Ford
> Explorer | Explorer Sport Trac
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
94 Ford Explorer 140000mi.
97 Explorer Shake/Vibration @ 65+
95 explorer idle surge
V8 or V6?
99 ford explorer idle problems
performance
93 explorer hard start then ping
98 Warm Idle Issues
Weak on pulling hill
96 Expl codes p0135; p0141 & p0155
Heavy Clutch / Gear Change
Wheres the Wire?
Door Chime won't stop
Engine Flush
96 Ford Exp Sport Hard To Shift
Hard to start on cold days
keyless entry problem
Checking To See If 2001 If Worth It?
1998 Explorer Oil Pump Problem
obd I codes
obd I codes
Need to find fuel pump safety switch, 2000 Explorer
1994 V6 Ford Explorer Limited Edition Alternator Problem! Please Help!
2000 XLT Eddie Bauer Fuel Delivery problem
96 Explorer 4.0 head removal...
94 explorer ign switch
2002 Explorer O2 Sensor Location
Need Info. on Pioneer Decks
bad smell
97 Explorer XLT V8 Runs Rough poor power/mileage!
"old engine" noise, but only when warm?
Dim odometer display
I would like to trash my abs system, can it be done?
95 Explorer won't start
question about billet grille
Black Box?????????
paint
'96 explorer control trac, 4x4 and transmission trouble !
96 Oxygen Sensor?
gear shift hang up from reverise to park
2003 explorer transmission, no dip stick!
Code P0430???
Rough idle
Bill that says that Bestbuy can instaill my alarm?
rear window washer
ford 1994 problems
Erratic Engine Temperature
Wrong Fluid was put in.. help
1997 Explorer: Problem with locks
manual tranny shifting problems
How long has your battery lasted?
99 Explorer vibration (Front End)
'99 Explorer noise & poor gas milage
REAR BUMPER ABSORBER Question
Flashing Air Bag Lite on 97 Explorer XLT V8
coil pack
2000 fog light
05 Explorer Gas Guage
tranny
94 explorer problem
Running lean and they want to charge a fortune!
00 Explorer Squeak and vibration on front drivers side
High Pitched Noise from back on 02
positive switch headlight system
Are all 4.0L OHV equal '91 to '97
95 Explorer Electrical Problem Blinkers/Reverse/Radio
97 Exlporer For sale 5500
sterring
2002 Explorer Sport Hatch Latch Problem
Door Ajar Problem
ABS Codes
2000 explorer runs rough
Explorer tailgate
Question about problems with cooling sys
Parting out 1991 Explorer
Overheating 2002 explorer
4x4 light
94 ford explorer axles
OBD 1 or 2 ?? 1995 wont start
1996 Ford Explorer wiper problem
97 Explorer factory AM/FM/CD
bleeding 94 explorer abs brakes
Leaf springs
2002 Ford Explorer 4x4
03 Explorer EB How to Disable factory alarm?
Before You Buy! Research You Explorer!
1991 Explorer Lifter Collapse
1998 Ford Explorer lights turn off.
Poor Heat
Concerns!!
91 Explorer parts
2001 Explorer Sport 4x4 for sale
98 Explorer Instrument Cluster Lights
98 Explorer 4.0 SOHC Automatic
Sport Trac ECU Location?
Brake lights do not work, dome does
check engine light
Problems with Explorer?
The Leech Monster
ABS Malfunction?
rubbing noise from front end while turning at low speed
Chilton Book
Code P0442 on 02 sport trac
97 heating problem
98 Expedition - Air Bag Light Blinking
Engine hesitation while in park 2004 Sport Trac
Questions about 1992
2000 ford explorer
Few questions
99 Explorer codes PO171 & PO174
Engine Vibrates/Shakes real bad
transmission hydraulic pump???? mechanic said its bad 94 explorer 4x4
2002 Explorer Drivers Door Window Switch
2002 Mountaineer Liftgate Cracks
Is this normal?
Camber, Front Springs
Just Bought a 96 V8 Explorer XLT
'94 Explorer engine smoking
Bad front end noises... HELP!!
