel system
- 93 Jimmy steering lockplate removal?
- Thermostat orientation???
- heater problem?
- 95 Jimmy,An OBD I or OBD II??
- 96 Jimmy Tranny and Courtesy Lights
- Oil cooler line replacement
- Heater problems 2001 Jimmy
- 1997 Dies while driving for no reason ???
- Oil cooler lines
- 95 Jimmy SLT 4x4 O2 sensor code/Passenger side window problem
- '95 Jimmy no start - follow up
- another 4x4 question
- 2001 Jimmy--Will not change from 2hi to 4hi/4lo
- 1994 s15 jimmy not runing right
- questions on blazer/jimmy
- oil gage going crazy????
- temp. gage ????
- O2 sensor Curcuit High Volts
- 98 jimmy heater control vacumn lines
- need some advise on changing my bearings
- '95 4x4 problem
- '97 Jimmy 4x4 problem
- erratic idle jimmy 95
- fuel problem and hard starting
- 96 won't blow hot air
- new sound under r/s
- Catylitic converter
- 2001 jimmy won't start below 30 degrees
- 89 jimmy problems Please help!
- 2K Jimmy noise changing gears
- 99 Jimmy: Whirring noise in the dash?
- Who's got the brains to figure this one
- Tire Size and Transfer Case
- Transmission Fuild
- 1991 S15 will crank, but will not start
- 2001 Jimmy no start (but tries) good fuel pressure (60psi)
- 4wd switch problem
- ? Noise under right side floor
- 90 Jimmy 4wd problems
- 2001 Jimmy PCV Valve location
- 94 Jimmy cold weather noise
- 1998 battery issues?
- gas gauage
- Poor brakes
- 99 Jimmy: Possible Fuel Leak
- 95 Jimmy ABS
- Anti-theft Alarm System De-arming
- 1997 jimmy questions
- 95 Jimmy
- 1999 Jimmy Power Seat
- 94 Jimmy 4wd Problems
- Fuel Pump
- 97 Jimmy ignition cuts out/briefly
- looking for cd radio
- 4wd on jimmy
- Need Help Undoing Seat Belt Anchorage
- 1999 Jimmy power seat
- gmc jimmy rear brakes
- pushbutton 4wd not working
- Overheating V6 vortec
- Auto Climate control not woking-need a good reference manual!
- 1998 Climate Control - AC
- jimmy tranny prob.
- 99 Jimmy: Alternator Replacement
- gas gauge doesn't work anymore
- 95 jimmy won't stay running
- '85 s15 jimmy front diff prob
- 1999 Jimmy 4x4 Question
- 94 Jimmy stalls in reverse
- where position the hose...jimmy vortec cpi
- 95 jimmy 4.3 knocking and spuddering
- 97 jimmy hard to start cold
- 95 jimmy transmission problem
- 2001 Jimmy short?
- 4 wheel drive blows fuses
- 95 Jimmy start problems
- Red Neutral Light On
- from 2.8 to 350
- ign/gau fuse keeps popping
- Cruise Control And Rpm Gage Not Working
- Wheel Nut Torque
- electical problem?
- Air Pump-right Or Left Side??
- Jimmy 98 stuck on 4HI
- 1998 JIMMY front end pop.....>>>>>>
- Service engine light - powertrain intake - a little help?
- Center Console
- 1999 GMC Jimmy, No Start
- 1996 Jimmy
- need some info.......
- Overdrive Vibration
- Short Circuit
- O2 sensor heater circuit
- Front End grinding noise- please help!
- clunk?
- 93 Jimmy 4.3 Vortec Vin (W) again
- Engine Washing
- Strange 4WD Problem
- 1997 Jimmy SLT Highway power is lacking.
- turn signal switch
- 94 Jimmy - Cranks but won't start
- Body Damage!!
- taking steering coloum off
- ecs and oil line adapter
- So Screwed...
