View Full Version : Jimmy
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. 1992 Jimmy (w) compatible with Blazer rear end?
  2. Help with written off Jimmy to get back on her Feet
  3. Westin push bar/guard
  4. Pulling Airbag fuse
  5. rebuild 4.3 with low (no) oil pressure
  6. Dash cluster light(s), cruise control not present?
  7. Climate control & heated seats Q's
  8. ignition module
  9. 94 Jimmy 4 Wheel Drive problem
  10. P0452
  11. CV joint boot to front transaxle.
  12. 1998 Jimmy axel nut torque
  13. code 42
  14. Need help with oil leaking problem from oil filter plate fitting thing.
  15. Fuel line gaskets at Manifold - 97 Jimmy
  16. suburban a/c problems
  17. 1995 4.3W High Idle Problem
  18. tranny problems
  19. Another CPI How-to (focus on regulator)
  20. How-to change the PITA #3 spark plug
  21. 1996 Jimmy problems
  22. Oil Filter, Which one?
  23. Need Help, poor college student with a broken truck
  24. Antifreeze/coolant in Engine oil
  25. 99 1 brake light out bulb good
  26. Where is the battery fuse located on a 95 Jimmy
  27. 93 Jimmy has leaking heater core
  28. P1870 tranny code have anything to do with shift button?
  29. 95 jimmy O2 sensor
  30. 97 NOStart Jimmy & Elusive Solutions
  31. Front diff leaking antifreeze?
  32. 95 GMC Jimmy 4 wheel drive problem. please help
  33. Exhaust modification
  34. 1993 heater core removal
  35. Headlight Retainer Clip
  36. 93 jimmy cold start trouble
  37. Both banks are lean
  38. instrument panel lights 93 jimmy
  39. Heater Control Switch "Hissing"
  40. 1995 GMC Jimmy emergency brake light
  41. 92 Jimmy Waterpump torque spec
  42. 1995 Jimmy won't start...no spark??
  43. Heater Fan problems
  44. Code P1441 on a 95 Jimmy?
  45. Fuel pressure regulator
  46. 4.3L oil pressure sensor
  47. door attachment
  48. 95 jimmy dash lights gone out
  49. blower motor and wiper problem for the wiring gurus
  50. Reverse type Heater problem
  51. Fuel Pump going out every 3-6 weeks :(
  52. HELP GMC'ers!
  53. Front Windshield wiper nozzles
  54. "Check Engine Soon" Code 128 meaning
  55. Door lock bypass
  56. 1998 Jimmy with cold starting issue
  57. Dome Light Always On
  58. fuel tank part question
  59. rear window will not open
  60. 1997 JIMMY No oil and tapping!
  61. Is it even possible?
  62. How to have fun with a crappy Jimmy
  63. 1998 jimmy wiring info for remote staeters
  64. 1992 Jimmy 4WD help
  65. Heater Core 2000 GMC Jimmy
  66. dash ghosts??
  67. Heater Fan quit
  68. Read First - FAQ & how to thread!!
  69. My Heater Core Is Out Can I Drive?
  70. Remote car starter ...recommendations
  71. No power to some fuses (Htr, A/C, PwrWindows) all of a sudden???
  72. 99 Jimmy - 4wd problem
  73. won't start
  74. '96 Jimmy turn signals
  75. 1991 s15 jimmy 4x4 front wheel bearing and axle
  76. Last try....need any suggestions you got!
  77. Transmission Fluid in Transfer Case
  78. Unknown Buzz
  79. Does bad CPI cause P1506?
  80. Sudden Rough Idle/95 Jimmy??!!??
  81. P0143 Code
  82. Motor Silk?
  83. stumped with 4.3 spider assembley, help!!!
  84. Can't bleed brakes
  85. 95 Jimmy fan speed control smokes
  86. check engine light.
  87. What is common between the front wipers and rear wiper???
  88. 1988 Rear Window
  89. 95 Pontiac Grand Am stalls in reverse, runs in all other positions.
  90. Why does GM charge so much for their parts?
  91. noise on left front wheel of 1991 s15 jimmy
  92. '91 won't start
  93. lack of power when accalerating
  94. Jimmy cold starting problem
  95. Full time 4x4 on my Jimmy
  96. Heater is a pain in the a$$. HELP!
  97. Door locks
  98. Help! Back Brakes 99 jimmy
  99. how to set the universal garage door opener
  100. Driverside door Pins and bushing replacement
  101. Cant adjust passenger side headlight...
  102. 1997 Jimmy License Plate Lamp
  103. 95 jimmy 4.3w
  104. 1993 Gmc Jimmy 4.3L Vtech.....not starting
  105. 1996 Jimmy 4 wheel drive not working
  106. CPI Fuel Pressure regulator
  107. Little help
  108. Someone might be upset
  109. heater doesnt work
  110. wheel bearing replacement
  111. front wheel bearing 2000 jimmy 4x4
  112. What would you do
  113. 87 blazer 2.8L to 4.3L
  114. 1998 Jimmy SLS Rear Defogger\Defroster
  115. my '94 S15 is officially dead
  116. Engine rev-ing off and on when warm
  117. 305hp Awd
  118. Hot butt how-to!
  119. Squeel from pulley
  120. Jimmy 4 Wheel transfer quit
  121. 1997 Jimmy with a transfer case problem.
