Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
GMC
> Jimmy |
View Full Version :
Jimmy
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
Stinky Jimmy
1988 GMC Jimmy received with metal-like tapping sound...And transmission slipping?
Location of EGR Valve for 4.3 L Vortec?
92 Rear axle leak
Body Parts Interchangeable
performance
jimmy stalling solution
Best differential oil?
Headlight Removal?? 1998 JMC Jimmy-- PLEASE HELP!
Dual tailpipes for 2000 4dr?
Fuel Gauge, Air Bag Light, Rear Hatch Release
96 Jimmy, Fuel delivery problem??
2001 GMC Jimmy-Weird Problem-HELP!!
1999 GMC Jimmy SLT Towing with bumper
2000 jimmy, Need help Replacing drivers pwr window Motor
Help We Are Boggled 2001 Jimmy
2000 GMC Jimmy SLT getting really bad gas mileage
front end loose!!
remote programming
Wiper / Turn Signal Problem...HELP...'92 Jimmy...
Rear Door On '92 Jimmy...HELP!!!
wiring digram and used horn
Ball Joints
S-15 Rear View Mirror Switch Discontinued?
1998 jimmy flasher relay
Daytime Running Lights
94 Jimmy Vortec CPI...It will not turn over...HELP>>>>>PLEASE
1992 Jimmy cuts out during acceleration
front end/suspension parts interchange 1994 jimmy
outside air temp sensor
body swap/removal
98 Jimmy Parking Brake
2001 Jimmy is possesed
2000 GMC Jimmy idle clicking?
axle popped out!!
1984 Jimmy
Service Engine Soon Light
95 jimmy vortec - HELP!! plz
Help! 96 jimmy wont start
bad brake vacuum booster?
Stereo Help!!!!
95 Jimmy- no driving lights
Instrument Cluster on a 91
1991 Jimmy for sale
Rough idle gas fumes from tail pipe 1993 jimmy s-15 vortec
1999 Jimmy SLT A/C Compressor cut in
power steering pump
2001 Jimmy A/C issue
'95 GMC Jimmy Flasher Unit
Wiring Diagram for an 89 Jimmy?
taking power mirrors apart
1995 Jimmy Fuel Pump
airbag replacement
Speedometer Gone Wild!!!!
99 Jimmy 4X4 with no heat
1998 Jimmy noise... help!
93 Jimmy Transmission slow to shift... ?
93 Jimmy Bad Cluster??
Po446
RUNS ROUGH and Smells Like eggs
gauge problem
Oxygen Sensor
1988 GMC Jimmy MPG Woes
91 jimmy moter swap
2000 Jimmy - humming sound
86 s-15 2.8 JUST WONT START
How do I find out....?????
Oil Pressure Line Leak
hard to start when engine cold!
Windshield Wiper Switch/Motor/Circuit Board?
Customizing a '93 HELP!
dash lights ( cluster)
found programming keyless remote 94 Jimmy
Common Transmission Failures
Overhead console
1988 jimmy slow to kick into overdrive
loss of power at 45mph
2000 GMC Jimmy Supercharger Application Recommendations
'86 S-15 Jimmy may not be what it looks like
Help! 1997 Won't start & dies while running!
Heater core replacement - '97 Jimmy...HELP
95 jimmy - computer error code - bank1 rich
2001 Jimmy SLT humming noise front end....
Help!! 2000 GMC Jimmy Popping and whining
power locks jimmy
Driver Side Door
Transmission problem
brake light & turn signal relay
Bad turn signals on 95 SLE Jimmy...
93 Vortex - EGR - not the normal problem...
Aftermarket regulator Legit?
New Truck
2001 jimmy for sale (great price!)
Trailer wiring harness.
FUSE for Rear Hatch Release Keyless Entry??
service engine soon light came on (96 Jimmy)
It won't stop!!
AC Compressor
96 Jimmy running rough
1995 S15 Jimmy
Code Scanner recommendations?
O2 sensors
95 Jimmy 4.3 bogging down(sputtering)
1991 GMC Jimmy Faulty Gauges??
'99 SLT - Front Brake Rotors Disintegrating
Wont Start
1992 Jimmy temp gauge and idle problem
1996 dead
96 GMC Jimmy.....A/C and turn signal problems
92 4.3L Wseries Dies and wont restart for a couple of hours??
Factory (?) Alarm
96 jimmy multiple problems.help...
