View Full Version : Explorer/Explorer Sport Trac
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. heat quit working
  2. 99 XL Center Console
  3. 1996 explorer code-but which sensor?
  4. 03 Explorer 4.0 L P2270 Code
  5. 02' explorer - inop. Power windows
  6. '99 Explorer keeps eating coil. HELP!
  7. 97 Explorer Sport alarm bypass
  8. 99 Explorer XLS
  9. 99' Frd Expl 4.0l - Pass Upper Ball Joint
  10. no comunication with data link
  11. Horn
  12. Help with remote starter / alarm installation
  13. Sealed Explorer transmission oil?
  14. Fuel Filter Tool Question -- 97 Explorer 5.0
  15. Bleeding Master Cylinder/ABS System
  16. Compressor cycles too often when using the heater
  17. replaced alternator and battery
  18. 2004 Explorer horn goes off when key removed
  19. '97 5.0 V8 will not start, no fuel at the rail
  20. door ajar light
  21. 98 explorer missing uphills
  22. Tranny won't shift into reverse! 2003 Explorer
  23. explorer timing
  24. need big time help with parts name..............
  25. P0409
  26. 2000 explorer sport seat problem
  27. HELP!! 4X4 Problems 2001 Explorer Sport 4.0 V6
  28. 99 Explorer Sport No Ac No Blower Motor
  29. 2002 explorer differential rebuild
  30. 1996 Explorer code reader
  31. 98 explorer blinker problems
  32. 1998 Explorer Sport Upper ball joint (drivers side)
  33. need blueprints for 98 transmission
  34. 93 explorer brake problem
  35. 93 explorer brake problem
  36. Cruise Control Issue
  37. outside mirror light replacement 2002
  38. chrome strip coming loose
  39. 01 Explorer sport ABS problem at low speeds
  40. 1998 explorer sport starts the stalls
  41. Vacuum leak
  42. 2002 Explorer: Scraping noise in rear tire
  43. 98 explorer loss of power stering and over heating at same time
  44. 1994 explorer lights stay on
  45. 02 Explorer power window regulator
  46. 99 ford explorer won't start
  47. oil pressure gauge fluttering / tapping noise
  48. Trailer lights......
  49. Mirror
  50. thermostat housing/water outlet
  51. Explorer 2007 Trans oil change
  52. need some info think you
  53. will a 1992 ford explorer xlt 4x4 trans bolt up to a 1994 ford explorer 4x4??
  54. 95 Explorer starting issues
  55. '03 Wheels start leading to the side when hot
  56. wheel noise 05 sporttrac 2wd
  57. Why won't the A/C take a charge? Is it clogged?
  58. Trans not shifting!!
  59. Airbag/A/C problems..??
  60. 99 explorer ac problem
  61. A/C clutch engages and disengages
  62. 1997 5.0 ODBII Question -- Expected Calculated Engine Load Reading at Idle
  63. 98 explorer air conditioning problem
  64. Engine stalls
  65. 2001 Roof Rack Peeling Paint
  66. 1994 ford explorer 4x4 module
  67. 1997 5.0 Rough Idle, No Codes, Brief ODB Data Linked -- Help Interpret?
  68. 2004 Ford Explorer 4.0 Rough Idle VIN K
  69. Misfire on Cylinder 3
  70. 91' Explorer 4x4 inop no power on switch
  71. 4x4 light stuck on
  72. alternator prob!!! HELP PLEASE
  73. Explorer and the CFC Program
  74. Replace an alternator ?
  75. FORD vs CHEVY vs JEEP? HELP ME OUT
  76. Sport Trac Climate control
  77. 2005 sport trac soft brake pedal
  78. 2003 Rear End Noise
  79. can you help? 2004 explorer - crack on front
  80. tow with 02 V6 A/T 2wd???
  81. Blown Ignition fuse
  82. 1993 Explorer XLT problems starting
  83. PCM power relay
  84. black plastic surrounding rear window fadding fast
  85. 2002 Ford Explorer Power Seats blowing FUSE
  86. factory color touch up paint.
  87. 00 explorer sport..rh turn signals inop Lh work?
  88. 1998 Explorer Sport Head Gasket
  89. 2000 Explorer 4x4
  90. Radiator Install - Banging head in wall!!!
  91. Need help with radio/fuses/dome light
  92. 97 5.0 explorer intake elbow
  93. no pressure in brake lines.
  94. Annoying,False "O/D Off" Light Flashing
  95. Starting issues sometime
  96. Glowing altenator
  97. ABS light on (01 ford sport trac 4x4)
  98. 92 explorer wont start. fuel problems?
  99. 97 explorer abs no communication
  100. 99 model 4.0 explorer died...runs fine today
  101. Cold air kit question
  102. adjust shifter linkage on 02 explorer
  103. 2002 Explorer XLT A/C issue
  104. A/C and Alternator Problems
  105. '91 4.0 code 14
  106. 3 trans rebuilds in the last 3 mths is it every going to work again
  107. Upper ball joint replacement 1996 Explorer
  108. trans fluid fill question
  109. transmission question
  110. Standard Transmission Question
  111. 2002 ford explorer brake control plug for trailer
  112. 02 explorer transfer case not shifting?
  113. 02 explorer o/d rpms?
  114. 2002 ford explorer front end noise
  115. Hub and Bearing Axle Nut Torque Number???
  116. 93 Explorer runs rough when warm
  117. power seat problem
  118. wont stay running in "D" or "R"
  119. What years are compatible???
  120. 2000 Explorer,windows Won't Work
  121. '97 Explorer interiior light comes on & off randomonly
  122. 96 Explorer Interior Lights Won't Go Off !
