View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. 04 sporttrac rough idle
  2. Ford Explorer Transmission 1994
  3. 2002 explorer hard turn clunking noise
  4. P0174
  5. 2004 explorer multiple recurring issues
  6. 2000 Explorer - Problem w/Power Windows
  7. 2002 explorer power window regulator
  8. 2002 Explorer problem
  9. 2000 Explorer XLS (V6) misfiring
  10. tricking out a '93 EXP Limited
  11. k&n filter
  12. PCV Valve Location
  13. 2002 Eddie Bauer O/D Off Transmission warning
  14. How often should I drive my Explorer?
  15. 1999 Explorer XLS Possible intake leak
  16. ignition switch 95 explorer
  17. 2002 Explorer A/C clicking
  18. Thanks for the help.
  19. ford partd online??
  20. this is for 98 owners, Question
  21. Broken Transponder Chip. Need Help!!!
  22. I need advice on subwoofer wiring 04 Sport Trac
  23. A debate of sorts, what is the best year for the explorer?
  24. How are 98 explorers xlt?
  25. 98, rear tires making a whining sound
  26. want to deep six 2002 cd changer
  27. Abs
  28. Just got my 02 Sport Trac
  29. switching from auto to 4wd high should i?
  30. Loud noises coming from front end 97 4x4 explorer
  31. 97 explorer 4x4 problems switch wiring question
  32. new transmission
  33. Rear windshield washer fluid
  34. Vehicle
  35. Loud Humming noise with A/C on & Idling
  36. ABS light on 98 explorer AWD 8cyl.
  37. Sprt Trk idling rough with A/C on
  38. Compatible Transmissions for 92 Explorer?
  39. tcc???
  40. new lock actuator out of sync
  41. Fuel Pump Relay Location
  42. New Member: Need advice on SOHC v6
  43. Body Lift
  44. ARC Problems..what is this Module???
  45. Making My Explorer Show Worthy!!!
  46. New Member Here: NEW Explorer Blend Door fix write-up
  47. Vacuum line???
  48. Removing Liftgate?
  49. explorer transmission dip stick tube replacment
  50. '93 Explorer rough idle {possible dead cylinder?} Help!
  51. wheres the 4x4 button?
  52. 2002 Explorer Air Conditioning???
  53. What is it?
  54. Ford Explorer Sport Trac 2005
  55. Chime still going off when Key is out
  56. 1994 Explorer problems with starting
  57. Keep blowing 15amp Alternater Charging circuit Fuse
  58. Starting problem
  59. Towing lights?
  60. Towing lights?
  61. transmission lines
  62. Rough Idle. Missing?
  63. Rear axle nut on 2002 ford explorer
  64. Oil?
  65. General 1992 maintanance questions, including performance.
  66. Hazard Flasher Help
  67. Options?
  68. EGR flow problem
  69. Auto 4Wheel?
  70. Explorer running cold, how to fix?
  71. Speedometer going in and out.
  72. starting problem
  73. 1996 XLT Sport Trac engine compat.
  74. 98 explorer 4.0 speedometer
  75. No Fast Idle
  76. muffler recomendation
  77. 94 explorer running bad
  78. What motors were available in the Excursion
  79. 99 Explorer transmission - no holdback
  80. 93 xlt bogging problem
  81. Are you new to Forums?
  82. 1994 Ford Explorer Braking question
  83. 94' Ford Exployer Sprot track
  84. 1996 Explorer XLT Ball Joints
  85. 2002 Ford Explorer Sport - Smart Buy?
  86. Sport Trac Question
  87. Isolated P0171
  88. 2003 Explorer V8, jerking problem
  89. Now a shudder?
  90. My delema! 97 Explorer AWD 5.0 Blower issues
  91. 2003 Ford Explorer - Smart Buy?
  92. Air Intake risk?
  93. 2003 Explorer Sport Too Lean
  94. Need some modifications...
  95. cabin filter
  96. air conditioning problem
  97. 93 Starter problem
  98. for real mechanics
  99. 94 explorer timing chain
  100. gauges inop on 1994 EB 4.0 explorer 4WD
  101. dual exhaust for a 01 explorer sport?
  102. 1996 Parts and Problems
  103. '99 Explorer parking brake
  104. wont start when engine has run for awhile
  105. 1998 Ford Explorer Window lock
  106. 2000 5.0L coolant leak from intake manifold?
  107. Grinding noise on Explorer 99 XLT 4x4
  108. 94 Explorer wont turnover
  109. 95 Explorer hesitation problem
  110. *LEMON-LAW*CLASS-ACTION* Bad dust seals
  111. Trouble Code
  112. Cruise Control On/Off Switch Help
  113. Changing fluids
  114. compass/temp gauge broken
  115. transmission slipping
  116. Center dash kit for 2003 sport trac
  117. Power Steering Fluid specs for 99 Explorer,Tranny fluid?
  118. 98 Ford Explorer 2 door
  119. Getting a door open
  120. 97 Explorer Eddie Bauer AWD 5.0 issues
  121. Problem with remote start!
  122. Clockspring part number??
  123. 95 Limited Editon Sub
  124. Any one wanna buy a 1995 Ford Explorer Limited Edition
  125. Rough Idle
  126. Size lug nuts for 1999 Ford Explorer
  127. tranny flush
  128. Back Hatch on Explore
  129. Explorer Brake Lights
  130. '99 Explorer power window control
  131. sway bar bushings
  132. Stereo Amp
  133. Need help fast with a Explr XLT 4WD brakes
  134. Sea Foam?
  135. Radio won't work!
  136. 2002 Ford Explorer compass replacement
  137. 1997 Ford Explorer P0171 & P0174 Help!!!
