View Full Version : Jimmy
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11
- Fuel pump Help !!!!
- 98 jimmy no acceleration
- Still Unknown Quit Issue
- torque converter
- code po101
- 1996 Jimmy
- Rear wiper spray button no worky!
- 95 Jimmy fuel, electrical problem
- My KEY is stuck! HELP quick
- bg products
- P size vs. LT size.
- Liberator Tires
- Need help setting timing
- Few questions
- '92 S15 door alignment
- ABS Brakes?
- So many questions...
- 1994 jimmy dash lights
- 1995 gmc jimmy stalls after warmup,has good fuel pressure
- Is the fuel pump really bad?
- Spark Plugs for Jimmy
- Dumb Question looking for good answer
- Some Coolant In Oil...
- Fuel Pressure Shrader Valve Question
- klunk noise from tranny?
- catalytic converter and fuel pump
- sound insulation
- 1998 Jimmy SLT 2 Problems
- 1995 jimmy 4.3 4x4 automatic
- Help 1996 Gmc Jimmy
- Transfer case, actuator, or gear problem... YOU CHOOSE!
- Self-shifting to 4-Lo...YOW!!
- swaying
- 84 S-10 auto transmission shifgt indicator
- taillight
- Search Before You Ask Questions!
- specs
- I think I found the problem...
- Howling From Front
- I know this is stupid to ask but whats my top speed
- Transmittion problem
- Tire Recommendation?
- 95 Jimmy 4x4 front shock installation
- 95 Jimmy SLS - Transmission problem
- fram
- throttle cable
- 99 Jimmy steering wheel radio controls
- does anyone no were can i find a diamond edition bushgard 4 my 95 jimmy slt?
- tranny locking in and out
- 1996 Trouble Code P0140
- 2000 Jimmy 4wd won't engage
- 1997 Jimmy overview
- 1995 jimmy slt 4wd problems!
- 95 Jimmy check eng light rough idle
- 95 jimmy - Rough idle, Misfiring, Massive Fuel Consumption
- Tie rod Grease fittings?
- 2000 Jimmy- motor Mount/ Electric Problem
- should i stay or should i go???
- 2000 Jimmy oil cooler lines
- thinking of v8 swap any people with expernce in v8 swaps here?
- Fuel tank,.... thingie?
- 1998 Jimmy - 4WD selector switch - no lights
- Fuel Pump Installation?
- 97 jimmy front end noise
- Low water temp.
- 1995 Gmc Jimmy 4.3 Vortec CPI Flooding on #3 Cylinder Stalling and Misfireing
- Headlight's blinking
- Oil hoses
- 97 Jimmy hesitates still
- automatic 94 Jimmy shifting problem?
- Blazer Jimmy 4x4
- Rear hatch not releasing
- Raise my 1992 Jimmy
- 95 Jimmy 4x4 Abs LIGHT ON
- 2000 Jimmy 4wd
- bulbs
- bulbs
- Sometimes it clicks, Sometimes it starts
- engine revs high at startup
- Jimmy dies without foot on brake
- power steering problem on 1996 jimmy
- Delayed Shift/Loud Intake Noise
- idle misfire, scope says its random
- 2000 GMC Jimmy High Idle & More
- Battery Indicator is on, guage at one quarter
- help me customize my 94 jimmy
- '94 Jimmy Fuel Pump Testing
- 95 suspesion clunking
- Last straw!!
- yet another problem
- no reverse lights
- 99 Jimmy-How do replace ignition switch?
- Tie Rods and steering
- 1995 jimmy hesitates when its cold
- 1997 GMC Jimmy Transmission Problems
- 85 t15 jimmy 2.8 timing belt? or chain?
- 1997 Jimmy hesitation problem..
- front end
- problems with 97 jimmy
- speedometer doesn't work
- Jimmy License Plate Lights
- Airbag light on, fuse blown
- Jimmy run worse after air intake temp replaced
- no power under load
- oil gauge
- Coolant problem
- 94 Jimmy Idler Arm
- spark plugs
- 85 t15 jimmy brake prob.
- Ignition switch locked up.
- Emergency brake won't work
- 99 jimmy hard to start (little gray box helps)
- lift questions
- Alternator/ Engine Replacement
- digital dash is completely out
- Sluggish 1999 Jimmy - gimme some help!!
- Indiglo guages available for your ride?
- Carr LightWing
- Temp gage spiking, then rapidly dropping, and intermittent window problem
- Ball Joints 97 Jimmy Help Please
- fuel filter
- buyin a newer jimmy/blazer
- Woman In Trouble
- 1997 4WD problems
- 96 Keyless entry programming.
