Our Community is 705,000 Strong. Join Us.
View Full Version : Jimmy
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. 93 Jimmy Oil Filter Location
  2. oil pan removal
  3. 1993 Jimmy SLT 4x4 FOR SALE
  4. tachometer jumps in rhythm w/ blinker
  5. idle problem and lost of power with the a/c on
  6. left vent noise
  7. Question on interior lights
  8. I don't believe/trust the 2 diagnosis on my '98 jimmy
  9. No heat in 2000 Jimmy
  10. sloppy idle..almost hiccups
  11. sloppy idle..almost hiccups
  12. 98 Jimmy brake rotor
  13. Smelly, inefficient, misses out, and more!
  14. 95 HVAC problem
  15. help
  16. Best Plugs and Wires to Use on a 1995 GMC Jimmy
  17. 1992 jimmy won't start one day, the next day it does
  18. Oil Pressure Switch
  19. 98 jimmy digital dash cluster
  20. Shift lever 99 Jimmy
  21. 1998 jimmy stalls evry day when first started
  22. 1997 Jimmy blowing transmission fluid out!
  23. Truck Not Running Right? Hard On Fuel And Sluggish Power? Try These First.....
  24. PLEASE HELP!!! Billet grille instal!!!
  25. egr screen?
  26. passenger side front wheel noise 92 gmc jimmy
  27. 1993 Jimmy No trans codes, bad shift
  28. Rough idle Bad Gas Mileage
  29. 99 Jimmy Overheating
  30. 1999 jimmy won't shift to 4 wheel low
  31. no reverse 2nd or 4th gears
  32. 95 power seats
  33. speedometer lags,abs light on
  34. SES,tranny,no brakes, EGR,
  35. 1998 Jimmy - ABS Light on Intermittantly
  36. Smoke is coming out of dipstick tube, after motor oil change
  37. Everything dead and key is stuck
  38. 97 jimmy cranks won't fire
  39. 1995 GMC Jimmy ABS Controller Module
  40. Help! 1995 Jimmy turn signal flasher
  41. How do I read transmission codes?
  42. Dash gauges are ugly...
  43. pin outs for a digital dash
  44. Rough idle and acceleration
  45. Intermittent Vibration at Highway Speeds
  46. 1995 GMC Jimmy Electric Fan Installation
  47. 1995 jimmy 1/4 mile times?
  48. Ignition Switch
  49. 1995 GMC Jimmy Harmonic Balance
  50. please help 94 jimmy smoking mysteriously
  51. Dexcool
  52. vacuum hose routing
  53. not getting fuel into the throttle body
  54. How do i attach an engine hoist?
  55. fuel gauge not registering
  56. signal lights clicking but not on ?
  57. Changing my guages
  58. 4WD 2001 Jimmy surging, stalling, hardto start--It was the Coolant Temp. Sensor, prom
  59. Car idles bad, no brakes, exhuast rushing out of tailpipe
  60. Odd problem - Dash lights up like a Christmas tree
  61. 98 Jimmy rear brakes sticking
  62. 95 Jimmy running hot
  63. oil in coolant tank
  64. How much oil do you add when you change your oil and filter?
  65. Where is the Tach wire?
  66. Where's the drain on the radiator of 97 Jimmy 4x4?
  67. Squeaking front-end chassis
  68. transmission
  69. 1995 RPO Code question
  70. Torsion Bar Lift
  71. Found a Jimmy
  72. Kill the chime module!!!
  73. Rough Idle fixed for good this time.
  74. rough acceleration
  75. 1995 Jimmy Belt Or????
  76. transmission clunks into third
  77. 1995 jimmy fuel pump won't shut off/ relay location
  78. Four Codes All At Once
  79. electrical short?
  80. 2001 GMC Jimmy Humming Noise
  81. Is this all connected
  82. Catalytic converter or Gasoline ping???
  83. Overhead install
  84. Alarm & Remote Starter - Any Issues with Jimmy Install?
  85. 1995 GMC Jimmy Backfire, blows muffler
  86. Horsepower and Torque
  87. Power Seat failure, Dashboard lights - any fix?
  88. I'm so happy!!!!!
  89. Grinding AC/Heator switcharoo
  90. computer climate controle
  91. Fuel Gauge and SES light
  92. Have I siezed my engine? Replaced starter but still not turning.
  93. 1995 GMC Jimmy questions
  94. 2000 Jimmy Terrible Gas Mileage
  95. lost power to horn,radio,lighter,and rear window
  96. 99 Jimmy tailgate not opening
  97. code P0147
  98. oil plug
  99. anyone tried 6gun tuner or venom400?
  100. 92 Jimmy spark plug wire order
  101. Anyone tried to clear headlights on a 98 or newer Jimmy?
  102. level of octane to run?
