View Full Version : Explorer/Explorer Sport Trac
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Out of ideas Please Help
  2. '97 w/ 5.0 & Codes P0171 & P0304
  3. PLEASE HELP FAST - 2000 Explorer - Noise while driving (front pas. wheel)
  4. Want to hardwire Sirius in '05
  5. fuel pressures
  6. Two new tools out.
  7. Thinking about buying Explorer Sport
  8. How to disable door lock
  9. 1993 explorer abs light on...
  10. 1996 Explorer low beam issue...
  11. 1996 explorer makes noise when turning
  12. 2003 explorer sport tail light?
  13. 2002 ford explorer rear brake light problems
  14. back up lights fuse blowing
  15. Stuttering and dying
  16. codes p0133, p0340, p0300
  17. 2005 Tail light
  18. 2002 Ford Explorer?
  19. Abs Brake Question...
  20. Abs Brake Question...
  21. Reason for sudden antifreeze leak into oil pan?
  22. starter
  23. Stereo Wiring
  24. 95 fuel/running/idk probs
  25. 2000 Explorer SOHC No Start
  26. 91 explorer rough idle
  27. 01 Exlorer Won't Idle
  28. Hesitation at low rpm only
  29. P1812 code
  30. both oxygen sensors ??
  31. 2000 Explorer seat belt
  32. 2002 Explorer rear window hinge/ panel cracking
  33. Shock question
  34. 5r55e tranny manual
  35. 02 Explorer clicking
  36. Window Replacement Complexity re 2002 Ford Explorer Sport Drivers Side Window
  37. Explorer won't run unless I give it gas
  38. 94 Explorer Sport Front end noise
  39. 95 explorer with 2004 engine and trans HELP
  40. no heat
  41. Installing Amps Rear of 02 Explorer
  42. Explorer 4.0l PUSHROD egr location
  43. 2002 Ford Explorer V6 Rattle When Starting
  44. 2000 XLT Transmission problem
  45. front door short
  46. Advice on buying used 99 Eddie Bauer.
  47. 94explorer trans problem
  48. 2002 ford explorer remoter problems
  49. Trany extrange noise
  50. Crankcase Breather Filter
  51. 1999 Ford Explorer Eddie Bauer - Dash Lights may or maynot come on
  52. 2004 Eplorer ABS code
  53. 2001 Ford Explorer Sport 4wd Engages And Disengages while driving!!!!!!!
  54. 02 Explorer OBD P0401 Question
  55. 1998 Ford Explorer Clunk, then loud Whirr
  56. 1994 Explorer Missing
  57. OBD Code P0401 Question
  58. 1995 Explorer-Fuel line, filter to pump
  59. parking light turn off from keyless remote unlock
  60. 98 Explorer Swap/Upgrade Help????
  61. DPFE sensor
  62. 2001 Strange Electrical Problem
  63. I need help ASAP 94 explorer has no heat!!
  64. dash a/c
  65. Vibration
  66. Where is my Thermostat??
  67. 96 V8 5.0 EGR Valve-Where is it?
  68. low oil pressure at 2k rpm
  69. 2003 Sport Trac Brake Fluid Low???
  70. 97 Explorer Auto Transmission
  71. Removing Factory Radio Question
  72. Trying to program a remote
  73. Explorer.falls on face then dies,will idle
  74. REMOTE for alarm programming *need help*
  75. 98 Ford Explorer Help
  76. Changing the rotors.
  77. how to remove the slide cover from the moon roof
  78. 2000 Explorer XLS Horn?
  79. 2001 Explorer No 4WD
  80. 1998 Explorer SOHC Stalls on Incline
  81. 97 Ford Explorer
  82. Fuel Filter Location - 2002 Sport Trac
  83. Awd on 2000 exploder xlt
  84. left tail light and brake light inoperational
  85. 5 speed manual tranny noise
  86. Piaa Lights
  87. will start but won't idle until engine warms up
  88. Location of PCV Valve?
  89. 2000 Explorer Idles slow
  90. shakes and studders between 45-55 mph
  91. tranny vs thermastat
  92. 02 Explorer Engine Swap
  93. 96 Explorer High Mount $top light
  94. Funky exhaust or maybe transmission noise during light acceleration
  95. Need suggestions for rusted axle threads
  96. in dash dvd
  97. 2008 Ford Explorer Sport Trac XTL
  98. power windows and moonroof
  99. ford is running rough
  100. 2000 ford explorer DRL's not turning off
  101. rough idle
  102. Help: Front Differential Vent Hose Routing
  103. abs problem
  104. Lag
  105. Adding/Programming Remote Transmitter to 94 Explorer
  106. 1996 horn location
  107. Coolant System Drain & Flush
  108. Explorer Fuel Pump Woes!
  109. brakes
  110. 1998 Ford Explorer Wiring Diagram For Power Windows And Sun Roof
  111. 03 explorer trans hard shift neut/drive
  112. Electrical short or bad ground?
  113. P0171 & P0174
  114. Spark Plug Gap Question
  115. 2003 Sport Trac, no wipers, dome lights & Speedo
  116. Need torque specs for 93 4.0L
  117. factory paint
  118. Does the fuel pump need replaced
  119. 91 Explorer power steering pulley question
  120. low fuel light
  121. 05 Ford Expolorer Sport trac xlt door panel removal
  122. DPFE on 1999 Ford Explorer
  123. 2002 Explore Shift Problem
  124. interchangeable parts
  125. heat shield removal
  126. 99 Explorer tranny problem
  127. 95 Ford Explorer Neutral Switch
  128. 1998 Explorer "Thump" Noise While Driving Up Hills
  129. 2003 ford explorer v-8
  130. 1997 Ford Explorer smokes out the tailpipe in the morning
  131. Accessories??
  132. Tranny Problem- Aamco or Dealer?
  133. Extreme shutter after steering rack installed
  134. brake issues
  135. 95 Explorer check engine light
  136. Help Stuck in 4x4 low with no turn signals
  137. Front Differential Issues, Please someone!
  138. Explore will not start, Was running good
  139. 1994 Explorer
  140. Replace Steering Rack Boot 95 Explorer EB
  141. removing air box?! and vacuum lines??
