Our Community is 705,000 Strong. Join Us.
View Full Version : Jimmy
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Front Windshield wiper nozzles
  2. "Check Engine Soon" Code 128 meaning
  3. Door lock bypass
  4. 1998 Jimmy with cold starting issue
  5. Dome Light Always On
  6. fuel tank part question
  7. rear window will not open
  8. 1997 JIMMY No oil and tapping!
  9. Is it even possible?
  10. How to have fun with a crappy Jimmy
  11. 1998 jimmy wiring info for remote staeters
  12. 1992 Jimmy 4WD help
  13. Heater Core 2000 GMC Jimmy
  14. dash ghosts??
  15. Heater Fan quit
  16. Read First - FAQ & how to thread!!
  17. My Heater Core Is Out Can I Drive?
  18. Remote car starter ...recommendations
  19. No power to some fuses (Htr, A/C, PwrWindows) all of a sudden???
  20. 99 Jimmy - 4wd problem
  21. won't start
  22. '96 Jimmy turn signals
  23. 1991 s15 jimmy 4x4 front wheel bearing and axle
  24. Last try....need any suggestions you got!
  25. Transmission Fluid in Transfer Case
  26. Unknown Buzz
  27. Does bad CPI cause P1506?
  28. Sudden Rough Idle/95 Jimmy??!!??
  29. P0143 Code
  30. Motor Silk?
  31. stumped with 4.3 spider assembley, help!!!
  32. Can't bleed brakes
  33. 95 Jimmy fan speed control smokes
  34. check engine light.
  35. What is common between the front wipers and rear wiper???
  36. 1988 Rear Window
  37. 95 Pontiac Grand Am stalls in reverse, runs in all other positions.
  38. Why does GM charge so much for their parts?
  39. noise on left front wheel of 1991 s15 jimmy
  40. '91 won't start
  41. lack of power when accalerating
  42. Jimmy cold starting problem
  43. Full time 4x4 on my Jimmy
  44. Heater is a pain in the a$$. HELP!
  45. Door locks
  46. Help! Back Brakes 99 jimmy
  47. how to set the universal garage door opener
  48. Driverside door Pins and bushing replacement
  49. Cant adjust passenger side headlight...
  50. 1997 Jimmy License Plate Lamp
  51. 95 jimmy 4.3w
  52. 1993 Gmc Jimmy 4.3L Vtech.....not starting
  53. 1996 Jimmy 4 wheel drive not working
  54. CPI Fuel Pressure regulator
  55. Little help
  56. Someone might be upset
  57. heater doesnt work
  58. wheel bearing replacement
  59. front wheel bearing 2000 jimmy 4x4
  60. What would you do
  61. 87 blazer 2.8L to 4.3L
  62. 1998 Jimmy SLS Rear Defogger\Defroster
  63. my '94 S15 is officially dead
  64. Engine rev-ing off and on when warm
  65. 305hp Awd
  66. Hot butt how-to!
  67. Squeel from pulley
  68. Jimmy 4 Wheel transfer quit
  69. 1997 Jimmy with a transfer case problem.
  70. wont go into 4x4
  71. 2001 Jimmy stalls in rain
  72. digital dash
  73. Idle Problem
  74. GMC Logo Patches
  75. 95 jimmy fuel pump replacement
  76. 97 jimmy axle seal replacement
  77. 1996 jimmy no heat, is it the blend door?
  78. Front Wheel Bearings
  79. vacuum digram for heater needed
  80. both turn signals and hazzard lights failed
  81. Electrical static noise
  82. 96 jimmy heater core, do i really have to remove the dash?
  83. 1995 jimmy cpi/nut kit?
  84. Where is the Transfer Case Control Module TCCM?
  85. 01 Jimmy Havoc
  86. 4x4 switch has no lights
  87. Air filter, spark plugs, and wiper weirdness
  88. Any Idea How To Program Keyless Fobs For 1994 Jimmy??help!!
  89. starter
  90. '98 Jimmy leaking coolant (dumping, really)
  91. Ignition won't turning
  92. hard to start in cold weather
  93. 95 Jimmy, slow battery drain
  94. not getting fuel
  95. Evap Code - No Flow Detected
  96. 2001 Jimmy shuddering upon acceleration
  97. Lift struts for rear window
  98. 93 s15 Jimmy 4wd
  99. Engine revs at idle!!
  100. 88 FI oil pan removal
  101. Steering seems.. loose
  102. Is a the frame on a 73 the same as a 76?
  103. I don't think I'm getting fuel
  104. Hitchikers
  105. Dealer said its makin' metal now... Updated.
  106. 94 Jimmy 4x4 Issue
  107. Block Heater
  108. 1995 Gmc Jimmy 4wd Wont Work But 4wd Low Does
  109. Service 4wd light
  110. Got bored over lunch.. boy am I lame...
  111. Its just 1 bolt holding the oil lines to the oil adapter?
  112. Electrical Whine
  113. 99 Jimmy heater core "How do you open the box?"
  114. Front end growl/grind
  115. 2000 Jimmy SLT windshield leak & gas guage problem. Please help!!!!
  116. 2001 jimmy bose system
  117. Just paid .84 cents per gallon for gas, I love Amerika!
  118. Trans OBD II Code P1886 Trouble.
  119. smelling anti freeze
  120. hvac fan
  121. Sound from steeling wheel while turning
  122. Anti Freeze?
  123. 4X4 Issue. BATTERY RESET TO FIX is Temp FIX.
