View Full Version : Jimmy
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. hmm... transmission advice
  2. bolt pattern
  3. 1996 jimmy tranny fluid and filter change
  4. 93 jimmy speedo
  5. rotors?
  6. radiator cap
  7. Removal of 97 Radiator Drain Petcock?
  8. GMC Jimmy turn signal problems!!!
  9. 1993 Starting Problems
  10. fueling problems
  11. '98 Jimmy 4WD.HELP PLEASE.Stuck Ball joint
  12. 97 Blinkers.
  13. Air conditioner freon leak - help
  14. For better results...
  15. Temperature gauge
  16. 1996 Jimmy - How to remove the trailer hitch?
  17. looking at jimmy as daily driver need advice
  18. 96 jimmy front bumper
  19. 2001 Jimmy relay for the secondary air injection pump
  20. Need help with 99 jimmy powertrain control module
  21. 1992 need help removing the ECM
  22. Jimmy Idles fine, but when driving...
  23. 91 jimmy bumper and grille
  24. 96 Jimmy Braking problems. Please help.
  25. Service Engine Soon codes
  26. Going to replace plugs
  27. lift kit
  28. 98 Jimmy not starting
  29. 94 GMC Jimmy 4x4 4.3L(W)CPI Vortec---surging, no start, and wont shift
  30. 94 GMC Jimmy 4x4 4LO works but not 4HI...
  31. my 2.8 Sucks
  32. 1998 Jimmy radio flashing
  33. trip keeps reseting
  34. 2000 Jimmy door panel removal/speaker replacement
  35. 97 jimmy relay sitch
  36. 4X4 trouble...I love this site!!!!
  37. Tires Tires Tires
  38. ECM on a 1996 jimmy
  39. help with a 92 gmc jimmy
  40. Replacement Bumper End
  41. female stuck in park
  42. Programming new remote
  43. Side View Mirror Not responding...
  44. ABS problems on my 93 jimmy
  45. distributor out of wack 98 jimmy 4.3
  46. distributor out of wack
  47. 96 jimmy jumping against starter
  48. 84 jimmy 4wd 2.8 2bbl hesitation
  49. 84 jimmy 4wd fuel filter location
  50. Inexpensive mechanics/Co.
  51. Heater core
  52. stalling trouble
  53. Front bumper 1995 Jimmy
  54. fuel pump relay location ?
  55. 96 jimmy ses lite
  56. High/Low headlight mod
  57. 2000 Jimmy SLT, Sunroof electrical Problems
  58. 1999 Gmc Jimmy
  59. 89 s-15 jimmy door lock relay
  60. jimmy 94 hatch lock cylinder
  61. I have no knowledge about car mechanic - should I buy a Jimmy?
  62. Jimmy's average lifetime and other question...
  63. jimmy 1996 4wd
  64. rear wiper wiring issues
  65. 1994 stalling, this seems unique
  66. Jimmy whistle sound
  67. Lower the Jimmy?
  68. 97 Jimmy Oil Filter Location
  69. 95 gas tank vents (where to get)
  70. 1999 Gmc Jimmy Sls 2 Door Heat/engine Problem
  71. 2001 Jimmy a/c drain tube location
  72. Forum Rules! READ ME BEFORE POSTING!
  73. 95 Jimmy Motor Shot, Will a 94 4.3 vortec fit?
  74. 92 s15 4wd inop
  75. 95 Jimmy wont start plz help
  76. 93 GMC S15 jimmy or S10 blazer power windows
  77. P0440 - 96 Jimmy
  78. 90 GMC Jimmy Knocks
  79. 2000 Gmc Jimmy Quit And Won't Start
  80. Intermitten tranny.... Any suggestions?
  81. misfire problem
  82. Speedo inop
  83. Do it yourself questions.
  84. How to buy a better Jimmy ?
  85. 96 Jimmy hard to start
  86. odometer
  87. 4wd trouble / 97 jimmy 4.3
  88. Power Window Stopped Working
  89. An easy one for ya, old timers.. ;)
  90. 1993 Jimmy GMC PLEASE HELP!
  91. Climate control knob failure
  92. Shuttering through steering wheel
  93. Alarm system? (i am helpless)
  94. 96 to 2000 converson?!
  95. Gas Smell/Leak On Fill Up
  96. help finding check/purge valve on 99 jimmy
  97. 94 jimmy timing problem.
  98. SQUEEK SQUEEK SQUEEK argh!
  99. 94 Jimmy uncommon wiper problem
  100. '92 Jimmy windshield washer sprayer
  101. 1997 GMC Jimmy HELP!!
  102. 4X4 default problem
  103. 2001 GMC Jimmy Keyless entry problems...
  104. Low Idle
  105. Escort 15.5'' dual speed electric cooling fan
  106. headlights/ flicker
  107. 31" tires on '98 jimmy sle... how?
  108. 95 jimmy blows ecm fuse when I floor it
  109. 89 jimmy wiring problem
  110. trans fluid loss
  111. Over heating only at idle
  112. Fuel Gauge fluxuates alot .
  113. Vortech 4.3 knock with info.
  114. Help....cant drive at night! Headlights wont work
  115. Intermittent starting problems-2000 jimmy
  116. 93 Jimmy not downshifting to pass
  117. 98 door stop pins
  118. 1996 jimmy new PCM tranny won't shift now!
  119. 2001 Jimmy loud Noise Problem...
  120. could use some advise, 2001 gmc jimmy
  121. No a/c or heat
  122. Is there anyway to check the VCM-A
  123. 91 s15 jimmy sle
  124. 2000 jimmy wont start
  125. 91 Jimmy wont start
  126. Tranmission Problem...I think!
  127. Front knocking noise passanger side
  128. 92 Jimmy sputtering and hesitating...
