View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17
  1. 1999 Explorer grinding brakes
  2. Voltage drain!!!
  3. Noise while idle
  4. 1999 Explorer door chime
  5. Installing new Speakers
  6. 01 Explorer, high idle and trans shifting prob
  7. Power locks and blink lights
  8. Tow plug issue.
  9. 91 explorer tranny problem
  10. Aftermarket Stereo Deck
  11. 2001 Explorer .. high idle
  12. tranny code P0715
  13. what should i do about this lemon
  14. 98 Expl. ABS disaster on the beach
  15. problems developing
  16. 97 overheating
  17. a/c not working at idle
  18. A/C problems
  19. A/C Problems
  20. Rear hatch won't open, 99 XLT AWD V8
  21. Transmission Output Shaft Broken
  22. Power locks won't work
  23. Torsion bar adjuster arms
  24. Alignment issues!!!
  25. 93 Ford Explorer
  26. '92 explorer-which a/c hose?
  27. intake gasket question
  28. Power window broken
  29. 02 explorer power seat trouble
  30. Trying to buy new
  31. 93 explorer over heating
  32. 93 explorer wont shift into overdrive
  33. steering wheel lights
  34. 91 Explorer Engine Replacement
  35. How do I install a performance cooling fan?
  36. 96 intermittent starting problems
  37. Vacuum leak on 91 Ford Explorer
  38. 97 explorer tranny issue, OD light flashing
  39. 4.0 V6 Head Removal
  40. '93 Cruise control
  41. '93 Explorer/limited edition Wipers
  42. i need new shocks
  43. An other Horn problem EB 2002
  44. Keyless entry for a 95 Explorer Sport
  45. transmission swap
  46. 2002 Ford Explorer AC Vacumn check valve
  47. what would you do to an explorer?
  48. wheres the pcv valve?
  49. Bumping noise from rear while driving
  50. 1992 explorer
  51. where can i get a 3" lift kit?
  52. any advice?
  53. 02 Explorer ABS Sensor and A/C
  54. Explorer 2000, computer problem
  55. Tranny problems
  56. Installing New Rotors
  57. smoking brakes
  58. bleeding the clutch on first gen?
  59. Tired of husband replacing parts Help.
  60. 94 Sport Explorer (manual)
  61. transmission and 4whl drv question
  62. 95 Explorer AC Blower Stopped Suddenly???
  63. 20" Cobra R wheels
  64. 1994 Explorer check engine light
  65. Daytime Running Lights
  66. Oil in Radiator
  67. Problems starting....'95 sport
  68. 1994 Explorer Engine Code ?
  69. Tail light problem
  70. 02 stuck rear rotor
  71. keyless entry code
  72. keyless entry code
  73. 2001 Explorer Over heating
  74. 2003 Explorer air bag connections
  75. I figured out the problem with my door but know i dont know how to fix it?
  76. 94 Explorer Sport
  77. 2000 Explorer Tranny Question
  78. Speaker problems
  79. drivers door won't unlock
  80. need help on parts
  81. Where Is My Keyless Entry Code???
  82. 02 Explorer transmission problems or something else?
  83. whistling noise
  84. Thinking about getting exhaust???
  85. exhaust manifold
  86. '98 explorer driver side window won't go up
  87. Where's My Horn???
  88. I MESSED up My door side operating system. HOw? i dont know. HELP!!!!!!!!!
  89. How to recharge A/C on 92
  90. Alternative VIN# Locations
  91. 94 Explorer, heat and AC don't blow unless on high
  92. 1991 Parasitic Battery Drainage
  93. 93 explorer starter relay wiring
  94. wont start theft light flashing
  95. 1999 Explorer 4.0 Air bag codes definition
  96. 1998 ford explorer 4 wd slipping in and out
  97. getting upset 92 explorer
  98. Clicking noise
  99. Hard Starting 4.6 2002 Explorer
  100. Rear Wiper does not work
  101. clicking noise-starter?
  102. 97 explorer engine problems
  103. Way2old....need opinion
  104. 4R55E reverse problems
  105. blinking light/remote starter
  106. vibration 60mph and up
  107. Growls at her truck
  108. Engine Humming
  109. 1997 Won't start, cranks and has fuel
  110. Wobbling when in 4wd
  111. Problems with my 1992 XLT
  112. catalytic converter problem
  113. Rear Door Ac Acculator
  114. long crank to start, runs smooth
  115. Rough accell 92 exploder 4.0
  116. Just rebuilt 4.0 SOHC - lost oil pressure
  117. Rear hatch opens when rear passenger door opens
  118. 2002 Explorer 4.0L cranks, but won't start
  119. 01 Explorer Stalls abruptly at stop. Torque CVTR?
  120. 95 XLT - two power windows work, 2 don't
  121. 92 explorer for sale
  122. air conditioner
  123. 92 tranny
  124. black box
  125. better mpg
  126. 93 Explorer Clicks once but wont start
  127. 2003 explorer outer cv boot
  128. bleeding the clutch
  129. 98 Explorer...Tranny slipage!!
