View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19
  1. tranny driving me nuts
  2. AC Clutch Engages/Disengages
  3. Trans gone south?
  4. Take my ford to the dealership for maintenance and repairs or to any regular bodyshop
  5. ALtenator
  6. Explorer for sale
  7. Transmission fluid
  8. Oil change?
  9. upper/lower ball joints on a 95 explorer
  10. 99 Explorer Sport
  11. 2003 Handling woes
  12. Radio Display problem........
  13. 00-03 Explorer Sport (redesigned)
  14. 97 Explorer shocks???
  15. 94 Explorer A/C blower
  16. 98 Explorer power window problem
  17. 2000 Explorer noise/vibration when turning from a stop
  18. 2000 for explorer lacks power
  19. power window problems
  20. 94 ford explorer wont shift into overdrive.
  21. Where is PCV on 94 Explorer V6 4.0?
  22. 96 engine replacement
  23. 02 Explorer trans went out - do this!
  24. tranny problems on 97 explorer!
  25. Turn signals don't work
  26. small hole leaking engine coolant
  27. 98 OD light blinking
  28. Anyone Know A 1992 Explorer Bolt Pattern?
  29. fuel pump
  30. what is your fuel milage??
  31. Explorer Sport Brush Guards?
  32. 2002 explorer windshield wiper problem
  33. Fuse Panel, 1996 Ford Explorer
  34. please help! Explorer won't start
  35. 94 ford explorer eddie bauer fuel kill switch
  36. fuel gauge
  37. 2000 Explorer Recalls
  38. 95 Explorer 4x4 Not Engaging
  39. Piston issues
  40. Explorer XLT 94' When turning from stop rear makes grinding noise
  41. keypad entry disable or new code entry
  42. Where is thermostat?
  43. running boards-side step rails ford exp
  44. 1994 Ford Explorer 4x4 5 speed
  45. Bumpy ride/stiff shocks
  46. 1998 Ford Explorer Transmission Problem..
  47. Tachometer, fuel gauge, oil pressure gauge not working.
  48. 94 Explorer Transmission / Engine Problem
  49. someone please help 1994 explorer loosing power
  50. 02 Explorer Suspension Squeaky
  51. power window switches
  52. keyless entry not working on drivers door
  53. Keypad entry programming
  54. 02 vibration noise in drivetrain
  55. 97 explorer - tranny problem?
  56. 1994 Ford Explorer Losing Power
  57. 2004 explorer limited wont turn over
  58. Has anyone used a K&N intake?
  59. worth
  60. 94 Explorer
  61. Rewiring Radio, som help needed please
  62. getting at the gauges
  63. Rear door
  64. 1994 4X4 not working
  65. Dual Alternators
  66. 1997 Explore 4wd Low Light Blinks
  67. grinding in the front end
  68. 1996 Explorer Sport clutch/transmission? not right! Any suggestions?
  69. 2001 Burning Smell
  70. Can someone answer my questions about a Explorer?
  71. Alternator/Total Amps on 1995 Explorer
  72. Fog Light question
  73. 94 explorer has high beams but no low beams
  74. Warning lights flash..Windows don't work
  75. Explorer Questions
  76. 92 explorer transmission
  77. No Start 92
  78. 1995 Explorer new sound system help
  79. 1997 Sport door chime
  80. 2002 transmission oil- thanks O.H.
  81. OD light flashing....again.
  82. Tire diameter question
  83. 1996 Explorer Sport Fuel Filter
  84. 1991 Explorer 4.0 blowing eec maxi fuse !
  85. factory entry code for 1987 nissan maxima
  86. 2000 Explorer Transmission
  87. Overheating after 2mi
  88. Drivers door unlock switch inoperative
  89. Plug Keeps Melting???
  90. 94 4*4 Ford Explorer Tranny problems!!
  91. pulling to the right
  92. Iac & mas sensors
  93. Need transmission help please!!
  94. 2002 transmission oil change?
  95. Overheating & alternator.
  96. 98 XLT - Check Engine Diagnostic Codes
  97. Programming 2002 Keyless Remote
  98. It does not start anytime ???? HELP
  99. 1993 Tran Problem?
  100. 98 Explorer Sport not spraying washer fluid
  101. Rough idle
  102. rough idle on hot start
  103. 92 Explorer Surges
  104. 92 Explorer trailer connection
  105. intake noise when hot
  106. Squeaking noise
  107. 1998 ford explorer keypad
  108. No Heat (Burrr!)
  109. 91 Explorer Engine Shake when switching to overdrive
  110. explorer trans problem
  111. 99 explorer rough ridle and ride
  112. 2001 explorer sport door entry programming
  113. '94 Explorer Acceleration
  114. 99 Explorer Sport Engine Noise
  115. Piece of junk explorer!
  116. 96 Explorer DTC P0154, Replace All 02 Sensors?
  117. daytime running lights
  118. FS: 1995 Explorer Service Manual
  119. engine light
  120. Jeep Cherokee vs Ford Explorer
  121. 02 hood moves a lot NORMAL?
  122. 98 Explorer XLT has sporadic idle then stalls+Engine light
  123. 2002 Explorer Limited V8 idle stall
  124. Message center
  125. 96 Explorer, Check engine light on for 3rd time, help!
  126. Found Source of engine noise
  127. Engine Advice
  128. 2000 Explorer revs when clutch pedal depressed
  129. 96 exp. sport-manual trans shifting problems
  130. 96 ford explorer--call father marin-its possessed!!