  103. 93' Jimmy 4WD problems
  104. rear wheel bearing
  105. Been doing a test on our gasoline
  106. 93' Jimmy
  107. 1987 jimmy fuel problem
  108. 1995 rear window wiper
  109. Transmission problems
  110. Check Engine Light
  111. throttle body spacers
  112. "Service Engine Soon" light on '94 S15 Jimmy
  113. 98 Jimmy, rough starts
  114. 94 Jimmy, Belt Squeal
  115. 2001 Jimmy 4wd stalling, reving
  116. Fuel System Help
  117. 96 Jimmy no crank- intermittent
  118. 2000 Jimmy Loud Front End Noise
  119. Engine Oil Capacity?
  120. Torsion bar isolator mounts?
  121. Once more, an idle question. Tried a search
  122. AC Problem
  123. automatic head lights
  124. Warning Lights
  125. 1996 Transmission
  126. wiring digrams
  127. Exhaust problem
  128. Lighting System Issue
  129. 96 no start prob
  130. A new type over overhead Console <evil grin>
  131. Ignition switch wiring diagram.
  132. EGR gasket w/ screen update
  133. jimmy front end noise
  134. 2000 Jimmy A/C problems
  135. replacing shocks
  136. Rivets holding power window motor
  137. P0410
  138. oil pressure question
  139. Heavy Trans Leak Under Load???A
  140. Rough Idle and starting problem
  141. Hazards stuck ON
  142. ABS Light
  143. 98 jimmy service light
  144. 1996 Jimmy rough idle - still trying
  145. MoDifications
  146. H.I.D. Conversion
  147. Hi. Newbie with a 97
  148. EGR Valve
  149. Note to Blazer LT
  150. digital
  151. Oil Question
  152. sway bar bushings
  153. 1990 rear hatch
  154. Programming instructions for 00 Jimmy remote
  155. Folw-up to the Fuel Pump Question below
  156. Fuel Pump / Relay Issue??
  157. 1984 Jimmy, keep or sell?
  158. AC Problems
  159. power window motor replacement question
  160. Jimmy spark plugs
  161. 1998 Tranny problem
  162. Random-ish stalling
  163. Acts like brakes are sticking
  164. Oil guage fluctuating
  165. Wheel Bearings
  166. Slight Hesitation or Bucking when going uphill
  167. would'nt come out of 4 low
  168. 1998 Jimmy Tranny cooling lines at radiator
  169. surging and stalling and hard starting
  170. Power window problem
  171. Yet another Transmission question!
  172. 2000 Jimmy Intermittent Stall at stops
  173. Tire Size VS MPH
  174. Wierd 4x4 problem 1997 GMC
  175. Loud humming noise from front end
  176. 1993 Jimmy wont start
  177. 94 Jimmy EGR Valve, Code 32, please help ASAP!
  178. 1993 Jimmy Fuel Pump Relay Location
  179. 1996 GMC Jimmy Transmission
  180. Rough idle, Very Strong Exhaust Fumes, Feels like it misses, Ect...
  181. Air only blows cool at idle?
  182. Another 97 Jimmy Problem, please help!
  183. transmission filter
  184. open/closed loop trouble? 1994 S-15
  185. 1998 jimmy waterpump
  186. 99' GMC driving problems
  187. 95 jimmy vortec 4.3 Rough Idle, Gas and carbon Smell, Engine shakes
  188. ***List of OBD II Codes***
  189. **Transmission Codes - What They Mean and What Happens**
  190. Roof rack capacity of the Jimmy?
  191. fuel pressure, please help, cpi?
  192. 1999 GMC Jimmy stuck in 4LO
  193. Goodbye 99' Jimmy!!!
  194. tranny pukes when starting only!
  195. 4x4 troubles, vacuum hose routing
  196. 2000 GMC Jimmy SLT
  197. good bye jimmy
  198. P0175 too rich
  199. Stuck rotor
  200. steering stabilizer
  201. All lights ok but no brake lights.
  202. how to change out headlights
  203. 94 Jimmy Brakes....please help
  204. '94 leaky AT on side near tailshaft
  205. 97 Jimmy smells of gas after filling up
  206. DEX-COOL Engine Coolant Information
  207. Blew trans fluid out overflow on trans?
  208. Key FOB
  209. Rod knocking from valve cover 1999 Jimmy 4wd...
  210. 98 S15 Jimmy 4x4 problem
  211. Ugh Stalling
  212. Transmission???
  213. ground question
  214. 97 Jimmy AC Compressor Installation Help
  215. brake brakes bleed fluid anti-lock
  216. ALternator Testing and Loosening belt to remove
  217. broken motor mounts
  218. Hissing from dashboard
  219. 1992 Jimmy Diagnostic codes
  220. 95 Jimmy - Won't shift past 2nd...w/ other jerking issues V6 4WD
  221. For Sale
  222. new edelbrock air filter problems
  223. Code reader Recommendation
  224. 96' Jimmy SLE Tranny problem - PLEASE HELP!
  225. engine has slight shake when idling
  226. Code 103, help!
  227. 88 Jimmy Engine problems PLEASE HLP
  228. Tranny Problems
  229. A/C Stalls!!
  230. Knock Sensor Location
  231. Installing cylinder head on 88ish Jimmy?
  232. Trany Trouble codes
  233. Fuel Pump Thanks
  234. 1996 jimmy overhead console install. Also have a bunch of consoles
  235. roadmaster Active suspension?
  236. rear hatch?
  237. Voltage and Door Problems
  238. A little info about 96+ fuel systems
  239. 2000 Jimmy Radio
  240. 2001 Jimmy accessories
  241. Updated my web page, what do you think?
  242. jimmy radiator replacment
  243. '94 Jimmy a/c question ( have checked threads)
  244. 99 front diff prob?
  245. 1996 jimmy keyless entry failure
  246. 98 Jimmy air bag idiot light
  247. OBDII code- cat. efficiency below threshold
  248. 95 jimmy runnin like crap
  249. A/C Conversion Kit
  250. Who to Trust? Upper Control Arm Issue
