View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17
  1. V8 or V6?
  2. 99 ford explorer idle problems
  3. performance
  4. 93 explorer hard start then ping
  5. 93 explorer hard start then ping
  6. 98 Warm Idle Issues
  7. Weak on pulling hill
  8. 96 Expl codes p0135; p0141 & p0155
  9. Heavy Clutch / Gear Change
  10. Wheres the Wire?
  11. Door Chime won't stop
  12. Engine Flush
  13. 96 Ford Exp Sport Hard To Shift
  14. Hard to start on cold days
  15. keyless entry problem
  16. Checking To See If 2001 If Worth It?
  17. 1998 Explorer Oil Pump Problem
  18. obd I codes
  19. obd I codes
  20. Need to find fuel pump safety switch, 2000 Explorer
  21. 1994 V6 Ford Explorer Limited Edition Alternator Problem! Please Help!
  22. 2000 XLT Eddie Bauer Fuel Delivery problem
  23. 96 Explorer 4.0 head removal...
  24. 94 explorer ign switch
  25. 2002 Explorer O2 Sensor Location
  26. Need Info. on Pioneer Decks
  27. bad smell
  28. 97 Explorer XLT V8 Runs Rough poor power/mileage!
  29. "old engine" noise, but only when warm?
  30. Dim odometer display
  31. I would like to trash my abs system, can it be done?
  32. 95 Explorer won't start
  33. question about billet grille
  34. Black Box?????????
  35. paint
  36. '96 explorer control trac, 4x4 and transmission trouble !
  37. 96 Oxygen Sensor?
  38. gear shift hang up from reverise to park
  39. 2003 explorer transmission, no dip stick!
  40. Code P0430???
  41. Rough idle
  42. Bill that says that Bestbuy can instaill my alarm?
  43. rear window washer
  44. ford 1994 problems
  45. Erratic Engine Temperature
  46. Wrong Fluid was put in.. help
  47. 1997 Explorer: Problem with locks
  48. manual tranny shifting problems
  49. How long has your battery lasted?
  50. 99 Explorer vibration (Front End)
  51. '99 Explorer noise & poor gas milage
  52. REAR BUMPER ABSORBER Question
  53. Flashing Air Bag Lite on 97 Explorer XLT V8
  54. coil pack
  55. 2000 fog light
  56. 05 Explorer Gas Guage
  57. tranny
  58. 94 explorer problem
  59. Running lean and they want to charge a fortune!
  60. 00 Explorer Squeak and vibration on front drivers side
  61. High Pitched Noise from back on 02
  62. positive switch headlight system
  63. Are all 4.0L OHV equal '91 to '97
  64. 95 Explorer Electrical Problem Blinkers/Reverse/Radio
  65. 97 Exlporer For sale 5500
  66. sterring
  67. 2002 Explorer Sport Hatch Latch Problem
  68. Door Ajar Problem
  69. ABS Codes
  70. 2000 explorer runs rough
  71. Explorer tailgate
  72. Question about problems with cooling sys
  73. Parting out 1991 Explorer
  74. Overheating 2002 explorer
  75. 4x4 light
  76. 94 ford explorer axles
  77. OBD 1 or 2 ?? 1995 wont start
  78. 1996 Ford Explorer wiper problem
  79. 97 Explorer factory AM/FM/CD
  80. bleeding 94 explorer abs brakes
  81. Leaf springs
  82. 2002 Ford Explorer 4x4
  83. 2002 Ford Explorer 4x4
  84. 03 Explorer EB How to Disable factory alarm?
  85. Before You Buy! Research You Explorer!
  86. 1991 Explorer Lifter Collapse
  87. 1998 Ford Explorer lights turn off.