  130. 98 Eddie Bauer Explorer won't start
  131. 1992 Explorer problems.........
  132. Help replacing radiator
  133. problems turning over
  134. Broken power seat on '95 EB Edition
  135. Broken moon roof on '95 EB edition Explorer
  136. Replacing '95 EB edition stereo with OEM model
  137. Overheating
  138. 94 explorer cruise control
  139. 99' Whinning noise
  140. 1996 Ford Explorer AC problems
  141. 94 Dome lights
  142. interior parts
  143. rear end?
  144. 1993 explorer dome light problem
  145. Tire Dye to repair scuff
  146. 1994 Explorer Voltage Needle Far Left
  147. 91 explorer head gasket issues!
  148. Won't turnover using Viper Car starter if it's higher than 85 outside!
  149. Overhead Module Readout
  150. 02 explorer problem
  151. 93 Ford Explorer pulls to the right
  152. tranny problems
  153. Transmission-repair or replace
  154. questions about changing the stock head unit
  155. Speed conrol and cills.
  156. 4x4 woes
  157. If you have strange electrical problems
  158. 98 Explorer front end noise
  159. 98 Explorer Power steering
  160. 95 Explorer Power windows & interior lights
  161. '98 Explorer Bucks on Turns
  162. dual exhaust
  163. Cruise Control Amplifier Location 1997
  164. Pulling 4.0 SOHC
  165. 4.0 Sohc Help
  166. 94 explorer alarm
  167. Power Mirror Switch on the door
  168. 94 Explorer, no pwer on hills
  169. 2000 Ford Explorer Drivers Side Door Lock sticking
  170. 92 explorer wont shift
  171. 4x4 woes
  172. new air conditioner
  173. need 5- speed tranny for 94 explorer
  174. 92 Explorer Where do I put .......
  175. crankshaft sensor
  176. fuel pump problem???
  177. 98 trans shifting issue
  178. check engine light & 4x4 low
  179. 1991 1993 ford explorer switching motors but wiring harness not same on one
  180. Alarm System
  181. Torsion bar removal and cleaning
  182. 1995 4X4 Explorer Front End Whistling Noise
  183. PCV Valve location on 2003 Explorer Sport
  184. 99 XLS Instrument dash light
  185. Steering wheel controls for fan speed/temp not working
  186. help, 2003 explorer sport trac
  187. 99 explorer XL 5 speed manual
  188. 91 manual shifting problem
  189. 97 explorer side mirror
  190. 96 explorer tranny not shifting 911
  191. code po 401
  192. 97 lift kits???????????
  193. 1993 Auto Trans vacuum modulator questions
  194. Found, Keyless programing and poss code location
  195. 99 XLS Brake Problem
  196. where is my amplifier
  197. need stereo help
  198. 94 Sport Headlights
  199. 1996 Explorer FOR SALE
  200. Set Clock on '96 Explorer
  201. 91 exp. EEC relay in Power Distribution box is blowing when key is turned
  202. parts questions
  203. Spedometer Cable 1994 XL
  204. 93 Ford Explorer-cel on while towing
  205. ford vs gmc
  206. How to Program a 1998 Explorer Remote Fob
  207. AC Compressor Problem ???
  208. sex appeal
  209. 95 explorer check engine light on
  210. 96 explorer
  211. New Rotors 02 Sportrac 2wd
  212. Dome light gremlins - '01 Sport Trac
  213. Overheating almost - 96 Auto 111K
  214. Coolant leak unusual place
  215. Windows Don't Work
  216. Reverse does not work, but drive does
  217. Changing 2000 Eddie Baur Shocks
  218. 98 Explorer Door Lock Actuator Mounting
  219. 97 explorer possible catalytic converter problem
  220. check engine on 98 explorer sport
  221. 97 eddie bauer door locks
  222. Ford Explorer 4WD Light
  223. 1994 Ford Explorer Won't Start
  224. 1994 Explorer stalling when idle
  225. Power antenna
  226. SVT Explorer?
  227. 97 Exloprer Wiper-washer Problems
  228. Oil Pan Gasket
  229. EGR EVP Sensor
  230. 94 Explorer Gas Gauge
  231. Weird Noises
  232. Weird problems after having transmssion replaced
  233. Seat swap question
  234. Clunk sound in front end
  235. 2002 ford exp. shudders when accelrating on inclines ?
  236. Rear Wiper 95 to 2001 Adjustment
  237. '93 dead tranny. Options/Suggestions?
  238. Faulty Oil Pressure Gauge
  239. 2 questions... tires and bumpers
  240. 97 explorer tape deck
  241. Bumper color code
  242. 98 Explorer heater
  243. 97 explorer 2500rpm vibrations
  244. Tornado results
  245. o/d light flashing....again!
  246. WTB- 5.0L Explorer serp set up
  247. Stall Stall Stall
  248. starting problem 94 explorer
  249. Overheating!!!
  250. Fuel Injector Cleaners Safe???
