View Full Version : Explorer/Explorer Sport Trac
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. no comunication with data link
  2. Horn
  3. Help with remote starter / alarm installation
  4. Sealed Explorer transmission oil?
  5. Fuel Filter Tool Question -- 97 Explorer 5.0
  6. Bleeding Master Cylinder/ABS System
  7. Compressor cycles too often when using the heater
  8. replaced alternator and battery
  9. 2004 Explorer horn goes off when key removed
  10. '97 5.0 V8 will not start, no fuel at the rail
  11. door ajar light
  12. 98 explorer missing uphills
  13. Tranny won't shift into reverse! 2003 Explorer
  14. explorer timing
  15. need big time help with parts name..............
  16. P0409
  17. 2000 explorer sport seat problem
  18. HELP!! 4X4 Problems 2001 Explorer Sport 4.0 V6
  19. 99 Explorer Sport No Ac No Blower Motor
  20. 2002 explorer differential rebuild
  21. 1996 Explorer code reader
  22. 98 explorer blinker problems
  23. 1998 Explorer Sport Upper ball joint (drivers side)
  24. need blueprints for 98 transmission
  25. 93 explorer brake problem
  26. 93 explorer brake problem
  27. Cruise Control Issue
  28. outside mirror light replacement 2002
  29. chrome strip coming loose
  30. 01 Explorer sport ABS problem at low speeds
  31. 1998 explorer sport starts the stalls
  32. Vacuum leak
  33. 2002 Explorer: Scraping noise in rear tire
  34. 98 explorer loss of power stering and over heating at same time
  35. 1994 explorer lights stay on
  36. 02 Explorer power window regulator
  37. 99 ford explorer won't start
  38. oil pressure gauge fluttering / tapping noise
  39. Trailer lights......
  40. Mirror
  41. thermostat housing/water outlet
  42. Explorer 2007 Trans oil change
  43. need some info think you
  44. will a 1992 ford explorer xlt 4x4 trans bolt up to a 1994 ford explorer 4x4??
  45. 95 Explorer starting issues
  46. '03 Wheels start leading to the side when hot
  47. wheel noise 05 sporttrac 2wd
  48. Why won't the A/C take a charge? Is it clogged?
  49. Trans not shifting!!
  50. Airbag/A/C problems..??
  51. 99 explorer ac problem
  52. A/C clutch engages and disengages
  53. 1997 5.0 ODBII Question -- Expected Calculated Engine Load Reading at Idle
  54. 98 explorer air conditioning problem
  55. Engine stalls
  56. 2001 Roof Rack Peeling Paint
  57. 1994 ford explorer 4x4 module
  58. 1997 5.0 Rough Idle, No Codes, Brief ODB Data Linked -- Help Interpret?
  59. 2004 Ford Explorer 4.0 Rough Idle VIN K
  60. Misfire on Cylinder 3
  61. 91' Explorer 4x4 inop no power on switch
  62. 4x4 light stuck on
  63. alternator prob!!! HELP PLEASE
  64. Explorer and the CFC Program
  65. Replace an alternator ?
  66. FORD vs CHEVY vs JEEP? HELP ME OUT
  67. Sport Trac Climate control
  68. 2005 sport trac soft brake pedal
  69. 2003 Rear End Noise
  70. can you help? 2004 explorer - crack on front
  71. tow with 02 V6 A/T 2wd???
  72. Blown Ignition fuse
  73. 1993 Explorer XLT problems starting
  74. PCM power relay
  75. black plastic surrounding rear window fadding fast
  76. 2002 Ford Explorer Power Seats blowing FUSE
  77. factory color touch up paint.
  78. 00 explorer sport..rh turn signals inop Lh work?
  79. 1998 Explorer Sport Head Gasket
  80. 2000 Explorer 4x4
  81. Radiator Install - Banging head in wall!!!
  82. Need help with radio/fuses/dome light
  83. 97 5.0 explorer intake elbow
  84. no pressure in brake lines.
  85. Annoying,False "O/D Off" Light Flashing
  86. Starting issues sometime
  87. Glowing altenator
  88. ABS light on (01 ford sport trac 4x4)
  89. 92 explorer wont start. fuel problems?
  90. 97 explorer abs no communication
  91. 99 model 4.0 explorer died...runs fine today
  92. Cold air kit question
  93. adjust shifter linkage on 02 explorer
  94. 2002 Explorer XLT A/C issue
  95. A/C and Alternator Problems
  96. '91 4.0 code 14
  97. 3 trans rebuilds in the last 3 mths is it every going to work again
  98. Upper ball joint replacement 1996 Explorer
  99. trans fluid fill question
  100. transmission question
  101. Standard Transmission Question
  102. 2002 ford explorer brake control plug for trailer
  103. 02 explorer transfer case not shifting?
  104. 02 explorer o/d rpms?
  105. 2002 ford explorer front end noise
  106. Hub and Bearing Axle Nut Torque Number???
  107. 93 Explorer runs rough when warm
  108. power seat problem
  109. wont stay running in "D" or "R"
  110. What years are compatible???
  111. 2000 Explorer,windows Won't Work
  112. '97 Explorer interiior light comes on & off randomonly
  113. 96 Explorer Interior Lights Won't Go Off !
  114. I need help bad!!
  115. Slow speed shudder
  116. Help!! removing shifter from top of tranny
  117. 2002 O/D flashing 2 Diag. done both different diag.
  118. 96 Exp. electrical issues
  119. New Transmission Fluid cause slippage
  120. 96 explorer need shocks?
  121. AAAH anti-freeze in engine HELP!!!
  122. 96 fuel problem
  123. exhaust bolts to engine
  124. bang on drum
  125. camshaft position sensor
  126. fuel line disconnect????
