View Full Version : Jimmy
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12
- 95 jimmy runnin like crap
- A/C Conversion Kit
- Who to Trust? Upper Control Arm Issue
- Help Fuel problem
- 1997 Jimmy not starting
- 88 Jimmy Sierra Classic engine problems
- A/c Question
- '94 Jimmy SLT 4x4 question
- Best production year
- 96 jimmy
- Tune ups
- fault code list
- What's Missing from my 95 Jimmy?
- Manually release rear door on 2000 GMC Jimmy
- wtb 2000 Jimmy 4x4 rear bumper...or where can I get one
- A/C compressor
- 1987 Jimmy BODY lift
- 1993 S-15 Jimmy: Cranks but won't start
- tranny seems to be slipping
- body work
- 1985 top speed (urgently importent) repsond before 6/2/05
- 1997 fuel pump problem
- accessory belt squeak/chirp
- 2001 humming
- 95 4wd rough start if start and misfire and sputtering like it is running 3 cylinders
- Ignition Questions
- Auto-Rx in a Jimmy? sludge?
- 1995 jimmy rear door latch
- a.c. problems
- 98 gm c jimmy key stuck in ignition, fuel gauge not working????
- need help on replacing door hinge pins
- SES light on and audio problem
- oil line replacement how-to
- lowering 4x4
- Temperature Sensor
- Anyone wanna take credit for a fix???
- '00 Jimmy Front End Noise
- P0753
- 2000 Jimmy Waterpump troubles
- Headlight Adjustment on ’95 Jimmy
- Coolant loss
- Starter problems
- horsepower ideas
- blowing ign. and gauges fuse
- 5/32 vacum line
- Clanking when shifting into Drive or reverse
- need new mats
- Misfire?
- 1993 Vortec won't start
- What’s the capacity of 1995 Jimmy V6 radiator (just the radiator)
- EGR Code 32 Highway Mode
- 1996 fuel problems!
- 2000 Jimmy error codes?
- Problem with front wheels ......
- A Severe Overheating Problem -1995 Jimmy (I did a search – no help) - Anyone
- 85 Jimmy frozen column???
- 97 wandering
- code 0340
- 200 Jimmy SLE grinding and rattling noise in front end
- bad engine?
- Signal flasher question
- INOP W/W front and rear
- 97 jimmy service engine light
- Finding gear ratio?
- Crank fuse keeps blowing
- in desperate need of help
- This is probably a stupid question
- acid flushing radiator cooling system
- Console brake light problem
- Fuel filter replacement '92 Jimmy
- installing automatic door glass
- Keyless Entry System
- trouble codes
- Hello from a Jimmy "newbie"
- Spinning noise under hood - help?
- Electric problems?
- 1990 Jimmy 4x4 Problems
- Remote engine oil filter failure
- Will the bad luck ever end????
- fuel pressure question=95 jimmy
- need help
- CV boot
- '93 Jimmy catastrophic engine failure
- 95 jim wont fire
- 96 Jimmy SLT eletric problems?
- heat/vent/ac switch
- Brake Problem
- Steering slop
- what tires do you have?
- '76 Jimmy Fuel Gauge doesn't work
- 96 jimmyproblems
- 95 Jimmy squeel or whine when idle
- 99 Jimmy
- Transmission
- p1870
- 97 4.3 Wont start, too much gas? Help
- what color wire on a 2000 jimmy goes to the breaks
- how do I take off the back door panel?
- cold wire
- 2000 Jimmy abs light stays on
- Power window/lock problem
- 96 JIMMY keyless remote programming
- Lady In Distress 93 Jimmy Problem
- how to remove headrest ?
- Hyper Tech programmers
- 95 Jimmy blowing fuses
- 1988 S15 Jimmy
- wheel spacers
- 97 4X4 Hard start when warm
- Engine running REAL bad
- engine running bad
- P1406
- going crazy over clunking...
- Transmission Installation Problem
- Very low oil pressure! Tapping!
- Did you ever have just one of those months?
- jimmy AC problem - talk to me like I'm FIVE YEARS OLD
- adld comp. which wires to use for codes
- 91 S15 Jimmy 4X4 4.3L Motor Mounts?
- Help with Code PO146
- P0452
- Air Distribution Venting Direction Problem
- 98 GMC Jimmy Fuel Gauge
- Consumer Reports says
- Boost gas mileage
- need help fast
- 99 jimmy fuel pressure test #s hard start rough idle bad mpg
- Does Yours Do This?