  142. 1998 Ford Explorer A/C Maintenance
  143. Having Single Fuse Blow on a 2001 Exp. Sprt.
  144. Dead AC...
  145. Transmission makes grinding noise when put in gear
  146. what's this part called?
  147. front differential and fuel filter
  148. what years will plug and play with a 97 4.0
  149. shutter ford explore
  150. Automatic Transmission
  151. 2003 Driver Window problems
  152. 99 xlt alarm questions
  153. 1996 Explorer - P0153
  154. Help Me Please! 03 Explorer
  155. 94 explorer fuel odor
  156. 1994 4 door explorer power window help
  157. '97 4wd front wheel bearing
  158. P1451, P0304, P0305, P0171, P0174
  159. P0171 and P0174
  160. Problem with losing antifreeze/coolant
  161. 96 explorer sport dash and tail lights
  162. a/c & heater problem
  163. Help PO401 code
  164. Fog Light Help
  165. Replacing o2 sensor on a 1998 Explorer
  166. Identify 1998 exporer alloy wheels
  167. Cruise Control Update 03 Explorer, Any ideas?
  168. Thankx 2 All
  169. 2002 ford explorer rear brake lights wont cut off.
  170. Does anyone know????
  171. 2000 Ford Explorer XLS
  172. Cruise Control Issues 03 Explorer; Help please
  173. Fuel Filter remover tool for Ford explorer 2000???
  174. 2000 Ford Explorer XLS
  175. 91 explorer starting issues
  176. 99 frd expl 4.0L codes p0171/0174
  177. 95 Explorer O/D light flashing code 647
  178. Fuel Filter Location 2000 Explorer
  179. Loud Screeching in my 2000 explorer sport motor
  180. Brakes on 03 Explorer Make some $$$
  181. 1996 Explorer lower ball joint movement specs?
  182. Mass Air Flow Sensor Hums
  183. Vehicle security sustem
  184. anyone parting out a 91_94 explorer 4x4?
  185. emergency flashers, cigarette lighter
  186. Check engine light
  187. 2002 sport trac leaking fuel filling up
  188. 04 trans noise when coasting
  189. 2001 Explorer Sport 4X4 4.0 sohc Brake Pedal always drops
  190. 97 explorer trans swap
  191. 2005 improve ride and gas mileage
  192. Door Ajar Light Wont Go Off
  193. driver window issues for 2000 explorer
  194. driver seat is crooked
  195. 91 explorer runs rough, eats gas
  196. 1991 explorer brake problems
  197. Sticky accelerator pedal (2001 sport trac)
  198. 98 explorer will not start
  199. which drive gear should i use?
  200. 97 Explorer Daytime Running Lights Not Working
  201. 2002 Eddie Bauer Squeaky/ Cracked Springs
  202. Whining Noise On Decel
  203. 03 XLT rear entertainment DVD remote
  204. Radio antenna cable questuons
  205. 03 Explorer Emergency Brake
  206. all wheel drive is hopping on pavment like its in four wheel drive on sharp turns
  207. NEED TO GET OUT OF 4X4 low tonight
  208. 2002 Explorer door locking issues
  209. Headliner Removal
  210. 2002 4.6 Liter Knock Sensor Location?
  211. removing 6 cd player
  212. BIG PROBLEMS after motor swap 98 explorer xlt sohc
  213. 93 explorer timing cover gasket replacement
  214. '02 model owners: strange favor to ask
  215. vvs
  216. Explore power lock problem only locks from back
  217. Transmission Swap
  218. 2000 Explorer constant vibration
  219. 1998 Ford Explorer For Sale/Parts
  220. 2003 Sport trac dome light
  221. rear window off track?
  222. Do I have a tow package or not????
  223. 2 dead Cylinders?
  224. brake hose or caliper
  225. Removing front rotors
  226. help: 2003 XLT side view mirrors do not work!
  227. vacuum port
  228. 2002 Sport Trac Heater Core issue
  229. Emergency Flashers
  230. 93 Explorer emergency brake
  231. 1991 4X4 indicator light doesn't work
  232. min. thick ft. rotor 97 Exploder
  233. 95 explorer stereo
  234. po300, po171, po174, please help
  235. Bad CAM sensor
  236. 2004 ExplorerXLT_HatchCrack
  237. 99 Explorer LOUD pulsing hum and vibration from the front end
  238. 98 Explorer ocassionly will not start.
  239. 1999 Ford Explorer problems
  240. 95 explorer eddie rear axel removal
  241. 2000 Explorer tranny and electrical problems
  242. 2001 4.0 sohc automatic 4x4
  243. dome lamp switch??
  244. Vaccum smoke test port
  245. 95 explorer 4.0 4x4 power problem
  246. 97 Ford Explorer- rough idle-and missing top end
  247. towing turn signal
  248. anyone have a wiring schematic???
  249. 2003 Explorer 2wd
  250. 91 explorer fuel pump?