Milage
99 Jimmy front end roar. Bad wheel bering???
2000 Jimmy dead!
95 jimmy-hearing a noise when accerating in gear
'94 Jimmy Dash Removal (attempting to remove heater core)
1993 Jimmy 4dr Replacing Cylinders on Rear Window
Where is the reverse-lights switch?
carbon in EGR causing problems
Automatic garage opener
95 Jimmy Back Hatch
1995 Jimmy 4.3 Vortec won't start
97 Jimmy4.3 rough idle
nigga wheels
'97 Jimmy Heater Core Removal
99 Jimmy DIED
Rough Idle
96 Jimmy Remote Keyless Entry
99 jimmy idles fast
Ac controls switch
2000 Automatic locks
1998 GMC Jimmy SLT - FOR SALE
Air Bag Module Location?
89 jimmy transmission change
89 jimmys dash changes
Code P440 on 2001 Jimmy
1997 jimmy remote entry location
4wd
'99 SLT Outside Tempature Guage Inaccurate
factory keyless entry
Power Seat Not Working????
Keyless entry?
'83 454 performance parts
20" rims 4 sale
Engine Swap
1995 Jimmy with S-L-O-W signal lights
Rough Cranking Idle
96 S15 jimmy rear end noise
Three very bad spark plugs
2001 Jimmy fuel gauge drops
running alittle rough
Any low budget Cpi units out there?
1989 gmc jimmy digital dash panel is dead!
2001 Jimmy Diamond Studder
tin can like rattle
1996 cranks but wont fire
1993 GMC Jimmy running rough
Rear Brakes Stuck on!
Rattling noise coming from the engine
EGR/code 32
more 97 jimmy probs. help please
Check engine light 2001 jimmy
Help...Need Spark Plug gap data...
Signal switch replacement help
heat/vent control hissing
96 Jimmy Stalling
Towing with 2000 GMC Jimmy (your opinion)
97 Jimmy center stick removal (squeeky spring)?
97 jimmy problems
2000 Jimmy Steering Problems
Clutch hard to shift 90 S15 4WD
Accuracy of electronic temperature display
1989 SPark plug wire hook up order look at diagram
89 jimmy starting problem urgent fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Car Stereo Code
Hiding my amp.
Groaning from frontend
4w drive clunkin bad going out and in???
01 jimmy klunk
Hazard button broke. Can you replace just the button?
P1870 xmission code
Wipers don't listen
FS OEM Manuals
Rear hatch problems
Cleaned EGR Valve
Name of part
Passlock2 Merlin Please Look
1991 GMC Jimmy rear main seal
Cruise stopped working
selling an '87 s15 jimmy
Line loose leaking transmission fluid.
1991 jimmy starter removal???Help Please
blower motor comes on when it wants to!
Blower motor location
towing
Intermediate hard start problem
New EGR valve, same problems
Changing Sparkplugs. How the hell do you get the one behind the steering shaft out?
Serpentine Belt Diagram
Starting trouble
Gas gauge is possessed!!
1997 jimmy slt block heater? do i have one?
brake dust
Water Pump Replacement - 1999 Jimmy
Many Many Thanks...to ALL
4x4 not working
intermittent stalling/hesitation
engine hesitation
performance parts for a 94
Carbon Buildup/EGR Probs
Ball joints
rotten eggs and gunowder??
4 Wheel Drive Problem
Bad Idle, Smell Gas, Can't read codes
Do I need a reverse flush on heat system?
stalling/ bogging problem solved
2000 Jimmy Blowing warm to cold
WANTED! 4.3 performance tips
97 Jimmy Turn Signal
bad idle, pulling time, and burning rich
How to tell if water pump is bad (Merlin?)
my Jimmy using excess fuel
Jimmy stuck in 4x4 won't change
1995 Jimmy Performance Help
94 Jimmy stinks
vacuum lines at transfer case 95 jimmy 4.3
2001 jimmy 4 sale
Leaky windshield.
ABS and brake lights
Oxygen sensor 1997 Jimmy
1998 jimmy power loss(please look Merlin)
Engine Knock
cd player
96 Jimmy "no start"
98 Jimmy Trip odometer resetting
High Mileage Jimmy
Towing
Just to let you all know.....
code 43 on a gmc jimmy can any body help
2000 Jimmy keyless
PLEASE HELP !!removable top '77 jimmy question
4X4 Clicking but not engaging
98 GMC jimmy Trans prob dont know what to do.
99 Jimmy climate control problem
Long beeping tone?
2001 jimmy 4dr 4 sale
'99 crank sensor location?
97 Jimmy 4WD Problem
Web
AF
