Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Explorer/Explorer Sport Trac |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
1992 Explorer Trans. leak. Sometimes?
'92 explorer starting help!
2003 Explorer Cigar Lighter isn't working, can someone please help?
trans leak on 94
1997 Explorer: Rear Passenger Speaker goes out
What is rec. fuel pressure on 2000 4.0L EB?
egr problem
Abs
94 Explorer No power/start
1998 Eddie Bauer Explorer Turn Signal
transmission shifting at 3000 rpm
Explorer Radio Got Rained On...
1995 explorer electrical problem
Occasional Suggish throttle
Same suspension as ranger?
94 Center Console/Armrest
Diagnostic codes?
M A F mass air flow sensor ?
Rocker arm off
Steering sometimes tight
2000 Transmission Recall Notices??
Sirius Radio
99 Explorer trans fliud leak
94 Blower motor resistor
keyless entry help
99 explorer xlt WHISTLE
96 5.0 V8 Transmission fluid?
94 Ford Explorer a/c problem
How to get air out of steering fluid?
rear subwoofer
Rough Idle
realiabity on a sport trac
96 XLT Speedometer trouble
93 changed radio no sound
Engine Smokes and makes weird noise
Need help Code P1309
93 explorer keycode
overhead console
96 explorer 6 CD changer wont play cds
Bad U-Joints maybe?
Popimg when turning
Whirring noise and tug when going about 70 mph
2001 ST overheating ... running out of ideas ...
Gear
Weird Sound
Werid Noise ...can someone tell me what it is?
explorer problem when backing up
Exploer CCD vacuum line
2002 clicking from rear
97 Explorer 4WD lights flashing
Sensor Location
Left Frt Upper control arm
City Driving Gear?
sluggish shifting
B1 S1 Sensor Location
Anything else!!!!
96 explorer obd2 0455 emission control leak
resetting readiness code
Sport Trac Off-Road Truck
94 Getting in gear/brakes/sensors?
1995 Ford Explorer trans/rear end issues???
1995 Ford Explorer Problems
service engine soon light
Check engine light error message p1400
sport trac question
Resetting check engine light?
1998 xlt 4.0 beeps
Noise in frt end???
Explorer Rear Axle Replacement
Rear speaker replacement
1997 explorer 4x4
01 Explorer sport will not turn over.
94 hard starting
torque specs
replacing hubs '96
'97 Explorer Check Engine Light
cold air intake...
front turn signal bulbs
1997 ford explorer 4x4
'99' Explorer won't shift from Overdrive
Power steering Pump/rack???
trans fluid change on 2002 XLT
To sell or not to sell
body lift 98 explorer
Alignment Question
Charging problem?
Flushing Brake Fluid for 1994 Explorer with ABS Brakes
2006+ MP3/CD changer in 2004 Explorer?
door ajar lights on ...please help!
2000 Explorer Sport 4.0 liter. Idling trouble.
98 Explorer - Acceleration "Surging" (and other problems!)
please help make desicion
pcv valve change on 2002 4.0 v6
engine problem
92 Explorer noise
2004 explorer limited
transmission maybe
Brush Guard Question
5R55E Tranny Help!!!!!! ugent!!!
2001 Ford Explorer Sport Trac
94 explorer trans problem
Remote Entry System on 96 Explorer won't work
What oil and weight do you use in your Explorer
94 explorer tranny bucking
how to spark plug?
97 Explorer Sport Frt Bumper
1993 4x4
2002 Exp Ford
2004 Explorer/Mountaineer Keypad Code
Engine missing
Ford Code P1309
02 explorer theft light (When the transmission DISENGAGES at speed!!!)
Constant Door Chime
Radio display light
Need new rims, what size?
93 explorer trans
Flashing the computer on a 1999 XLS???
Belt Buckle Replacement
Front driver's side wheel squeaking non-stop- what is it?
94 Explorer
1991 Ford Explorer - automatic transmission problem
'02 Eddie Bauer Explorer? What do you think?
Dash Light Replacement
Number codes???
Please HELP!!
Old Pressure Gauge Pegs to Red
98 XLT 4WD - 4.0 SOHC Brake System
95 Blower motor control kit connector help
Another 99 Explorer ABS Question
Racing Stock
shift display wrong?
