View Full Version : Jimmy
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. 2001 jimmy overaggressive
  2. 1999 Jimmy does not start
  3. High temp on cold block
  4. 98 jimmy securty light problems
  5. 97 JImmy grill
  6. adjusting timing
  7. 93 jimmy egr w 4.3
  8. dash lights going on and off
  9. 1988 4.3 jimmy overheating and running rough
  10. 30X9.50R15 size tires on a 2000 Jimmy 4X4 4 Door
  11. ABS activating at low speed
  12. power seat not working
  13. power seat not working?relay?
  14. Got problems with a loose front end, think you need shocks, etc..
  15. 94 jimmy a/c low side service port
  16. Heat for 10 secs, already reverse-flushed....
  17. ABS light symtom of another problem...
  18. 1989 Jimmy S15 4.3l just died
  19. HELP>> Start problems
  20. throttle body stuck? high idle RPMs-->Help!!
  21. Fuel Pressure Regulator
  22. Reseting the Computer
  23. What happened to the Tahoe
  24. 96 4.3 wont start after heavy rain
  25. Anyone re&re a Blazer front differential
  26. Ignition Key
  27. 2000 jimmy SES p0463
  28. multifunction/turn signal switch for 96 jimmy?
  29. abs makes brakes pulse intermittently/A?C question
  30. 1998 Having ALL KINDS of electrical problems
  31. 2001 GMC Jimmy Keyless Remote Location
  32. jack stands
  33. computer or sensor or....?
  34. DexCool gunking problem in 96 Jimmy
  35. 4 inch suspension lift
  36. That's it -- I can'ts takes it no-more!
  37. S-15 starting problems
  38. Outside Temprature display not working
  39. overhead console woes
  40. Intake Manifold Gasket
  41. Locked in Park
  42. 94 Jimmy Vacuum problems
  43. 1987 Jimmy Engine Probs
  44. 1988 GMC Jimmy (full size) for sale
  45. Stuck in Backyard...
  46. How to change the alternator on a 97????? HELP
  47. Help! '97 remote programming
  48. can you find trouble codes like you can with chrystler?
  49. heater assy
  50. 97 Jimmy - Mounting Driving Lights?
  51. transmission issue
  52. hot floorboard
  53. Front wheels not locking (4wd)
  54. Trying to removal a heater core (96 Jimmy)
  55. 95 jimmy metal in oil
  56. Can anyone tell me how to remove door panel?
  57. 98 jimmy
  58. gauges
  59. Wrist pin and/or rod baron in a 1996 Jimmy
  60. 1996 jimmy turn signal
  61. intermittent ABS light
  62. 1995 Jimmy S15
  63. '96 jimmy turn signal
  64. Window motor replacement
  65. I Need Some Seroius Help
  66. 2001 jimmy tire choices????????
  67. Rough starting, running rich
  68. 2000 Jimmy no power!!
  69. performance chip for 1991 s-15 jimmy
  70. Turn Signal Switch
  71. 95 jimmy air bag removal
  72. Jimmy Transmission
  73. heater problem 1991 jimmy - cold air only
  74. Gauge problem?
  75. Two questions on my 99
  76. 1999 GMC Jimmy Problems - Please help
  77. I cant get out.
  78. Many parts for sale for Jimmy/Blazer
  79. Cargo Net for Jimmy/Blazer
  80. 4.3 Vortec for Sale
  81. 4.3L Dual exhaust on a 89 JIMMY S15?
  82. rear wiper
  83. 1990 Jimmy Won't Start
  84. Radiator replacement
  85. StartingProblems 1997 Jimmy
  86. Piecing my 95 SLT out...any needed parts?
  87. Windsheild Wipers
  88. 1997 Jimmy Wont Start
  89. 1999 Jimmy Running very rough
  90. firing order 88 jimmy
  91. 89 S 15 shifting
  92. Fuel Injector Fuse
  93. minor oil leak
  94. Speakers
  95. tire size HELP
  96. 1997 Jimmy SLE
  97. Stuck in 4 wheel low
  98. Fuel pump relay location
  99. 93 Jimmy
  100. wont start
  101. Clunking under my feet
  102. 4.3 Vortec For Sale
  103. 99 Jimmy Complete Electrical Failure
  104. Removing door panles for 95 jimmy
  105. mirrors 97 to New04 style swap
  106. 4x4 problem drive shaft turning
  107. 2001 Jimmy Stalls
  108. catalytic converter??
  109. 2001 Jimmy Hestation
  110. Need your help/opinions
  111. headlights not working!
  112. can't let off gas or it dies
  113. CD player and Cruise Control
  114. '95 jimmy - lots o probs
  115. I need to know the rear-end size!! For a 1994 Jimmy 4 dr. 4x4!! HELP!!
  116. '97 Jimmy Overheating - please help
  117. remove radio from 1995 jimmy
  118. Jimmy S15 88 Stalling
  119. 87 4x4 s15 jimmy
  120. 1997 Jimmy with hesitation and a pinging sound.
  121. my jumping 2000 jimmy slt
  122. Scratch/slurp sound on acceleration
  123. power door locks
  124. trouble on cold start/ intermittent stalling
  125. '97 4.3 vortec turned bearings.
  126. 89 jimmy digetal
  127. programming the OEM alarm VSS-350
  128. "Buzzing" Engine?