  138. WAAG brush guard for sale!!!
  139. valves tapping after start up..........
  140. Clutch Release Bearing - How To Remove?
  141. Flash intermittent problem
  142. help changing fuel filter
  143. Brake pedal switch
  144. u joint and hub problems
  145. Fuel Pump Strainers
  146. 2003 explorer
  147. 95 Explorer code 214
  148. Trailer Light Plug
  149. 1991 Explorer power window problems
  150. 1999 ford explorer with 24 inch rims
  151. no running lights on trailer
  152. "Check Tail Lights" on console 95 Eddie
  153. 1993 Explorer Transmission leak
  154. '07 Explorer: Want Steering Wheel Media Controls
  155. oil pan gasket repllacement 98 explorer v8 engine
  156. What is this thing? (No picture available)
  157. 2003 sport trac rear noice
  158. 97 Explorer wiring probs
  159. hELP ME PLEASE !!!
  160. 96 model has very odd rough idle
  161. 91 Explorer Transmissons
  162. Broken Thermostat
  163. 92 explorer needs help
  164. 2003 Sports Trac entry code
  165. 94 expl smells sweet
  166. Squeaky Explorer 2003
  167. 1994 Fuel filter location?
  168. Help me make my mind up
  169. Need some help. 2001 Explorer Sport
  170. Oil Changes
  171. lifting my 96 EB
  172. Special battery cables?
  173. 02 explorer with strange codes I never seen before
  174. 98 EXPLORER questions
  175. PLEASE HELP!!!! factory sub (how to install)
  176. Schraeder valve removal on 2002 XLT
  177. Sluggish
  178. Trannie Issues
  179. 2005 sport trac keypad code location
  180. 03 Sport Trac Shifting problems
  181. 94 AC Hot Air
  182. Replacing steering gear on 5.0L 1998 explorer
  183. 1997 Ford Explorer
  184. 2001 ford explorer sportrac
  185. 99 Explorer Drivers Seat Bending Back
  186. Overhead compass/Outside Temp.
  187. 99 explorer Shaking at 70 miles an hour
  188. 98 Explorer. Reverse Went Out!! Please Help!
  189. 99 Explorer manual to power seats?
  190. 99 Explorer Air Conditioning Problem
  191. Rear differential CV axle seals leaking
  192. FS: Chilton's 1983-91 Explorer/Bronco II/Ranger
  193. Funny thing in a '02 Ford Explorer Sport 5-speed manual transmission
  194. Valves Tapping
  195. I think my heater went?
  196. Evaporator Drain Tube Help
  197. mis fire problem
  198. 2004 Explorer?
  199. Air CONDTIONING :(
  200. 98 explorer flooding help
  201. 97 Eddie Bauer No Power Mirrors?
  202. K&N Filter Questions
  203. gas smell ala Seinfeld episode!!!
  204. 1998 Explorer XLT 4.0 SOHC 150K miles
  205. 95 EB - Will not start and Scanner cannot run tests
  206. 2001 drivers door panel removal
  207. Fuel Pump always on when key is on Please Help!
  208. anti theft problem 93 Explorer
  209. '95 EB Will not start
  210. anyone need some wheels?
  211. Door Ajar Warning light
  212. 1996 Explorer Sport 4wd 5 speed - transfer case leak?
  213. Catalytic converter question
  214. Catalytic converter question
  215. "DOOR AJAR" light on dash
  216. explorer oil change
  217. transmission
  218. Cruise Control and Radio Issue
  219. 94 Issues
  220. Help please ! 98 EXPLORER LIMITED V6-245 4.0L SOHC
  221. Looking for part can't find ? HELP PLEASE
  222. cooling fan clutch
  223. 97 explorer sport door chime
  224. question about
  225. 1997 Explorer XLT crazy problem
  226. rough idle
  227. 2004: Sport Trac Alarm Question.. Need Quik Reply.. please :)
  228. 1998 Explorer 4.0L SOHC Spark Plug Removal Middle and Rear Passenger Side
  229. only defrost blows air
  230. Interior lamp and outside mirror light stay on
  231. 2000 explorer front jack point
  232. 2003 and 2004 speedometer for explorer
  233. 2002 Explorer Drivers Window Motor or Switch?
  234. 02 Explorer tranny/driveshaft problems
  235. 96 Explorer won't start
  236. Anything special about explorer sport?
  237. ABS Light Help!
  238. Poor gas mileage '02 Explorer 4.6l V8
  239. need Keyless Fob Numbers - 2002 Sport (not Trac)
  240. Will a wind deflector reduce bug splatter?
  241. Leaking front differential
  242. small problem
  243. Sticky: Keypad code location
  244. S.o.s
  245. Mysterous rear axle hose?
  246. 95 Explorer Sport Code 212
  247. '91 explorer coolant leak
  248. thumping in driver side wheel
  249. check eng light
  250. I want a change.....