  123. I need help bad!!
  124. Slow speed shudder
  125. Help!! removing shifter from top of tranny
  126. 2002 O/D flashing 2 Diag. done both different diag.
  127. 96 Exp. electrical issues
  128. New Transmission Fluid cause slippage
  129. 96 explorer need shocks?
  130. AAAH anti-freeze in engine HELP!!!
  131. 96 fuel problem
  132. exhaust bolts to engine
  133. bang on drum
  134. camshaft position sensor
  135. fuel line disconnect????
  136. depressurize fuel lines!!!
  137. brake lights not working when in gear 2002 Explorer
  138. Transmission problem
  139. 2002 Explorer 4.0 light problems
  140. 98 explorer AWD Thunk on Acceleration
  141. what is that part behind the engine.
  142. 1997 A/C only Hot
  143. 2005 Ford Explorer, Problem with Brakes
  144. 1996 explorer trans problems
  145. head gasket
  146. 2003 Explorer 4WD suspension
  147. 1994 Explorer trans leaking into oil
  148. HARD Vibration...please help
  149. Torque spec's
  150. 04 Explorer SRS light
  151. Proper fuel pressure for 95 explorer??
  152. 02 explorer break lights stay on
  153. 2000 ford explorer front end shakes when i hit 70 and apply brakes
  154. 1995 Eddid Bauer won't take an AC charge
  155. Explorer 4.0L Power steering issue
  156. Radio Removal 2003 Explorer
  157. Antifreeze Disappearing From Overflow Tank
  158. switch from US to European position light/turn signal
  159. doors wont open from inside on 2002 sport trac
  160. 1992 High idle in park and rough idle in gears
  161. 98 4.0 into a 2000 w/4.0 explorer
  162. 06 Expl Heater Fan stuck full blast/can't stop!
  163. 93 explorer vibration noises
  164. P0305 Cylinder 5 Misfire
  165. '97 Fog Lights
  166. 98 explorer making sound (like a blender)
  167. check gauge light
  168. 2004 rack and pinion failure
  169. 01 Sport Trac Door Code???
  170. 4x4 light flashing
  171. 96 Explorer Running Rough when hot
  172. 01 Explorer Sport Trac, Several Issues...HELP
  173. 2000 XLS ball joints
  174. right hand timing chain lubrication
  175. 2005 SportsTrac-Belt squeaking
  176. 92 Explorer hard cranking
  177. 2000 Ford Explorer Bubbles in coolant reservoir when running
  178. Remove Automatic Transmission
  179. starting to hate my new car...
  180. stock speakers?
  181. 97 no heat control
  182. diagnostic mode
  183. 2000 4.0 Belt Tensioner
  184. alarm going off on 05 Explorer
  185. 2000 explorer v6 plug change
  186. 1997 Explorer
  187. 97 Explorer Cold start issues and diagnostic
  188. 93 Explorer codes
  189. Heated Mirrors smoking the inside.
  190. 2003 Ford Explorer vibration/noise from front end tires?
  191. 2004 Explorer fuel in oil pan???
  192. Rear wiper inoperative,and door ajar light.
  193. ford '01 sport trak door wiring
  194. Dirt in the Radiator
  195. power steering flush?
  196. Carfax
  197. 97 sport trac no heat
  198. ambient air sensor on a '04 location
  199. 05 Fuel Filter location
  200. Greetings & a Question
  201. what to do
  202. 98-01 Used Explorer -What to watch for?
  203. transfer case clanking
  204. Push button 4x4
  205. 01 ford explorer sport trac lf wheel noise
  206. Ford Explorer: Push Brakes and it Accelerates!!
  207. Anyone flush a tranny b4?
  208. My 1st Suv!
  209. Emmissions Prob
  210. 98' 4.0 sohc wiring problem
  211. 95 Ford Explorer - Can you disable ABS Light
  212. Replacing Rear View Mirror
  213. CEL Codes
  214. A/C Low Port
  215. Power windows dont work on 03' explorer
  216. 98 Exp. Trans slipping
  217. 03 sport trac dies in reverse
  218. 2004 ford explorer won't accept gas !!!
  219. body lift 2000 explorer xls
  220. 2000 ford explorer idling really rough
  221. 04 Explorer tire pressure sensors
  222. 99 explorer sport 2wd suspension problems
  223. 95 explorer problems
  224. Door Key Pad
  225. 94 ford explorer with white smoke
  226. 2002 sport trac 4 wheel drive stop working
  227. Overdrive Dashlight flashing on / off
  228. 2000 front seat question.
  229. Tough decision between 2 Sport Trac
  230. 1997 Explorer Wipers
  231. p071/p0174
  232. Cold Air Coming in through Glove Box
  233. 2000 Explorer Sport 4.0 SOHC lacks power @ operating temperature
  234. 03 Explorer--starting trouble.
  235. 2000 explorer, no blinkers, no high beam HELP!!!!!!!!
  236. 98 Explorer wont start. Can't find solinoid (HELP!)
  237. 94 Explorer sometimes won't start or idles rough
  238. 02 explorer code P1506, manufacturer controlled idle speed
  239. Explorer idles ok but stalls in gear
  240. 99 Explorer Sport Intake Manifold Gaskit Kit Install
  241. remote starter
  242. 93 explorer clutch fluid leaks out of bottom of tranny mud guard
  243. 02 Sport Trac "hissing"
  244. Two 2003 Explorer Questions
  245. explorer sport front end "earthquake"
  246. 5-20W oil for 2004 Explorer?
  247. 2005 Wiper and sprayer problem.
  248. Alarm sounds when opening doors
  249. Rubber hose attached to top of rear axle:
  250. need help with new speakers