  129. 99 Envoy/Jimmy Odometer Flickering?
  130. 2000 jimmy 4x4 problems
  131. Jimmy Service Engine soon light question
  132. 1999 Jimmy Intermitent Hesitation .. Plz Help.
  133. intake??????
  134. CPI Vortec Engine
  135. not fuel pump, but wiring?
  136. 91 Jimmy coolant leaking into A/C
  137. pitman and idler arms
  138. Radio is locked
  139. does anyone know?
  140. pcv valve
  141. Changing Dash Cluster Jimmy 97... Question!
  142. 97 GMC Jimmy
  143. won't start/fuel pump
  144. computer chip
  145. 88 s-15 misfiring
  146. 2002 Jimmy AUX on radio
  147. Gas gauge stuck on full
  148. 1992 gmc jimmy will not start
  149. 1996 Jimmy AC
  150. 1996 Jimmy Turn Flasher....where is it???
  151. Programming Remote
  152. It's new to me....
  153. 89 Heater control/AC GMCTECH HELP
  154. Steering geometry: 1988 S-15 4x4 Jimmy
  155. Driver Side window will not go up
  156. 96 Jimmy Fuel pump question
  157. Recharging the a/c?
  158. 96 Gmc Jimmy Tires??
  159. Buying advice
  160. O2 Sensor Location/ P0134/ Block 1 Sensor 2
  161. Hot air blowing on my feet
  162. 1996 Jimmy HVAC Filter
  163. Wanted
  164. 98 Jimmy Airbag Light
  165. 1994 jimmy stop!!!!!!!!!
  166. Please help timming 1994
  167. Which is Better? Second Gen Jimmy or Blazer?
  168. 2000 Jimmy SLT Seat Tilt
  169. 95 Jimmy no acceleration plus ABS light
  170. Fuel problem on '90 S15 Jimmy 4.3 4WD
  171. 98 GMC Jimmy: Noise from front end
  172. 1992 GMC A/C Compressor question
  173. 98 Jimmy Ignition Lock
  174. 96 jimmy jumping against starter
  175. choice of fuel pump carter or master?
  176. Front Wipers 98 Jimmy
  177. 97' S15 headlight removal
  178. Defroster doesn't start AC
  179. '99 Jimmy with P0420 TC - Catalyst System Efficiency Below Threshold (Bank 1)
  180. possesed interior lights
  181. oil pressure gauge
  182. Rear Pinion Seal
  183. Code P1416
  184. 1995 misses & backfires
  185. 4wd not working
  186. Brake service
  187. power window problems
  188. 1997 Jimmy gas gauge flicking
  189. Front End Clunking
  190. tranny spewing fluid/ flaming jimmy
  191. fuel pump code?
  192. Changing Plugs on 2001 GMC Jimmy
  193. 96 Jimmy acceleration and stalling
  194. TCCM codes
  195. code 1870
  196. ABS warning light
  197. TransmissionFluid&Filter
  198. lojack
  199. aftermarket parts???
  200. 1994-dash light problem and check engine light on...(went to autozone...)
  201. always on defrost?
  202. Jimmy just died on me, third fuel pump already
  203. ecm
  204. 4.3 Vortec
  205. Does GM Have a Quality Control Department?
  206. Erg
  207. Can't find the Spark Plugs in 2000 Jimmy/Envoy
  208. 1996 Jimmy AC problem
  209. 98 Jimmy brake light on and brakes go down to the floor
  210. 2001 jimmy, no 4wd switching, control issues?
  211. 2001 Jimmy clunk/rattle in front end
  212. 95 To 97 Gauge Cluster
  213. control vent hissing
  214. trasmission problems
  215. 2001 GMC Jimmy Keyless Entry
  216. can't find fuel filter on 97 jimmy
  217. A/C Down. Replace PCM ??? Help!
  218. static while exccelerating
  219. 97 jimmy problem
  220. 89 Jimmy V1500 pops or pings ! code 43
  221. Fuel Gage and Console issues on 2000 Jimmy
  222. High Center Mounted Break Light
  223. Deceleration noise
  224. Service Engine Light..AGAIN
  225. Rough Running 1995 GMC Jimmy Has No Power
  226. 89 jimmy fuel pump problems
  227. Turbo a 2.8 in an s10 jimmy
  228. 1997 Jimmy Intermittent Stalling
  229. Won't go into 4wd
  230. serpentine belt keeps popping off
  231. anyone put a fbss kit on Jimmy?
  232. 98 chevy blazer ABS no Speedometer and will not shift out of 1st gear
  233. Starting Problem
  234. engine hesitates
  235. 1997 GMC Jimmy Question
  236. installing a cd deck in a 98 Jimmy
  237. Fuel Pump Howl
  238. Turn signals inoperable/Gas gauge/more problems
  239. 1998 GMC Jimmy Directional Signal problem, makes blinking sound w/o signal on (MORE)
  240. Window motor replacement
  241. 1993 Jimmy Keyless Entry
  242. Firing Order
  243. 2001 Jimmy Leaning
  244. 1998 Jimmy Shifting Trouble
  245. Stinky Jimmy
  246. 1988 GMC Jimmy received with metal-like tapping sound...And transmission slipping?
  247. Location of EGR Valve for 4.3 L Vortec?
  248. 92 Rear axle leak
  249. Body Parts Interchangeable
  250. performance
