Our Community is 705,000 Strong. Join Us.
GMC
> Jimmy
View Full Version :
Jimmy
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
airbag replacement
Speedometer Gone Wild!!!!
99 Jimmy 4X4 with no heat
1998 Jimmy noise... help!
93 Jimmy Transmission slow to shift... ?
93 Jimmy Bad Cluster??
Po446
RUNS ROUGH and Smells Like eggs
gauge problem
Oxygen Sensor
1988 GMC Jimmy MPG Woes
91 jimmy moter swap
2000 Jimmy - humming sound
86 s-15 2.8 JUST WONT START
How do I find out....?????
Oil Pressure Line Leak
hard to start when engine cold!
Windshield Wiper Switch/Motor/Circuit Board?
Customizing a '93 HELP!
dash lights ( cluster)
found programming keyless remote 94 Jimmy
Common Transmission Failures
Overhead console
1988 jimmy slow to kick into overdrive
loss of power at 45mph
2000 GMC Jimmy Supercharger Application Recommendations
'86 S-15 Jimmy may not be what it looks like
Help! 1997 Won't start & dies while running!
Heater core replacement - '97 Jimmy...HELP
95 jimmy - computer error code - bank1 rich
2001 Jimmy SLT humming noise front end....
Help!! 2000 GMC Jimmy Popping and whining
power locks jimmy
Driver Side Door
Transmission problem
brake light & turn signal relay
Bad turn signals on 95 SLE Jimmy...
93 Vortex - EGR - not the normal problem...
Aftermarket regulator Legit?
New Truck
2001 jimmy for sale (great price!)
Trailer wiring harness.
FUSE for Rear Hatch Release Keyless Entry??
service engine soon light came on (96 Jimmy)
It won't stop!!
AC Compressor
96 Jimmy running rough
1995 S15 Jimmy
Code Scanner recommendations?
O2 sensors
95 Jimmy 4.3 bogging down(sputtering)
1991 GMC Jimmy Faulty Gauges??
'99 SLT - Front Brake Rotors Disintegrating
Wont Start
1992 Jimmy temp gauge and idle problem
1996 dead
96 GMC Jimmy.....A/C and turn signal problems
92 4.3L Wseries Dies and wont restart for a couple of hours??
Factory (?) Alarm
96 jimmy multiple problems.help...
Milage
99 Jimmy front end roar. Bad wheel bering???
2000 Jimmy dead!
95 jimmy-hearing a noise when accerating in gear
'94 Jimmy Dash Removal (attempting to remove heater core)
1993 Jimmy 4dr Replacing Cylinders on Rear Window
Where is the reverse-lights switch?
carbon in EGR causing problems
Automatic garage opener
95 Jimmy Back Hatch
1995 Jimmy 4.3 Vortec won't start
97 Jimmy4.3 rough idle
nigga wheels
'97 Jimmy Heater Core Removal
99 Jimmy DIED
Rough Idle
96 Jimmy Remote Keyless Entry
99 jimmy idles fast
Ac controls switch
2000 Automatic locks
1998 GMC Jimmy SLT - FOR SALE
Air Bag Module Location?
89 jimmy transmission change
89 jimmys dash changes
Code P440 on 2001 Jimmy
1997 jimmy remote entry location
4wd
'99 SLT Outside Tempature Guage Inaccurate
factory keyless entry
Power Seat Not Working????
Keyless entry?
'83 454 performance parts
20" rims 4 sale
Engine Swap
1995 Jimmy with S-L-O-W signal lights
Rough Cranking Idle
96 S15 jimmy rear end noise
Three very bad spark plugs
2001 Jimmy fuel gauge drops
running alittle rough
Any low budget Cpi units out there?
1989 gmc jimmy digital dash panel is dead!
2001 Jimmy Diamond Studder
tin can like rattle
1996 cranks but wont fire
1993 GMC Jimmy running rough
Rear Brakes Stuck on!
Rattling noise coming from the engine
EGR/code 32
more 97 jimmy probs. help please
Check engine light 2001 jimmy
Help...Need Spark Plug gap data...
Signal switch replacement help
heat/vent control hissing
96 Jimmy Stalling
Towing with 2000 GMC Jimmy (your opinion)
97 Jimmy center stick removal (squeeky spring)?
97 jimmy problems
2000 Jimmy Steering Problems
Clutch hard to shift 90 S15 4WD
Accuracy of electronic temperature display
1989 SPark plug wire hook up order look at diagram
89 jimmy starting problem urgent fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Car Stereo Code
Hiding my amp.