  127. depressurize fuel lines!!!
  128. brake lights not working when in gear 2002 Explorer
  129. Transmission problem
  130. 2002 Explorer 4.0 light problems
  131. 98 explorer AWD Thunk on Acceleration
  132. what is that part behind the engine.
  133. 1997 A/C only Hot
  134. 2005 Ford Explorer, Problem with Brakes
  135. 1996 explorer trans problems
  136. head gasket
  137. 2003 Explorer 4WD suspension
  138. 1994 Explorer trans leaking into oil
  139. HARD Vibration...please help
  140. Torque spec's
  141. 04 Explorer SRS light
  142. Proper fuel pressure for 95 explorer??
  143. 02 explorer break lights stay on
  144. 2000 ford explorer front end shakes when i hit 70 and apply brakes
  145. 1995 Eddid Bauer won't take an AC charge
  146. Explorer 4.0L Power steering issue
  147. Radio Removal 2003 Explorer
  148. Antifreeze Disappearing From Overflow Tank
  149. switch from US to European position light/turn signal
  150. doors wont open from inside on 2002 sport trac
  151. 1992 High idle in park and rough idle in gears
  152. 98 4.0 into a 2000 w/4.0 explorer
  153. 06 Expl Heater Fan stuck full blast/can't stop!
  154. 93 explorer vibration noises
  155. P0305 Cylinder 5 Misfire
  156. '97 Fog Lights
  157. 98 explorer making sound (like a blender)
  158. check gauge light
  159. 2004 rack and pinion failure
  160. 01 Sport Trac Door Code???
  161. 4x4 light flashing
  162. 96 Explorer Running Rough when hot
  163. 01 Explorer Sport Trac, Several Issues...HELP
  164. 2000 XLS ball joints
  165. right hand timing chain lubrication
  166. 2005 SportsTrac-Belt squeaking
  167. 92 Explorer hard cranking
  168. 2000 Ford Explorer Bubbles in coolant reservoir when running
  169. Remove Automatic Transmission
  170. starting to hate my new car...
  171. stock speakers?
  172. 97 no heat control
  173. diagnostic mode
  174. 2000 4.0 Belt Tensioner
  175. alarm going off on 05 Explorer
  176. 2000 explorer v6 plug change
  177. 1997 Explorer
  178. 97 Explorer Cold start issues and diagnostic
  179. 93 Explorer codes
  180. Heated Mirrors smoking the inside.
  181. 2003 Ford Explorer vibration/noise from front end tires?
  182. 2004 Explorer fuel in oil pan???
  183. Rear wiper inoperative,and door ajar light.
  184. ford '01 sport trak door wiring
  185. Dirt in the Radiator
  186. power steering flush?
  187. Carfax
  188. 97 sport trac no heat
  189. ambient air sensor on a '04 location
  190. 05 Fuel Filter location
  191. Greetings & a Question
  192. what to do
  193. 98-01 Used Explorer -What to watch for?
  194. transfer case clanking
  195. Push button 4x4
  196. 01 ford explorer sport trac lf wheel noise
  197. Ford Explorer: Push Brakes and it Accelerates!!
  198. Anyone flush a tranny b4?
  199. My 1st Suv!
  200. Emmissions Prob
  201. 98' 4.0 sohc wiring problem
  202. 95 Ford Explorer - Can you disable ABS Light
  203. Replacing Rear View Mirror
  204. CEL Codes
  205. A/C Low Port
  206. Power windows dont work on 03' explorer
  207. 98 Exp. Trans slipping
  208. 03 sport trac dies in reverse
  209. 2004 ford explorer won't accept gas !!!
  210. body lift 2000 explorer xls
  211. 2000 ford explorer idling really rough
  212. 04 Explorer tire pressure sensors
  213. 99 explorer sport 2wd suspension problems
  214. 95 explorer problems
  215. Door Key Pad
  216. 94 ford explorer with white smoke
  217. 2002 sport trac 4 wheel drive stop working
  218. Overdrive Dashlight flashing on / off
  219. 2000 front seat question.
  220. Tough decision between 2 Sport Trac
  221. 1997 Explorer Wipers
  222. p071/p0174
  223. Cold Air Coming in through Glove Box
  224. 2000 Explorer Sport 4.0 SOHC lacks power @ operating temperature
  225. 03 Explorer--starting trouble.
  226. 2000 explorer, no blinkers, no high beam HELP!!!!!!!!
  227. 98 Explorer wont start. Can't find solinoid (HELP!)
  228. 94 Explorer sometimes won't start or idles rough
  229. 02 explorer code P1506, manufacturer controlled idle speed
  230. Explorer idles ok but stalls in gear
  231. 99 Explorer Sport Intake Manifold Gaskit Kit Install
  232. remote starter
  233. 93 explorer clutch fluid leaks out of bottom of tranny mud guard
  234. 02 Sport Trac "hissing"
  235. Two 2003 Explorer Questions
  236. explorer sport front end "earthquake"
  237. 5-20W oil for 2004 Explorer?
  238. 2005 Wiper and sprayer problem.
  239. Alarm sounds when opening doors
  240. Rubber hose attached to top of rear axle:
  241. need help with new speakers
  242. 2001 Explorer driver door panel
  243. abs brakes 2001 ford explorer
  244. Center Console power Outlet Removal
  245. Starting Trouble. PLEASE HELP
  246. 95 explorer won't start in cold weather
  247. 1995 Explorer Coolant temp guage/sensor problem
  248. 2005 ford exploder starting issues
  249. big storm tomorrow!!4x4 trouble!!!
  250. 99 explorer 4.0l, turn signals and door locks
