View Full Version : Jimmy
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. Fluid Capacities for Jimmy Drive Trian
  2. cheap lift
  3. interior lights do not go out
  4. motorr oil in coolant resevoir
  5. air shocks
  6. P1415 - Secondary Air Injection (AIR) system Bank 1
  7. 91 Jimmy power windows problem
  8. Radiator Cap
  9. Will this tran work w/my 95 Jimmy?!!!
  10. tweeters
  11. 1991 JIMMY 4X4 Transmission
  12. 91 jimmy power mirror problem
  13. 1995 keyless entry ?
  14. headlamps stay on
  15. 1988 jimmy speaker size
  16. gas tank popping
  17. 98 Jimmy - Remove the Rear Rotar
  18. Jimmy-1 question- 500+?
  19. heater core
  20. replacing rear torsion bar mounts?
  21. replacing EGR Valve?
  22. 1995 GMC Jimmy Power Locks
  23. What is the VSC2200 or the VSC2300?
  24. p1870 trouble code
  25. automatic climate control no heat
  26. Steering shaft
  27. brake lines
  28. For ONCE can someone answer this: Broken Rear Gate (not glass)
  29. Intermittant spark 95 Jimmy I'll try ANYTHING!
  30. Moderator Suggestions
  31. 92 gmc jimmy se
  32. location of fuel filter??????
  33. Tornado and similar products.
  34. how-to with Brakes on 92 Jimmy
  35. wheel studs
  36. Which fuel pump do I need? (98 Jimmy)
  37. 1997 - Front doors leak
  38. dash buttons
  39. What oil grade should I use?
  40. PO446 code
  41. Rapidfire vs. Platinum?
  42. 98 Jimmy to blazer front end
  43. ABS brake light is on
  44. Installing distributor after turning crankshaft
  45. Jimmy sputtering after startup?
  46. The list keeps getting longer, but I have found....
  47. Transfer case with custom, special order Bondo applied
  48. problem with 1994 gmc jimmy
  49. 93 Jimmy Oil Filter Location
  50. oil pan removal
  51. 1993 Jimmy SLT 4x4 FOR SALE
  52. tachometer jumps in rhythm w/ blinker
  53. idle problem and lost of power with the a/c on
  54. left vent noise
  55. Question on interior lights
  56. I don't believe/trust the 2 diagnosis on my '98 jimmy
  57. No heat in 2000 Jimmy
  58. sloppy idle..almost hiccups
  59. sloppy idle..almost hiccups
  60. 98 Jimmy brake rotor
  61. Smelly, inefficient, misses out, and more!
  62. 95 HVAC problem
  63. help
  64. Best Plugs and Wires to Use on a 1995 GMC Jimmy
  65. 1992 jimmy won't start one day, the next day it does
  66. Oil Pressure Switch
  67. 98 jimmy digital dash cluster
  68. Shift lever 99 Jimmy
  69. 1998 jimmy stalls evry day when first started
  70. 1997 Jimmy blowing transmission fluid out!
  71. Truck Not Running Right? Hard On Fuel And Sluggish Power? Try These First.....
  72. PLEASE HELP!!! Billet grille instal!!!
  73. egr screen?
  74. passenger side front wheel noise 92 gmc jimmy
  75. 1993 Jimmy No trans codes, bad shift
  76. Rough idle Bad Gas Mileage
  77. 99 Jimmy Overheating
  78. 1999 jimmy won't shift to 4 wheel low
  79. no reverse 2nd or 4th gears
  80. 95 power seats
  81. speedometer lags,abs light on
  82. SES,tranny,no brakes, EGR,
  83. 1998 Jimmy - ABS Light on Intermittantly
  84. Smoke is coming out of dipstick tube, after motor oil change
  85. Everything dead and key is stuck
  86. 97 jimmy cranks won't fire
  87. 1995 GMC Jimmy ABS Controller Module
  88. Help! 1995 Jimmy turn signal flasher
  89. How do I read transmission codes?
  90. Dash gauges are ugly...
  91. pin outs for a digital dash
  92. Rough idle and acceleration
  93. Intermittent Vibration at Highway Speeds
  94. 1995 GMC Jimmy Electric Fan Installation
  95. 1995 jimmy 1/4 mile times?
  96. Ignition Switch
  97. 1995 GMC Jimmy Harmonic Balance
  98. please help 94 jimmy smoking mysteriously
  99. Dexcool
  100. vacuum hose routing
  101. not getting fuel into the throttle body
  102. How do i attach an engine hoist?
  103. fuel gauge not registering
  104. signal lights clicking but not on ?
  105. Changing my guages
  106. 4WD 2001 Jimmy surging, stalling, hardto start--It was the Coolant Temp. Sensor, prom
  107. Car idles bad, no brakes, exhuast rushing out of tailpipe
  108. Odd problem - Dash lights up like a Christmas tree
  109. 98 Jimmy rear brakes sticking
  110. 95 Jimmy running hot
  111. oil in coolant tank
  112. How much oil do you add when you change your oil and filter?
  113. Where is the Tach wire?
  114. Where's the drain on the radiator of 97 Jimmy 4x4?
  115. Squeaking front-end chassis
  116. transmission
  117. 1995 RPO Code question
  118. Torsion Bar Lift
  119. Found a Jimmy
  120. Kill the chime module!!!
  121. Rough Idle fixed for good this time.
  122. rough acceleration
  123. 1995 Jimmy Belt Or????
