View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. 91 explorer fuel pump?
  2. 02 Eddie Bauer V6 4.0 Rattling Noise While Stopped in Gear
  3. 2002 explorer fuse location
  4. 1998 Explorer 4wdhi and 4lo light keeps blinkin
  5. 2002 Eddie Bauer Fog Light Grill Removal?
  6. new fog lights needed
  7. ford explorer abs problem
  8. 4.0 SOHC supercharger
  9. head swap
  10. HELP- 2002 Explorer Eddie Bauer- Radio, Interior Lights Not Working, No Fuses Blown?
  11. 1999 ford explorer
  12. 1996 tranny problem
  13. Tranny
  14. 2003 Sport Trac Differential Identification
  15. 2004 Ford Explorer XLT tow hitch question
  16. Window Regulator
  17. Where is the PVC vacuum hose
  18. 1995 Explorer Stalls at Idle
  19. airbags
  20. Door lock Actuators not working
  21. 99 Explorer Making Strange Vibration After Timing Chain Replacement
  22. od light flashing
  23. Help, poor gas mileage...
  24. Upper Intake manifold gasket
  25. 99 Exploer - Malfunction Indicator Lamp (MIL) Method
  26. 2106 tac system forced limited power
  27. 98 AWD Clicking sound from front
  28. steering shudder
  29. Help with air ride controle module
  30. 2001 Thermostat assy remove & replace
  31. Front locker for 1999 Ford Explorer Front differential.
  32. Drivers door lock not operating properly
  33. Trouble Codes P0300, P0316 on my Sport Trac.
  34. Coil Pack Question
  35. 99 explorer beeps 5 times @ startup
  36. 99 sohc timing chain repl.: what special tools are needed?
  37. 92 Ford Explorer Sport Cranks but wont start/ missing part due to parent
  38. Oil Leak Around Oil Filter?
  39. accessory lights
  40. O2 sensor problems
  41. problems filling up tank
  42. Child Locks!
  43. 98 ford explorer
  44. 01 sporttrack p1633 code????
  45. Possible PCM failure?
  46. Rear Wiper Arm
  47. 2001 Ford Explorer V8
  48. 02 explorer passenger window problem
  49. Is it a thump or a clunk?
  50. Screwed Up Dashlights
  51. 2004 Ford Explorer Front Washer Fluid Doesn't Work
  52. Fuel Gauge issue
  53. Engine tach going to 2-3k when applying brakes.
  54. Upper intake plenum OHC 4.0
  55. Air bag light, code 3-6, 3-7 99' Exp XLT-Update
  56. headlights
  57. Freeze plug leaking
  58. transmission troubles 2000 explorer sport 4x4
  59. 99 Expl stuck in low?
  60. 99 explorer wont start!!!
  61. coolant temp sensor issues
  62. my 96 squeeks
  63. bumper advice
  64. 98 Explorer Limited Washer Motor
  65. 1996 Explorer Power Windows not working.
  66. Hesitation and burning smell
  67. 2003 Explorer Xlt Problems
  68. 2002 Explorer 4 Dr, Code B2292, 4.0 Eng
  69. i NEED HELP
  70. unable to pull ABS code on 1996
  71. set timing on a 97 sohc
  72. 04 Sport Trac rear end question
  73. Overdrive
  74. 2000 Explorer..4x4 won't engage
  75. Catalityc converter on explorer 96 XLT V6
  76. Where to Buy Fog Lights for 1994 Explorer
  77. Keyless or not? 1994 expl. xlt
  78. Increase Milage chips
  79. Doors do not stay open 94 XLT
  80. Daytime running lights on 94 XLT - Like to turn off
  81. Mileage 2007 Ford Sport Trac 4.6L
  82. 2003 Explorer Xtl Key System
  83. side view mirror
  84. Rear tail lamp assembly
  85. 98 4.0 sohc explorer died in operation
  86. 94 Exporer Transmission noise
  87. 1994 Keyless entry - does mine have it?
  88. Explorer transmission module?
  89. Emissions
  90. 99 explorer problems with climate control
  91. Air Bag light code 3-6. 3-7 99' exp 4.0l good fix
  92. Merry Christmas
  93. rim sizes
  94. squeaking/grinding noise
  95. Another 1998 Heater Problem
  96. locating starter 2003 sport trac
  97. 2000 explorer AWD problem
  98. 1997 XLT 5.0L AWD - Jammed Wipers
  99. CD Changer tempermental 97 XLT
  100. more 4x4 problems
  101. electric windows stick in cold weather
  102. 2002 Explorer XLT aftermarket wheels and tires
  103. 1997 4.0 Oil Filter Adapter Question...
  104. Brake problem
  105. 02 Crack on hatchback panel under rear window
  106. 1993 5.0 into 1996 explorer with current 4.0 engine
  107. tps location
  108. 99 explorer misfire when cold
  109. Possible PCM issue?
  110. CheckEngine light on Explorer 96 XLT
  111. Buying a used Explorer 97-2001
  112. 96 4.0L ABS motor comes on/no ABS light?
  113. Abs light .99 Explorer 4.0l 4wd
  114. ABS light - Clear cut answer needed
  115. Replacing alternator on 91 explorer
  116. Question on clearing trouble codes
  117. Unballanced drive train
  118. '99 ford explorer rotors seized -fixed part 2
  119. borg warner 4405 transfer seal.
  120. '99 explorer front rotors seized - fixed!
  121. 97 explorer 2dr.AWD,replacing rear(transfer) output seal...
