View Full Version : Jimmy
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. DEX-COOL Engine Coolant Information
  2. Blew trans fluid out overflow on trans?
  3. Key FOB
  4. Rod knocking from valve cover 1999 Jimmy 4wd...
  5. 98 S15 Jimmy 4x4 problem
  6. Ugh Stalling
  7. Transmission???
  8. ground question
  9. 97 Jimmy AC Compressor Installation Help
  10. brake brakes bleed fluid anti-lock
  11. ALternator Testing and Loosening belt to remove
  12. broken motor mounts
  13. Hissing from dashboard
  14. 1992 Jimmy Diagnostic codes
  15. 95 Jimmy - Won't shift past 2nd...w/ other jerking issues V6 4WD
  16. For Sale
  17. new edelbrock air filter problems
  18. Code reader Recommendation
  19. 96' Jimmy SLE Tranny problem - PLEASE HELP!
  20. engine has slight shake when idling
  21. Code 103, help!
  22. 88 Jimmy Engine problems PLEASE HLP
  23. Tranny Problems
  24. A/C Stalls!!
  25. Knock Sensor Location
  26. Installing cylinder head on 88ish Jimmy?
  27. Trany Trouble codes
  28. Fuel Pump Thanks
  29. 1996 jimmy overhead console install. Also have a bunch of consoles
  30. roadmaster Active suspension?
  31. rear hatch?
  32. Voltage and Door Problems
  33. A little info about 96+ fuel systems
  34. 2000 Jimmy Radio
  35. 2001 Jimmy accessories
  36. Updated my web page, what do you think?
  37. jimmy radiator replacment
  38. '94 Jimmy a/c question ( have checked threads)
  39. 99 front diff prob?
  40. 1996 jimmy keyless entry failure
  41. 98 Jimmy air bag idiot light
  42. OBDII code- cat. efficiency below threshold
  43. 95 jimmy runnin like crap
  44. A/C Conversion Kit
  45. Who to Trust? Upper Control Arm Issue
  46. Help Fuel problem
  47. 1997 Jimmy not starting
  48. 88 Jimmy Sierra Classic engine problems
  49. A/c Question
  50. '94 Jimmy SLT 4x4 question
  51. Best production year
  52. 96 jimmy
  53. Tune ups
  54. fault code list
  55. What's Missing from my 95 Jimmy?
  56. Manually release rear door on 2000 GMC Jimmy
  57. wtb 2000 Jimmy 4x4 rear bumper...or where can I get one
  58. A/C compressor
  59. 1987 Jimmy BODY lift
  60. 1993 S-15 Jimmy: Cranks but won't start
  61. tranny seems to be slipping
  62. body work
  63. 1985 top speed (urgently importent) repsond before 6/2/05
  64. 1997 fuel pump problem
  65. accessory belt squeak/chirp
  66. 2001 humming
  67. 95 4wd rough start if start and misfire and sputtering like it is running 3 cylinders
  68. Ignition Questions
  69. Auto-Rx in a Jimmy? sludge?
  70. 1995 jimmy rear door latch
  71. a.c. problems
  72. 98 gm c jimmy key stuck in ignition, fuel gauge not working????
  73. need help on replacing door hinge pins
  74. SES light on and audio problem
  75. oil line replacement how-to
  76. lowering 4x4
  77. Temperature Sensor
  78. Anyone wanna take credit for a fix???
  79. '00 Jimmy Front End Noise
  80. P0753
  81. 2000 Jimmy Waterpump troubles
  82. Headlight Adjustment on ’95 Jimmy
  83. Coolant loss
  84. Starter problems
  85. horsepower ideas
  86. blowing ign. and gauges fuse
  87. 5/32 vacum line
  88. Clanking when shifting into Drive or reverse
  89. need new mats
  90. Misfire?
  91. 1993 Vortec won't start
  92. What’s the capacity of 1995 Jimmy V6 radiator (just the radiator)
  93. EGR Code 32 Highway Mode
  94. 1996 fuel problems!
  95. 2000 Jimmy error codes?
  96. Problem with front wheels ......
  97. A Severe Overheating Problem -1995 Jimmy (I did a search – no help) - Anyone
  98. 85 Jimmy frozen column???
  99. 97 wandering
  100. code 0340
  101. 200 Jimmy SLE grinding and rattling noise in front end
  102. bad engine?
  103. Signal flasher question
  104. INOP W/W front and rear
  105. 97 jimmy service engine light
  106. Finding gear ratio?
  107. Crank fuse keeps blowing
  108. in desperate need of help
  109. This is probably a stupid question
  110. acid flushing radiator cooling system
  111. Console brake light problem
  112. Fuel filter replacement '92 Jimmy
  113. installing automatic door glass
  114. Keyless Entry System
  115. trouble codes
  116. Hello from a Jimmy "newbie"
  117. Spinning noise under hood - help?
  118. Electric problems?
  119. 1990 Jimmy 4x4 Problems
  120. Remote engine oil filter failure
  121. Will the bad luck ever end????
  122. fuel pressure question=95 jimmy
  123. need help
  124. CV boot
  125. '93 Jimmy catastrophic engine failure
  126. 95 jim wont fire
  127. 96 Jimmy SLT eletric problems?