1999 Ford Explorer Key lock problem
98 - 2001 Explorer - review
96 Explorer back up light switch
1999 Explorer V-6 rough at start-up
Spare Tire Winch
Mysterious hose?
I don't think my problem is the Blender Door. Please help.
1998 Ford Explorer - Low Beams Not Working
2002 Explorer XLT- seat/ac
Fuel economy on All wheel drive
Engine noise
indeglo gauges/dash cluster over lay/ white face gauges
Rear Rotors
wont start w/o remote
Buying used and Towing with Eddie Bauer
Oil capacity? 91' explorer
Engine Question
odometer failure
95 Explorer Trailer wiring
2005 Explorer Keys Dont Unlock
1996 ford limited control trac
Fuel filter connector damaged
Dash Lights
No Power windows no radio or interior lights
Squeaking noise 99 explorer rear of 4.0 engine
converting 95 Explorer from 4WD to 2WD
stuck in 4x4 all the time
Abs
Locks
whine noise in subwoofer
cluster lights are all completely black!
Fog lights don't work
1992 power window inop
Overhead console
2000 Ford explorer limited key code
transmission compatabilities
bulb replacement
looking for a free manual for my 1991 ford explorer
leaking roof
Gear engageing
Keyless entry
1991 Ford Explorer Engine Wont Start (HARD ONE!)
96 explorer door locks
Wheel bearings
97 ford explorer sport trac problems
manual book ford explorer sport 2001
02 Explorer Power Windows Do Not Work
adding auto headlamps on a 1996
'02 Door lock key pad
2002 Explorer door ajar light
Help!!!!!!!!!!!!
fuses for my 2000 explorer sport.
95 Explorer How to program
95 Explorer Keyless Remote Not Working
2000 Ford Explorer 4.0 Sohc Timing Chain Tensioner
99 Explorer Hard to Start
Fuel pressure on a 94 ford explorer
99 explorer inactive for 2 yrs
2000 EB Climate Control Problem
Flowmaster hurt or help fuel economy?
catalyc converter
Removing fuel hoses from fuel tank
98 Explorer Eddie Bauer, 4x4 Selector
96 Explorer No Power to Windows
Different oil treatments?
how reliable is the explorer?
drivers side door broke! Help quick!
does anyone now how to lower the rear end useing the stock rear leaf springs????????
2000 - Intsrument panel lights
explorer hatch
'02 Explorer power window repair
2002 Explorer No Start No Spark
fuel in crankcase
keyless entry AGAIN!!!!!!!
ABS Brakes
starter and power locks
Maxamizing the MPG on a 94 explorer
Turn Signal problem
Front End Question
97 Explorer brake go to floor
FORSALE: Ford Explorer XLT 4X4
2001 Explorer XLS - rough ride - no grease fittings?
Explorer 2002 Eddie Bauer OVERHEATS
2002 Explorer 4-wheel drive
97 explorer VERY harsh ride.. any ideas?
2000 EB Exporer Climate Contol Wiggin Out
93 explorer
Wheel balance and alignment
Replacing Keyless Module on 98 Explorer Sport
oil levels
2000 5.0 l P0340 runnin rough
94 5spd Sport - 3 major problems!! PLEASE HELP!
a4ld tranny
Any good method to bleed Hyd Clutch?
Location Of Freeze Plugs On 4.0 Engine
A real mind boggler
1997 Explorer Heat Problem
1996 Ford Explorer XLT V8 for sale!!!
Blend Door Heat Issue on 2001?
sport trac shaking some,rpms go up and down a little, black smoke from exhaust?
2003 Explorer ABS light on/off/on/off..etc.
2000 explorer sport coolant sensor
Can you disable the Passenger airbag???
2003 explorer bucks in reverse
95 Explorer ABS light on and brake problem.
Stuck cargo door
2002 Sport Trac EGR issues
94 Ford Explorer 140000mi.
97 Explorer Shake/Vibration @ 65+
95 explorer idle surge
V8 or V6?
99 ford explorer idle problems
performance
93 explorer hard start then ping
98 Warm Idle Issues
Weak on pulling hill
96 Expl codes p0135; p0141 & p0155
Web
AF