  129. 98 Jimmy A/C on again off again
  130. Help 89 jimmy sunroof removel
  131. 91 Jimmy rear hatch broken
  132. 1996 Jimmy 4WD Problems
  133. oil on my bell housing 1990 s15 jimmy
  134. Transmission Trouble on a 1995 GMC Jimmy
  135. Keyless entry and alarm
  136. 1995 Jimmy 4.3 CPI no start-have fuel pressure
  137. 98 Jimmy rebuild project - help in removal!
  138. Distributor installation on 95 4.3???????????
  139. 01 ABS Light On
  140. 99 jimmy SLT reverse will not work?
  141. Fan clutch
  142. Tailgate Latch Control
  143. 97 Jimmy fuel pump pressure
  144. 4 wheel drive problem
  145. broken connection on a/c clutch???
  146. 1990 S15 jimmy is rattling underneath???????????
  147. Little info needed
  148. A/C compressor making growling noise
  149. 4.3 vortec transmision compatability
  150. 2000 Jimmy .Slt, Buttons Above Drivers Sunvisor ?
  151. bosch fuel pump and spare wires
  152. 1999 Jimmy HVAC Control Head and Gauge Lights acting up.
  153. Tips for putting the gas tank back into place on a 1993 Jimmy.
  154. are gear ratios diferent between 1991-1993?
  155. A/C - Heater Fan won't turn off 98 jimmy
  156. 1990 jimmy digital dash,temp reads 200+
  157. 90 S15 Jimmy New Starter Wont Disengage
  158. Brakes work but motor doesn't
  159. 97 Jimmy Driver Power Seat Not Working
  160. E-85 question
  161. Shocks
  162. 93 s15 jimmy 4wd and abs
  163. 2001 Jimmy 4WD Self-Engages
  164. powered driver seat in 95 Jimmy SLE not working
  165. 92 jimmy ignition module
  166. '95 Jimmy 4.3 CPI Vortec - I'm AT WITS END!
  167. Some Knocking Noise????
  168. electrical problem need help!
  169. 95 jimmy ignition switch?
  170. Swap to a ZQ8 steering box
  171. Noise
  172. '95 Jimmy 4.3 Vortec doing it again....
  173. 95 Jimmy SLE died while driving and now won't start
  174. need advice, and a little help from me friends!!
  175. Does This Estimate Sound Right To You?
  176. 94 Jimmy Hood issue?
  177. 97 Jimmy Fuel Delivery
  178. "Service 4WD"
  179. 2001 Jimmy Starter
  180. Few random questions...91 Jimmy
  181. '95 Jimmy 4X4 brake job - COMPLEATED!
  182. Blower motor breaks down in extreme cold?
  183. 95 jimmy fuseable link burns
  184. 94 Jimmy battery drain
  185. Sticky pedal
  186. Suggestions for fuel pump
  187. Wiring
  188. 1996 Jimmy won't start
  189. old vs new injector leaks
  190. Gas
  191. Fuel pressure details
  192. Best way to remove a "stuck" rear brake drum?
  193. Ignition
  194. Trouble with lights
  195. 1993 starting problems - and where is the darn fuel pump relay?
  196. 93 Jimmy 4.3 Vortec idle problem
  197. Corroded Transmission Dipstick
  198. Door Retainer Clips
  199. A heads up on No-Starting
  200. Where does everyone seem to be finding their 36mm Deep Sockets????
  201. Balljoints and torsion bar
  202. 93 jimmy 4.3 valve spacing
  203. Try it one more time...
  204. Wiper Motor stops and buzzes?
  205. 99 jimmy breaking
  206. ABS Code Reading
  207. 1993 Jimmy Transmission fluid change
  208. How the heck do you remove the #3 plug in a 4.3 Vortec?
  209. Seafoam?
  210. 91 S15 Jimmy Check Gages Light when stopping
  211. 01 Jimmy Lock Cylinder/Ignition
  212. Bad alternator or battery?
  213. Manual transfer case won't shift into 4hi
  214. Digital read on compass says OC
  215. Replace steering rag joint with urethane
  216. 1998 Jimmy runs -- then stalls
  217. Questions
  218. 2001 Jimmy - Code 0440
  219. anyone try to improve fuel economy?
  220. Engine misfire on one cyl
  221. Trailer wiring for a 94 s15 4x4
  222. 95 Jimmy 4.3 Vortec starting problems - weird
  223. Finally fixed; stalling when hot (long)
  224. ZR2 conversion 99 Jimmy (Lift kit)
  225. 4.3l power lost & Back Fire
  226. 4 Lo light stays on... Power window motor
  227. 95 Jimmy engine swap
  228. steering is out
  229. 95 battery drain
  230. bogging no power off idle
  231. 93 into 95 motor swap
  232. Gas smell
  233. where is it?
  234. 2000 Jimmy Shake/ Wobble
  235. 95 Fuel pump, etc...
  236. 98 GMC Jimmy power loss
  237. What gives these pigs better fuel economy?
  238. Ok, I got it ordered......now what.......
  239. Code explaination. OBD2 (Jimmy)
  240. 2000 Jimmy A/C and Blinker Problem
  241. Suspension woes -what gives?
  242. Tranny Fluid
  243. 85 700r4 transmission
  244. Gmc Jimmy-axle Swap
  245. Check Engine Light
  246. Fuel delivery issue
  247. Cheap Power Boost?
  248. jimmy tire sizes
  249. 4L60E Trans ?
  250. 96 Jimmy - ? fuel pump sound