  128. heat/vent/ac switch
  129. Brake Problem
  130. Steering slop
  131. what tires do you have?
  132. '76 Jimmy Fuel Gauge doesn't work
  133. 96 jimmyproblems
  134. 95 Jimmy squeel or whine when idle
  135. 99 Jimmy
  136. Transmission
  137. p1870
  138. 97 4.3 Wont start, too much gas? Help
  139. what color wire on a 2000 jimmy goes to the breaks
  140. how do I take off the back door panel?
  141. cold wire
  142. 2000 Jimmy abs light stays on
  143. Power window/lock problem
  144. 96 JIMMY keyless remote programming
  145. Lady In Distress 93 Jimmy Problem
  146. how to remove headrest ?
  147. Hyper Tech programmers
  148. 95 Jimmy blowing fuses
  149. 1988 S15 Jimmy
  150. wheel spacers
  151. 97 4X4 Hard start when warm
  152. Engine running REAL bad
  153. engine running bad
  154. P1406
  155. going crazy over clunking...
  156. Transmission Installation Problem
  157. Very low oil pressure! Tapping!
  158. Did you ever have just one of those months?
  159. jimmy AC problem - talk to me like I'm FIVE YEARS OLD
  160. adld comp. which wires to use for codes
  161. 91 S15 Jimmy 4X4 4.3L Motor Mounts?
  162. Help with Code PO146
  163. P0452
  164. Air Distribution Venting Direction Problem
  165. 98 GMC Jimmy Fuel Gauge
  166. Consumer Reports says
  167. Boost gas mileage
  168. need help fast
  169. 99 jimmy fuel pressure test #s hard start rough idle bad mpg
  170. Does Yours Do This?
  171. 89 Jimmy Digital Dash ---further questions
  172. 88 s-15 tranny & shifting prob's
  173. Thinking of Buying 2001 Jimmy
  174. Jimmy Shocks
  175. Fuel Pump in 1999 Jimmy
  176. Seats
  177. Code P0135
  178. Another Jimmy fuel pump question (sorry, long post)
  179. 91 Jimmy Brake HELP PLEASE!
  180. Shift Solenoid?????
  181. 86 gmc jimmy no start-help!!!
  182. P0452
  183. 97 SLT AWD Transfer Case
  184. Clicking Ignition Coil
  185. More Power
  186. 97 Jimmy transmission issue
  187. 99 jimmy 4wd actuator
  188. 87 GMC dies
  189. Electric SuperCharger
  190. Having trouble getting vehicle out of PARK
  191. Exterior mounted spare tire rack
  192. 1985 jimmy 2.5 To 4.3 swap
  193. Gas Gauge
  194. 21.6 mpg on my '94 S15 v6
  195. Intermittant engine compartment hood lamp
  196. check engine light blinking(help asap)
  197. EGR Questions
  198. 96 jimmy blinker system in-op
  199. 93 Digital dash/ dimmer switch
  200. Help! Windshield Washer Reservoir Leak.
  201. Jimmy Distributor Caps
  202. Xmission is Wonky
  203. Sloshing under dash
  204. 97 Jimmy Lift
  205. trouble changing the transmission fluid 97 jimmy
  206. Leaking Front Diff.
  207. Rough erratic idle, hesitation, stalling, sulpher smell
  208. Boa remote start/keyless entry
  209. Miraculous Brake fix
  210. 97 Jimmy Ignition Switch
  211. Fuel gauge misreads
  212. Oil Cooler Lines
  213. 1999 Jimmy SLT
  214. 95 Jimmy dies in the rain
  215. Problems Driving Me Nuts
  216. 1996 Jimmy rough idle
  217. clutch not relesing
  218. 4x4 trouble and other things
  219. 95 Jimmy wow's
  220. 78 jimmy round to square headlight conversion?
  221. Clicking Noise!
  222. Temp check
  223. Always Loud!
  224. No-Start Nightmare!
  225. C - Clips
  226. Stalling Out Jimmy
  227. Engine Idling Questions
  228. New battery, no starting only the click...
  229. Vibration
  230. all-in-one signal switch.... 1998 Jimmy
  231. Rear defrost
  232. Radiator fluid smell
  233. Another fun fix with the Jimmy
  234. 1992 jimmy s15
  235. Jimi half doors
  236. 88 Jimmy, where is the ignition switch located?
  237. body lift price difference
  238. 96 Rear Wheel Bearing Replacement
  239. motor mounts (quick help please)
  240. motor mounts
  241. Stalling out
  242. do i need to replace the rearend??
  243. MAP Sensor
  244. Belt Tensioner for the 4.3 Vortec
  245. 1997 Jimmy Blinkers
  246. Spewing by the quart
  247. Wiring problem/question
  248. 96 Jimmy AfterMarket Exhaust Questions
  249. 97' Jimmy 4x4 switch flashing, no 4x4
  250. Fuel pump Help !!!!