Groaning from frontend
4w drive clunkin bad going out and in???
01 jimmy klunk
Hazard button broke. Can you replace just the button?
P1870 xmission code
Wipers don't listen
FS OEM Manuals
Rear hatch problems
Cleaned EGR Valve
Name of part
Passlock2 Merlin Please Look
1991 GMC Jimmy rear main seal
Cruise stopped working
selling an '87 s15 jimmy
Line loose leaking transmission fluid.
1991 jimmy starter removal???Help Please
blower motor comes on when it wants to!
Blower motor location
towing
Intermediate hard start problem
New EGR valve, same problems
Changing Sparkplugs. How the hell do you get the one behind the steering shaft out?
Serpentine Belt Diagram
Starting trouble
Gas gauge is possessed!!
1997 jimmy slt block heater? do i have one?
brake dust
Water Pump Replacement - 1999 Jimmy
Many Many Thanks...to ALL
4x4 not working
intermittent stalling/hesitation
engine hesitation
performance parts for a 94
Carbon Buildup/EGR Probs
Ball joints
rotten eggs and gunowder??
4 Wheel Drive Problem
Bad Idle, Smell Gas, Can't read codes
Do I need a reverse flush on heat system?
stalling/ bogging problem solved
2000 Jimmy Blowing warm to cold
WANTED! 4.3 performance tips
97 Jimmy Turn Signal
bad idle, pulling time, and burning rich
How to tell if water pump is bad (Merlin?)
my Jimmy using excess fuel
Jimmy stuck in 4x4 won't change
1995 Jimmy Performance Help
94 Jimmy stinks
vacuum lines at transfer case 95 jimmy 4.3
2001 jimmy 4 sale
Leaky windshield.
ABS and brake lights
Oxygen sensor 1997 Jimmy
1998 jimmy power loss(please look Merlin)
Engine Knock
cd player
96 Jimmy "no start"
98 Jimmy Trip odometer resetting
High Mileage Jimmy
Towing
Just to let you all know.....
code 43 on a gmc jimmy can any body help
2000 Jimmy keyless
PLEASE HELP !!removable top '77 jimmy question
4X4 Clicking but not engaging
98 GMC jimmy Trans prob dont know what to do.
99 Jimmy climate control problem
Long beeping tone?
2001 jimmy 4dr 4 sale
'99 crank sensor location?
97 Jimmy 4WD Problem
Blower motor
2000 GMC Jimmy stalling
Noise under feet
Rear Window Squeak
Need aluminum wheel center cap :(
98 Jimmy Speedometer Problem
Wiring Problems
Heads for 92 4.3 Vortec V6
95 Jimmy Tail lights/ dash lights
rear end seal leak??
1993 GMC Jimmy 4.3 4x4 switch problem
99 jimmy power window problem
Power Mirror/Power Lock Challenge
Merlin, Can U Help?????????
NO HEAT in Michigan
Starts and Dies (security light on)
GMC Jimmy center stick removal
Heater FAn Controls
1993 4.3 Wseries that Stinks???
Side View Mirrors
power seat not working?
4x4 Prob#2
4x4 Problems(help Me Please)
1997 headlight adjustment
1997 jimmy outside temp reading wrong.
Used OEM Delco Radio and speaker question
95 Jimmy Idle fast and Stalls
water in A.I.R. pump
1998 dash lights and remote starter problems
2000 Jimmy Outside Temperature Display is off
1995 Jimmy makes odd noise!
1992 GMC Jimmy Parts for Sale
fuel problem
4WD wouldn't kick in....it's fixed thx 2 u guys!
S-15 Interlock Solenoid
How to reverse flush heating system
1993 jimmy
No overdrive or low
2001 jimmy wheels/tires for sale cheap
keyless entry and auto start
Heater Core Removal
serpentine belt
93 Jimmy Instrument cluster lights
1995 Jimmy w/ Blown motor
Transmission Problem
radiator coolant leak
2001 jimmy cuts off when I shift outta park
Power Locks have a mind of their own
Idle very bad stop
Service Engine Soon ??
Signal Relay continues to tick
Wiring lows/brights to run at same time?
Automotive Network, Inc., Copyright ©2013