- Low Oil pressure....
- Cricket noise in engine compartment.
- dumb theif messed up my HI-BEAM switch
- Rear differential maintenance
- Clicking sound
- right turn clunk??
- a whole lotta shakin
- Jimmy Vs. Blazer
- Front Diffrential 99 Jimmy SLT
- Fan Noise
- Battery Question
- Truck starting to shake....
- heater control
- 01 Jimmy, P0440 code
- Can't open hood!
- code 32 - but not the egr
- Heater door
- 4wd Not Working Below Freezing
- Stalling and loud fuel pump
- 01 Jimmy, OBD II code
- 4wd
- Power door lock not locking..
- 95 Jimmy CPI & Nut Set???
- error code help
- 2001 Jimmy Shuts Off
- 1995 jimmy pulses
- Rear wheel noise
- transmission seal replacement
- Gate window not closing
- 99 jimmy
- Lower intake leaking
- Tough to replace U joints?
- 97 Jimmy Hazard - Stop lights switch intermittant
- 97 Jimmy Headlight Aiming Adjustment
- tranny
- Trans problem....
- Oil Cooler leaking
- Radio Lights
- 95 jimmy fuel problems
- Bumps and Lights!!!!
- 1991 jimmy 4.3 PROBLEMS stalls/iratic idle
- Ball Joints need replacing like oil does
- I feel stupid...
- 99 4.3 Vortec
- '94 jimmy fuel problems
- 1997 Jimmy Audio problem
- rear window/interioir lights?
- How-to: Factory fog light switch with non factory fog lamps
- Transfer case lube
- Throttle Valve Cable Loc? 93 S15 4.3L V6
- 93' in dash temp gage
- 92 Jimmy digital dash problem
- 94', can't get out of 4HI
- Cruise control problem
- Seafoam engine cleaner.
- '94 S15 instrument panel with tach?
- Klunking noise when shifting from park to drive
- Generic Cold Air intake...
- Fuel Pump Pulsator/Check Valve
- 94 Jimmy transmission "CTF"
- Tensioner and Serpentine belt problems
- 99 Envoy Front Diff and Tranny Problems
- 97 jimmy key stuck
- 94 Jimmy Front Suspension Problems
- 4x4 does not engage when I push the button
- oxygen sensor 1997 Jimmy
- Need help with the Codes
- relay system - fuel pump
- 87 transmission problems
- Stuck Oil Filter, gooey radiator, bad gas mileage
- Inaccurate Fuel gauge on 2000 GMC Jimmy SLT
- Uh oh... this is bad
- 4x4 inop
- 97 jimmy, ignition problem
- My check engine light
- Jimmy Remote Programming!
- Is It Worth Fixing????
- '96 Jimmy hard start
- rear suspension fix
- P0101 code Backfires
- 94 Jimmy fuel pressure?
- 1994 jimmy tranny!!!!!!
- Heater
- Took it up the rear again... ouch...
- Buzzing from gas tank
- small black wire with rt-angle fitting near distributor?
- 5/32 vacuum hose config at rear of intake manifold?
- Service manual?
- off-white wire w/ connector below passenger compartment?
- Mysterious Coolant Leak
- sway bar for 2000 Jimmy?
- 2000 Jimmy Door Dropping
- valve noise? 1996 jimmy
- lossing accelleration when
- Help setting timing on '94 V6 4.3 CPI S15
- '96 jimmy serpentine belt
- 87 jimmy 4X4 problem
- 1994 Jimmy Fule pump Q's
- few prob. please help
- 97 jimmy fuel pressure drops. hard starting
- Jimmy's seat
- 93 gmc jimmy 4.3 vortex fuel problem
- Noob Intro and question...
- 92 jimmy - 4.3L V6 to 305 V8
- How do I cut metal fuel line?
- cold air intake vs k&n airbox filter
- Wheel hub bearing assembly
- Heater
- remote start wire question
- Heater Problem!
- '94 S15 V6 4.3L vortec valve lash adjust?
- 95 jimmy
- Flashing Brake Light
- Burning oil?
- 93 Jimmy Transmission Problems
- 2000 GMC Jimmy-A/C, Heat and Defrost don't work!!!
- Pop or Klunk
- 95 GMC Jimmy hesitation, fuel gage jumping
- Serious Oil Leak! Need Help!
- 93 Fan control switch
- Torsion bar?????
- 94 jimmy sudden death cyndrom
- 94 Jimmy GMC suddenly dies
- Door pin
- What's the differance?