  122. Manual hubs
  123. Location of Oxygen Sensors '00 Explorer
  124. 95 explorer 4x4 problem
  125. Clutch Won't Disengage
  126. 93 Explorer will not start <Need help finding starter
  127. My latest off road stuck story
  128. Where should i start? (A CHALLENGE FOR SHOROD and ALL)
  129. 93' Explorer blinkers not working
  130. 1994 Explorer XLT - does it have Keyless?
  131. 1994 Explorer 2 doors,4x4,Camber Adjustements
  132. 1998 Explorer XLT Fan Motor
  133. Front Rotors siezed 1999 Ford Explorer
  134. 2002 explorer blend air temperature motor removal?
  135. brake trouble
  136. 2002 Explorer 4x4 XLT preventative maintenance
  137. 95 exploder : 3 CODES . . . 114 327 636 HELP ! ! !
  138. Manual Lever Position Sensor???
  139. My "new" '91 Explorer
  140. 92 explorer gas tank removal
  141. What would you do?
  142. 02 Explorer HomeLink
  143. 2001 Explorer Sport 4.0 SOHC
  144. keypad not working...Rock did the trick. I HAVE THE CODE
  145. 93 Exp.starts OK, runs bad after heated up
  146. 99 xlt front washer relay
  147. 94 Explorer: Is the PCM the issue?
  148. Removing Filler Hose - 96 Explorer
  149. Cruise control lights in steering wheel
  150. 96 Explorer - Fuel Pump?
  151. I had my keypad reprogrammed
  152. 95 Eddie pass side headlight out
  153. 02 Explorer Climate Control Squeak
  154. 94 Ford Exlorer Electrical
  155. 2003 Eddie Bauer heated seat problem
  156. 2002 Explorer Rear Differential
  157. 02 explorer glove compartment light wont go off!
  158. No heat control 97 EXPLORER EDDIE BAUER
  159. check engine light on
  160. Idle Question...
  161. what can i get for my explorer
  162. Keypad code
  163. noise in front end
  164. front parking light bulb
  165. Engine Coolant Temperature sensor housing
  166. Its "hot" in my 96 explorer!!!! Whats a girl to do???
  167. Oil Leak in 2000 Ford Explorer XKS
  168. 2004 Ford Explorer Dash Light????
  169. 2000 Evap Inc and 171 and 174 Codes
  170. 99 Explorer Hard Start and Rough Idle
  171. valve tapping
  172. 2001 Explorer Sport - Seat Belts
  173. 2001 Explorer Sport - Rear Window Wiper doesn't touch rear window
  174. 2001 Explorer Sport - Power lock on driver side is broken
  175. 99 explorer probs
  176. O/D OFF blinking on 99 Explorer
  177. Fuel Filter Replacement w/pics
  178. 95 explorer shaking badly at idle
  179. '03 Sport Trac heated seats
  180. 04 XLT ABS light stays on?
  181. 2003 explorer sport trac fuel problem
  182. leakage from head gaskets-95 Exployer
  183. rough idle
  184. alternator issue
  185. 2002 4.6 Liter Engine Knock
  186. Location Unknown
  187. 2003 Explorer, Assorted Problems
  188. Best Leather Conditioner for Ford Leather?
  189. Vents won't work...
  190. 2001 Ford Explorer-Shaking at 3,700rpm in Neutral
  191. 93 ford Explorer 4WD selector switch problems
  192. 93 Explorer 4wheel drive selector switch problems
  193. Explorer won't start unless gas pedal is depressed
  194. 2000 Exporer oil problems
  195. 02 Explorer Serpentine Belt Tensioner Problems
  196. wheel bearing spacer
  197. Fuel tank leak
  198. 1997 AWD 4.0 Gas Mileage
  199. More Horsepower wanted
  200. Od Light Blinking
  201. no air coming out of front vents
  202. Pitman arm
  203. 2003 explorer upgrade to Dual Climate Ctrl./other mods
  204. small problem....
  205. 2000 Ford Explorer-Idles up and down
  206. Break lights don't work on 98 explorer
  207. Help (related to EGR)
  208. Fuel filter location?
  209. Evap system hiss....need input!
  210. 97 explorer drivetrian grinding noise
  211. 2002 Transmission Slipping
  212. 2002 Explorer stuck in 4 low
  213. 2003 Explorer Sport stalls at idle
  214. 96 Ford Explorer - Transmission
  215. blower motors stays on
  216. Window Switch Not Lit
  217. Thermostat and tranny shudder
  218. 00' Brakes
  219. Engine greasing
  220. Electrical issues with 96 Eddie bauer edition
  221. 90,000 mile service
  222. help needed 94 exploder
  223. 94 explorer wheel problems
  224. purchasing 2002 Explorer XLS
  225. Replacing the door behind the front ducts on an 2004
  226. synchronizer settings
  227. 2001 Sport Trac Winding Noise
  228. 95 Explorer electrical issues
  229. 00' Tailgate woes and drivers lock issues
  230. 00' Tailgate replacement/Drivers door lock issue
  231. 99 for explorer suspension squeaky
  232. '92 Explorer 4x4 stalling
  233. Problem - Driver Window Only
  234. Diagnostic Codes
  235. 98 Explorer Sport Not Blend door issue
  236. Should i buy...'04
  237. Wiper Switch or Motor
  238. 94 luggage rack peeling
  239. 02 Manual Explorer Sport (Idle Problem)
  240. 2002 & 2006 roof rack???
  241. 2002 Windshield Wiper Woes
  242. code 327 and 632
  243. 04 sporttrac rough idle
  244. Ford Explorer Transmission 1994
  245. 2002 explorer hard turn clunking noise
  246. P0174
  247. 2004 explorer multiple recurring issues
  248. 2000 Explorer - Problem w/Power Windows
  249. 2002 explorer power window regulator
  250. 2002 Explorer problem