  124. plz help my jimmy went crazy
  125. 4x4 low and hi ele switch and rearwindow wiper
  126. 93 jimmy ignition? starting to drive me crazy
  127. 91 jimmy power windows.fuse panel schematic.
  128. Any one know part # for egr valve screen?
  129. Rear drum to disc conversion
  130. Replaced spider, nut kit, air filter, changed the oil and still...
  131. heater flap 2000 Jimmy
  132. Changing an Oil Pressure Sender 4.3L
  133. '93 Jimmy Heater core replacement
  134. 93 jimmy starts but turns over for ever
  135. up in smoke
  136. 2000 Jimmy SLE: starting problems
  137. 93 jimmy transmission dragging??
  138. digital dash lights
  139. 1997 Jimmy-Draining Torque Converter
  140. Help 93 4x4 Not Wokin Wheres Vacum
  141. 255/60/18 vs. 255/55/18 - Braking??
  142. weird noise and leak
  143. Door pin and bushing repair How-To!
  144. rods and pistons
  145. 1997 jimmy radio codes
  146. 1994 Jimmy Drop Kit
  147. noise in cab
  148. The Tremclad Jimmy (56k..ye be warned)
  149. 95-96 No 4x4 Hi - Low works - I did a search w/no results.
  150. Russian Roulette Jimmy!
  151. The elusive door sping tool
  152. ses light 1996 jimmy
  153. newbie
  154. dash
  155. no spark from coil. its new
  156. Fuel Pump Removal
  157. 1995 Jimmy intermitent starting
  158. Where can I find an exhaust for..?
  159. 1996 Jimmy - No Electrical Power - Head Gasket R&R
  160. 31's?
  161. Jimmy - Brakes (Please Help!)
  162. PO 171 code system lean bank 1
  163. Fuel Pump
  164. even-fire or odd-fire engine
  165. Keyless Entry 2000 Jimmy
  166. 96 Jimmy 4.3 Is it dead question
  167. wheel hub replacement
  168. ABS light, no codes found
  169. 2000 Jimmy SLE: Crappy ride
  170. 2000 Jimmy SLE: Alarm
  171. Brakes: fixed but still squealing 2000 Jimmy SLE
  172. So.. what to do with this Jimmy?
  173. shifter unlocks/locks doors and hatch
  174. front end noise
  175. v8 conversion kit
  176. performance exhaust question
  177. How Do I Get To It?
  178. Wiper Installation
  179. 1995 Jimmy
  180. Jimmy front end problems
  181. IAC Valve location
  182. Temperature Sensor
  183. Leaky Fuel Tank
  184. Low end break up......
  185. This is why I don't do bodywork...
  186. 1995 jimmy problems all at once
  187. 1993 jimmy fuel problem
  188. heater core replacement 99 slt
  189. TBI Problems
  190. Driving-hesitation in my 99 Jimmy
  191. Bumpers on Axle
  192. 97 Jimmy Question
  193. Climate Control????
  194. location of "90" jimmy radiator drain plug?
  195. Automatic Transmission oil change nightmare
  196. PO 0133/0134 N02S...location?
  197. Who wants to see me with my upper plenum off?
  198. 6 X 9 Speakers in 94 Jimmy
  199. Reconnecting ABS Breaking system
  200. locating ecm on my truck
  201. 97 Jimmy No start no crank
  202. Stalling 95 Jimmy
  203. Fluid Capacities for Jimmy Drive Trian
  204. cheap lift
  205. interior lights do not go out
  206. motorr oil in coolant resevoir
  207. air shocks
  208. P1415 - Secondary Air Injection (AIR) system Bank 1
  209. 91 Jimmy power windows problem
  210. Radiator Cap
  211. Will this tran work w/my 95 Jimmy?!!!
  212. tweeters
  213. 1991 JIMMY 4X4 Transmission
  214. 91 jimmy power mirror problem
  215. 1995 keyless entry ?
  216. headlamps stay on
  217. 1988 jimmy speaker size
  218. gas tank popping
  219. 98 Jimmy - Remove the Rear Rotar
  220. Jimmy-1 question- 500+?
  221. heater core
  222. replacing rear torsion bar mounts?
  223. replacing EGR Valve?
  224. 1995 GMC Jimmy Power Locks
  225. What is the VSC2200 or the VSC2300?
  226. p1870 trouble code
  227. automatic climate control no heat
  228. Steering shaft
  229. brake lines
  230. For ONCE can someone answer this: Broken Rear Gate (not glass)
  231. Intermittant spark 95 Jimmy I'll try ANYTHING!
  232. Moderator Suggestions
  233. 92 gmc jimmy se
  234. location of fuel filter??????
  235. Tornado and similar products.
  236. how-to with Brakes on 92 Jimmy
  237. wheel studs
  238. Which fuel pump do I need? (98 Jimmy)
  239. 1997 - Front doors leak
  240. dash buttons
  241. What oil grade should I use?
  242. PO446 code
  243. Rapidfire vs. Platinum?
  244. 98 Jimmy to blazer front end
  245. ABS brake light is on
  246. Installing distributor after turning crankshaft
  247. Jimmy sputtering after startup?
  248. The list keeps getting longer, but I have found....
  249. Transfer case with custom, special order Bondo applied
  250. problem with 1994 gmc jimmy