  124. transmission clunks into third
  125. 1995 jimmy fuel pump won't shut off/ relay location
  126. Four Codes All At Once
  127. electrical short?
  128. 2001 GMC Jimmy Humming Noise
  129. Is this all connected
  130. Catalytic converter or Gasoline ping???
  131. Overhead install
  132. Alarm & Remote Starter - Any Issues with Jimmy Install?
  133. 1995 GMC Jimmy Backfire, blows muffler
  134. Horsepower and Torque
  135. Power Seat failure, Dashboard lights - any fix?
  136. I'm so happy!!!!!
  137. Grinding AC/Heator switcharoo
  138. computer climate controle
  139. Fuel Gauge and SES light
  140. Have I siezed my engine? Replaced starter but still not turning.
  141. 1995 GMC Jimmy questions
  142. 2000 Jimmy Terrible Gas Mileage
  143. lost power to horn,radio,lighter,and rear window
  144. 99 Jimmy tailgate not opening
  145. code P0147
  146. oil plug
  147. anyone tried 6gun tuner or venom400?
  148. 92 Jimmy spark plug wire order
  149. Anyone tried to clear headlights on a 98 or newer Jimmy?
  150. level of octane to run?
  151. 93' Jimmy 4WD problems
  152. rear wheel bearing
  153. Been doing a test on our gasoline
  154. 93' Jimmy
  155. 1987 jimmy fuel problem
  156. 1995 rear window wiper
  157. Transmission problems
  158. Check Engine Light
  159. throttle body spacers
  160. "Service Engine Soon" light on '94 S15 Jimmy
  161. 98 Jimmy, rough starts
  162. 94 Jimmy, Belt Squeal
  163. 2001 Jimmy 4wd stalling, reving
  164. Fuel System Help
  165. 96 Jimmy no crank- intermittent
  166. 2000 Jimmy Loud Front End Noise
  167. Engine Oil Capacity?
  168. Torsion bar isolator mounts?
  169. Once more, an idle question. Tried a search
  170. AC Problem
  171. automatic head lights
  172. Warning Lights
  173. 1996 Transmission
  174. wiring digrams
  175. Exhaust problem
  176. Lighting System Issue
  177. 96 no start prob
  178. A new type over overhead Console <evil grin>
  179. Ignition switch wiring diagram.
  180. EGR gasket w/ screen update
  181. jimmy front end noise
  182. 2000 Jimmy A/C problems
  183. replacing shocks
  184. Rivets holding power window motor
  185. P0410
  186. oil pressure question
  187. Heavy Trans Leak Under Load???A
  188. Rough Idle and starting problem
  189. Hazards stuck ON
  190. ABS Light
  191. 98 jimmy service light
  192. 1996 Jimmy rough idle - still trying
  193. MoDifications
  194. H.I.D. Conversion
  195. Hi. Newbie with a 97
  196. EGR Valve
  197. Note to Blazer LT
  198. digital
  199. Oil Question
  200. sway bar bushings
  201. 1990 rear hatch
  202. Programming instructions for 00 Jimmy remote
  203. Folw-up to the Fuel Pump Question below
  204. Fuel Pump / Relay Issue??
  205. 1984 Jimmy, keep or sell?
  206. AC Problems
  207. power window motor replacement question
  208. Jimmy spark plugs
  209. 1998 Tranny problem
  210. Random-ish stalling
  211. Acts like brakes are sticking
  212. Oil guage fluctuating
  213. Wheel Bearings
  214. Slight Hesitation or Bucking when going uphill
  215. would'nt come out of 4 low
  216. 1998 Jimmy Tranny cooling lines at radiator
  217. surging and stalling and hard starting
  218. Power window problem
  219. Yet another Transmission question!
  220. 2000 Jimmy Intermittent Stall at stops
  221. Tire Size VS MPH
  222. Wierd 4x4 problem 1997 GMC
  223. Loud humming noise from front end
  224. 1993 Jimmy wont start
  225. 94 Jimmy EGR Valve, Code 32, please help ASAP!
  226. 1993 Jimmy Fuel Pump Relay Location
  227. 1996 GMC Jimmy Transmission
  228. Rough idle, Very Strong Exhaust Fumes, Feels like it misses, Ect...
  229. Air only blows cool at idle?
  230. Another 97 Jimmy Problem, please help!
  231. transmission filter
  232. open/closed loop trouble? 1994 S-15
  233. 1998 jimmy waterpump
  234. 99' GMC driving problems
  235. 95 jimmy vortec 4.3 Rough Idle, Gas and carbon Smell, Engine shakes
  236. ***List of OBD II Codes***
  237. **Transmission Codes - What They Mean and What Happens**
  238. Roof rack capacity of the Jimmy?
  239. fuel pressure, please help, cpi?
  240. 1999 GMC Jimmy stuck in 4LO
  241. Goodbye 99' Jimmy!!!
  242. tranny pukes when starting only!
  243. 4x4 troubles, vacuum hose routing
  244. 2000 GMC Jimmy SLT
  245. good bye jimmy
  246. P0175 too rich
  247. Stuck rotor
  248. steering stabilizer
  249. All lights ok but no brake lights.
  250. how to change out headlights