  131. 2002 Keyless Entry Break-In
  132. window trim removal
  133. Help~Interior fan stays on all the time
  134. Help!! Transmission powershifts
  135. Right Tire Shakes
  136. 99 explorer stalling when driving and stopping
  137. rough idle
  138. Loud Noise
  139. Keyless entry
  140. 2001 Clock radio set/program
  141. Heated Seat problems
  142. 95-99 explorer mild lift?
  143. Amplifier Location?
  144. 2000 Explorer tailgate problems
  145. 2001 Explorer Engine
  146. 1991 ford explorer
  147. egr
  148. 351w in 92 explorer ?
  149. Radio/Speaker Wiring Problems
  150. 98 Explorer Transfer Case
  151. Adjusting 96 Explorer Parking Brake
  152. 2000 Ford Explorer O/D light flashing!!!
  153. 93 radio fuse location?
  154. 95 Explorer 4x4 auto tranny fluid capacity??
  155. Dead Stereo Fuse Slot
  156. Broken Antenna '96 Explorer
  157. Wiring diagram 91explorier 4wd
  158. Need help OPERA HOUSE ...if your around
  159. 98 sport trouble starting
  160. Need transmission help !!!
  161. 2000 Explorer burning extreme amount of gas
  162. Reprogramming Keyless Entry
  163. Need '95 JBL subwoofer
  164. 99 explorer trouble starting when cold
  165. 96 Explorer shifting issue?
  166. 95 Explorer power steering pump replacement
  167. 1998 Ford Explorer Alarm
  168. 20" rims 4 sale
  169. 1998 explorer 4.0 ( spark knock?)
  170. 1995 Explorer Premium sound, PROBLEMS!
  171. securilock/1key .no horn/alarm 1998
  172. keyless entry on 1996 ford explorer
  173. 95 Explorer 4x4 stalling when coming to a stop
  174. Loud squeak 1998 Explorer
  175. 96 Explorer break issue
  176. Wiring Problems Engine keeps cranking without a key in ignition
  177. Help with fuses to replace
  178. brake liights and controller
  179. 99 Explorer 4.0 4R44 Trans Help
  180. check engine light comes on
  181. my 2000 explorer is driving me nuts!!!!
  182. Problem Starting
  183. 02 Explorer High Pitched Whistle Sound
  184. 2000 Ford Explorer Transmission Trouble
  185. 2002 Ford Explorer front crank seal leaking
  186. Desperate Transmission help
  187. Changing instrument cluster on 2002 Explorer
  188. (experts needed)costly mistake, but need help ASAP
  189. '93 Explorer Check Engine Light
  190. 2000 Explorer - Where is IAT sensor
  191. 99 explorer
  192. 91 Explorer 4 Wheel Drive Grinding
  193. Where is the PCV valve?
  194. temp guage
  195. 1994 Explorer with engine knocking?
  196. Front Suspension...please Help!!!
  197. Explorer Trailer Wiring???
  198. 92 EB spark knock. Has new open air intake
  199. 99 explorer Lean Right, Left Bank code
  200. Tranny problems
  201. 94 explorer with 4 wheel drive problems - should I buy car?
  202. ford explorer overhead console wiring diagram
  203. 97 Acceleration/deceleration noise
  204. 93 4x4 problem
  205. 1993 Ford Explorer Alarm keeps going off
  206. 98 v8 engine noise
  207. Purdue ME design course survay
  208. Amp Wiring!!
  209. Low Beam Headlights Gone, One at a time
  210. AC modes control on 2002 Explorer
  211. 4x4 wont disengage
  212. wiring diagram
  213. Replacing Torn Leather Seats
  214. Rear defrorst 95 Explorer Limited
  215. 95 Explorer Wiring Diagram JBL Antenna
  216. Explorer not starting
  217. '95 Exp. oil in my air filter?
  218. 99 Explorer Rear Wiper not working
  219. Sports trac high pitch whistling sound?!
  220. Daytime running lights.
  221. Defroster/Heater Core
  222. 92 4 Wheel won't Engage/Whirring Sound
  223. 96 Heater Problem - Difficult?
  224. 2002 Explorer Sport Keyless Entry on the fritz
  225. What's my problem??
  226. Escorts Key Worked In '97 Explorer...!
  227. Needed Help
  228. no 4x4 lo
  229. Shifting Problem
  230. Keyless Entry System Module-Where is it?
  231. i need a radio wiring diagram for a 97 explorer
  232. Transmission Fluid change - mystery check valve?
  233. Mysterious Explorer Starting Problems..
  234. "clattering" 2000 explorer sport 4.0 ohv
  235. just got 91 explorer and it has a starting problem
  236. Extreme Power Loss
  237. 1996 Idle increase/decrease with possible hissing noise!
  238. 2002 Explorer Gas pedal vibration
  239. 1998 Explorer Keys
  240. Remote start....
  241. Transmission cooler that come standard
  242. High Pitched Whistling Sound in 98 Ford Explorer Sport
  243. 99 Explorer Sport, loud noise, fluttering idle
  244. Determing witch axle I have on my 94 4wd
  245. DESPERATE fuel line removal tool
  246. 91 Explorer engine removal
  247. headlights not working
  248. 99 Epxl Sport -- Low Gas Mileage
  249. Engine Problem
  250. tranny