- getting frustrated,,94 jimmy
- 98 Jimmy 4x4 issues
- Crank But No Start!!!!! Help
- Inside Door Panel
- smoke coming from tailpipe
- Frnt/Rear Wipers and my Power Retainment
- Interior Lights
- 95 & 02 Jimmy compatability
- 1997 GMC Jimmy stuck in 4 high.
- Hard starting, very rough idle and foul exhaust smell on 93 Jimmy
- 1995 Jimmy SLE Keyless Entry Wiring --------HELP ---- LOOK AT THIS ONE!!!
- Jimmy acceleration problems
- automatic locks
- Keyless Entry System
- fuel pump fuse
- 95 Jimmy vaccum leak ????
- Starting Problems & Traction Question
- P1870 Transmission Component Slipping
- Grille
- Tapping sound from 4.3L engine in cold weather
- s15 jimmy transmission
- Stock Offset?
- 4hi dash button not working on 97 Jimmy
- antifreeze leaking from engine
- tires
- engines
- Tilt Stearing 1991 Jimmy
- 1992 s15 jimmy and abs
- 4 wheel high
- 2000 jimmy hinge pin replacement?
- Catalytic Converter
- 4x4 jimmy selector lights flash
- OIL CHANGE in 4.3L GMC
- QUICK!! Blazer and Jimmy Diamond Edition compatablility ?'s QUICK!
- 4X4 attempting to engage with not in 4X4 mode
- grinding noise from engine on '99 Jimmy
- 87' Jimmy engine swap
- rear hatch window trouble
- V8 upgrade
- Programming Keyless Entry Fob for 1998 GMC Jimmy
- Constant Front End Problem Fix
- how does the brake handle come off??? HELP!
- 2000 jimmy oil leak
- 2001 GMC Jimmy Stalls
- Need CPI??? Screw eBay!
- acceleration flat spot
- EGR gasket w/screen upgrade
- 97 Jimmy Tail shaft
- 1999 jimmy brakes
- Does it matter which water pump is used?
- 95 slt heater core
- 94' Jimmy Heater Control
- 94' Jimmy 4-Wheel Drive Help
- plug wire problems
- 96 GMC Jimmy P0108
- 92' Jimmy Won't Start!
- 96 Jimmy airbag light
- TRansmision control
- Jimmy repair project
- 1990 Jimmy Electrical
- 93 Jimmy stalls out after getting warm
- '90 S15 Jimmy - O-ring replacement, oil filter lines
- 1999 Piece of crap.
- V6 4.3L plenum gasket?
- Sensor 1, Bank 1.
- Clearing CEL codes and Tranny Problem
- Strange problem w/93 Jimmy 4x4
- 97 transmission - not impressed
- 93 Jimmy Tailgate/hatch handle/lock
- Compressor kit
- Can't open hood
- exhaust questions
- Brake light always on, help?!?!
- Front axle seal replacement
- 2001 Jimmy Rear Axle Torque
- Air Conditioning
- 1995 GMC Jimmy Idles Rough
- Dome lights stay on.
- Brake lights 50% working.
- Heating problem
- Transmissions Wont shift?!
- lift?
- 99 jimmy no 4wd lock-in
- 9 Jimmy And Passenger Seat
- 1998 4wd 4dr off-roading
- 1998 Jimmy heat blending door
- What would you want to do if you were given this Jimmy for free?
- Gears
- 93 Jimmy
- Coolant system rusted
- 1992 s-15 Jimmy floods with gas when it reaches operating temp
- keyless entry remote part number
- 2000 GMC Jimmy front/shock or bushing makes noise when warm
- Scorching hot blowing air
- Spark plug vs steering column
- 95 Exhaust manifold removal
- 98 jimmy heater core
- 1992-1995 Vin W CPI Injector Leak Photo
- Considering Buying 1992 GMC Jimmy
- 98 jimmy
- 98 jimmy
- 95 Jimmy S15 Fuel Problem
- 2000 GMC Jimmy transmission
- air bags?
- Message to GMMerlin--need your advise!
- 95 jimmy test
- good susp. lift for 97 2wd?