  88. Poor Heat
  89. Concerns!!
  90. 91 Explorer parts
  91. 2001 Explorer Sport 4x4 for sale
  92. 98 Explorer Instrument Cluster Lights
  93. 98 Explorer 4.0 SOHC Automatic
  94. Sport Trac ECU Location?
  95. Brake lights do not work, dome does
  96. check engine light
  97. Problems with Explorer?
  98. The Leech Monster
  99. ABS Malfunction?
  100. rubbing noise from front end while turning at low speed
  101. Chilton Book
  102. Code P0442 on 02 sport trac
  103. 97 heating problem
  104. 98 Expedition - Air Bag Light Blinking
  105. Engine hesitation while in park 2004 Sport Trac
  106. Questions about 1992
  107. 2000 ford explorer
  108. Few questions
  109. 99 Explorer codes PO171 & PO174
  110. Engine Vibrates/Shakes real bad
  111. transmission hydraulic pump???? mechanic said its bad 94 explorer 4x4
  112. 2002 Explorer Drivers Door Window Switch
  113. 2002 Mountaineer Liftgate Cracks
  114. Is this normal?
  115. Camber, Front Springs
  116. Just Bought a 96 V8 Explorer XLT
  117. '94 Explorer engine smoking
  118. Bad front end noises... HELP!!
  119. 2001 Ford Explorer won't crank when cold
  120. speaker wiring
  121. replacing fuel injectors 94 explorer
  122. Help - Anti-theft alarm keeps going off
  123. '94 Eddie Bauer Explorer Tranny Troubles
  124. 95 LTD 4x4 Control Trac problems
  125. What PSI capacity 12v compressor works on an Explorer
  126. 4.0l OHV performance
  127. Sport Trac Wheel squeek
  128. 95 4.0l lifter removal
  129. Brush guard help for 1997 Explorer
  130. Interior lights, 94 explorer?
  131. Whiney rear-end
  132. rockers
  133. just a dumb question
  134. Shrill sound
  135. Start very hard below 20 degrees F.
  136. No more regular premium oil???
  137. 99 Explorer Sport Front Brake Vebration
  138. Tranny servicing
  139. 97 explorer codes: 1824, 1359, & 1405
  140. Anyone repaired auto hubs??
  141. 4x4 won't stay engaged
  142. '96 Explorer Electrical Problem, I think?!
  143. 2002 Explorer power window doesn't work
  144. 2005 EXPLORER keyless?
  145. Codes PO171 & PO174 1999 Ford Explorer
  146. Questions
  147. Looking to buy?
  148. windshield washer
  149. 2002 explorer tailgate panel cracked
  150. multi function switch
  151. 1996 explorer- back seat problems
  152. Radio/Amp problems
  153. Heeeeeelp !!! AutoXray readiness test results ?!?
  154. coil pack
  155. 2002 Explorer Electrical Problems
  156. 97' ford explorer noise
  157. '97 XLT Loud Whining Noise... (not my wife)
  158. Door ajar light on 02 explorer stays on
  159. 1995 Explorer Radio
  160. Help me pick(Buy)?????
  161. ECU TEST connector location !!
  162. ????91 explorer parts any one
  163. check engine light
  164. antifreeze leak
  165. 4.0 V-6 Radiator
  166. obd11 codes
  167. 91 xlt tranny update
  168. 94 Eddie Bauer start problem...
  169. 1998 Eddie Bauer
  170. freeze plug
  171. freeze plug
  172. engine revs before shifting into next gear
  173. keyless remote problem
  174. '97 CD Wiring Needed Plz
  175. Changing a CV joint
  176. 1996 Ford Explorer, Ed Bauer, Disengage the Alarm System
  177. 99 explorer 4wheel disk brake rotor removal
  178. 99 Explorer Transfer case
  179. 96 ilde problem
  180. 2003 ford explorer cracked rear hatch
  181. 2003 ford explorer cracked rear hatch
  182. driver side brake light and turn signal
  183. Doors will not unlock with remote or button
  184. 91 xlt losing power
  185. 91 explorer performance mods
  186. OBDII Code Display
  187. egr on a 1992
  188. Cracked air intake tube
  189. Cracked Head? What are the symptoms?
  190. 99 EB Check Engine Light-Lean On Bank 2
  191. 99' V8 EB pinging ang Knocking....
  192. 99 explorer trans. problems
  193. 99 explorer
  194. 2000 explorer cold idle problems
  195. 1999 explorer will not idle
  196. 99 ford explorer will not idle
  197. 4x4 wont engage
  198. oil in my water???
  199. Radial Arm Bushings
  200. Heater Core R & R
  201. 1992 Explorer 4x4
  202. Transmission Leak BAD!!!
  203. keyless door code
  204. Cruise control switch recall- fused jumper part #
  205. stereo
  206. Explorer Stalls/Transmission Problem
  207. abs light (what else can happen to an explorer)
  208. Squeaking brakes
  209. Trans acting up
  210. Check Engine Light
  211. 4x4
  212. Getting Codes
  213. car is surging at idle
  214. Irritating from Blinker lever
  215. Just Bought a 2005 Explorer
  216. O/D blink and CHECK ENGINE ON
  217. 1996 ford explorer
  218. Pulling Codes 94 Explorer
  219. Torque converter rattle??
  220. 18" Cobra's for sale
  221. bumper
  222. weird noise
  223. Headlights
  224. Rumbling Explorer
  225. Too many miles?
  226. Headlights won't go out!
  227. How to Adjust Idle on 4.0 SOHC engine
  228. Front-end shudder
  229. 2001 XLT door keypad top button not working.
  230. Anyway to disable the Check Engine light?
  231. Strange Temperature Behavior in 2000 Ford Explorer
  232. High idle and overheating
  233. Hesitation @ cruising speed(any speed)
  234. 99 explorere
  235. HELP! I removed the wrong drain plug...
  236. 04 Expolorer Ltd factory keypad code
  237. overdrive flashes
  238. 2000 explorer with code PO171
  239. Transmission Problems
  240. service engine light
  241. fuel filter on a 01explorer
  242. 93 explorer fuel gauge issues
  243. 94 explorer speedometer and more
  244. Thermostat Stuck Open
  245. Starter Change
  246. Squealing in front drivers side after repairs
  247. 2003 Explorer Remote Starter / Anti-theft problem
  248. 03 Explorer Radio Question
  249. coolant smell
  250. Explorer Sportrac 2004 gauges
