Ford
> Expedition
View Full Version :
Expedition
Pages :
1
2
3
4
5
Expedition running too lean
Rough Idline and shaking while accelerating
No Heat in My Expedition
rear noise clunk at start out
Dvd To Cd Changer Connector In 98 Exp
rear noise
Air Suspension problems
Bad Coil again??
Momentary loss of current during start
2003 Expedition Rear Rotor Thickness - Service Limit
A/C Clutch Rattling
97 Expedition ....Heater not working
2000 EB seat heater
real axle seal
I hate the gray stuff
PSI what works best
Doors rattle on a 03
Underbody Skid Plate?
Expedition Navigation/CD
99 Expedition
turning problem
99 Expedition Instrument lights
99 Expo heat problem
99 Expo Squeaks a lot
1998 Expedition electical problems.....
2003 expedition cabin filter
Transmission
99 ABS Light
keypad code stolen!!
Spark Plugs 02 expedition
Wheel Studs Breaking
Recall??
orifice tube location?
Help!!!!
fuces
Cold and Noisy
door motor
Changing spark plugs on daughters 2000 Expedition need help!
odometer or mileage readout
Air Bag warning light blinks
Engine stalls while driving 2003 Expedition
heater blows cold in front and hot in back
1999 expedition speed assist steering problem
99 Expy EB 4 x 4 Wiper probs... help please
'98 intermittent start "fix"
Lights Out
Tape Stuck in tape player
2003 Expedition Brakes
1999 Expedition Wiring Problems
1998 Expedition problem with rear wheel "thumping" that feels like a flat tire
2003 expedition transmission & transfer
2001 Expedition Front A/C blows hot
2000 Flasher (Emergency/Turn signal) Where is it???
CD Stuck in CD Changer - 2000 Ford Expedition
odometer wont work
2000 Expedition will not turn-over
Key less entry pad
2000 Expedition acceleration rumble / shudder
Daytime Running Lamps
97 Air/Fuel Metering
Keyless Entry
03 Expedition Power Side Mirror problem
97 Epedition Check Engine Light
Rear Brake Lights on 2002 Ford Expedition
2003 Ford Expedition Radio/Navigation System
2000 Exp Has 15 Error Codes
Anti-theft issue
97 expedition air suspension troubleshoot tips
2002 Expd_brakes Rear
Expy XM radio install
keypad malfunction
where is the fule filter on a 98 5.4 eb
Lower trim pieces fading on Expedition
2000 Expedition rough starting, usually first start of the day
starter is new
99 Expedition Engine Parts For Sale
CD changer for 97
99 Expedition Steering Noise
98 Expedition alt overcharged electrical sys
00 Navigator won't go into drive
98 Expedition -trailer running lights fuse blows
1999 EB Transmission problem?
ERG Valve Pressure Sensor
99 exp. EB blowing hot air
03 Rear Window
Front AC/Heat fan motor location?
electrical problems
98 expedition
Lack of power??? Any ideas?
4x4 drive -
rear wiper
Abs
Preparing plastic parts for paint
1999 odometer goes out
program homelink buttons
True Dual Exhaust
headlight 1 low beam not working
Lost Power After Tow
interior lights and
diagnostic help po141
obd codes 401&402
1997 expedition radio problem
How to tell if air suspension
2005 Squeaky Gas Pedal
98 ford expedition
Expedition Gas Mileage
rear subwoofer
2001 EXP rear A/C Problems
Transmission Cooling System
air suspension,1999
98 Expedition overhead interior lights don't all work
98' Expedition Driver's side Power window
2005 Owner
Parts
is it the battery please help
battery or electrical
Rear axle seals
97 expedition sunroof
hesitation
rear window wiper
Replacing dashboard light
coils
03-05 Exped, Navi wheels fit 99 navi?
K&N air filter for '99 Expedition $20 shipped.
Need HVAC Help
ford confession
Rear Speaker Blown!
reverse parking sensors
'98 Expo Replacing Lower Ball Joint
'99 Expedition motor swap
Expedition Running Rich?
97 expedition sunroof problems
'99 keyless entry
97 Passenger window wont go down
97 expedition check engine light
97 check engine light
2001 EXP plugs
98 Expedition Keyless Entry
Expedition will run even with key out.
Problems with brakes (ABS??)
97 Heater Blower Problems
2000 Ford Expedition Ashtray
00 expedition bank 1 to lean code
04 tire pressure sensors deactivation
1998 Expedition - won't start
Valve problem?
2005 Expedition- Anybody Own One?
?GOES WRONG IN 1998's
lemon
interior lights
2001 Ford expedition surging
2003 Expedition Front Air Stuck
Check it out.
Daily Dead Battery - 2003 Expedition
Left Turn Signal/Brake Light out
Question on a 99 EB
Replacing Air Ride with Coil?
oil separators
2000 exp transfer case
Trailer reverse light won't work
99 ABS Light comes on at times
02 Expy weak stereo
4R70W tranny in '99 Exp. 3rd and fourth gone.
97 expedition stuck in park
99 Exped need to recharge my A/C
Oil Consumption
Rims and Tires?
shocks for 98 expedition
How to take apart the whole dash?
vehicle speed sensor wire
Its getting hot and I need my A/C!!!!
Power windows wont work
Lowering
recall on certain fords
1998 Expedition 4.6L fuel filter
99 ford expodition oil leak
Please help my 98 expedition
Blinking Overdrive Light
Billet Grille
More Power
Rear View Mirrors
sputtering and surging
towing capacity
1998 Expedition
#4 coil location on 98 expedition
Brake Master Cylinder Reservoir R&R
2000 EB Expedition average miles per gallon
Vibration In Rear
97 Expedition HeadGasket ?
'98 Expedition seems to lose power...
1999 Exp. Door Trim Removal
1998 Expedition XLT..Change Spark Plugs
99exp --> Do you recommend Head Gasket Liquid Aluminum?
99EXP--> Door Ajar light stays on, doors don't lock right away
2003 Expedition seat covers
2002 Idle Problems
99 Exp - Digital Odometer goes on & off
99 Exp Gear shifter dropped down 1 gear
Removing Axel Nut and Rotor
Cabin Lights go on and off
Engine Coolant Leak?
pls help dizzy mare about "dead" expedition
Power locks problem
Air Suspension
Strange tranny problem
98' Expedition engine install
ford expeditions
99 Expedition
2003 Expedition Sub Amp Wiring
Wheel exchangeability/compatibility
99 EB Air suspension shock question
wireless headphones
2000 Expedition Resistor Replacement
1998 Expedition Strange Brake Problem
AC system questions?
2001 Eb Expedition 5.4 Trition
02 Expedition
front brake rotor removal
headlight and switch
Hey guys im new here
2000 Expedition sometimes won't start
98 Expedition CE Light
97 shift lock actuator
2000 Expedition EB "Alternator" Woes
power seats not working-wet wires??
The Alternator from hell...
AC Problems
Rough Idle, rough accelleration, CEL
1998 Expedition stalls
2wd 1997 having front end noise
Trouble in starting 1999 Expedition, 4.6L, 8 cylinder
2000 Expediton Transmission Problem
'98 Expedition spark plugs
replacing brake light
Auto loock deactivation
Demand Window Recall 2000 Expedition!
bought used 00 expo and need some help
Cabin Air filter
Expedition Door Locks
97 Expedition Converter Lock At 20-30 Mph
98 5.4 Loosing Coolant
Headlights
interior lights/door ajar
Floor Mats Needed For O4' Expedition
Under the steering wheel leak.
Ford fires
03 Expedition door code