  122. wont go into 4x4
  123. 2001 Jimmy stalls in rain
  124. digital dash
  125. Idle Problem
  126. GMC Logo Patches
  127. 95 jimmy fuel pump replacement
  128. 97 jimmy axle seal replacement
  129. 1996 jimmy no heat, is it the blend door?
  130. Front Wheel Bearings
  131. vacuum digram for heater needed
  132. both turn signals and hazzard lights failed
  133. Electrical static noise
  134. 96 jimmy heater core, do i really have to remove the dash?
  135. 1995 jimmy cpi/nut kit?
  136. Where is the Transfer Case Control Module TCCM?
  137. 01 Jimmy Havoc
  138. 4x4 switch has no lights
  139. Air filter, spark plugs, and wiper weirdness
  140. Any Idea How To Program Keyless Fobs For 1994 Jimmy??help!!
  141. starter
  142. '98 Jimmy leaking coolant (dumping, really)
  143. Ignition won't turning
  144. hard to start in cold weather
  145. 95 Jimmy, slow battery drain
  146. not getting fuel
  147. Evap Code - No Flow Detected
  148. 2001 Jimmy shuddering upon acceleration
  149. Lift struts for rear window
  150. 93 s15 Jimmy 4wd
  151. Engine revs at idle!!
  152. 88 FI oil pan removal
  153. Steering seems.. loose
  154. Is a the frame on a 73 the same as a 76?
  155. I don't think I'm getting fuel
  156. Hitchikers
  157. Dealer said its makin' metal now... Updated.
  158. 94 Jimmy 4x4 Issue
  159. Block Heater
  160. 1995 Gmc Jimmy 4wd Wont Work But 4wd Low Does
  161. Service 4wd light
  162. Got bored over lunch.. boy am I lame...
  163. Its just 1 bolt holding the oil lines to the oil adapter?
  164. Electrical Whine
  165. 99 Jimmy heater core "How do you open the box?"
  166. Front end growl/grind
  167. 2000 Jimmy SLT windshield leak & gas guage problem. Please help!!!!
  168. 2001 jimmy bose system
  169. Just paid .84 cents per gallon for gas, I love Amerika!
  170. Trans OBD II Code P1886 Trouble.
  171. smelling anti freeze
  172. hvac fan
  173. Sound from steeling wheel while turning
  174. Anti Freeze?
  175. 4X4 Issue. BATTERY RESET TO FIX is Temp FIX.
  176. plz help my jimmy went crazy
  177. 4x4 low and hi ele switch and rearwindow wiper
  178. 93 jimmy ignition? starting to drive me crazy
  179. 91 jimmy power windows.fuse panel schematic.
  180. Any one know part # for egr valve screen?
  181. Rear drum to disc conversion
  182. Replaced spider, nut kit, air filter, changed the oil and still...
  183. heater flap 2000 Jimmy
  184. Changing an Oil Pressure Sender 4.3L
  185. '93 Jimmy Heater core replacement
  186. 93 jimmy starts but turns over for ever
  187. up in smoke
  188. 2000 Jimmy SLE: starting problems
  189. 93 jimmy transmission dragging??
  190. digital dash lights
  191. 1997 Jimmy-Draining Torque Converter
  192. Help 93 4x4 Not Wokin Wheres Vacum
  193. 255/60/18 vs. 255/55/18 - Braking??
  194. weird noise and leak
  195. Door pin and bushing repair How-To!
  196. rods and pistons
  197. 1997 jimmy radio codes
  198. 1994 Jimmy Drop Kit
  199. noise in cab
  200. The Tremclad Jimmy (56k..ye be warned)
  201. 95-96 No 4x4 Hi - Low works - I did a search w/no results.
  202. Russian Roulette Jimmy!
  203. The elusive door sping tool
  204. ses light 1996 jimmy
  205. newbie
  206. dash
  207. no spark from coil. its new
  208. Fuel Pump Removal
  209. 1995 Jimmy intermitent starting
  210. Where can I find an exhaust for..?
  211. 1996 Jimmy - No Electrical Power - Head Gasket R&R
  212. 31's?
  213. Jimmy - Brakes (Please Help!)
  214. PO 171 code system lean bank 1
  215. Fuel Pump
  216. even-fire or odd-fire engine
  217. Keyless Entry 2000 Jimmy
  218. 96 Jimmy 4.3 Is it dead question
  219. wheel hub replacement
  220. ABS light, no codes found
  221. 2000 Jimmy SLE: Crappy ride
  222. 2000 Jimmy SLE: Alarm
  223. Brakes: fixed but still squealing 2000 Jimmy SLE
  224. So.. what to do with this Jimmy?
  225. shifter unlocks/locks doors and hatch
  226. front end noise
  227. v8 conversion kit
  228. performance exhaust question
  229. How Do I Get To It?
  230. Wiper Installation
  231. 1995 Jimmy
  232. Jimmy front end problems
  233. IAC Valve location
  234. Temperature Sensor
  235. Leaky Fuel Tank
  236. Low end break up......
  237. This is why I don't do bodywork...
  238. 1995 jimmy problems all at once
  239. 1993 jimmy fuel problem
  240. heater core replacement 99 slt
  241. TBI Problems
  242. Driving-hesitation in my 99 Jimmy
  243. Bumpers on Axle
  244. 97 Jimmy Question
  245. Climate Control????
  246. location of "90" jimmy radiator drain plug?
  247. Automatic Transmission oil change nightmare
  248. PO 0133/0134 N02S...location?
  249. Who wants to see me with my upper plenum off?
  250. 6 X 9 Speakers in 94 Jimmy