- 89 Jimmy Digital Dash ---further questions
- 88 s-15 tranny & shifting prob's
- Thinking of Buying 2001 Jimmy
- Jimmy Shocks
- Fuel Pump in 1999 Jimmy
- Seats
- Code P0135
- Another Jimmy fuel pump question (sorry, long post)
- 91 Jimmy Brake HELP PLEASE!
- Shift Solenoid?????
- 86 gmc jimmy no start-help!!!
- P0452
- 97 SLT AWD Transfer Case
- Clicking Ignition Coil
- More Power
- 97 Jimmy transmission issue
- 99 jimmy 4wd actuator
- 87 GMC dies
- Electric SuperCharger
- Having trouble getting vehicle out of PARK
- Exterior mounted spare tire rack
- 1985 jimmy 2.5 To 4.3 swap
- Gas Gauge
- 21.6 mpg on my '94 S15 v6
- Intermittant engine compartment hood lamp
- check engine light blinking(help asap)
- EGR Questions
- 96 jimmy blinker system in-op
- 93 Digital dash/ dimmer switch
- Help! Windshield Washer Reservoir Leak.
- Jimmy Distributor Caps
- Xmission is Wonky
- Sloshing under dash
- 97 Jimmy Lift
- trouble changing the transmission fluid 97 jimmy
- Leaking Front Diff.
- Rough erratic idle, hesitation, stalling, sulpher smell
- Boa remote start/keyless entry
- Miraculous Brake fix
- 97 Jimmy Ignition Switch
- Fuel gauge misreads
- Oil Cooler Lines
- 1999 Jimmy SLT
- 95 Jimmy dies in the rain
- Problems Driving Me Nuts
- 1996 Jimmy rough idle
- clutch not relesing
- 4x4 trouble and other things
- 95 Jimmy wow's
- 78 jimmy round to square headlight conversion?
- Clicking Noise!
- Temp check
- Always Loud!
- No-Start Nightmare!
- C - Clips
- Stalling Out Jimmy
- Engine Idling Questions
- New battery, no starting only the click...
- Vibration
- all-in-one signal switch.... 1998 Jimmy
- Rear defrost
- Radiator fluid smell
- Another fun fix with the Jimmy
- 1992 jimmy s15
- Jimi half doors
- 88 Jimmy, where is the ignition switch located?
- body lift price difference
- 96 Rear Wheel Bearing Replacement
- motor mounts (quick help please)
- motor mounts
- Stalling out
- do i need to replace the rearend??
- MAP Sensor
- Belt Tensioner for the 4.3 Vortec
- 1997 Jimmy Blinkers
- Spewing by the quart
- Wiring problem/question
- 96 Jimmy AfterMarket Exhaust Questions
- 97' Jimmy 4x4 switch flashing, no 4x4
- Fuel pump Help !!!!
- 98 jimmy no acceleration
- Still Unknown Quit Issue
- torque converter
- code po101
- 1996 Jimmy
- Rear wiper spray button no worky!
- 95 Jimmy fuel, electrical problem
- My KEY is stuck! HELP quick
- bg products
- P size vs. LT size.
- Liberator Tires
- Need help setting timing
- Few questions
- '92 S15 door alignment
- ABS Brakes?
- So many questions...
- 1994 jimmy dash lights
- 1995 gmc jimmy stalls after warmup,has good fuel pressure
- Is the fuel pump really bad?
- Spark Plugs for Jimmy
- Dumb Question looking for good answer
- Some Coolant In Oil...
- Fuel Pressure Shrader Valve Question
- klunk noise from tranny?
- catalytic converter and fuel pump
- sound insulation
- 1998 Jimmy SLT 2 Problems
- 1995 jimmy 4.3 4x4 automatic
- Help 1996 Gmc Jimmy
- Transfer case, actuator, or gear problem... YOU CHOOSE!
- Self-shifting to 4-Lo...YOW!!
- swaying
- 84 S-10 auto transmission shifgt indicator
- taillight
- Search Before You Ask Questions!
- specs
- I think I found the problem...
- Howling From Front
- I know this is stupid to ask but whats my top speed
- Transmittion problem
- Tire Recommendation?
- 95 Jimmy 4x4 front shock installation
Automotive Network, Inc., Copyright ©2013