2001 Ford Explorer won't crank when cold
speaker wiring
replacing fuel injectors 94 explorer
Help - Anti-theft alarm keeps going off
'94 Eddie Bauer Explorer Tranny Troubles
95 LTD 4x4 Control Trac problems
What PSI capacity 12v compressor works on an Explorer
4.0l OHV performance
Sport Trac Wheel squeek
95 4.0l lifter removal
Brush guard help for 1997 Explorer
Interior lights, 94 explorer?
Whiney rear-end
rockers
just a dumb question
Shrill sound
Start very hard below 20 degrees F.
No more regular premium oil???
99 Explorer Sport Front Brake Vebration
Tranny servicing
97 explorer codes: 1824, 1359, & 1405
Anyone repaired auto hubs??
4x4 won't stay engaged
'96 Explorer Electrical Problem, I think?!
2002 Explorer power window doesn't work
2005 EXPLORER keyless?
Codes PO171 & PO174 1999 Ford Explorer
Questions
Looking to buy?
windshield washer
2002 explorer tailgate panel cracked
multi function switch
1996 explorer- back seat problems
Radio/Amp problems
Heeeeeelp !!! AutoXray readiness test results ?!?
coil pack
2002 Explorer Electrical Problems
97' ford explorer noise
'97 XLT Loud Whining Noise... (not my wife)
Door ajar light on 02 explorer stays on
1995 Explorer Radio
Help me pick(Buy)?????
ECU TEST connector location !!
????91 explorer parts any one
check engine light
antifreeze leak
4.0 V-6 Radiator
obd11 codes
91 xlt tranny update
94 Eddie Bauer start problem...
1998 Eddie Bauer
freeze plug
freeze plug
engine revs before shifting into next gear
keyless remote problem
'97 CD Wiring Needed Plz
Changing a CV joint
1996 Ford Explorer, Ed Bauer, Disengage the Alarm System
99 explorer 4wheel disk brake rotor removal
99 Explorer Transfer case
96 ilde problem
2003 ford explorer cracked rear hatch
driver side brake light and turn signal
Doors will not unlock with remote or button
91 xlt losing power
91 explorer performance mods
OBDII Code Display
egr on a 1992
Cracked air intake tube
Cracked Head? What are the symptoms?
99 EB Check Engine Light-Lean On Bank 2
99' V8 EB pinging ang Knocking....
99 explorer trans. problems
99 explorer
2000 explorer cold idle problems
1999 explorer will not idle
99 ford explorer will not idle
4x4 wont engage
oil in my water???
Radial Arm Bushings
Heater Core R & R
1992 Explorer 4x4
Transmission Leak BAD!!!
keyless door code
Cruise control switch recall- fused jumper part #
stereo
Explorer Stalls/Transmission Problem
abs light (what else can happen to an explorer)
Squeaking brakes
Trans acting up
Check Engine Light
4x4
Getting Codes
car is surging at idle
Irritating from Blinker lever
Just Bought a 2005 Explorer
O/D blink and CHECK ENGINE ON
1996 ford explorer
Pulling Codes 94 Explorer
Torque converter rattle??
18" Cobra's for sale
bumper
weird noise
Headlights
Rumbling Explorer
Too many miles?
Headlights won't go out!
How to Adjust Idle on 4.0 SOHC engine
Front-end shudder
2001 XLT door keypad top button not working.
Anyway to disable the Check Engine light?
Strange Temperature Behavior in 2000 Ford Explorer
High idle and overheating
Hesitation @ cruising speed(any speed)
99 explorere
HELP! I removed the wrong drain plug...
04 Expolorer Ltd factory keypad code
overdrive flashes
2000 explorer with code PO171
Transmission Problems
service engine light
fuel filter on a 01explorer
93 explorer fuel gauge issues
94 explorer speedometer and more
Thermostat Stuck Open
Starter Change
Squealing in front drivers side after repairs
2003 Explorer Remote Starter / Anti-theft problem
